[QGIS Commit] r13547 - in trunk/qgis/src: app app/attributetable ui
svn_qgis at osgeo.org
Sat May 22 11:45:49 EDT 2010
Author: jef
Date: 2010-05-22 11:45:49 -0400 (Sat, 22 May 2010)
New Revision: 13547
trunk/qgis/src/app/attributetable/qgsattributetablememorymodel.cpp
trunk/qgis/src/app/attributetable/qgsattributetablememorymodel.h
trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp
trunk/qgis/src/app/attributetable/qgsattributetablemodel.h
trunk/qgis/src/app/qgsoptions.cpp
trunk/qgis/src/ui/qgsoptionsbase.ui
[FEATURE] forward port r9689 to model based attribute table
Modified: trunk/qgis/src/app/attributetable/qgsattributetablememorymodel.cpp
--- trunk/qgis/src/app/attributetable/qgsattributetablememorymodel.cpp 2010-05-22 15:41:42 UTC (rev 13546)
+++ trunk/qgis/src/app/attributetable/qgsattributetablememorymodel.cpp 2010-05-22 15:45:49 UTC (rev 13547)
@@ -60,6 +60,7 @@
+#if 0
void QgsAttributeTableMemoryModel::featureDeleted( int fid )
QgsDebugMsg( "entered." );
@@ -75,6 +76,7 @@
mFeatureMap.insert( fid, f );
QgsAttributeTableModel::featureAdded( fid );
+#endif
void QgsAttributeTableMemoryModel::layerDeleted()
Modified: trunk/qgis/src/app/attributetable/qgsattributetablememorymodel.h
--- trunk/qgis/src/app/attributetable/qgsattributetablememorymodel.h 2010-05-22 15:41:42 UTC (rev 13546)
+++ trunk/qgis/src/app/attributetable/qgsattributetablememorymodel.h 2010-05-22 15:45:49 UTC (rev 13547)
@@ -40,6 +40,7 @@
QgsAttributeTableMemoryModel( QgsVectorLayer *theLayer );
protected slots:
+#if 0
* Launched when a feature has been deleted
* @param fid feature id
@@ -50,6 +51,7 @@
virtual void featureAdded( int fid );
+#endif
* Launched when layer has been deleted
Modified: trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp
--- trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp 2010-05-22 15:41:42 UTC (rev 13546)
+++ trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp 2010-05-22 15:45:49 UTC (rev 13547)
@@ -21,6 +21,7 @@
#include "qgslogger.h"
#include "qgisapp.h"
#include "qgsattributeaction.h"
+#include "qgsmapcanvas.h"
#include <QtGui>
#include <QVariant>
@@ -35,10 +36,8 @@
mFeat.setFeatureId( std::numeric_limits<int>::min() );
mLayer = theLayer;
- mFeatureCount = mLayer->pendingFeatureCount();
loadAttributes();
connect( mLayer, SIGNAL( layerModified( bool ) ), this, SLOT( layerModified( bool ) ) );
//connect(mLayer, SIGNAL(attributeValueChanged(int, int, const QVariant&)), this, SLOT( attributeValueChanged(int, int, const QVariant&)));
//connect(mLayer, SIGNAL(featureDeleted(int)), this, SLOT( featureDeleted(int)));
@@ -52,6 +51,7 @@
return mLayer->featureAtId( fid, mFeat, false, true );
+#if 0
void QgsAttributeTableModel::featureDeleted( int fid )
@@ -83,6 +83,7 @@
QgsDebugMsg( QString( "map sizes:%1, %2" ).arg( mRowIdMap.size() ).arg( mIdRowMap.size() ) );
reload( index( 0, 0 ), index( rowCount(), columnCount() ) );
+#endif
void QgsAttributeTableModel::attributeAdded( int idx )
@@ -189,37 +190,56 @@
QgsFeature f;
bool ins = false, rm = false;
+ int previousSize = mRowIdMap.size();
mRowIdMap.clear();
mIdRowMap.clear();
- int pendingFeatureCount = mLayer->pendingFeatureCount();
- if ( mFeatureCount < pendingFeatureCount )
+ QSettings settings;
+ int behaviour = settings.value( "/qgis/attributeTableBehaviour", 0 ).toInt();
+ if ( behaviour == 1 )
+ const QgsFeatureList &features = mLayer->selectedFeatures();
+ for ( int i = 0; i < features.size(); ++i )
+ mRowIdMap.insert( i, features[i].id() );
+ mIdRowMap.insert( features[i].id(), i );
+ else
+ QgsRectangle rect;
+ if ( behaviour == 2 )
+ // current canvas only
+ rect = QgisApp::instance()->mapCanvas()->extent();
+ mLayer->select( mAttributes, rect, false );
+ for ( int i = 0; mLayer->nextFeature( f ); ++i )
+ mRowIdMap.insert( i, f.id() );
+ mIdRowMap.insert( f.id(), i );
+ if ( previousSize < mRowIdMap.size() )
QgsDebugMsg( "ins" );
ins = true;
- beginInsertRows( QModelIndex(), mFeatureCount, pendingFeatureCount - 1 );
+ beginInsertRows( QModelIndex(), previousSize, mRowIdMap.size() - 1 );
- else if ( mFeatureCount > pendingFeatureCount )
+ else if ( previousSize > mRowIdMap.size() )
QgsDebugMsg( "rm" );
rm = true;
- beginRemoveRows( QModelIndex(), pendingFeatureCount, mFeatureCount - 1 );
+ beginRemoveRows( QModelIndex(), mRowIdMap.size(), previousSize - 1 );
- mLayer->select( mAttributes, QgsRectangle(), false );
- // preallocate data before inserting
- mRowIdMap.reserve( pendingFeatureCount + 50 );
- mIdRowMap.reserve( pendingFeatureCount + 50 );
- for ( int i = 0; mLayer->nextFeature( f ); ++i )
- mRowIdMap.insert( i, f.id() );
- mIdRowMap.insert( f.id(), i );
// not needed when we have featureAdded signal
mFieldCount = mAttributes.size();
if ( ins )
@@ -287,7 +307,7 @@
int QgsAttributeTableModel::rowCount( const QModelIndex &parent ) const
- return mFeatureCount;
+ return mRowIdMap.size();
int QgsAttributeTableModel::columnCount( const QModelIndex &parent ) const
Modified: trunk/qgis/src/app/attributetable/qgsattributetablemodel.h
--- trunk/qgis/src/app/attributetable/qgsattributetablemodel.h 2010-05-22 15:41:42 UTC (rev 13546)
+++ trunk/qgis/src/app/attributetable/qgsattributetablemodel.h 2010-05-22 15:45:49 UTC (rev 13547)
@@ -166,6 +166,7 @@
virtual void layerModified( bool onlyGeometry );
protected slots:
+#if 0
@@ -176,6 +177,7 @@
+#endif
@@ -183,7 +185,6 @@
protected:
QgsVectorLayer *mLayer;
- int mFeatureCount;
int mFieldCount;
mutable QgsFeature mFeat;
Modified: trunk/qgis/src/app/qgsoptions.cpp
--- trunk/qgis/src/app/qgsoptions.cpp 2010-05-22 15:41:42 UTC (rev 13546)
+++ trunk/qgis/src/app/qgsoptions.cpp 2010-05-22 15:45:49 UTC (rev 13547)
@@ -142,6 +142,13 @@
// set the current theme
cmbTheme->setItemText( cmbTheme->currentIndex(), settings.value( "/Themes" ).toString() );
+ // set the attribute table behaviour
+ cmbAttrTableBehaviour->clear();
+ cmbAttrTableBehaviour->addItem( tr( "Show all features" ) );
+ cmbAttrTableBehaviour->addItem( tr( "Show selected features" ) );
+ cmbAttrTableBehaviour->addItem( tr( "Show features in current canvas" ) );
+ cmbAttrTableBehaviour->setCurrentIndex( settings.value( "/qgis/attributeTableBehaviour", 0 ).toInt() );
// set the display update threshold
spinBoxUpdateThreshold->setValue( settings.value( "/Map/updateThreshold" ).toInt() );
//set the default projection behaviour radio buttongs
@@ -478,6 +485,7 @@
settings.setValue( "/qgis/showLegendClassifiers", cbxLegendClassifiers->isChecked() );
settings.setValue( "/qgis/hideSplash", cbxHideSplash->isChecked() );
settings.setValue( "/qgis/dockAttributeTable", cbxAttributeTableDocked->isChecked() );
+ settings.setValue( "/qgis/attributeTableBehaviour", cmbAttrTableBehaviour->currentIndex() );
settings.setValue( "/qgis/dockIdentifyResults", cbxIdentifyResultsDocked->isChecked() );
settings.setValue( "/qgis/addPostgisDC", cbxAddPostgisDC->isChecked() );
settings.setValue( "/qgis/addNewLayersToCurrentGroup", cbxAddNewLayersToCurrentGroup->isChecked() );
Modified: trunk/qgis/src/ui/qgsoptionsbase.ui
--- trunk/qgis/src/ui/qgsoptionsbase.ui 2010-05-22 15:41:42 UTC (rev 13546)
+++ trunk/qgis/src/ui/qgsoptionsbase.ui 2010-05-22 15:45:49 UTC (rev 13547)
@@ -414,6 +414,48 @@
</property>
</widget>
</item>
+ <item>
+ <layout class="QHBoxLayout" name="horizontalLayout_5">
+ <item>
+ <widget class="QLabel" name="textLabel1_7">
+ <property name="sizePolicy">
+ <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <property name="text">
+ <string>Attribute table behaviour</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <spacer name="horizontalSpacer_4">
+ <property name="orientation">
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <property name="sizeHint" stdset="0">
+ <size>
+ <width>40</width>
+ <height>20</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item>
+ <widget class="QComboBox" name="cmbAttrTableBehaviour">
+ <property name="duplicatesEnabled">
+ <bool>false</bool>
+ </property>
+ <item>
+ <string/>
+ </property>
+ </item>
+ </widget>
+ </item>
+ </layout>
+ </item>
</layout>
</widget>
</item>
