[QGIS Commit] r13544 - trunk/qgis/src/plugins/georeferencer
svn_qgis at osgeo.org
Fri May 21 05:32:01 EDT 2010
Author: mmassing
Date: 2010-05-21 05:31:57 -0400 (Fri, 21 May 2010)
New Revision: 13544
trunk/qgis/src/plugins/georeferencer/qgsgeorefconfigdialog.cpp
trunk/qgis/src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui
trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp
trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.h
Amend previously ommited docking feature of patch #2673.
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeorefconfigdialog.cpp
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefconfigdialog.cpp 2010-05-21 06:32:06 UTC (rev 13543)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefconfigdialog.cpp 2010-05-21 09:31:57 UTC (rev 13544)
@@ -70,6 +70,15 @@
mShowCoordsCheckBox->setChecked( false );
+ if ( s.value( "/Plugin-GeoReferencer/Config/ShowDocked" ).toBool() )
+ mShowDockedCheckBox->setChecked( true );
+ else
+ mShowDockedCheckBox->setChecked( false );
void QgsGeorefConfigDialog::writeSettings()
@@ -77,4 +86,5 @@
QSettings s;
s.setValue( "/Plugin-GeoReferencer/Config/ShowId", mShowIDsCheckBox->isChecked() );
s.setValue( "/Plugin-GeoReferencer/Config/ShowCoords", mShowCoordsCheckBox->isChecked() );
+ s.setValue( "/Plugin-GeoReferencer/Config/ShowDocked", mShowDockedCheckBox->isChecked() );
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui 2010-05-21 06:32:06 UTC (rev 13543)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui 2010-05-21 09:31:57 UTC (rev 13544)
@@ -19,15 +19,15 @@
<property name="title">
<string>Point tip</string>
</property>
- <layout class="QHBoxLayout" name="horizontalLayout">
- <item>
+ <layout class="QGridLayout" name="gridLayout">
+ <item row="0" column="0">
<widget class="QCheckBox" name="mShowIDsCheckBox">
<property name="text">
<string>Show IDs</string>
</property>
</widget>
</item>
- <item>
+ <item row="1" column="0">
<widget class="QCheckBox" name="mShowCoordsCheckBox">
<string>Show coords</string>
@@ -38,6 +38,13 @@
</widget>
</item>
+ <widget class="QCheckBox" name="mShowDockedCheckBox">
+ <property name="text">
+ <string>Show Georeferencer window docked</string>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="0">
<widget class="QDialogButtonBox" name="buttonBox">
<property name="orientation">
<enum>Qt::Horizontal</enum>
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp 2010-05-21 06:32:06 UTC (rev 13543)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp 2010-05-21 09:31:57 UTC (rev 13544)
@@ -86,6 +86,7 @@
, mMapCoordsDialog( 0 )
, mUseZeroForTrans( false )
, mLoadInQgis( false )
+ , mDock( 0 )
setupUi( this );
@@ -104,8 +105,35 @@
mActionLinkQGisToGeoref->setEnabled( false );
mCanvas->clearExtentHistory(); // reset zoomnext/zoomlast
+ QSettings s;
+ dockThisWindow( true );
+void QgsGeorefPluginGui::dockThisWindow( bool dock )
+ if ( mDock )
+ setParent( 0 );
+ show();
+ mIface->removeDockWidget( mDock );
+ mDock->setWidget( 0 );
+ delete mDock;
+ mDock = 0;
+ if ( dock )
+ mDock = new QgsGeorefDockWidget( tr( "Georeferencer" ), mIface->mainWindow() );
+ mDock->setWidget( this );
+ connect( this, SIGNAL( destroyed() ), mDock, SLOT( close() ) );
+ mIface->addDockWidget( Qt::BottomDockWidgetArea, mDock );
QgsGeorefPluginGui::~QgsGeorefPluginGui()
QgsTransformSettingsDialog::resetSettings();
@@ -123,6 +151,7 @@
delete mToolAddPoint;
delete mToolDeletePoint;
delete mToolMovePoint;
+ delete mDock;
// ----------------------------- protected --------------------------------- //
@@ -568,6 +597,17 @@
mCanvas->refresh();
mIface->mapCanvas()->refresh();
+ QSettings s;
+ //update dock state
+ bool dock = s.value( "/Plugin-GeoReferencer/Config/ShowDocked" ).toBool();
+ if ( dock && !mDock )
+ else if ( !dock && mDock )
+ dockThisWindow( false );
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.h
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.h 2010-05-21 06:32:06 UTC (rev 13543)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.h 2010-05-21 09:31:57 UTC (rev 13544)
@@ -159,7 +159,10 @@
void logRequaredGCPs();
void clearGCPData();
+ /**Docks / undocks this window*/
+ void dockThisWindow( bool dock );
QMenu *mPanelMenu;
QMenu *mToolbarMenu;
@@ -207,5 +210,7 @@
bool mExtentsChangedRecursionGuard;
bool mGCPsDirty;
bool mLoadInQgis;
+ QDockWidget* mDock;
#endif
