[QGIS Commit] r13584 - trunk/qgis/src/providers/postgres
svn_qgis at osgeo.org
Fri May 28 17:58:36 EDT 2010
Author: jef
Date: 2010-05-28 17:58:35 -0400 (Fri, 28 May 2010)
New Revision: 13584
trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
trunk/qgis/src/providers/postgres/qgspostgresprovider.h
postgres provider update:
- lazy determine extent and invalidate extent on subst string change (fixes #2752 for postgres)
- use estimate extent when "use estimate metadata" is set (reverts r13499)
- remove rest of unused threading
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2010-05-28 21:31:38 UTC (rev 13583)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2010-05-28 21:58:35 UTC (rev 13584)
@@ -134,7 +134,7 @@
deduceEndian();
- calculateExtents();
+ layerExtent.setMinimal();
featuresCounted = -1;
// set the primary key
@@ -717,12 +717,6 @@
layerExtent.setYMinimum( newExtent.yMinimum() );
-// TODO - make this function return the real extent_
-QgsRectangle QgsPostgresProvider::extent()
- return layerExtent; //extent_->MinX, extent_->MinY, extent_->MaxX, extent_->MaxY);
* Return the feature type
@@ -2740,9 +2734,8 @@
// uri? Perhaps this needs some rationalisation.....
setDataSourceUri( mUri.uri() );
- // need to recalculate the number of features...
return true;
@@ -2752,16 +2745,13 @@
long QgsPostgresProvider::featureCount() const
- if( featuresCounted >= 0 )
+ if ( featuresCounted >= 0 )
return featuresCounted;
// get total number of features
- // First get an approximate count; then delegate to
- // a thread the task of getting the full count.
QString sql;
- if ( !isQuery && mUseEstimatedMetadata && sqlWhereClause.isEmpty() )
+ if ( !isQuery && mUseEstimatedMetadata )
sql = QString( "select reltuples::int from pg_catalog.pg_class where oid=regclass(%1)::oid" ).arg( quotedValue( mQuery ) );
@@ -2787,130 +2777,79 @@
-void QgsPostgresProvider::calculateExtents()
+QgsRectangle QgsPostgresProvider::extent()
- QString sql;
- Result result;
- QString ext;
- // get the extents
- if ( !isQuery && ( mUseEstimatedMetadata || sqlWhereClause.isEmpty() ) )
+ if ( layerExtent.isEmpty() )
- // do stats exists?
- sql = QString( "SELECT COUNT(*) FROM pg_stats WHERE schemaname=%1 AND tablename=%2 AND attname=%3" )
- .arg( quotedValue( mSchemaName ) )
- .arg( quotedValue( mTableName ) )
- .arg( quotedValue( geometryColumn ) );
- result = connectionRO->PQexec( sql );
- if ( PQresultStatus( result ) == PGRES_TUPLES_OK && PQntuples( result ) == 1 )
+ QString sql;
+ Result result;
+ QString ext;
+ // get the extents
+ if ( !isQuery && ( mUseEstimatedMetadata || sqlWhereClause.isEmpty() ) )
- if ( QString::fromUtf8( PQgetvalue( result, 0, 0 ) ).toInt() > 0 )
+ // do stats exists?
+ sql = QString( "SELECT COUNT(*) FROM pg_stats WHERE schemaname=%1 AND tablename=%2 AND attname=%3" )
+ .arg( quotedValue( mSchemaName ) )
+ .arg( quotedValue( mTableName ) )
+ .arg( quotedValue( geometryColumn ) );
+ result = connectionRO->PQexec( sql );
+ if ( PQresultStatus( result ) == PGRES_TUPLES_OK && PQntuples( result ) == 1 )
- sql = QString( "select estimated_extent(%1,%2,%3)" )
- ext = PQgetvalue( result, 0, 0 );
+ if ( QString::fromUtf8( PQgetvalue( result, 0, 0 ) ).toInt() > 0 )
+ sql = QString( "select estimated_extent(%1,%2,%3)" )
+ ext = PQgetvalue( result, 0, 0 );
- else
- QgsDebugMsg( QString( "no column statistics for %1.%2.%3" ).arg( mSchemaName ).arg( mTableName ).arg( geometryColumn ) );
- if ( ext.isEmpty() )
- sql = QString( "select extent(%1) from %2" )
- .arg( quotedIdentifier( geometryColumn ) )
- .arg( mQuery );
- if ( !sqlWhereClause.isEmpty() )
- sql += QString( " where %1" ).arg( sqlWhereClause );
- if ( PQresultStatus( result ) != PGRES_TUPLES_OK )
- connectionRO->PQexecNR( "ROLLBACK" );
- else if ( PQntuples( result ) == 1 )
- QgsDebugMsg( "Got extents using: " + sql );
- QRegExp rx( "\\((.+) (.+),(.+) (.+)\\)" );
- if ( ext.contains( rx ) )
- QStringList ex = rx.capturedTexts();
- layerExtent.setXMinimum( ex[1].toDouble() );
- layerExtent.setYMinimum( ex[2].toDouble() );
- layerExtent.setXMaximum( ex[3].toDouble() );
- layerExtent.setYMaximum( ex[4].toDouble() );
- else
- QgsDebugMsg( "extents query failed" );
- QgsDebugMsg( "Set extents to: " + layerExtent.toString() );
- * Event sink for events from threads
-void QgsPostgresProvider::customEvent( QEvent * e )
- QgsDebugMsg( "received a custom event " + QString::number( e->type() ) );
- switch (( int ) e->type() )
- case QGis::ProviderExtentCalcEvent:
- QgsDebugMsg( "extent has been calculated" );
- // Collect the new extent from the event and set this layer's
- // extent with it.
+ else
- QgsRectangle* r = (( QgsProviderExtentCalcEvent* ) e )->layerExtent();
- setExtent( *r );
+ QgsDebugMsg( QString( "no column statistics for %1.%2.%3" ).arg( mSchemaName ).arg( mTableName ).arg( geometryColumn ) );
- QgsDebugMsg( "new extent has been saved" );
+ if ( ext.isEmpty() )
+ sql = QString( "select extent(%1) from %2" )
+ .arg( quotedIdentifier( geometryColumn ) )
+ .arg( mQuery );
- QgsDebugMsg( "Set extent to: " + layerExtent.toString() );
+ if ( !sqlWhereClause.isEmpty() )
+ sql += QString( " where %1" ).arg( sqlWhereClause );
- QgsDebugMsg( "emitting fullExtentCalculated()" );
+ if ( PQresultStatus( result ) != PGRES_TUPLES_OK )
+ connectionRO->PQexecNR( "ROLLBACK" );
+ else if ( PQntuples( result ) == 1 )
- emit fullExtentCalculated();
+ QgsDebugMsg( "Got extents using: " + sql );
- // TODO: Only uncomment this when the overview map canvas has been subclassed
- // from the QgsMapCanvas
+ QRegExp rx( "\\((.+) (.+),(.+) (.+)\\)" );
+ if ( ext.contains( rx ) )
+ QStringList ex = rx.capturedTexts();
- // QgsDebugMsg("emitting repaintRequested()");
- // emit repaintRequested();
+ layerExtent.setXMinimum( ex[1].toDouble() );
+ layerExtent.setYMinimum( ex[2].toDouble() );
+ layerExtent.setXMaximum( ex[3].toDouble() );
+ layerExtent.setYMaximum( ex[4].toDouble() );
+ else
+ QgsDebugMsg( "extents query failed" );
- break;
- case QGis::ProviderCountCalcEvent:
- QgsDebugMsg( "count has been calculated" );
- featuresCounted = (( QgsProviderCountCalcEvent* ) e )->featuresCounted();
- QgsDebugMsg( "count is " + QString::number( featuresCounted ) );
- break;
- default:
- // do nothing
- break;
+ QgsDebugMsg( "Set extents to: " + layerExtent.toString() );
- QgsDebugMsg( "Finished processing custom event " + QString::number( e->type() ) );
+ return layerExtent;
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.h
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.h 2010-05-28 21:31:38 UTC (rev 13583)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.h 2010-05-28 21:58:35 UTC (rev 13584)
@@ -567,14 +567,6 @@
int enabledCapabilities;
- //! Calculate the extents of the layer
- void calculateExtents();
- void customEvent( QEvent *e );
void appendGeomString( QgsGeometry *geom, QString &geomParam ) const;
QString paramValue( QString fieldvalue, const QString &defaultValue ) const;
