[QGIS Commit] r14523 - trunk/qgis/src/app/legend
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Nov 6 19:24:53 EDT 2010
Author: jef
Date: 2010-11-06 16:24:53 -0700 (Sat, 06 Nov 2010)
New Revision: 14523
   trunk/qgis/src/app/legend/qgslegend.cpp
   trunk/qgis/src/app/legend/qgslegend.h
   trunk/qgis/src/app/legend/qgslegendgroup.cpp
fix legend
Modified: trunk/qgis/src/app/legend/qgslegend.cpp
--- trunk/qgis/src/app/legend/qgslegend.cpp	2010-11-06 22:52:03 UTC (rev 14522)
+++ trunk/qgis/src/app/legend/qgslegend.cpp	2010-11-06 23:24:53 UTC (rev 14523)
@@ -48,10 +48,10 @@
 const int AUTOSCROLL_MARGIN = 16;
 QgsLegend::QgsLegend( QgsMapCanvas *canvas, QWidget * parent, const char *name )
-    : QTreeWidget( parent )
-    , mMousePressedFlag( false )
-    , mMapCanvas( canvas )
-    , mMinimumIconSize( 20, 20 )
+  : QTreeWidget( parent )
+  , mMousePressedFlag( false )
+  , mMapCanvas( canvas )
+  , mMinimumIconSize( 20, 20 )
   setObjectName( name );
@@ -161,7 +161,6 @@
   else
     group = new QgsLegendGroup( this, name );
-  group->setData( 0, Qt::UserRole, Qt::Checked );
   QModelIndex groupIndex = indexFromItem( group );
   setExpanded( groupIndex, expand );
   setCurrentItem( group );
@@ -235,7 +234,6 @@
         delete ll;
         break;
@@ -280,14 +278,14 @@
     QgsDebugMsg( "layers prior to move: " + mLayersPriorToMove.join( ", " ) );
     // record which items were selected and hide them
-    foreach( QTreeWidgetItem *item, selectedItems() )
+    foreach( QTreeWidgetItem * item, selectedItems() )
       item->setHidden( true );
       mItemsBeingMoved << item;
     // remove and unhide items, whose parent is already to be moved
-    foreach( QTreeWidgetItem *item, mItemsBeingMoved )
+    foreach( QTreeWidgetItem * item, mItemsBeingMoved )
       QTreeWidgetItem *parent = item->parent();
@@ -423,7 +421,7 @@
   hideLine();
   // unhide
     item->setHidden( false );
@@ -441,7 +439,7 @@
         showItem( "prev sibling", mDropTarget );
           moveItem( item, mDropTarget );
           mDropTarget = item;
@@ -468,7 +466,7 @@
       showItem( "drop after", mDropTarget );
         mDropTarget = item;
@@ -479,7 +477,7 @@
       showItem( "insert into", mDropTarget );
         insertItem( item, mDropTarget );
@@ -592,12 +590,10 @@
   if ( llayer->isVisible() )
     llayer->setCheckState( 0, Qt::Checked );
-    llayer->setData( 0, Qt::UserRole, Qt::Checked );
   else
     llayer->setCheckState( 0, Qt::Unchecked );
-    llayer->setData( 0, Qt::UserRole, Qt::Unchecked );
   blockSignals( false );
@@ -677,7 +673,7 @@
   QList<QgsMapLayer *> layers;
     QgsLegendLayer *ll = dynamic_cast<QgsLegendLayer *>( item );
     if ( ll )
@@ -803,7 +799,7 @@
 bool QgsLegend::writeXML( QList<QTreeWidgetItem *> items, QDomNode &node, QDomDocument &document )
-  foreach( QTreeWidgetItem *currentItem, items )
+  foreach( QTreeWidgetItem * currentItem, items )
     QgsLegendItem *item = dynamic_cast<QgsLegendItem *>( currentItem );
     if ( !item )
@@ -944,17 +940,14 @@
       if ( checked == "Qt::Checked" )
         theGroup->setCheckState( 0, Qt::Checked );
-        theGroup->setData( 0, Qt::UserRole, Qt::Checked );
       else if ( checked == "Qt::Unchecked" )
         theGroup->setCheckState( 0, Qt::Unchecked );
       else if ( checked == "Qt::PartiallyChecked" )
         theGroup->setCheckState( 0, Qt::PartiallyChecked );
-        theGroup->setData( 0, Qt::UserRole, Qt::PartiallyChecked );
@@ -1070,13 +1063,11 @@
     ll->setVisible( true );
     ll->setCheckState( 0, Qt::Checked );
-    ll->setData( 0, Qt::UserRole, Qt::Checked );
     ll->setVisible( false );
     ll->setCheckState( 0, Qt::Unchecked );
-    ll->setData( 0, Qt::UserRole, Qt::Unchecked );
@@ -1535,14 +1526,23 @@
   if ( item->data( 0, Qt::UserRole ).toInt() == item->checkState( 0 ) )
     return;
+  saveCheckStates( invisibleRootItem() );
   bool renderFlagState = mMapCanvas->renderFlag();
   if ( renderFlagState )
     mMapCanvas->setRenderFlag( false );
-  foreach( QTreeWidgetItem *i, selectedItems() )
+  if ( !item->isSelected() )
-    propagateItemChange( i, item->checkState( 0 ) );
+    propagateItemChange( item, item->checkState( 0 ) );
+  else
+    foreach( QTreeWidgetItem * i, selectedItems() )
+      propagateItemChange( i, item->checkState( 0 ) );
   // update layer set
   updateMapCanvasLayerSet();
@@ -1553,6 +1553,16 @@
     mMapCanvas->setRenderFlag( true );
+void QgsLegend::saveCheckStates( QTreeWidgetItem *item )
+  for ( int i = 0; i < item->childCount(); i++ )
+    QTreeWidgetItem *child = item->child( i );
+    child->setData( 0, Qt::UserRole, child->checkState( 0 ) );
+    saveCheckStates( child );
 void QgsLegend::propagateItemChange( QTreeWidgetItem *item, Qt::CheckState state )
   QgsLegendGroup* lg = dynamic_cast<QgsLegendGroup *>( item ); //item is a legend group
@@ -1588,8 +1598,6 @@
           items << lg->child( i );
-    item->setData( 0, Qt::UserRole, state );
   QgsLegendLayer* ll = dynamic_cast<QgsLegendLayer *>( item ); //item is a legend layer
@@ -1597,8 +1605,7 @@
     blockSignals( true );
     ll->setCheckState( 0, state );
-    blockSignals( false );
-    ll->setData( 0, Qt::UserRole, ll->checkState( 0 ) );
     if ( ll->layer() )
       ll->setVisible( state == Qt::Checked );
@@ -1608,11 +1615,10 @@
     while ( lg )
       lg->updateCheckState();
-      lg->setData( 0, Qt::UserRole, lg->checkState( 0 ) );
       lg = dynamic_cast<QgsLegendGroup*>( lg->parent() );
-    //update check state of the legend group
+    blockSignals( false );
@@ -1820,7 +1826,7 @@
     if ( lg )
Modified: trunk/qgis/src/app/legend/qgslegend.h
--- trunk/qgis/src/app/legend/qgslegend.h	2010-11-06 22:52:03 UTC (rev 14522)
+++ trunk/qgis/src/app/legend/qgslegend.h	2010-11-06 23:24:53 UTC (rev 14523)
@@ -419,6 +419,9 @@
     /**QgsLegend does not set the icon with/height to values lower than the minimum icon size*/
     QSize mMinimumIconSize;
+    /** save item check states */
+    void saveCheckStates( QTreeWidgetItem *item );
     /** structure which holds pixmap which are used in legend */
     class QgsLegendPixmaps
Modified: trunk/qgis/src/app/legend/qgslegendgroup.cpp
--- trunk/qgis/src/app/legend/qgslegendgroup.cpp	2010-11-06 22:52:03 UTC (rev 14522)
+++ trunk/qgis/src/app/legend/qgslegendgroup.cpp	2010-11-06 23:24:53 UTC (rev 14523)
@@ -25,7 +25,7 @@
 #include <QIcon>
 QgsLegendGroup::QgsLegendGroup( QTreeWidgetItem * theItem, QString theName )
-    : QgsLegendItem( theItem, theName )
+  : QgsLegendItem( theItem, theName )
   mType = LEGEND_GROUP;
   setFlags( Qt::ItemIsEditable | Qt::ItemIsUserCheckable | Qt::ItemIsEnabled | Qt::ItemIsSelectable );
@@ -34,7 +34,7 @@
   setIcon( 0, myIcon );
 QgsLegendGroup::QgsLegendGroup( QTreeWidget* theListView, QString theString )
-    : QgsLegendItem( theListView, theString )
+  : QgsLegendItem( theListView, theString )
@@ -114,7 +114,7 @@
     return;
   Qt::CheckState theState = elements[0]->checkState( 0 );
-  foreach( QgsLegendItem *li, elements )
+  foreach( QgsLegendItem * li, elements )
     if ( theState != li->checkState( 0 ) )
@@ -125,8 +125,6 @@
   if ( theState != checkState( 0 ) )
-    treeWidget()->blockSignals( true );
     setCheckState( 0, theState );
-    treeWidget()->blockSignals( false );
More information about the QGIS-commit mailing list
