[QGIS Commit] r13162 - trunk/qgis/mac/xcode/Qgis.xcodeproj
svn_qgis at osgeo.org
Thu Mar 25 22:33:57 EDT 2010
Author: kyngchaos
Date: 2010-03-25 22:33:56 -0400 (Thu, 25 Mar 2010)
New Revision: 13162
trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj
grass module filename fix (r13156)
Modified: trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj
--- trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj 2010-03-25 20:07:18 UTC (rev 13161)
+++ trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj 2010-03-26 02:33:56 UTC (rev 13162)
@@ -2630,7 +2630,7 @@
isa = PBXContainerItemProxy;
containerPortal = 20286C28FDCF999611CA2CEA /* Project object */;
proxyType = 1;
- remoteGlobalIDString = 72B236AC11570743007B4803 /* displacementplugin */;
+ remoteGlobalIDString = 72B236AC11570743007B4803;
remoteInfo = displacementplugin;
72BD9FEF10A49CEE00FEA70F /* PBXContainerItemProxy */ = {
@@ -6771,7 +6771,7 @@
72ACC859100E143400894938 /* r.sunmask.position.3.png */ = {isa = PBXFileReference; lastKnownFileType = image.png; name = r.sunmask.position.3.png; path = "../../src/plugins/grass/modules-common/r.sunmask.position.3.png"; sourceTree = SOURCE_ROOT; };
72ACC85A100E143400894938 /* r.in.bin.1.png */ = {isa = PBXFileReference; lastKnownFileType = image.png; name = r.in.bin.1.png; path = "../../src/plugins/grass/modules-common/r.in.bin.1.png"; sourceTree = SOURCE_ROOT; };
72ACC85B100E143400894938 /* r.circle.qgm */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = text.xml; name = r.circle.qgm; path = "../../src/plugins/grass/modules-common/r.circle.qgm"; sourceTree = SOURCE_ROOT; };
- 72ACC85C100E143400894938 /* r.circle.png */ = {isa = PBXFileReference; lastKnownFileType = image.png; name = r.circle.png; path = "../../src/plugins/grass/modules-common/r.circle.png"; sourceTree = SOURCE_ROOT; };
+ 72ACC85C100E143400894938 /* r.circle.1.png */ = {isa = PBXFileReference; lastKnownFileType = image.png; name = r.circle.1.png; path = "../../src/plugins/grass/modules-common/r.circle.1.png"; sourceTree = SOURCE_ROOT; };
72ACC85D100E143400894938 /* db.copy.qgm */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = text.xml; name = db.copy.qgm; path = "../../src/plugins/grass/modules-common/db.copy.qgm"; sourceTree = SOURCE_ROOT; };
72ACC85E100E143400894938 /* db.copy.2.png */ = {isa = PBXFileReference; lastKnownFileType = image.png; name = db.copy.2.png; path = "../../src/plugins/grass/modules-common/db.copy.2.png"; sourceTree = SOURCE_ROOT; };
72ACC85F100E143400894938 /* db.copy.1.png */ = {isa = PBXFileReference; lastKnownFileType = image.png; name = db.copy.1.png; path = "../../src/plugins/grass/modules-common/db.copy.1.png"; sourceTree = SOURCE_ROOT; };
@@ -12489,7 +12489,7 @@
72ACC859100E143400894938 /* r.sunmask.position.3.png */,
72ACC85A100E143400894938 /* r.in.bin.1.png */,
72ACC85B100E143400894938 /* r.circle.qgm */,
- 72ACC85C100E143400894938 /* r.circle.png */,
+ 72ACC85C100E143400894938 /* r.circle.1.png */,
72ACC85D100E143400894938 /* db.copy.qgm */,
72ACC85E100E143400894938 /* db.copy.2.png */,
72ACC85F100E143400894938 /* db.copy.1.png */,
@@ -19568,7 +19568,7 @@
COPY_PHASE_STRIP = NO;
GCC_GENERATE_DEBUGGING_SYMBOLS = YES;
GCC_OPTIMIZATION_LEVEL = 0;
- QGIS_VERSION_BUILD = 13139;
+ QGIS_VERSION_BUILD = 13161;
STRIP_INSTALLED_PRODUCT = NO;
name = Debug;
@@ -19579,7 +19579,7 @@
buildSettings = {
COPY_PHASE_STRIP = YES;
GCC_GENERATE_DEBUGGING_SYMBOLS = NO;
STRIP_INSTALLED_PRODUCT = YES;
name = Release;
