[QGIS Commit] r13566 - trunk/qgis/i18n
svn_qgis at osgeo.org
Mon May 24 14:07:01 EDT 2010
Author: pcav
Date: 2010-05-24 14:06:54 -0400 (Mon, 24 May 2010)
New Revision: 13566
trunk/qgis/i18n/qgis_it.ts
More IT GUI translation
Modified: trunk/qgis/i18n/qgis_it.ts
--- trunk/qgis/i18n/qgis_it.ts 2010-05-24 17:31:02 UTC (rev 13565)
+++ trunk/qgis/i18n/qgis_it.ts 2010-05-24 18:06:54 UTC (rev 13566)
@@ -361,7 +361,7 @@
<message>
<location filename="../python/plugins/fTools/tools/frmJoinAttributes.ui" line="174"/>
<source>Keep all records (including non-matching target records)</source>
- <translation type="unfinished"></translation>
+ <translation>Includi tutti i record (compresi quelli non corrispondenti)</translation>
</message>
<message>
<location filename="../python/plugins/fTools/tools/frmSpatialJoin.ui" line="193"/>
@@ -1036,7 +1036,7 @@
</message>
<message>
<source>Cancel</source>
- <translation type="unfinished">Annulla</translation>
+ <translation>Annulla</translation>
</message>
<message>
<source>Merging</source>
@@ -4988,7 +4988,7 @@
<message>
<location filename="../src/app/qgisapp.cpp" line="3048"/>
<source>New Shapefile</source>
- <translation>Nuovo Shapefile</translation>
+ <translation>Nuovo shapefile</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="3049"/>
@@ -5763,23 +5763,23 @@
<message>
<location filename="../src/app/qgisapp.cpp" line="964"/>
<source>New Shapefile Layer...</source>
+ <translation>Nuovo layer shapefile...</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="965"/>
<source>Ctrl+Shift+N</source>
<comment>Create a New Shapefile layer</comment>
- <translation type="unfinished">Ctrl+Shift+N</translation>
+ <translation>Ctrl+Shift+N</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="966"/>
<source>Create a New Shapefile layer</source>
+ <translation>Crea un nuovo shapefile</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="970"/>
<source>New SpatiaLite Layer ...</source>
+ <translation>Nuovo layer SpatiaLite ...</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="971"/>
@@ -6057,7 +6057,6 @@
<comment>number of selected features</comment>
<numerusform></numerusform>
- <numerusform></numerusform>
</translation>
</message>
<message>
@@ -16827,19 +16826,19 @@
<message>
<location filename="../src/app/qgsnewspatialitelayerdialog.cpp" line="97"/>
<source>New SpatiaLite Database File</source>
+ <translation>Nuovo database SpatiaLite</translation>
</message>
<message>
<location filename="../src/app/qgsnewspatialitelayerdialog.cpp" line="99"/>
<source>SpatiaLite (*.sqlite *.db )</source>
+ <translation>SpatiaLite (*.sqlite *.db)</translation>
</message>
<message>
<location filename="../src/app/qgsnewspatialitelayerdialog.cpp" line="218"/>
<location filename="../src/app/qgsnewspatialitelayerdialog.cpp" line="238"/>
<location filename="../src/app/qgsnewspatialitelayerdialog.cpp" line="304"/>
<source>SpatiaLite Database</source>
+ <translation>Database SpatiaLite</translation>
</message>
<message>
@@ -17073,7 +17072,7 @@
<message>
<location filename="../src/app/qgsnewvectorlayerdialog.cpp" line="42"/>
<source>ESRI Shapefile</source>
- <translation>ESRI Shapefile</translation>
+ <translation>ESRI shapefile</translation>
</message>
</context>
<context>
@@ -22941,7 +22940,6 @@
<comment>selected geometries</comment>
</translation>
</message>
<message>
@@ -23424,7 +23422,7 @@
<message>
<location filename="../src/plugins/spit/qgsspit.cpp" line="162"/>
<source>Add Shapefiles</source>
- <translation>Aggiungi Shapefile</translation>
+ <translation>Aggiungi shapefile</translation>
</message>
<message>
<location filename="../src/plugins/spit/qgsspit.cpp" line="458"/>
@@ -23516,12 +23514,12 @@
for this Shapefile in the main dialog file list.
Do you want to overwrite the [%2] relation?</source>
- <translation>Lo Shapefile:
+ <translation>Lo shapefile:
%1
vuole usare la tabella [%2] per questi dati,
che già esiste e possiede dati.
Per evitare di perdere dati cambiare il "Nome Tabella DB"
-per questo Shapefile nella finestra generale di dialogo del file.
+per questo shapefile nella finestra generale di dialogo del file.
Si vuole realmente sovrascrivere la tabella [%2]?</translation>
</message>
@@ -23531,7 +23529,7 @@
<message>
<location filename="../src/plugins/spit/qgsspitbase.ui" line="20"/>
<source>SPIT - Shapefile to PostGIS Import Tool</source>
- <translation>SPIT - Utilità di importazione ESRI Shapefile in PostGIS</translation>
+ <translation>SPIT - Utilità di importazione shapefile in PostGIS</translation>
</message>
<message>
<location filename="../src/plugins/spit/qgsspitbase.ui" line="108"/>
@@ -23664,7 +23662,7 @@
<message>
<location filename="../src/plugins/spit/qgsspitplugin.cpp" line="67"/>
<source>&Import Shapefiles to PostgreSQL</source>
- <translation>&Importa Shapefile in PostgreSQL</translation>
+ <translation>&Importa shapefile in PostgreSQL</translation>
</message>
<message>
<location filename="../src/plugins/spit/qgsspitplugin.cpp" line="69"/>
@@ -25464,7 +25462,6 @@
<comment>selected layer count</comment>
</translation>
</message>
<message>
@@ -26008,7 +26005,6 @@
<comment>tile request count</comment>
</translation>
</message>
<message numerus="yes">
@@ -26018,7 +26014,6 @@
<comment>tile cache hits</comment>
</translation>
</message>
@@ -26028,7 +26023,6 @@
<comment>tile cache missed</comment>
</translation>
</message>
@@ -26038,7 +26032,6 @@
<comment>errors</comment>
</translation>
</message>
<message>
@@ -26114,7 +26107,6 @@
<comment>crs</comment>
</translation>
</message>
<message>
@@ -26764,7 +26756,7 @@
<message>
<location filename="../src/plugins/dxf2shp_converter/dxf2shpconverter.cpp" line="77"/>
<source>Converts DXF files in Shapefile format</source>
- <translation>Converte file DXF in formato Shapefile</translation>
+ <translation>Converte file DXF in formato shapefile</translation>
</message>
<message>
<location filename="../src/plugins/dxf2shp_converter/dxf2shpconverter.cpp" line="84"/>
@@ -28735,7 +28727,7 @@
<message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="190"/>
<source>Export vector to Shapefile</source>
- <translation>Esporta vettore in formato Shapefile</translation>
+ <translation>Esporta vettore in formato shapefile</translation>
</message>
<message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="191"/>
