[QGIS Commit] r13443 - in trunk/qgis: python/core src/app src/core src/providers/wms
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat May 8 15:16:25 EDT 2010
Author: jef
Date: 2010-05-08 15:16:21 -0400 (Sat, 08 May 2010)
New Revision: 13443
Added:
   trunk/qgis/python/core/qgsnetworkaccessmanager.sip
   trunk/qgis/src/core/qgsnetworkaccessmanager.cpp
   trunk/qgis/src/core/qgsnetworkaccessmanager.h
Removed:
   trunk/qgis/src/app/qgsnetworkproxyfactory.cpp
   trunk/qgis/src/app/qgsnetworkproxyfactory.h
   trunk/qgis/python/core/core.sip
   trunk/qgis/src/app/CMakeLists.txt
   trunk/qgis/src/app/qgisapp.cpp
   trunk/qgis/src/app/qgisapp.h
   trunk/qgis/src/app/qgsoptions.cpp
   trunk/qgis/src/app/qgswmssourceselect.cpp
   trunk/qgis/src/core/CMakeLists.txt
   trunk/qgis/src/providers/wms/qgswmsprovider.cpp
   trunk/qgis/src/providers/wms/qgswmsprovider.h
network manager changes:
- add QgsNetworkAccessManager to core as singleton
- add support for multiple proxy factories
- remove qgisNetworkAccessManager property hack
- python bindings
wms provider:
- use QgsNetworkAccessManager
- some precision changes
Modified: trunk/qgis/python/core/core.sip
--- trunk/qgis/python/core/core.sip	2010-05-08 19:09:42 UTC (rev 13442)
+++ trunk/qgis/python/core/core.sip	2010-05-08 19:16:21 UTC (rev 13443)
@@ -79,4 +79,6 @@
 %Include qgsvectorlayer.sip
 %Include qgsvectoroverlay.sip
+%Include qgsnetworkaccessmanager.sip
 %Include symbology-ng-core.sip
Added: trunk/qgis/python/core/qgsnetworkaccessmanager.sip
--- trunk/qgis/python/core/qgsnetworkaccessmanager.sip	                        (rev 0)
+++ trunk/qgis/python/core/qgsnetworkaccessmanager.sip	2010-05-08 19:16:21 UTC (rev 13443)
@@ -0,0 +1,51 @@
+ * \class QgsNetworkAccessManager
+ * \brief network access manager for QGIS
+ * \ingroup core
+ * \since 1.5
+ * This class implements the QGIS network access manager.  It's a singleton
+ * that can be used across QGIS.
+ * Plugins can insert proxy factories and thereby redirect requests to
+ * individual proxies.
+ * If no proxy factories are there or none returns a proxy for an URL a
+ * fallback proxy can be set.  There's also a exclude list that defines URLs
+ * that the fallback proxy should not be used for, then no proxy will be used.
+class QgsNetworkAccessManager : QNetworkAccessManager
+%TypeHeaderCode
+#include <qgsnetworkaccessmanager.h>
+%End
+    //! returns a point to the single instance
+    // and creates that instance on the first call.
+    static QgsNetworkAccessManager *instance();
+    //! destructor
+    ~QgsNetworkAccessManager();
+    //! insert a factory into the proxy factories list
+    void insertProxyFactory(QNetworkProxyFactory *factory /TransferTo/);
+    //! remove a factory from the proxy factories list
+    void removeProxyFactory(QNetworkProxyFactory *factory /TransferBack/);
+    //! retrieve proxy factory list
+    void setDiskCache( QString directory, qint64 size );
+    //! retrieve fall back proxy (for urls that no factory returned proxies for)
+    const QList<QNetworkProxyFactory *> proxyFactories() const;
+    //! retrieve exclude list (urls shouldn't use the fallback proxy)
+    const QStringList &excludeList() const;
+    const QNetworkProxy &fallbackProxy() const;
+    //! set fallback proxy and URL that shouldn't use it.
+    void setFallbackProxyAndExcludes( const QNetworkProxy &proxy, const QStringList &excludes );
Property changes on: trunk/qgis/python/core/qgsnetworkaccessmanager.sip
___________________________________________________________________
Added: svn:keywords
   + Revision Author Id
Modified: trunk/qgis/src/app/CMakeLists.txt
--- trunk/qgis/src/app/CMakeLists.txt	2010-05-08 19:09:42 UTC (rev 13442)
+++ trunk/qgis/src/app/CMakeLists.txt	2010-05-08 19:16:21 UTC (rev 13443)
@@ -75,7 +75,6 @@
   qgsuniquevaluedialog.cpp
   qgsvectorlayerproperties.cpp
   qgsquerybuilder.cpp
-  qgsnetworkproxyfactory.cpp
   qgsmanageconnectionsdialog.cpp
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2010-05-08 19:09:42 UTC (rev 13442)
+++ trunk/qgis/src/app/qgisapp.cpp	2010-05-08 19:16:21 UTC (rev 13443)
@@ -67,7 +67,8 @@
 #include <QVBoxLayout>
 #include <QWhatsThis>
-#include <QNetworkAccessManager>
 #include <QNetworkReply>
 #include <QNetworkProxy>
 #include <QAuthenticator>
@@ -154,7 +155,6 @@
 #include "qgsattributetabledialog.h"
 #include "qgsvectorfilewriter.h"
 #include "qgscredentialdialog.h"
-#include "qgsnetworkproxyfactory.h"
 #include "qgstilescalewidget.h"
 #ifdef HAVE_QWT
@@ -360,11 +360,7 @@
     : QMainWindow( parent, fl )
     , mSplash( splash )
     , mPythonUtils( NULL )
-    , mNAM( NULL )
     , mpTileScaleWidget( NULL )
-#if QT_VERSION >= 0x40500
-    , mProxyFactory( NULL )
-#endif
 #ifdef HAVE_QWT
     , mpGpsWidget( NULL )
 #endif
@@ -6523,28 +6519,17 @@
 void QgisApp::namSetup()
-  if ( mNAM )
-    return;
+  QgsNetworkAccessManager *nam = QgsNetworkAccessManager::instance();
-  mNAM = new QNetworkAccessManager( this );
   namUpdate();
-  connect( mNAM, SIGNAL( authenticationRequired( QNetworkReply *, QAuthenticator * ) ),
+  connect( nam, SIGNAL( authenticationRequired( QNetworkReply *, QAuthenticator * ) ),
            this, SLOT( namAuthenticationRequired( QNetworkReply *, QAuthenticator * ) ) );
-  connect( mNAM, SIGNAL( proxyAuthenticationRequired( const QNetworkProxy &, QAuthenticator * ) ),
+  connect( nam, SIGNAL( proxyAuthenticationRequired( const QNetworkProxy &, QAuthenticator * ) ),
            this, SLOT( namProxyAuthenticationRequired( const QNetworkProxy &, QAuthenticator * ) ) );
-  QCoreApplication::instance()->setProperty( "qgisNetworkAccessManager", qVariantFromValue<QObject*>( mNAM ) );
-QNetworkAccessManager *QgisApp::nam()
-  namSetup();
-  return mNAM;
 void QgisApp::namAuthenticationRequired( QNetworkReply *reply, QAuthenticator *auth )
   QString username = auth->user();
@@ -6627,15 +6612,11 @@
-  if ( !mProxyFactory )
-    mProxyFactory = new QgsNetworkProxyFactory();
-    mNAM->setProxyFactory( mProxyFactory );
-  mProxyFactory->setProxyAndExcludes( proxy, excludes );
+  nam->setFallbackProxyAndExcludes( proxy, excludes );
-  QNetworkDiskCache *cache = qobject_cast<QNetworkDiskCache*>( nam()->cache() );
+  QNetworkDiskCache *cache = qobject_cast<QNetworkDiskCache*>( nam->cache() );
   if ( !cache )
     cache = new QNetworkDiskCache( this );
@@ -6648,9 +6629,9 @@
   QgsDebugMsg( QString( "cacheDirectory: %1" ).arg( cache->cacheDirectory() ) );
   QgsDebugMsg( QString( "maximumCacheSize: %1" ).arg( cache->maximumCacheSize() ) );
-  if ( mNAM->cache() != cache )
-    mNAM->setCache( cache );
+  if ( nam->cache() != cache )
+    nam->setCache( cache );
 #else
-  mNAM->setProxy( proxy );
+  QgsNetworkAccessManager::instance()->setProxy( proxy );
 #endif
Modified: trunk/qgis/src/app/qgisapp.h
--- trunk/qgis/src/app/qgisapp.h	2010-05-08 19:09:42 UTC (rev 13442)
+++ trunk/qgis/src/app/qgisapp.h	2010-05-08 19:16:21 UTC (rev 13443)
@@ -62,7 +62,6 @@
 class QgsTileScaleWidget;
 class QDomDocument;
-class QNetworkAccessManager;
 class QNetworkReply;
 class QNetworkProxy;
 class QAuthenticator;
@@ -80,10 +79,6 @@
 #include "qgsfeature.h"
 #include "qgspoint.h"
-class QgsNetworkProxyFactory;
-#endif
 /*! \class QgisApp
  * \brief Main window for the Qgis application
@@ -174,9 +169,6 @@
     //! update proxy settings
     void namUpdate();
-    //! retrieve network manager
-    QNetworkAccessManager *nam();
     //! Helper to get a theme icon. It will fall back to the
     //default theme if the active theme does not have the required
     //icon.
@@ -1095,15 +1087,9 @@
     QgsUndoWidget* mUndoWidget;
-    QNetworkAccessManager *mNAM;
     //! Persistent tile scale slider
     QgsTileScaleWidget * mpTileScaleWidget;
-    QgsNetworkProxyFactory *mProxyFactory;
-#endif
     int mLastComposerId;
 #ifdef HAVE_QWT
Deleted: trunk/qgis/src/app/qgsnetworkproxyfactory.cpp
--- trunk/qgis/src/app/qgsnetworkproxyfactory.cpp	2010-05-08 19:09:42 UTC (rev 13442)
+++ trunk/qgis/src/app/qgsnetworkproxyfactory.cpp	2010-05-08 19:16:21 UTC (rev 13443)
@@ -1,63 +0,0 @@
-                          qgsnetworkproxyfactory.cpp - description
-    begin                : Sat Mar 20 2010
-    copyright            : (C) 2010 by Juergen E. Fischer
-    email                : jef at norbit dot de
- *   This program is free software; you can redistribute it and/or modify  *
- *   it under the terms of the GNU General Public License as published by  *
- *   the Free Software Foundation; either version 2 of the License, or     *
- *   (at your option) any later version.                                   *
-/* $Id$ */
-#include <QtGlobal>
-#include <QSettings>
-#include <QUrl>
-#include "qgslogger.h"
-QgsNetworkProxyFactory::QgsNetworkProxyFactory()
-void QgsNetworkProxyFactory::setProxyAndExcludes( const QNetworkProxy &proxy, const QStringList &excludes )
-  mProxy = proxy;
-  mExcludedURLs = excludes;
-QgsNetworkProxyFactory::~QgsNetworkProxyFactory()
-QList<QNetworkProxy> QgsNetworkProxyFactory::queryProxy( const QNetworkProxyQuery &query )
-  if( query.queryType() != QNetworkProxyQuery::UrlRequest )
-    return QList<QNetworkProxy>() << mProxy;
-  QString url = query.url().toString();
-  foreach( QString exclude, mExcludedURLs )
-    if ( url.startsWith( exclude ) )
-      QgsDebugMsg( QString("using default proxy for %1 [exclude %2]").arg( url ).arg( exclude ) );
-      return QList<QNetworkProxy>() << QNetworkProxy();
-  QgsDebugMsg( QString("using user proxy for %1").arg( url ) );
-#endif // QT_VERSION >= 0x40500
Deleted: trunk/qgis/src/app/qgsnetworkproxyfactory.h
--- trunk/qgis/src/app/qgsnetworkproxyfactory.h	2010-05-08 19:09:42 UTC (rev 13442)
+++ trunk/qgis/src/app/qgsnetworkproxyfactory.h	2010-05-08 19:16:21 UTC (rev 13443)
@@ -1,42 +0,0 @@
-                          qgsabout.h  -  description
-    begin                : Sat, 20 Mar 2010
-/* $Id:$ */
-#ifndef QGSNETWORKPROXYFACTORY_H
-#define QGSNETWORKPROXYFACTORY_H
-#include <QNetworkProxyFactory>
-#include <QStringList>
-class QgsNetworkProxyFactory : public QNetworkProxyFactory
-  public:
-    QgsNetworkProxyFactory();
-    virtual ~QgsNetworkProxyFactory();
-    virtual QList<QNetworkProxy> queryProxy( const QNetworkProxyQuery & query = QNetworkProxyQuery() );
-    void setProxyAndExcludes( const QNetworkProxy &proxy, const QStringList &excludes );
-  private:
-    QStringList mExcludedURLs;
-    QNetworkProxy mProxy;
-#endif
Modified: trunk/qgis/src/app/qgsoptions.cpp
--- trunk/qgis/src/app/qgsoptions.cpp	2010-05-08 19:09:42 UTC (rev 13442)
+++ trunk/qgis/src/app/qgsoptions.cpp	2010-05-08 19:16:21 UTC (rev 13443)
@@ -23,12 +23,12 @@
 #include "qgsgenericprojectionselector.h"
 #include "qgscoordinatereferencesystem.h"
 #include "qgstolerance.h"
+#include "qgsnetworkaccessmanager.h"
 #include <QFileDialog>
 #include <QColorDialog>
 #include <QLocale>
 #include <QNetworkDiskCache>
@@ -121,7 +121,7 @@
   // cache settings
-  QNetworkDiskCache *cache = qobject_cast<QNetworkDiskCache*>( QgisApp::instance()->nam()->cache() );
+  QNetworkDiskCache *cache = qobject_cast<QNetworkDiskCache*>( QgsNetworkAccessManager::instance()->cache() );
   if ( cache )
     mCacheDirectory->setText( cache->cacheDirectory() );
@@ -873,6 +873,6 @@
 void QgsOptions::on_mClearCache_clicked()
-  QgisApp::instance()->nam()->cache()->clear();
+  QgsNetworkAccessManager::instance()->cache()->clear();
 #endif
Modified: trunk/qgis/src/app/qgswmssourceselect.cpp
--- trunk/qgis/src/app/qgswmssourceselect.cpp	2010-05-08 19:09:42 UTC (rev 13442)
+++ trunk/qgis/src/app/qgswmssourceselect.cpp	2010-05-08 19:16:21 UTC (rev 13443)
@@ -33,7 +33,7 @@
 #include "qgsproject.h"
 #include "qgsproviderregistry.h"
 #include "qgswmssourceselect.h"
-#include <qgisinterface.h>
 #include <QButtonGroup>
 #include <QRadioButton>
@@ -47,7 +47,6 @@
 #include <QUrl>
 #include <QNetworkRequest>
@@ -1051,7 +1050,7 @@
   QUrl url( mySearchUrl.arg( leSearchTerm->text() ) );
   QgsDebugMsg( url.toString() );
-  QNetworkReply *r = QgisApp::instance()->nam()->get( QNetworkRequest( url ) );
+  QNetworkReply *r = QgsNetworkAccessManager::instance()->get( QNetworkRequest( url ) );
   connect( r, SIGNAL( finished() ), SLOT( searchFinished() ) );
Modified: trunk/qgis/src/core/CMakeLists.txt
--- trunk/qgis/src/core/CMakeLists.txt	2010-05-08 19:09:42 UTC (rev 13442)
+++ trunk/qgis/src/core/CMakeLists.txt	2010-05-08 19:16:21 UTC (rev 13443)
@@ -88,6 +88,8 @@
   qgsvectorlayerundocommand.cpp
   qgsvectoroverlay.cpp
+  qgsnetworkaccessmanager.cpp
   composer/qgscomposerarrow.cpp
   composer/qgscomposeritem.cpp
   composer/qgscomposeritemgroup.cpp
@@ -232,6 +234,7 @@
   qgsrunprocess.h
   qgsvectorlayer.h
   qgsrasterdataprovider.h
+  qgsnetworkaccessmanager.h
   composer/qgscomposerlegend.h
   composer/qgscomposermap.h
Added: trunk/qgis/src/core/qgsnetworkaccessmanager.cpp
--- trunk/qgis/src/core/qgsnetworkaccessmanager.cpp	                        (rev 0)
+++ trunk/qgis/src/core/qgsnetworkaccessmanager.cpp	2010-05-08 19:16:21 UTC (rev 13443)
@@ -0,0 +1,117 @@
+  This class implements a QNetworkManager with the ability to chain in
+  own proxy factories.
+          begin                : 2010-05-08
+          copyright            : (C) 2010 by Juergen E. Fischer
+          email                : jef at norbit dot de
+ *   This program is free software; you can redistribute it and/or modify  *
+ *   it under the terms of the GNU General Public License as published by  *
+ *   the Free Software Foundation; either version 2 of the License, or     *
+ *   (at your option) any later version.                                   *
+/*  $Id$ */
+#include <qgslogger.h>
+#include <QUrl>
+class QgsNetworkProxyFactory : public QNetworkProxyFactory
+  public:
+    QgsNetworkProxyFactory() {}
+    virtual ~QgsNetworkProxyFactory() {}
+    virtual QList<QNetworkProxy> queryProxy( const QNetworkProxyQuery & query = QNetworkProxyQuery() )
+      // iterate proxies factories and take first non empty list
+      foreach( QNetworkProxyFactory *f, nam->proxyFactories() )
+        QList<QNetworkProxy> proxies = f->queryProxy( query );
+        if ( proxies.size() > 0 )
+          return proxies;
+      // no proxies from the proxy factor list check for excludes
+      if ( query.queryType() != QNetworkProxyQuery::UrlRequest )
+        return QList<QNetworkProxy>() << nam->fallbackProxy();
+      QString url = query.url().toString();
+      foreach( QString exclude, nam->excludeList() )
+        if ( url.startsWith( exclude ) )
+          QgsDebugMsg( QString( "using default proxy for %1 [exclude %2]" ).arg( url ).arg( exclude ) );
+          return QList<QNetworkProxy>() << QNetworkProxy();
+      QgsDebugMsg( QString( "using user proxy for %1" ).arg( url ) );
+QgsNetworkAccessManager *QgsNetworkAccessManager::smNAM = 0;
+QgsNetworkAccessManager *QgsNetworkAccessManager::instance()
+  if ( smNAM )
+    return smNAM;
+  smNAM = new QgsNetworkAccessManager();
+  return smNAM;
+QgsNetworkAccessManager::QgsNetworkAccessManager( QObject *parent )
+    : QNetworkAccessManager( parent )
+  setProxyFactory( new QgsNetworkProxyFactory() );
+QgsNetworkAccessManager::~QgsNetworkAccessManager()
+void QgsNetworkAccessManager::insertProxyFactory( QNetworkProxyFactory *factory )
+  mProxyFactories.insert( 0, factory );
+void QgsNetworkAccessManager::removeProxyFactory( QNetworkProxyFactory *factory )
+  mProxyFactories.removeAll( factory );
+const QList<QNetworkProxyFactory *> QgsNetworkAccessManager::proxyFactories() const
+  return mProxyFactories;
+const QStringList &QgsNetworkAccessManager::excludeList() const
+  return mExcludedURLs;
+const QNetworkProxy &QgsNetworkAccessManager::fallbackProxy() const
+  return mFallbackProxy;
+void QgsNetworkAccessManager::setFallbackProxyAndExcludes( const QNetworkProxy &proxy, const QStringList &excludes )
+  mFallbackProxy = proxy;
+  mExcludedURLs = excludes;
Property changes on: trunk/qgis/src/core/qgsnetworkaccessmanager.cpp
Added: svn:keywords
Added: trunk/qgis/src/core/qgsnetworkaccessmanager.h
--- trunk/qgis/src/core/qgsnetworkaccessmanager.h	                        (rev 0)
+++ trunk/qgis/src/core/qgsnetworkaccessmanager.h	2010-05-08 19:16:21 UTC (rev 13443)
@@ -0,0 +1,83 @@
+                          qgsnetworkaccessmanager.h  -  description
+/* $Id$ */
+#ifndef QGSNETWORKACCESSMANAGER_H
+#define QGSNETWORKACCESSMANAGER_H
+#include <QList>
+#include <QStringList>
+#include <QNetworkAccessManager>
+#include <QNetworkProxy>
+ * \ingroup core
+ * \since 1.5
+ * that can be use across QGIS.
+class CORE_EXPORT QgsNetworkAccessManager : public QNetworkAccessManager
+    Q_OBJECT
+  public:
+    //! destructor
+    void insertProxyFactory( QNetworkProxyFactory *factory );
+    void removeProxyFactory( QNetworkProxyFactory *factory );
+  private:
+    QgsNetworkAccessManager( QObject *parent = 0 );
+    QList<QNetworkProxyFactory*> mProxyFactories;
+    QNetworkProxy mFallbackProxy;
+    QStringList mExcludedURLs;
+    static QgsNetworkAccessManager *smNAM;
+#endif // QGSNETWORKACCESSMANAGER_H
Property changes on: trunk/qgis/src/core/qgsnetworkaccessmanager.h
Added: svn:keywords
Modified: trunk/qgis/src/providers/wms/qgswmsprovider.cpp
--- trunk/qgis/src/providers/wms/qgswmsprovider.cpp	2010-05-08 19:09:42 UTC (rev 13442)
+++ trunk/qgis/src/providers/wms/qgswmsprovider.cpp	2010-05-08 19:16:21 UTC (rev 13443)
@@ -31,8 +31,8 @@
 #include "qgscoordinatetransform.h"
 #include "qgsrectangle.h"
@@ -83,50 +83,6 @@
     , mCacheMisses( 0 )
     , mErrors( 0 )
-  if ( !smNAM )
-    QList<QByteArray> propertyNames = QCoreApplication::instance()->dynamicPropertyNames();
-    foreach( QByteArray name, propertyNames )
-      QgsDebugMsg( QString( "property name: %1" ).arg( QString::fromUtf8( name ) ) );
-    if ( propertyNames.contains( "qgisNetworkAccessManager" ) )
-      smNAM = qobject_cast<QNetworkAccessManager*>( QCoreApplication::instance()->property( "qgisNetworkAccessManager" ).value<QObject*>() );
-      if ( smNAM )
-        QNetworkProxy proxy = smNAM->proxy();
-        QgsDebugMsg( QString( "proxy host:%1:%2 type:%3 user:%4 password:%5 capabilities:%6" )
-                     .arg( proxy.hostName() ).arg( proxy.port() )
-                     .arg( proxy.type() )
-                     .arg( proxy.user() ).arg( proxy.password() )
-                     .arg( proxy.capabilities() )
-#else
-        QgsDebugMsg( QString( "proxy host:%1:%2 type:%3 user:%4 password:%5" )
-#endif
-    if ( !smNAM )
-      QgsDebugMsg( "application doesn't have a network access manager - creating wmscache" );
-      smNAM = new QNetworkAccessManager( this );
-      QNetworkDiskCache *ndc = new QNetworkDiskCache( this );
-      ndc->setCacheDirectory( "wmsCache" );
-      smNAM->setCache( ndc );
-#endif
   // URL may contain username/password information for a WMS
   // requiring authentication. In this case the URL is prefixed
   // with username=user,password=pass,url=http://xxx.xxx.xx/yyy...
@@ -537,7 +493,7 @@
     QgsDebugMsg( QString( "getmap: %1" ).arg( url ) );
     QNetworkRequest request( url );
     request.setAttribute( QNetworkRequest::CacheSaveControlAttribute, true );
-    cacheReply = smNAM->get( request );
+    cacheReply = QgsNetworkAccessManager::instance()->get( request );
     connect( cacheReply, SIGNAL( finished() ), this, SLOT( cacheReplyFinished() ) );
     connect( cacheReply, SIGNAL( downloadProgress( qint64, qint64 ) ), this, SLOT( cacheReplyProgress( qint64, qint64 ) ) );
@@ -571,8 +527,6 @@
     double tres = mResolutions[i];
-    double dx = mTileWidth * tres;
-    double dy = mTileHeight * tres;
     // clip view extent to layer extent
     double xmin = std::max( viewExtent.xMinimum(), layerExtent.xMinimum() );
@@ -581,12 +535,12 @@
     double ymax = std::min( viewExtent.yMaximum(), layerExtent.yMaximum() );
     // snap to tile coordinates
-    double x0 = floor(( xmin - layerExtent.xMinimum() ) / dx ) * dx + layerExtent.xMinimum();
-    double y0 = floor(( ymin - layerExtent.yMinimum() ) / dy ) * dy + layerExtent.yMinimum();
+    double x0 = floor(( xmin - layerExtent.xMinimum() ) / mTileWidth / tres ) * mTileWidth * tres + layerExtent.xMinimum();
+    double y0 = floor(( ymin - layerExtent.yMinimum() ) / mTileHeight / tres ) * mTileHeight * tres + layerExtent.yMinimum();
 #ifdef QGISDEBUG
     // calculate number of tiles
-    int n = ceil(( xmax - xmin ) / dx ) * ceil(( ymax - ymin ) / dy );
+    int n = ceil(( xmax - xmin ) / mTileWidth / tres ) * ceil(( ymax - ymin ) / mTileHeight / tres );
 #endif
     QgsDebugMsg( QString( "layer extent: %1,%2 %3x%4" )
@@ -604,13 +558,13 @@
     QgsDebugMsg( QString( "tile extent: %1,%2 %3x%4 pixel:%5x%6 res:%7" )
                  .arg( x0, 0, 'f' ).arg( y0, 0, 'f' )
-                 .arg( dx, 0, 'f' ).arg( dy, 0, 'f' )
+                 .arg( mTileWidth * tres, 0, 'f' ).arg( mTileHeight * tres, 0, 'f' )
                  .arg( mTileWidth ).arg( mTileHeight )
                  .arg( tres, 0, 'f' )
     QgsDebugMsg( QString( "tile number: %1x%2 = %3" )
-                 .arg( ceil(( xmax - xmin ) / dx ) )
-                 .arg( ceil(( ymax - ymin ) / dy ) )
+                 .arg( ceil(( xmax - xmin ) / mTileWidth / tres ) )
+                 .arg( ceil(( ymax - ymin ) / mTileHeight / tres ) )
                  .arg( n )
@@ -635,33 +589,40 @@
     urlargs += QString( "&FORMAT=%1" ).arg( imageMimeType );
     urlargs += QString( "&TILED=true" );
+    i = 0;
     int j = 0;
-    for ( double y = y0; y < ymax; y += dy )
+    double y = y0;
+    while ( y < ymax )
-      for ( double x = x0; x <= xmax; x += dx )
+      int k = 0;
+      double x = x0;
+      while ( x < xmax )
         QString turl;
         turl += url;
         turl += QString( changeXY ? "&BBOX=%2,%1,%4,%3" : "&BBOX=%1,%2,%3,%4" )
                 .arg( x, 0, 'f' )
                 .arg( y, 0, 'f' )
-                .arg( x + dx, 0, 'f' )
-                .arg( y + dy, 0, 'f' );
+                .arg( x + mTileWidth * tres, 0, 'f' )
+                .arg( y + mTileHeight * tres, 0, 'f' );
         turl += urlargs;
         QNetworkRequest request( turl );
-        QgsDebugMsg( QString( "tileRequest %1 %2/%3: %4" ).arg( mTileReqNo ).arg( j++ ).arg( n ).arg( turl ) );
+        QgsDebugMsg( QString( "tileRequest %1 %2/%3: %4" ).arg( mTileReqNo ).arg( i++ ).arg( n ).arg( turl ) );
         request.setAttribute( QNetworkRequest::CacheLoadControlAttribute, QNetworkRequest::PreferCache );
         request.setAttribute( static_cast<QNetworkRequest::Attribute>( QNetworkRequest::User + 0 ), mTileReqNo );
         request.setAttribute( static_cast<QNetworkRequest::Attribute>( QNetworkRequest::User + 1 ), j );
-        request.setAttribute( static_cast<QNetworkRequest::Attribute>( QNetworkRequest::User + 2 ), QRectF( x, y, dx, dy ) );
+        request.setAttribute( static_cast<QNetworkRequest::Attribute>( QNetworkRequest::User + 2 ), QRectF( x, y, mTileWidth * tres, mTileHeight * tres ) );
         QgsDebugMsg( QString( "gettile: %1" ).arg( turl ) );
-        QNetworkReply *reply = smNAM->get( request );
+        QNetworkReply *reply = QgsNetworkAccessManager::instance()->get( request );
         tileReplies << reply;
         connect( reply, SIGNAL( finished() ), this, SLOT( tileReplyFinished() ) );
+        x = x0 + k++*mTileWidth * tres;
+      y = y0 + j++*mTileHeight * tres;
     mWaiting = true;
@@ -729,7 +690,7 @@
       reply->deleteLater();
       QgsDebugMsg( QString( "redirected gettile: %1" ).arg( redirect.toString() ) );
-      reply = smNAM->get( request );
+      reply = QgsNetworkAccessManager::instance()->get( request );
@@ -807,7 +768,7 @@
       cacheReply->deleteLater();
       QgsDebugMsg( QString( "redirected getmap: %1" ).arg( redirect.toString() ) );
-      cacheReply = smNAM->get( QNetworkRequest( redirect.toUrl() ) );
+      cacheReply = QgsNetworkAccessManager::instance()->get( QNetworkRequest( redirect.toUrl() ) );
       return;
@@ -861,7 +822,7 @@
     QgsDebugMsg( QString( "getcapabilities: %1" ).arg( url ) );
-    mCapabilitiesReply = smNAM->get( request );
+    mCapabilitiesReply = QgsNetworkAccessManager::instance()->get( request );
     connect( mCapabilitiesReply, SIGNAL( finished() ), this, SLOT( capabilitiesReplyFinished() ) );
     connect( mCapabilitiesReply, SIGNAL( downloadProgress( qint64, qint64 ) ), this, SLOT( capabilitiesReplyProgress( qint64, qint64 ) ) );
@@ -916,7 +877,7 @@
       mCapabilitiesReply->deleteLater();
       QgsDebugMsg( QString( "redirected getcapabilities: %1" ).arg( redirect.toString() ) );
@@ -2637,7 +2598,7 @@
         //   requestUrl += QString( "&I=%1&J=%2" ).arg( point.x() ).arg( point.y() );
         QgsDebugMsg( QString( "getfeatureinfo: %1" ).arg( requestUrl ) );
-        mIdentifyReply = smNAM->get( QNetworkRequest( requestUrl ) );
+        mIdentifyReply = QgsNetworkAccessManager::instance()->get( QNetworkRequest( requestUrl ) );
         connect( mIdentifyReply, SIGNAL( finished() ), this, SLOT( identifyReplyFinished() ) );
         while ( mIdentifyReply )
@@ -2676,7 +2637,7 @@
       mIdentifyReply->deleteLater();
       QgsDebugMsg( QString( "redirected getfeatureinfo: %1" ).arg( redirect.toString() ) );
-      mIdentifyReply = smNAM->get( QNetworkRequest( redirect.toUrl() ) );
+      mIdentifyReply = QgsNetworkAccessManager::instance()->get( QNetworkRequest( redirect.toUrl() ) );
       return;
@@ -2736,9 +2697,7 @@
   return WMS_DESCRIPTION;
 } //  QgsWmsProvider::description()
-QNetworkAccessManager *QgsWmsProvider::smNAM = 0;
  * Class factory to return a pointer to a newly created
  * QgsWmsProvider object
Modified: trunk/qgis/src/providers/wms/qgswmsprovider.h
--- trunk/qgis/src/providers/wms/qgswmsprovider.h	2010-05-08 19:09:42 UTC (rev 13442)
+++ trunk/qgis/src/providers/wms/qgswmsprovider.h	2010-05-08 19:16:21 UTC (rev 13443)
@@ -883,9 +883,6 @@
     int mTileWidth;
     int mTileHeight;
     QVector<double> mResolutions;
-    //! wms provider's network access manager
-    static QNetworkAccessManager *smNAM;
 #endif
More information about the QGIS-commit mailing list
