[QGIS Commit] r14476 - trunk/qgis/src/app
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Nov 1 06:26:14 EDT 2010
Author: mhugent
Date: 2010-11-01 03:26:14 -0700 (Mon, 01 Nov 2010)
New Revision: 14476
   trunk/qgis/src/app/qgsmaptoolselectutils.cpp
Reverse alt-key modification to be compatible with the old selection tool
Modified: trunk/qgis/src/app/qgsmaptoolselectutils.cpp
--- trunk/qgis/src/app/qgsmaptoolselectutils.cpp	2010-11-01 03:09:18 UTC (rev 14475)
+++ trunk/qgis/src/app/qgsmaptoolselectutils.cpp	2010-11-01 10:26:14 UTC (rev 14476)
@@ -33,8 +33,8 @@
 QgsVectorLayer* QgsMapToolSelectUtils::getCurrentVectorLayer( QgsMapCanvas* canvas )
   QgsVectorLayer* vlayer = NULL;
-  if ( !canvas->currentLayer()
-       || ( vlayer = qobject_cast<QgsVectorLayer *>( canvas->currentLayer() ) ) == NULL )
+  if( !canvas->currentLayer()
+      || ( vlayer = qobject_cast<QgsVectorLayer *>( canvas->currentLayer() ) ) == NULL )
     QMessageBox::warning( canvas, QObject::tr( "No active vector layer" ),
                           QObject::tr( "To select features, you must choose a "
@@ -61,7 +61,7 @@
     QPoint point )
   int boxSize = 0;
-  if ( vlayer->geometryType() != QGis::Polygon )
+  if( vlayer->geometryType() != QGis::Polygon )
     //if point or line use an artificial bounding box of 10x10 pixels
     //to aid the user to click on a feature accurately
@@ -85,12 +85,12 @@
     bool substractSelection,
     bool singleSelect )
-  if ( selectGeometry->type() != QGis::Polygon )
+  if( selectGeometry->type() != QGis::Polygon )
     return;
   QgsVectorLayer* vlayer = QgsMapToolSelectUtils::getCurrentVectorLayer( canvas );
-  if ( vlayer == NULL )
+  if( vlayer == NULL )
     return;
@@ -101,14 +101,14 @@
   // and then click somewhere off the globe, an exception will be thrown.
   QgsGeometry selectGeomTrans( *selectGeometry );
-  if ( canvas->mapRenderer()->hasCrsTransformEnabled() )
+  if( canvas->mapRenderer()->hasCrsTransformEnabled() )
     try
       QgsCoordinateTransform ct( canvas->mapRenderer()->destinationSrs(), vlayer->crs() );
       selectGeomTrans.transform( ct );
-    catch ( QgsCsException &cse )
+    catch( QgsCsException &cse )
       Q_UNUSED( cse );
       // catch exception for 'invalid' point and leave existing selection unchanged
@@ -134,18 +134,18 @@
   int closestFeatureId = 0;
   bool foundSingleFeature = false;
   double closestFeatureDist = std::numeric_limits<double>::max();
-  while ( vlayer->nextFeature( f ) )
+  while( vlayer->nextFeature( f ) )
     QgsGeometry* g = f.geometry();
-    if ( doContains && !selectGeomTrans.contains( g ) )
+    if( doContains && !selectGeomTrans.contains( g ) )
       continue;
-    if ( singleSelect )
+    if( singleSelect )
       foundSingleFeature = true;
       double distance = g->distance( selectGeomTrans );
-      if ( distance <= closestFeatureDist )
+      if( distance <= closestFeatureDist )
         closestFeatureDist = distance;
         closestFeatureId = f.id();
@@ -156,7 +156,7 @@
       newSelectedFeatures.insert( f.id() );
-  if ( singleSelect && foundSingleFeature )
+  if( singleSelect && foundSingleFeature )
     newSelectedFeatures.insert( closestFeatureId );
@@ -164,24 +164,24 @@
   QgsDebugMsg( "Number of selected features: " + QString::number( newSelectedFeatures.size() ) );
   QgsFeatureIds layerSelectedFeatures;
-  if ( addSelection )
+  if( addSelection )
     layerSelectedFeatures = vlayer->selectedFeaturesIds();
     QgsFeatureIds::const_iterator i = newSelectedFeatures.constEnd();
-    while ( i != newSelectedFeatures.constBegin() )
+    while( i != newSelectedFeatures.constBegin() )
       --i;
       layerSelectedFeatures.insert( *i );
-  else if ( substractSelection )
+  else if( substractSelection )
       --i;
-      if ( layerSelectedFeatures.contains( *i ) )
+      if( layerSelectedFeatures.contains( *i ) )
         layerSelectedFeatures.remove( *i );
@@ -198,7 +198,7 @@
 void QgsMapToolSelectUtils::setSelectFeatures( QgsMapCanvas* canvas, QgsGeometry* selectGeometry, QMouseEvent * e )
-  bool doContains = e->modifiers() & Qt::AltModifier ? false : true;
+  bool doContains = e->modifiers() & Qt::AltModifier ? true : false;
   bool addSelection = e->modifiers() & Qt::ControlModifier ? true : false;
   bool substractSelection = e->modifiers() & Qt::ShiftModifier ? true : false;
   setSelectFeatures( canvas, selectGeometry, doContains, addSelection, substractSelection );
More information about the QGIS-commit mailing list
