[QGIS Commit] r14518 - in trunk/qgis/src/plugins/grass: modules-6.3 modules-6.4 modules-common
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Nov 6 06:23:34 EDT 2010
Author: pcav
Date: 2010-11-06 03:23:34 -0700 (Sat, 06 Nov 2010)
New Revision: 14518
Added:
   trunk/qgis/src/plugins/grass/modules-common/g.proj.wkt.1.png
   trunk/qgis/src/plugins/grass/modules-common/g.proj.wkt.2.png
   trunk/qgis/src/plugins/grass/modules-common/g.proj.wkt.qgm
Removed:
   trunk/qgis/src/plugins/grass/modules-6.4/g.proj.wkt.1.png
   trunk/qgis/src/plugins/grass/modules-6.4/g.proj.wkt.2.png
   trunk/qgis/src/plugins/grass/modules-6.4/g.proj.wkt.qgm
   trunk/qgis/src/plugins/grass/modules-6.3/default.qgc
Moved g.proj.wkt GRASS module
Modified: trunk/qgis/src/plugins/grass/modules-6.3/default.qgc
--- trunk/qgis/src/plugins/grass/modules-6.3/default.qgc	2010-11-05 21:44:07 UTC (rev 14517)
+++ trunk/qgis/src/plugins/grass/modules-6.3/default.qgc	2010-11-06 10:23:34 UTC (rev 14518)
@@ -6,6 +6,9 @@
 <section label="GRASS MODULES">
 	<grass name="shell"/>
 	<section label="File">
+                <section label="Create new GRASS location from metadata file">
+                        <grass name="g.proj.wkt"/>
+                </section>
 		<section label="Import">
 			<section label="Import raster">
                                 <grass name="r.in.gdal.qgis"/>
Deleted: trunk/qgis/src/plugins/grass/modules-6.4/g.proj.wkt.1.png
(Binary files differ)
Deleted: trunk/qgis/src/plugins/grass/modules-6.4/g.proj.wkt.2.png
Deleted: trunk/qgis/src/plugins/grass/modules-6.4/g.proj.wkt.qgm
--- trunk/qgis/src/plugins/grass/modules-6.4/g.proj.wkt.qgm	2010-11-05 21:44:07 UTC (rev 14517)
+++ trunk/qgis/src/plugins/grass/modules-6.4/g.proj.wkt.qgm	2010-11-06 10:23:34 UTC (rev 14518)
@@ -1,8 +0,0 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
-<qgisgrassmodule label="Create new location from .prj (WKT) file" module="g.proj">
-	<flag key="c" answer="on" hidden="yes" />
-	<file key="wkt"/>
-	<option key="location"/>
-</qgisgrassmodule>
Copied: trunk/qgis/src/plugins/grass/modules-common/g.proj.wkt.1.png (from rev 14517, trunk/qgis/src/plugins/grass/modules-6.4/g.proj.wkt.1.png)
Copied: trunk/qgis/src/plugins/grass/modules-common/g.proj.wkt.2.png (from rev 14517, trunk/qgis/src/plugins/grass/modules-6.4/g.proj.wkt.2.png)
Copied: trunk/qgis/src/plugins/grass/modules-common/g.proj.wkt.qgm (from rev 14517, trunk/qgis/src/plugins/grass/modules-6.4/g.proj.wkt.qgm)
--- trunk/qgis/src/plugins/grass/modules-common/g.proj.wkt.qgm	                        (rev 0)
+++ trunk/qgis/src/plugins/grass/modules-common/g.proj.wkt.qgm	2010-11-06 10:23:34 UTC (rev 14518)
@@ -0,0 +1,8 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
+<qgisgrassmodule label="Create new location from .prj (WKT) file" module="g.proj">
+	<flag key="c" answer="on" hidden="yes" />
+	<file key="wkt"/>
+	<option key="location"/>
+</qgisgrassmodule>
More information about the QGIS-commit mailing list
