[QGIS Commit] r13527 - trunk/qgis/python/plugins/fTools/tools
svn_qgis at osgeo.org
Tue May 18 15:01:39 EDT 2010
Author: cfarmer
Date: 2010-05-18 15:01:38 -0400 (Tue, 18 May 2010)
New Revision: 13527
trunk/qgis/python/plugins/fTools/tools/doVectorSplit.py
trunk/qgis/python/plugins/fTools/tools/ftools_utils.py
Fix output folder selection for split vector layers tool. Patch from alexbruy. Fixes #2725.
Modified: trunk/qgis/python/plugins/fTools/tools/doVectorSplit.py
--- trunk/qgis/python/plugins/fTools/tools/doVectorSplit.py 2010-05-18 15:18:35 UTC (rev 13526)
+++ trunk/qgis/python/plugins/fTools/tools/doVectorSplit.py 2010-05-18 19:01:38 UTC (rev 13527)
@@ -84,10 +84,10 @@
def outFile(self):
self.outShape.clear()
- ( self.shapefileName, self.encoding ) = ftools_utils.saveDialog( self )
- if self.shapefileName is None or self.encoding is None:
+ ( self.folderName, self.encoding ) = ftools_utils.dirDialog( self )
+ if self.folderName is None or self.encoding is None:
return
- self.outShape.setText( QString( self.shapefileName ) )
+ self.outShape.setText( QString( self.folderName ) )
def split(self, vlayer, outPath, inField, progressBar):
provider = vlayer.dataProvider()
Modified: trunk/qgis/python/plugins/fTools/tools/ftools_utils.py
--- trunk/qgis/python/plugins/fTools/tools/ftools_utils.py 2010-05-18 15:18:35 UTC (rev 13526)
+++ trunk/qgis/python/plugins/fTools/tools/ftools_utils.py 2010-05-18 19:01:38 UTC (rev 13527)
@@ -261,12 +261,11 @@
return values
# Generate a save file dialog with a dropdown box for choosing encoding style
-def saveDialog( parent ):
+def saveDialog( parent, filtering="Shapefiles (*.shp)"):
settings = QSettings()
dirName = settings.value( "/UI/lastShapefileDir" ).toString()
- filtering = QString( "Shapefiles (*.shp)" )
encode = settings.value( "/UI/encoding" ).toString()
- fileDialog = QgsEncodingFileDialog( parent, "Save output shapefile", dirName, filtering, encode )
+ fileDialog = QgsEncodingFileDialog( parent, "Save output shapefile", dirName, QString(filtering), encode )
fileDialog.setDefaultSuffix( QString( "shp" ) )
fileDialog.setFileMode( QFileDialog.AnyFile )
fileDialog.setAcceptMode( QFileDialog.AcceptSave )
@@ -277,6 +276,35 @@
settings.setValue("/UI/lastShapefileDir", QVariant( QFileInfo( unicode( files.first() ) ).absolutePath() ) )
return ( unicode( files.first() ), unicode( fileDialog.encoding() ) )
+# Generate a save file dialog with a dropdown box for choosing encoding style
+def openDialog( parent, filtering="Shapefiles (*.shp)"):
+ settings = QSettings()
+ dirName = settings.value( "/UI/lastShapefileDir" ).toString()
+ encode = settings.value( "/UI/encoding" ).toString()
+ fileDialog.setFileMode( QFileDialog.AnyFile )
+ fileDialog.setAcceptMode( QFileDialog.AcceptOpen )
+ if not fileDialog.exec_() == QDialog.Accepted:
+ return None, None
+ files = fileDialog.selectedFiles()
+ settings.setValue("/UI/lastShapefileDir", QVariant( QFileInfo( unicode( files.first() ) ).absolutePath() ) )
+ return ( unicode( files.first() ), unicode( fileDialog.encoding() ) )
+# Generate a select directory dialog with a dropdown box for choosing encoding style
+def dirDialog( parent ):
+ fileDialog = QgsEncodingFileDialog( parent, "Save output shapefile", dirName, encode )
+ fileDialog.setFileMode( QFileDialog.DirectoryOnly )
+ fileDialog.setAcceptMode( QFileDialog.AcceptSave )
+ fileDialog.setConfirmOverwrite( False )
+ return None, None
+ folders = fileDialog.selectedFiles()
+ settings.setValue("/UI/lastShapefileDir", QVariant( QFileInfo( unicode( folders.first() ) ) ) )
+ return ( unicode( folders.first() ), unicode( fileDialog.encoding() ) )
# Return field type from it's name
def getFieldType(vlayer, fieldName):
fields = vlayer.dataProvider().fields()
