[QGIS Commit] r14499 - in trunk/qgis/src: gui/symbology-ng
ui/symbollayer
svn_qgis at osgeo.org
Wed Nov 3 17:11:02 EDT 2010
Author: wonder
Date: 2010-11-03 14:11:02 -0700 (Wed, 03 Nov 2010)
New Revision: 14499
trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp
trunk/qgis/src/ui/symbollayer/widget_svgfill.ui
trunk/qgis/src/ui/symbollayer/widget_svgmarker.ui
Further improvements in the speed when opening symbol properties dialog (symbology-ng)
Modified: trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp
--- trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp 2010-11-03 21:04:12 UTC (rev 14498)
+++ trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp 2010-11-03 21:11:02 UTC (rev 14499)
@@ -438,6 +438,7 @@
#include <QTime>
#include <QAbstractListModel>
+#include <QPixmapCache>
class QgsSvgListModel : public QAbstractListModel
@@ -458,17 +459,23 @@
if ( role == Qt::DecorationRole ) // icon
- QSvgRenderer renderer;
- QPainter painter;
- // render SVG file
- renderer.load( entry );
- QPixmap pixmap( QSize( 24, 24 ) );
- pixmap.fill();
- painter.begin( &pixmap );
- renderer.render( &painter );
- painter.end();
+ QPixmap pixmap;
+ if ( !QPixmapCache::find( entry, pixmap ) )
+ // render SVG file
+ QSvgRenderer renderer;
+ QPainter painter;
+ renderer.load( entry );
+ pixmap = QPixmap( QSize( 24, 24 ) );
+ pixmap.fill();
+ painter.begin( &pixmap );
+ renderer.render( &painter );
+ painter.end();
+ QPixmapCache::insert( entry, pixmap );
return pixmap;
else if ( role == Qt::UserRole || role == Qt::ToolTipRole )
Modified: trunk/qgis/src/ui/symbollayer/widget_svgfill.ui
--- trunk/qgis/src/ui/symbollayer/widget_svgfill.ui 2010-11-03 21:04:12 UTC (rev 14498)
+++ trunk/qgis/src/ui/symbollayer/widget_svgfill.ui 2010-11-03 21:11:02 UTC (rev 14499)
@@ -55,9 +55,15 @@
<property name="flow">
<enum>QListView::LeftToRight</enum>
</property>
+ <property name="layoutMode">
+ <enum>QListView::Batched</enum>
+ </property>
<property name="viewMode">
<enum>QListView::IconMode</enum>
</property>
+ <property name="uniformItemSizes">
+ <bool>true</bool>
+ </property>
</widget>
</item>
<item row="3" column="0">
Modified: trunk/qgis/src/ui/symbollayer/widget_svgmarker.ui
--- trunk/qgis/src/ui/symbollayer/widget_svgmarker.ui 2010-11-03 21:04:12 UTC (rev 14498)
+++ trunk/qgis/src/ui/symbollayer/widget_svgmarker.ui 2010-11-03 21:11:02 UTC (rev 14499)
@@ -141,6 +141,9 @@
<property name="movement">
<enum>QListView::Static</enum>
</property>
+ </property>
<property name="spacing">
<number>2</number>
</property>
@@ -153,6 +156,9 @@
</property>
+ <bool>true</bool>
+ </property>
<property name="wordWrap">
<bool>true</bool>
</property>
