[QGIS Commit] r13177 - trunk/qgis/src/core
svn_qgis at osgeo.org
Sun Mar 28 05:44:14 EDT 2010
Author: wonder
Date: 2010-03-28 05:44:13 -0400 (Sun, 28 Mar 2010)
New Revision: 13177
trunk/qgis/src/core/qgssearchtreenode.cpp
trunk/qgis/src/core/qgssearchtreenode.h
Initialize distance/area calculator only if we will be doing any calculations
(saves crs lookups when creating search tree nodes)
Modified: trunk/qgis/src/core/qgssearchtreenode.cpp
--- trunk/qgis/src/core/qgssearchtreenode.cpp 2010-03-28 08:34:54 UTC (rev 13176)
+++ trunk/qgis/src/core/qgssearchtreenode.cpp 2010-03-28 09:44:13 UTC (rev 13177)
@@ -18,6 +18,7 @@
/* $Id$ */
#include "qgslogger.h"
+#include "qgsdistancearea.h"
#include "qgsfield.h"
#include "qgsgeometry.h"
#include "qgssearchtreenode.h"
@@ -42,6 +43,8 @@
mNumber = number;
mLeft = NULL;
mRight = NULL;
+ init();
@@ -53,14 +56,7 @@
mLeft = left;
mRight = right;
- if ( mOp == opLENGTH || mOp == opAREA )
- //initialize QgsDistanceArea
- mCalc.setProjectionsEnabled( false );
- QSettings settings;
- QString ellipsoid = settings.value( "/qgis/measure/ellipsoid", "WGS84" ).toString();
- mCalc.setEllipsoid( ellipsoid );
+ init();
@@ -80,6 +76,8 @@
mText = text;
stripText();
+ init();
@@ -100,6 +98,8 @@
mRight = new QgsSearchTreeNode( *node.mRight );
else
mRight = NULL;
+ init();
@@ -112,8 +112,28 @@
if ( mRight )
delete mRight;
+ delete mCalc;
+void QgsSearchTreeNode::init()
+ if ( mType == tOperator && ( mOp == opLENGTH || mOp == opAREA ) )
+ //initialize QgsDistanceArea
+ mCalc = new QgsDistanceArea;
+ mCalc->setProjectionsEnabled( false );
+ QSettings settings;
+ QString ellipsoid = settings.value( "/qgis/measure/ellipsoid", "WGS84" ).toString();
+ mCalc->setEllipsoid( ellipsoid );
+ else
+ mCalc = NULL;
void QgsSearchTreeNode::stripText()
// strip single quotes on start,end
@@ -432,7 +452,7 @@
return QgsSearchTreeValue( 0 );
- return QgsSearchTreeValue( mCalc.measure( geom ) );
+ return QgsSearchTreeValue( mCalc->measure( geom ) );
//string operations with one argument
Modified: trunk/qgis/src/core/qgssearchtreenode.h
--- trunk/qgis/src/core/qgssearchtreenode.h 2010-03-28 08:34:54 UTC (rev 13176)
+++ trunk/qgis/src/core/qgssearchtreenode.h 2010-03-28 09:44:13 UTC (rev 13177)
@@ -24,10 +24,10 @@
#include <QString>
#include <QVariant>
-#include <qgsdistancearea.h>
#include <qgsfield.h>
#include <qgsfeature.h>
+class QgsDistanceArea;
class QgsSearchTreeValue;
/** \ingroup core
@@ -147,6 +147,9 @@
//! strips mText when node is of string type
void stripText();
+ //! initialize node's internals
+ void init();
private:
//! node type
@@ -164,7 +167,7 @@
QgsSearchTreeNode* mRight;
/**For length() and area() functions*/
- QgsDistanceArea mCalc;
+ QgsDistanceArea* mCalc;
// TODO: put it into separate file
