[QGIS Commit] r13485 - trunk/qgis/i18n
svn_qgis at osgeo.org
Fri May 14 08:31:31 EDT 2010
Author: pcav
Date: 2010-05-14 08:31:30 -0400 (Fri, 14 May 2010)
New Revision: 13485
trunk/qgis/i18n/qgis_it.ts
More typos and updates in IT translation
Modified: trunk/qgis/i18n/qgis_it.ts
--- trunk/qgis/i18n/qgis_it.ts 2010-05-14 08:30:58 UTC (rev 13484)
+++ trunk/qgis/i18n/qgis_it.ts 2010-05-14 12:31:30 UTC (rev 13485)
@@ -27798,12 +27798,12 @@
<message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="240"/>
<source>Import loaded raster</source>
- <translation>Importa un raster caricato</translation>
+ <translation>Importa raster caricato</translation>
</message>
<message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="241"/>
<source>Import loaded raster and create a fitted location</source>
- <translation>Importa un raster caricato e crea una location adatta</translation>
+ <translation>Importa raster caricato e crea una location adatta</translation>
</message>
<message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="242"/>
@@ -28088,7 +28088,7 @@
<message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="298"/>
<source>Projection conversion of vector</source>
- <translation>Conversione di proiezione di un vettore</translation>
+ <translation>Riproietta un vettore da una location alla location attuale</translation>
</message>
<message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="299"/>
@@ -28143,12 +28143,12 @@
<message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="309"/>
<source>Re-project raster from a location to the current location</source>
- <translation>Ri-proietta un raster da una location alla location attuale</translation>
+ <translation>Riproietta un raster da una location alla location attuale</translation>
</message>
<message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="310"/>
<source>Rebuild topology of all vectors in mapset</source>
- <translation>Riscotruisce la topologia per tutti i vettori nel mapset</translation>
+ <translation>Ricostruisce la topologia per tutti i vettori nel mapset</translation>
</message>
<message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="311"/>
@@ -28343,12 +28343,12 @@
<message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="349"/>
<source>Select features by attributes</source>
- <translation>Seleziona gli oggetti in base agli attributi</translation>
+ <translation>Estrai gli oggetti in base agli attributi</translation>
</message>
<message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="350"/>
<source>Select features overlapped by features in another map</source>
- <translation>Seleziona gli oggetti sovrapposti agli oggetti di un'altra mappa</translation>
+ <translation>Estrai gli oggetti sovrapposti agli oggetti di un'altra mappa</translation>
</message>
<message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="351"/>
