[QGIS Commit] r13157 - in trunk/qgis/src: plugins/grass
providers/grass
svn_qgis at osgeo.org
Thu Mar 25 05:00:54 EDT 2010
Author: rblazek
Date: 2010-03-25 05:00:53 -0400 (Thu, 25 Mar 2010)
New Revision: 13157
trunk/qgis/src/plugins/grass/qgsgrassselect.cpp
trunk/qgis/src/providers/grass/qgsgrass.cpp
trunk/qgis/src/providers/grass/qgsgrass.h
trunk/qgis/src/providers/grass/qgsgrassrasterprovider.cpp
QgsGrass::Exception reverted to std::runtime_error because with QgsException could not be caught
Modified: trunk/qgis/src/plugins/grass/qgsgrassselect.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassselect.cpp 2010-03-25 07:22:36 UTC (rev 13156)
+++ trunk/qgis/src/plugins/grass/qgsgrassselect.cpp 2010-03-25 09:00:53 UTC (rev 13157)
@@ -141,21 +141,15 @@
QString ldpath = egisdbase->text() + "/" + d[i];
- /* TODO: G_is_location() was added to GRASS 6.1 06-05-24,
- enable its use after some period (others do update) */
-#if 0
if ( QgsGrass::versionMajor() > 6 || QgsGrass::versionMinor() > 0 )
if ( !G_is_location( ldpath.toLocal8Bit().constData() ) ) continue;
else
-#endif
QString chf = egisdbase->text() + "/" + d[i] + "/PERMANENT/DEFAULT_WIND";
if ( !QFile::exists( chf ) ) continue;
-#if 0
-#endif
// if type is MAPSET check also if at least one mapset owned by user exists
if ( QgsGrassSelect::type == QgsGrassSelect::MAPSET )
Modified: trunk/qgis/src/providers/grass/qgsgrass.cpp
--- trunk/qgis/src/providers/grass/qgsgrass.cpp 2010-03-25 07:22:36 UTC (rev 13156)
+++ trunk/qgis/src/providers/grass/qgsgrass.cpp 2010-03-25 09:00:53 UTC (rev 13157)
@@ -1128,7 +1128,7 @@
crs.createFromWkt( wkt );
- catch ( QgsException &e )
+ catch ( QgsGrass::Exception &e )
QMessageBox::warning( 0, QObject::tr( "Warning" ),
QObject::tr( "Cannot get projection " ) + "\n" + e.what() );
@@ -1151,7 +1151,7 @@
return QgsRectangle( list[0].toDouble(), list[1].toDouble(), list[2].toDouble(), list[3].toDouble() ) ;
QObject::tr( "Cannot get raster extent" ) + "\n" + e.what() );
@@ -1174,7 +1174,7 @@
result[list[0]] = list[1];
QObject::tr( "Cannot query raster " ) + "\n" + e.what() );
Modified: trunk/qgis/src/providers/grass/qgsgrass.h
--- trunk/qgis/src/providers/grass/qgsgrass.h 2010-03-25 07:22:36 UTC (rev 13156)
+++ trunk/qgis/src/providers/grass/qgsgrass.h 2010-03-25 09:00:53 UTC (rev 13157)
@@ -23,6 +23,7 @@
#include <grass/form.h>
+#include <stdexcept>
#include "qgsexception.h"
#include <QString>
#include <QMap>
@@ -35,10 +36,20 @@
class QgsGrass
public:
+ // This does not work (gcc/Linux), such exception cannot be caught
+ // so I have enabled the old version, if you are able to fix it, please
+ // check first if it realy works, i.e. can be caught!
struct Exception : public QgsException
Exception( const QString &msg ) : QgsException( msg ) {}
+ struct Exception : public std::runtime_error
+ //Exception( const std::string &msg ) : std::runtime_error( msg ) {}
+ Exception( const QString &msg ) : std::runtime_error( msg.toUtf8().constData() ) {}
//! Get info about the mode
/*! QgsGrass may be running in active or passive mode.
Modified: trunk/qgis/src/providers/grass/qgsgrassrasterprovider.cpp
--- trunk/qgis/src/providers/grass/qgsgrassrasterprovider.cpp 2010-03-25 07:22:36 UTC (rev 13156)
+++ trunk/qgis/src/providers/grass/qgsgrassrasterprovider.cpp 2010-03-25 09:00:53 UTC (rev 13157)
@@ -104,8 +104,7 @@
data = QgsGrass::runModule ( mGisdbase, mLocation, cmd, arguments );
- //catch ( QgsGrass::Exception &e ) // does not work
QMessageBox::warning( 0, QObject::tr( "Warning" ), QObject::tr( "Cannot draw raster" ) + "\n"
+ e.what() );
