[QGIS Commit] r13488 - in trunk/qgis: cmake python
svn_qgis at osgeo.org
Sat May 15 03:28:29 EDT 2010
Author: jef
Date: 2010-05-15 03:28:28 -0400 (Sat, 15 May 2010)
New Revision: 13488
trunk/qgis/cmake/FindPyQt4.cmake
trunk/qgis/python/CMakeLists.txt
fix #2720
Modified: trunk/qgis/cmake/FindPyQt4.cmake
--- trunk/qgis/cmake/FindPyQt4.cmake 2010-05-14 16:06:37 UTC (rev 13487)
+++ trunk/qgis/cmake/FindPyQt4.cmake 2010-05-15 07:28:28 UTC (rev 13488)
@@ -22,10 +22,10 @@
# PYQT4_SIP_FLAGS - The SIP flags used to build PyQt.
-IF(EXISTS PYQT4_VERSION_STR)
+IF(EXISTS PYQT4_VERSION)
# Already in cache, be silent
SET(PYQT4_FOUND TRUE)
-ELSE(EXISTS PYQT4_VERSION_STR)
+ELSE(EXISTS PYQT4_VERSION)
FIND_FILE(_find_pyqt_py FindPyQt.py PATHS ${CMAKE_MODULE_PATH})
@@ -50,10 +50,4 @@
ENDIF(PYQT4_FIND_REQUIRED)
ENDIF(PYQT4_FOUND)
-ENDIF(EXISTS PYQT4_VERSION_STR)
-STRING(REGEX REPLACE "^([0-9]*)\\.[0-9]*\\.[0-9]*$" "\\1" PYQT4_MAJOR_VERSION ${PYQT4_VERSION_STR})
-STRING(REGEX REPLACE "^[0-9]*\\.([0-9]*)\\.[0-9]*$" "\\1" PYQT4_MINOR_VERSION ${PYQT4_VERSION_STR})
-STRING(REGEX REPLACE "^[0-9]*\\.[0-9]*\\.([0-9]*)$" "\\1" PYQT4_PATCH_VERSION ${PYQT4_VERSION_STR})
-MATH( EXPR PYQT4_NUM_VERSION "${PYQT4_MAJOR_VERSION}*10000 + ${PYQT4_MINOR_VERSION}*100 + ${PYQT4_PATCH_VERSION}")
+ENDIF(EXISTS PYQT4_VERSION)
Modified: trunk/qgis/python/CMakeLists.txt
--- trunk/qgis/python/CMakeLists.txt 2010-05-14 16:06:37 UTC (rev 13487)
+++ trunk/qgis/python/CMakeLists.txt 2010-05-15 07:28:28 UTC (rev 13488)
@@ -35,9 +35,9 @@
ADD_DEFINITIONS(-DNOMINMAX)
ENDIF(MSVC)
-IF(${PYQT4_NUM_VERSION} LESS 40600)
+IF(PYQT4_VERSION_TAG LESS 263680) # 0x040600
SET(SIP_DISABLE_FEATURES ${SIP_DISABLE_FEATURES} PROXY_FACTORY)
-ENDIF(${PYQT4_NUM_VERSION} LESS 40600)
+ENDIF(PYQT4_VERSION_TAG LESS 263680)
# core module
FILE(GLOB sip_files_core core/*.sip)
