[QGIS Commit] r13549 - trunk/qgis/i18n
svn_qgis at osgeo.org
Sat May 22 12:08:25 EDT 2010
Author: jef
Date: 2010-05-22 12:08:24 -0400 (Sat, 22 May 2010)
New Revision: 13549
trunk/qgis/i18n/qgis_de.ts
german translation update
Modified: trunk/qgis/i18n/qgis_de.ts
--- trunk/qgis/i18n/qgis_de.ts 2010-05-22 15:51:12 UTC (rev 13548)
+++ trunk/qgis/i18n/qgis_de.ts 2010-05-22 16:08:24 UTC (rev 13549)
@@ -3703,7 +3703,7 @@
<message>
<location filename="../src/plugins/georeferencer/qgsgeorefplugin.cpp" line="65"/>
<source>Georeferencer GDAL</source>
- <translation>GDAL-Georeferenzierer</translation>
+ <translation>GDAL-Georeferenzierung</translation>
</message>
<message>
<location filename="../src/plugins/georeferencer/qgsgeorefplugin.cpp" line="66"/>
@@ -6072,7 +6072,7 @@
<message>
<location filename="../src/app/qgisapp.cpp" line="5258"/>
<source>The layer %1 is not a valid layer and can not be added to the map</source>
- <translation type="unfinished"></translation>
+ <translation>Der Layer %1 ist ungültig und kann der Karte nicht hinzugefügt werden.</translation>
</message>
<message numerus="yes">
<location filename="../src/app/qgisapp.cpp" line="5755"/>
@@ -6627,22 +6627,22 @@
<context>
<name>QgsAttributeDialog</name>
<message>
- <location filename="../src/app/qgsattributedialog.cpp" line="139"/>
+ <location filename="../src/app/qgsattributedialog.cpp" line="140"/>
<source> (int)</source>
<translation> (Ganzzahl)</translation>
</message>
<message>
- <location filename="../src/app/qgsattributedialog.cpp" line="143"/>
+ <location filename="../src/app/qgsattributedialog.cpp" line="144"/>
<source> (dbl)</source>
<translation> (Fließkommazahl)</translation>
</message>
<message>
- <location filename="../src/app/qgsattributedialog.cpp" line="148"/>
+ <location filename="../src/app/qgsattributedialog.cpp" line="149"/>
<source> (txt)</source>
<translation> (Text)</translation>
</message>
<message>
- <location filename="../src/app/qgsattributedialog.cpp" line="189"/>
+ <location filename="../src/app/qgsattributedialog.cpp" line="190"/>
<source>Attributes - %1</source>
<translation>Attribute - %1</translation>
</message>
@@ -6924,7 +6924,7 @@
<context>
<name>QgsAttributeTableModel</name>
<message>
- <location filename="../src/app/attributetable/qgsattributetablemodel.cpp" line="429"/>
+ <location filename="../src/app/attributetable/qgsattributetablemodel.cpp" line="449"/>
<source>Attribute changed</source>
<translation>Attribut geändert</translation>
</message>
@@ -10678,13 +10678,9 @@
<translation>Vertikale Genauigkeit</translation>
</message>
<message>
- <source>Horizonal Accuracy</source>
- <translation type="obsolete">Horizontale Genauigkeit</translation>
- </message>
- <message>
<location filename="../src/ui/qgsgpsinformationwidgetbase.ui" line="207"/>
<source>Horizontal Accuracy</source>
+ <translation>Horizontale Genauigkeit</translation>
</message>
<message>
<location filename="../src/ui/qgsgpsinformationwidgetbase.ui" line="220"/>
@@ -11211,13 +11207,18 @@
<source>Show coords</source>
<translation>Koordinate</translation>
</message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui" line="43"/>
+ <source>Show Georeferencer window docked</source>
+ <translation>Georeferenzierungsfenster docken</translation>
+ </message>
</context>
<context>
<name>QgsGeorefDescriptionDialogBase</name>
<message>
<location filename="../src/plugins/georeferencer/qgsgeorefdescriptiondialogbase.ui" line="14"/>
<source>Description georeferencer</source>
- <translation>Beschreibung Georeferenzierer</translation>
+ <translation>Georeferenzierungsbeschreibung</translation>
</message>
<message>
<location filename="../src/plugins/georeferencer/qgsgeorefdescriptiondialogbase.ui" line="46"/>
@@ -11247,287 +11248,292 @@
<location filename="../src/plugins/georeferencer/qgsgeorefplugin.cpp" line="129"/>
<location filename="../src/plugins/georeferencer/qgsgeorefplugin.cpp" line="130"/>
<source>&Georeferencer</source>
- <translation>&Georeferenzierer</translation>
+ <translation>&Georeferenzierung</translation>
</message>
</context>
<context>
<name>QgsGeorefPluginGui</name>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="180"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="209"/>
<source>All other files (*)</source>
<translation>Alle anderen Dateien (*)</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="187"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="216"/>
<source>Open raster</source>
<translation>Raster öffnen</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="196"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="225"/>
<source>%1 is not a supported raster data source</source>
<translation>%1 ist keine unterstützte Rasterdatenquelle</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="201"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="230"/>
<source>Unsupported Data Source</source>
<translation>Nicht unterstütztes Datenformat</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="210"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="239"/>
<source>Raster loaded: %1</source>
<translation>Geladenes Raster: %1</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="211"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="240"/>
<source>Georeferencer - %1</source>
<translation>Georeferenzierung</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="289"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="918"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="318"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="958"/>
<source>Transform: </source>
<translation>Transformation: </translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="342"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="533"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="560"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1027"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1075"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1117"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1516"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1525"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1535"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1544"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1558"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="371"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="562"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="589"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1067"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1115"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1157"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1556"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1565"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1575"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1584"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1598"/>
<source>Info</source>
<translation>Information</translation>
</message>
<message>
<source>GDAL scripting is not supported for %1 transformation</source>
<translation>GDAL-Skripting für Transformation %1 nicht unterstützt</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="521"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="550"/>
<source>Load GCP points</source>
<translation>GCP-Punkte laden</translation>
</message>
<message>
<source>No GCP points to save</source>
<translation>Keine GCP-Punkte zu speichern</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="538"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="567"/>
<source>Save GCP points</source>
<translation>GCP-Punkte speichern</translation>
</message>
<message>
<source>Please load raster to be georeferenced</source>
<translation>Bitte laden Sie das zu georeferenzierende Raster</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="764"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="874"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="804"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="914"/>
<source>Help</source>
<translation>Hilfe</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="851"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="891"/>
<source>Panels</source>
<translation>Bedienfelder</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="855"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="895"/>
<source>Toolbars</source>
<translation>Werkzeugkästen</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="907"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="947"/>
<source>Coordinate: </source>
<translation>Koordinate: </translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="908"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="948"/>
<source>Current map coordinate</source>
<translation>Aktuelle Kartenkoordinate</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="919"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="959"/>
<source>Current transform parametrisation</source>
<translation>Aktuelle Transformationsparameterisierung</translation>
</message>
<message>
<source>Unable to open GCP points file %1</source>
<translation>Kann GCP-Punktdatei %1 nicht öffnen</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1146"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1186"/>
<source>Could not write to %1</source>
<translation>Konnte nicht in %1 schreiben</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1041"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1081"/>
<source>Save GCPs</source>
<translation>GCPs speichern</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1042"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="130"/>
+ <source>Georeferencer</source>
+ <translation>Georeferenzierung</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1082"/>
<source>Save GCP points?</source>
<translation>GCP-Punkte speichern?</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1076"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1116"/>
<source>Failed to get linear transform parameters</source>
<translation>Konnte Parameter der linearen Transformation nicht bestimmen</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1086"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1126"/>
<source>World file exists</source>
<translation>World-File existiert</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1087"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1127"/>
<source><p>The selected file already seems to have a world file! Do you want to replace it with the new world file?</p></source>
<translation><p>Die gewählte Datei scheint bereits eine World-Datei zu haben! Wollen Sie sie mit der neuen überschreiben?</p></translation>
</message>
<message>
<source>Failed to compute GCP transform: Transform is not solvable</source>
<translation>Konnte GCP-Transformation nicht berechnen. Transformation nicht lösbar</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1145"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1185"/>
<source>Error</source>
<translation>Fehler</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1240"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1280"/>
<source>Transformation parameters</source>
<translation>Transformationsparameter</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1295"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1335"/>
<source>Translation x</source>
<translation>X-Verschiebung</translation>
</message>
<message>
<source>Translation y</source>
<translation>y-Verschiebung</translation>
</message>
<message>
<source>Scale x</source>
<translation>X-Maßstab</translation>
</message>
<message>
<source>Scale y</source>
<translation>Y-Maßstab</translation>
</message>
<message>
<source>Rotation [degrees]</source>
<translation>Drehung [Grad]</translation>
</message>
<message>
<source>Mean error [map units]</source>
<translation>Mittlerer Fehler [Karteneinheiten]</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1314"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1354"/>
<source>Residuals</source>
<translation>Rest</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1339"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1379"/>
<source>map units</source>
<translation>Karteneinheiten</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1343"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1383"/>
<source>pixels</source>
<translation>Pixel</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1372"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1412"/>
<source>yes</source>
<translation>ja</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1376"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1416"/>
<source>no</source>
<translation>nein</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1422"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1462"/>
<source>Copy in clipboard</source>
<translation>In Zwischenablage kopieren</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1428"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1468"/>
<source>%1</source>
<translation>%1</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1435"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1475"/>
<source>GDAL script</source>
<translation>GDAL-Skript</translation>
</message>
<message>
<source>Please set transformation type</source>
<translation>Bitte Transformationstyp setzen</translation>
</message>
<message>
<source>Please set output raster name</source>
<translation>Bitte Ausgaberasternamen angeben</translation>
</message>
<message>
<source>%1 requires at least %2 GCPs. Please define more</source>
<translation>%1 erfordert mindestens %2 GCPs. Bitte mehr definieren</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1631"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1671"/>
<source>Linear</source>
<translation>Linear</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1633"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1673"/>
<source>Helmert</source>
<translation>Helmert</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1635"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1675"/>
<source>Polynomial 1</source>
<translation>Polynomial 1</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1637"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1677"/>
<source>Polynomial 2</source>
<translation>Polynomial 2</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1639"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1679"/>
<source>Polynomial 3</source>
<translation>Polynomial 3</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1641"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1681"/>
<source>Thin plate spline (TPS)</source>
<translation>Thin-Plate-Splines (TPS)</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1643"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1683"/>
<source>Not set</source>
<translation>Nicht gesetzt</translation>
</message>
@@ -11537,7 +11543,7 @@
<message>
<location filename="../src/plugins/georeferencer/qgsgeorefpluginguibase.ui" line="14"/>
- <translation>Georeferenzierer</translation>
</message>
<message>
<location filename="../src/plugins/georeferencer/qgsgeorefpluginguibase.ui" line="30"/>
@@ -17538,21 +17544,21 @@
<context>
<name>QgsOptions</name>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="312"/>
<location filename="../src/app/qgsoptions.cpp" line="319"/>
- <location filename="../src/app/qgsoptions.cpp" line="614"/>
+ <location filename="../src/app/qgsoptions.cpp" line="326"/>
+ <location filename="../src/app/qgsoptions.cpp" line="622"/>
<source>Semi transparent circle</source>
<translation>Teiltransparenter Kreis</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="313"/>
- <location filename="../src/app/qgsoptions.cpp" line="323"/>
- <location filename="../src/app/qgsoptions.cpp" line="618"/>
+ <location filename="../src/app/qgsoptions.cpp" line="320"/>
+ <location filename="../src/app/qgsoptions.cpp" line="330"/>
+ <location filename="../src/app/qgsoptions.cpp" line="626"/>
<source>Cross</source>
<translation>Kreuz</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="262"/>
+ <location filename="../src/app/qgsoptions.cpp" line="269"/>
<source>Detected active locale on your system: %1</source>
<translation>Festgestellte Spracheinstellung des Systems: %1</translation>
</message>
@@ -17572,67 +17578,82 @@
<translation>Von oben nach unten</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="282"/>
+ <location filename="../src/app/qgsoptions.cpp" line="147"/>
+ <source>Show all features</source>
+ <translation>Alle Objekte anzeigen</translation>
+ </message>
+ <message>
+ <location filename="../src/app/qgsoptions.cpp" line="148"/>
+ <source>Show selected features</source>
+ <translation>Alle gewählten Objekte anzeigen</translation>
+ </message>
+ <message>
+ <location filename="../src/app/qgsoptions.cpp" line="149"/>
+ <source>Show features in current canvas</source>
+ <translation>Alle Objekte des aktuellen Kartenausschnitts anzeigen</translation>
+ </message>
+ <message>
+ <location filename="../src/app/qgsoptions.cpp" line="289"/>
<source>To vertex</source>
<translation>Zum Stützpunkt</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="283"/>
+ <location filename="../src/app/qgsoptions.cpp" line="290"/>
<source>To segment</source>
<translation>Zum Segment</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="284"/>
+ <location filename="../src/app/qgsoptions.cpp" line="291"/>
<source>To vertex and segment</source>
<translation>Zum Stützpunkt und Segment</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="314"/>
- <location filename="../src/app/qgsoptions.cpp" line="327"/>
- <location filename="../src/app/qgsoptions.cpp" line="622"/>
+ <location filename="../src/app/qgsoptions.cpp" line="321"/>
+ <location filename="../src/app/qgsoptions.cpp" line="334"/>
+ <location filename="../src/app/qgsoptions.cpp" line="630"/>
<source>None</source>
<translation>Keine</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="819"/>
- <location filename="../src/app/qgsoptions.cpp" line="861"/>
+ <location filename="../src/app/qgsoptions.cpp" line="827"/>
+ <location filename="../src/app/qgsoptions.cpp" line="869"/>
<source>Choose a directory</source>
<translation>Verzeichnis wählen</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="292"/>
- <location filename="../src/app/qgsoptions.cpp" line="301"/>
+ <location filename="../src/app/qgsoptions.cpp" line="299"/>
+ <location filename="../src/app/qgsoptions.cpp" line="308"/>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="296"/>
- <location filename="../src/app/qgsoptions.cpp" line="305"/>
+ <location filename="../src/app/qgsoptions.cpp" line="303"/>
+ <location filename="../src/app/qgsoptions.cpp" line="312"/>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="338"/>
+ <location filename="../src/app/qgsoptions.cpp" line="345"/>
<source>Central point (fastest)</source>
<translation>Zentrum (am schnellsten)</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="339"/>
+ <location filename="../src/app/qgsoptions.cpp" line="346"/>
<source>Chain (fast)</source>
<translation>Kette (schnell)</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="340"/>
+ <location filename="../src/app/qgsoptions.cpp" line="347"/>
<source>Popmusic tabu chain (slow)</source>
<translation>Popmusik-Tabu-Kette (langsam)</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="341"/>
+ <location filename="../src/app/qgsoptions.cpp" line="348"/>
<source>Popmusic tabu (slow)</source>
<translation>Popmusik-Tabu (langsam)</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="342"/>
+ <location filename="../src/app/qgsoptions.cpp" line="349"/>
<source>Popmusic chain (very slow)</source>
<translation>Popmusik-Kette (sehr langsam)</translation>
</message>
@@ -17645,57 +17666,57 @@
<translation>Splashscreen beim Start nicht anzeigen</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="460"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="502"/>
<source>Map display will be updated (drawn) after this many features have been read from the data source</source>
<translation>Kartenanzeige wird erneuert (gezeichnet) nachdem soviele Objekte von der Datenquelle gelesen wurden</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1217"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1259"/>
<source>Select Global Default ...</source>
<translation>Globale Voreinstellung wählen ...</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="499"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="541"/>
<source>Make lines appear less jagged at the expense of some drawing performance</source>
<translation>Linien auf Kosten der Zeichengeschwindigkeit weniger gezackt zeichnen</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="446"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="488"/>
<source>By default new la&yers added to the map should be displayed</source>
<translation>Normalerweise werden alle neuen La&yer im Kartenfenster angezeigt</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="647"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="689"/>
<source>Measure tool</source>
<translation>Messwerkzeug</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="509"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="551"/>
<source>Fix problems with incorrectly filled polygons</source>
<translation>Problem mit falsch gefüllten Polygonen beheben</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="611"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="653"/>
<source>%</source>
<translation>%</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="748"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="790"/>
<source>Panning and zooming</source>
<translation>Verschieben und Zoomen</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="758"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="800"/>
<source>Zoom</source>
<translation>Zoom</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="763"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="805"/>
<source>Zoom and recenter</source>
<translation>Zoomen und mittig zentrieren</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="773"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="815"/>
<source>Nothing</source>
<translation>Nichts</translation>
</message>
@@ -17705,42 +17726,42 @@
<translation>Sprache</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1250"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1292"/>
<source>Locale to use instead</source>
<translation>Stattdessen folgende Spracheinstellungen benutzen</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1273"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1315"/>
<source>Additional Info</source>
<translation>Ergänzende Informationen</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1279"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1321"/>
<source>Detected active locale on your system:</source>
<translation>Festgestellte aktive Spracheinstellung:</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="877"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="919"/>
<source>Rubberband</source>
<translation>Gummiband</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="890"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="932"/>
<source>Line width in pixels</source>
<translation>Linienbreite in Pixel</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="923"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="965"/>
<source>Snapping</source>
<translation>Objektfang</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="506"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="548"/>
<source>Selecting this will unselect the 'make lines less' jagged toggle</source>
<translation>Das Auswählen deaktiviert die Option Linien weniger gezackt zeichnen</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="768"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="810"/>
<source>Zoom to mouse cursor</source>
<translation>Zur Mouseposition zoomen</translation>
</message>
@@ -17840,248 +17861,253 @@
<translation>Neuen Layer zur gewählten Gruppe hinzufügen</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="440"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="428"/>
+ <source>Attribute table behaviour</source>
+ <translation>Attributtabellenverhalten</translation>
+ </message>
+ <message>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="482"/>
<source>Rendering behavior</source>
<translation>Zeichenverhalten</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="453"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="495"/>
<source>Number of features to draw before updating the display</source>
<translation>Anzahl von Objekten nach deren Zeichnung die Anzeige aktualisiert werden soll</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="473"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="515"/>
<source><b>Note:</b> Use zero to prevent display updates until all features have been rendered</source>
<translation><b>Note:</b> 0 sorgt dafür, dass erst aktualisiert wird, wenn alle Objekte gezeichnet wurden</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="480"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="522"/>
<source>Use render caching where possible to speed up redraws</source>
<translation>Wo möglich den Darstellungscache benutzen, um das Neuzeichnen zu beschleunigen</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="490"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="532"/>
<source>Rendering quality</source>
<translation>Zeichenqualität</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="535"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="577"/>
<source>SVG paths</source>
<translation>SVG-Pfade</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="541"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="583"/>
<source>Path(s) to search for Scalable Vector Graphic (SVG) symbols</source>
<translation>Suchpfad(e) für SVG-Symbole (Scalable Vector Graphic)</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="519"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="561"/>
<source>Compatibility</source>
<translation>Kompatibilität</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="525"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="567"/>
<source>Use new generation symbology for rendering</source>
<translation>Darstellung der nächsten Generation verwenden</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="717"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="759"/>
<source>Preferred angle units</source>
<translation>Bevorzugtes Winkelmaß</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="724"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="766"/>
<source>Degrees</source>
<translation>Grad</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="731"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="773"/>
<source>Radians</source>
<translation>Bogenmaß</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="738"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="780"/>
<source>Gon</source>
<translation>Gon</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="781"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="823"/>
<source>Zoom factor</source>
<translation>Zoomfaktor</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="788"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="830"/>
<source>Mouse wheel action</source>
<translation>Mausradaktion</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1437"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1479"/>
<source>Cache settings</source>
<translation>Cache-Einstellungen</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1443"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1485"/>
<source>Directory</source>
<translation>Verzeichnis</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1453"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1495"/>
<source>...</source>
<translation>...</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1460"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1502"/>
<source>Size</source>
<translation>Grösse</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1470"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1512"/>
<source>Clear</source>
<translation>Löschen</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1482"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1524"/>
<source>WMS search address</source>
<translation>WMS-Suchadresse</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="637"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="679"/>
<source>Open feature form, if a single feature is identified</source>
<translation>Objektformular öffnen, wenn ein einzelnes Symbol abgefragt wird</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="663"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="705"/>
<source>Rubberband color</source>
<translation>Gummibandfarbe</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="653"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="695"/>
<source>Ellipsoid for distance calculations</source>
<translation>Ellipsoid für Abstandsberechnungen</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="696"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="738"/>
<source>Preferred measurements units</source>
<translation>Bevorzugte Maßeinheiten</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="703"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="745"/>
<source>Meters</source>
<translation>Meter</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="710"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="752"/>
<source>Feet</source>
<translation>Fuss</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="585"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="627"/>
<source>Identify</source>
<translation>Abfragen</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="594"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="636"/>
<source><b>Note:</b> Specify the search radius as a percentage of the map width</source>
<translation><b>Anmerkung:</b> Suchradius in Prozent der Kartenbreite angeben</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="604"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="646"/>
<source>Search radius for identifying features and displaying map tips</source>
<translation>Suchradius für die Objektidentifikation und zur Maptippanzeige</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="630"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="672"/>
<source>Mode</source>
<translation>Modus</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="883"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="925"/>
<source>Line width</source>
<translation>Linienbreite</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="929"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="971"/>
<source>Default snap mode</source>
<translation>Voreingestellter Fangmodus</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1171"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1213"/>
<source>Default Coordinate Reference System</source>
<translation>Voreingestelltes Koordinatenbezugssystem</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1392"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1434"/>
<source>Exclude URLs (starting with):</source>
<translation>Auszuschließende URLs (beginnen mit):</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1056"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1098"/>
<source>Vertex markers</source>
<translation>Knickpunktmarken</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="900"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="942"/>
<source>Line color</source>
<translation>Linienfarbe</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1062"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1104"/>
<source>Show markers only for selected features</source>
<translation>Markierungen nur für gewähltes Objekt anzeigen</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1069"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1111"/>
<source>Marker style</source>
<translation>Markenstil</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1112"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1154"/>
<source>Marker size</source>
<translation>Markergröße</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1180"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1222"/>
<source>When a new layer is created, or when a layer is loaded that has no coordinate reference system (CRS)</source>
<translation>Wenn ein neuer Layer angelegt oder geladen wird, der kein Koordinatenbezugssystem (KBS) hat</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1241"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1283"/>
<source>Override system locale</source>
<translation>System-Locale überschreiben</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1260"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1302"/>
<source><b>Note:</b> Enabling / changing overide on local requires an application restart</source>
<translation><b>Note:</b> Einschalten/Änderung der Locale-Überschreibung erfordert einen Anwendungsneustart</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1306"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1348"/>
<source>Use proxy for web access</source>
<translation>Proxy für Webzugriff benutzen</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1318"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1360"/>
<source>Host</source>
<translation>Host</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1328"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1370"/>
<source>Port</source>
<translation>Port</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1338"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1380"/>
<source>User</source>
<translation>Benutzer</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1345"/>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1359"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1387"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1401"/>
<source>Leave this blank if no proxy username / password are required</source>
<translation>Lassen Sie Benutzer/Passwort leer, wenn sie nicht benötigt werden</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1352"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1394"/>
<source>Password</source>
<translation>Passwort</translation>
</message>
@@ -18096,59 +18122,59 @@
<translation>KBS</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1190"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1232"/>
<source>Prompt for CRS</source>
<translation>KBS abfragen</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1197"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1239"/>
<source>Project wide default CRS will be used</source>
<translation>Projektweite KBS-Voreinstellung</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1204"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1246"/>
<source>Global default CRS displa&yed below will be used</source>
<translation>Untenstehende globale &Voreinstellung wird genutzt</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1135"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1177"/>
<source>Enter attribute values</source>
<translation>Attributwerte eingeben</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="946"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="988"/>
<source>Default snapping tolerance</source>
<translation>Voreingestellte Fangtoleranz</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="963"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1005"/>
<source>Search radius for vertex edits</source>
<translation>Suchradius für Knickpunktbearbeitung</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1141"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1183"/>
<source>Suppress attributes pop-up windows after each created feature</source>
<translation>Eingabe der Attributewerte bei der Erstellung neuer Objekte unterdrücken</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1512"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1554"/>
<source>Timeout for network requests (ms):</source>
<translation>Timeout für Netzwerkanfragen (ms):</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1369"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1411"/>
<source>Proxy type</source>
<translation>Proxytyp</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="561"/>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1408"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="603"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1450"/>
<source>Add</source>
<translation>Hinzufügen</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="568"/>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1401"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="610"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1443"/>
<source>Remove</source>
<translation>Entfernen</translation>
</message>
@@ -18158,24 +18184,24 @@
<translation>Überlagern</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="828"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="870"/>
<source>Position</source>
<translation>Position</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="834"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="876"/>
<source>Placement algorithm:</source>
<translation>Platzierungsalgorithmus:</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="987"/>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1001"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1029"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1043"/>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="992"/>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1006"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1034"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1048"/>
</message>
@@ -24353,27 +24379,27 @@
<context>
<name>QgsVectorLayer</name>
<message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="2690"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="2689"/>
<source>No renderer object</source>
<translation>Kein Darstellungsobjekt</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="2694"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="2693"/>
<source>Classification field not found</source>
<translation>Klassifikationsfeld nicht gefunden</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3185"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3184"/>
<source>ERROR: no provider</source>
<translation>FEHLER: kein Datenlieferant</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3191"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3190"/>
<source>ERROR: layer not editable</source>
<translation>FEHLER: Layer ist nicht veränderbar</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3205"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3204"/>
<source>SUCCESS: %n attribute(s) deleted.</source>
<comment>deleted attributes count</comment>
<translation>
@@ -24382,7 +24408,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3211"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3210"/>
<source>ERROR: %n attribute(s) not deleted.</source>
<comment>not deleted attributes count</comment>
<translation>
@@ -24391,7 +24417,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3227"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3226"/>
<source>SUCCESS: %n attribute(s) added.</source>
<comment>added attributes count</comment>
<translation>
@@ -24400,7 +24426,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3233"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3232"/>
<source>ERROR: %n new attribute(s) not added</source>
<comment>not added attributes count</comment>
<translation>
@@ -24409,17 +24435,17 @@
</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3274"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3273"/>
<source>SUCCESS: attribute %1 was added.</source>
<translation>ERFOLG: Attribut %1 hinzugefügt.</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3281"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3280"/>
<source>ERROR: attribute %1 not added</source>
<translation>FEHLER: Attribut %1 nicht hinzugefügt</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3343"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3342"/>
<source>SUCCESS: %n attribute value(s) changed.</source>
<comment>changed attribute values count</comment>
<translation>
@@ -24428,7 +24454,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3348"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3347"/>
<source>ERROR: %n attribute value change(s) not applied.</source>
<comment>not changed attribute values count</comment>
<translation>
@@ -24437,7 +24463,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3381"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3380"/>
<source>SUCCESS: %n feature(s) added.</source>
<comment>added features count</comment>
<translation>
@@ -24446,7 +24472,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3386"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3385"/>
<source>ERROR: %n feature(s) not added.</source>
<comment>not added features count</comment>
<translation>
@@ -24455,7 +24481,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3399"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3398"/>
<source>SUCCESS: %n geometries were changed.</source>
<comment>changed geometries count</comment>
<translation>
@@ -24464,7 +24490,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3404"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3403"/>
<source>ERROR: %n geometries not changed.</source>
<comment>not changed geometries count</comment>
<translation>
@@ -24473,7 +24499,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3416"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3415"/>
<source>SUCCESS: %n feature(s) deleted.</source>
<comment>deleted features count</comment>
<translation>
@@ -24482,7 +24508,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3426"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3425"/>
<source>ERROR: %n feature(s) not deleted.</source>
<comment>not deleted features count</comment>
<translation>
@@ -24491,7 +24517,7 @@
</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="2684"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="2683"/>
<source>Unknown renderer</source>
<translation>Unbekannte Darstellung</translation>
</message>
@@ -26382,16 +26408,19 @@
<context>
<name>UndoWidget</name>
<message>
+ <location filename="../src/app/qgsgeomerrorswidget.cpp" line="161"/>
<location filename="../src/app/qgsundowidget.cpp" line="161"/>
<source>Undo/Redo</source>
<translation>Rücknahme/Wiederholung</translation>
</message>
<message>
+ <location filename="../src/app/qgsgeomerrorswidget.cpp" line="162"/>
<location filename="../src/app/qgsundowidget.cpp" line="162"/>
<source>Undo</source>
<translation>Zurücknehmen</translation>
</message>
<message>
+ <location filename="../src/app/qgsgeomerrorswidget.cpp" line="163"/>
<location filename="../src/app/qgsundowidget.cpp" line="163"/>
<source>Redo</source>
<translation>Wiederholen</translation>
