[QGIS Commit] r14541 - in trunk/qgis/python/plugins:
GdalTools/tools fTools/tools
svn_qgis at osgeo.org
Thu Nov 11 01:08:19 EST 2010
Author: borysiasty
Date: 2010-11-10 22:08:19 -0800 (Wed, 10 Nov 2010)
New Revision: 14541
trunk/qgis/python/plugins/GdalTools/tools/widgetBuildVRT.ui
trunk/qgis/python/plugins/GdalTools/tools/widgetClipper.ui
trunk/qgis/python/plugins/GdalTools/tools/widgetContour.ui
trunk/qgis/python/plugins/GdalTools/tools/widgetConvert.ui
trunk/qgis/python/plugins/GdalTools/tools/widgetGrid.ui
trunk/qgis/python/plugins/GdalTools/tools/widgetInfo.ui
trunk/qgis/python/plugins/GdalTools/tools/widgetMerge.ui
trunk/qgis/python/plugins/GdalTools/tools/widgetNearBlack.ui
trunk/qgis/python/plugins/GdalTools/tools/widgetOverview.ui
trunk/qgis/python/plugins/GdalTools/tools/widgetPolygonize.ui
trunk/qgis/python/plugins/GdalTools/tools/widgetProjection.ui
trunk/qgis/python/plugins/GdalTools/tools/widgetProximity.ui
trunk/qgis/python/plugins/GdalTools/tools/widgetRasterize.ui
trunk/qgis/python/plugins/GdalTools/tools/widgetSieve.ui
trunk/qgis/python/plugins/GdalTools/tools/widgetTranslate.ui
trunk/qgis/python/plugins/GdalTools/tools/widgetWarp.ui
trunk/qgis/python/plugins/fTools/tools/frmPointDistance.ui
trunk/qgis/python/plugins/fTools/tools/frmReProject.ui
trunk/qgis/python/plugins/fTools/tools/frmSpatialJoin.ui
Modified: trunk/qgis/python/plugins/GdalTools/tools/widgetBuildVRT.ui
--- trunk/qgis/python/plugins/GdalTools/tools/widgetBuildVRT.ui 2010-11-10 07:56:10 UTC (rev 14540)
+++ trunk/qgis/python/plugins/GdalTools/tools/widgetBuildVRT.ui 2010-11-11 06:08:19 UTC (rev 14541)
@@ -28,7 +28,7 @@
<item row="0" column="0">
<widget class="QLabel" name="label">
<property name="text">
- <string>&Input files:</string>
+ <string>&Input files</string>
</property>
<property name="buddy">
<cstring>selectInputFilesButton</cstring>
@@ -59,7 +59,7 @@
<item row="1" column="0">
<widget class="QLabel" name="label_2">
- <string>&Output file:</string>
+ <string>&Output file</string>
</property>
<cstring>selectOutputFileButton</cstring>
@@ -90,7 +90,7 @@
<item row="2" column="0">
<widget class="QCheckBox" name="resolutionCheck">
- <string>&Resolution:</string>
+ <string>&Resolution</string>
</property>
</widget>
</item>
@@ -125,7 +125,7 @@
<item row="3" column="0">
<widget class="QCheckBox" name="srcNoDataCheck">
- <string>&Source No Data:</string>
+ <string>&Source No Data</string>
</property>
</widget>
</item>
Modified: trunk/qgis/python/plugins/GdalTools/tools/widgetClipper.ui
--- trunk/qgis/python/plugins/GdalTools/tools/widgetClipper.ui 2010-11-10 07:56:10 UTC (rev 14540)
+++ trunk/qgis/python/plugins/GdalTools/tools/widgetClipper.ui 2010-11-11 06:08:19 UTC (rev 14541)
@@ -25,7 +25,7 @@
</property>
@@ -56,7 +56,7 @@
<widget class="QCheckBox" name="noDataCheck">
- <string>&No data value:</string>
+ <string>&No data value</string>
</property>
</widget>
</item>
@@ -88,7 +88,7 @@
<item>
<widget class="QLabel" name="label_7">
- <string>or change the extent coordinates:</string>
+ <string>or change the extent coordinates</string>
</property>
</widget>
</item>
@@ -99,7 +99,7 @@
<item>
<widget class="QLabel" name="label_8">
- <string>1:</string>
+ <string>1</string>
</property>
</widget>
</item>
@@ -164,7 +164,7 @@
<item>
<widget class="QLabel" name="label_9">
- <string>2:</string>
+ <string>2</string>
</property>
</widget>
</item>
Modified: trunk/qgis/python/plugins/GdalTools/tools/widgetContour.ui
--- trunk/qgis/python/plugins/GdalTools/tools/widgetContour.ui 2010-11-10 07:56:10 UTC (rev 14540)
+++ trunk/qgis/python/plugins/GdalTools/tools/widgetContour.ui 2010-11-11 06:08:19 UTC (rev 14541)
@@ -25,7 +25,7 @@
- <string>&Input file (raster):</string>
+ <string>&Input file (raster)</string>
</property>
<cstring>selectInputFileButton</cstring>
@@ -62,7 +62,7 @@
- <string>&Output directory for contour lines (shapefile):</string>
+ <string>&Output directory for contour lines (shapefile)</string>
</property>
<cstring>selectOutputDirButton</cstring>
@@ -93,7 +93,7 @@
<widget class="QLabel" name="label_3">
- <string>I&nterval between contour lines:</string>
+ <string>I&nterval between contour lines</string>
</property>
<cstring>intervalDSpinBox</cstring>
@@ -118,7 +118,7 @@
<item>
<widget class="QCheckBox" name="attributeCheck">
- <string>&Attribute name:</string>
+ <string>&Attribute name</string>
</property>
</widget>
</item>
Modified: trunk/qgis/python/plugins/GdalTools/tools/widgetConvert.ui
--- trunk/qgis/python/plugins/GdalTools/tools/widgetConvert.ui 2010-11-10 07:56:10 UTC (rev 14540)
+++ trunk/qgis/python/plugins/GdalTools/tools/widgetConvert.ui 2010-11-11 06:08:19 UTC (rev 14541)
@@ -32,7 +32,7 @@
- <string>&Input file:</string>
+ <string>&Input file</string>
</property>
@@ -69,7 +69,7 @@
</property>
Modified: trunk/qgis/python/plugins/GdalTools/tools/widgetGrid.ui
--- trunk/qgis/python/plugins/GdalTools/tools/widgetGrid.ui 2010-11-10 07:56:10 UTC (rev 14540)
+++ trunk/qgis/python/plugins/GdalTools/tools/widgetGrid.ui 2010-11-11 06:08:19 UTC (rev 14541)
@@ -25,7 +25,7 @@
</property>
@@ -62,7 +62,7 @@
<widget class="QCheckBox" name="zfieldCheck">
- <string>&Z Field:</string>
+ <string>&Z Field</string>
</property>
</widget>
</item>
@@ -72,7 +72,7 @@
</property>
@@ -103,7 +103,7 @@
<widget class="QCheckBox" name="algorithmCheck">
- <string>&Algorithm:</string>
+ <string>&Algorithm</string>
</property>
</widget>
</item>
@@ -154,7 +154,7 @@
- <string>Power:</string>
+ <string>Power</string>
</property>
</widget>
</item>
@@ -168,7 +168,7 @@
<widget class="QLabel" name="label_4">
- <string>Smoothing:</string>
+ <string>Smoothing</string>
</property>
</widget>
</item>
@@ -185,7 +185,7 @@
<widget class="QLabel" name="label_5">
- <string>Radius1:</string>
+ <string>Radius1</string>
</property>
</widget>
</item>
@@ -202,7 +202,7 @@
<widget class="QLabel" name="label_6">
- <string>Radius2:</string>
+ <string>Radius2</string>
</property>
</widget>
</item>
@@ -219,7 +219,7 @@
<item row="4" column="0">
- <string>Angle:</string>
+ <string>Angle</string>
</property>
</widget>
</item>
@@ -236,7 +236,7 @@
<item row="5" column="0">
- <string>Max points:</string>
+ <string>Max points</string>
</property>
</widget>
</item>
@@ -250,7 +250,7 @@
<item row="6" column="0">
- <string>Min points:</string>
+ <string>Min points</string>
</property>
</widget>
</item>
@@ -264,7 +264,7 @@
<item row="7" column="0">
<widget class="QLabel" name="label_10">
- <string>No data:</string>
+ <string>No data</string>
</property>
</widget>
</item>
@@ -298,7 +298,7 @@
<widget class="QLabel" name="label_21">
</property>
</widget>
</item>
@@ -315,7 +315,7 @@
<widget class="QLabel" name="label_19">
</property>
</widget>
</item>
@@ -332,7 +332,7 @@
<widget class="QLabel" name="label_22">
</property>
</widget>
</item>
@@ -349,7 +349,7 @@
<widget class="QLabel" name="label_20">
</property>
</widget>
</item>
@@ -363,7 +363,7 @@
<widget class="QLabel" name="label_23">
</property>
</widget>
</item>
@@ -397,7 +397,7 @@
<widget class="QLabel" name="label_26">
</property>
</widget>
</item>
@@ -414,7 +414,7 @@
<widget class="QLabel" name="label_24">
</property>
</widget>
</item>
@@ -431,7 +431,7 @@
<widget class="QLabel" name="label_27">
</property>
</widget>
</item>
@@ -448,7 +448,7 @@
<widget class="QLabel" name="label_28">
</property>
</widget>
</item>
@@ -482,7 +482,7 @@
<widget class="QLabel" name="label_25">
- <string>Metrics:</string>
+ <string>Metrics</string>
</property>
</widget>
</item>
@@ -508,7 +508,7 @@
<widget class="QLabel" name="label_31">
</property>
</widget>
</item>
@@ -525,7 +525,7 @@
<widget class="QLabel" name="label_29">
</property>
</widget>
</item>
@@ -542,7 +542,7 @@
<widget class="QLabel" name="label_32">
</property>
</widget>
</item>
@@ -559,7 +559,7 @@
<widget class="QLabel" name="label_30">
</property>
</widget>
</item>
@@ -573,7 +573,7 @@
<widget class="QLabel" name="label_33">
</property>
</widget>
</item>
Modified: trunk/qgis/python/plugins/GdalTools/tools/widgetInfo.ui
--- trunk/qgis/python/plugins/GdalTools/tools/widgetInfo.ui 2010-11-10 07:56:10 UTC (rev 14540)
+++ trunk/qgis/python/plugins/GdalTools/tools/widgetInfo.ui 2010-11-11 06:08:19 UTC (rev 14541)
@@ -25,7 +25,7 @@
<item>
</property>
Modified: trunk/qgis/python/plugins/GdalTools/tools/widgetMerge.ui
--- trunk/qgis/python/plugins/GdalTools/tools/widgetMerge.ui 2010-11-10 07:56:10 UTC (rev 14540)
+++ trunk/qgis/python/plugins/GdalTools/tools/widgetMerge.ui 2010-11-11 06:08:19 UTC (rev 14541)
@@ -25,7 +25,7 @@
</property>
@@ -56,7 +56,7 @@
</property>
@@ -87,7 +87,7 @@
</property>
</widget>
</item>
@@ -127,7 +127,7 @@
<item>
<widget class="QGroupBox" name="creationGroupBox">
<property name="title">
- <string>&Creation Options:</string>
+ <string>&Creation Options</string>
</property>
<property name="checkable">
<bool>true</bool>
Modified: trunk/qgis/python/plugins/GdalTools/tools/widgetNearBlack.ui
--- trunk/qgis/python/plugins/GdalTools/tools/widgetNearBlack.ui 2010-11-10 07:56:10 UTC (rev 14540)
+++ trunk/qgis/python/plugins/GdalTools/tools/widgetNearBlack.ui 2010-11-11 06:08:19 UTC (rev 14541)
@@ -25,7 +25,7 @@
</property>
@@ -62,7 +62,7 @@
</property>
@@ -93,7 +93,7 @@
<widget class="QCheckBox" name="nearCheck">
- <string>How &far from black (or white):</string>
+ <string>How &far from black (or white)</string>
</property>
</widget>
</item>
Modified: trunk/qgis/python/plugins/GdalTools/tools/widgetOverview.ui
--- trunk/qgis/python/plugins/GdalTools/tools/widgetOverview.ui 2010-11-10 07:56:10 UTC (rev 14540)
+++ trunk/qgis/python/plugins/GdalTools/tools/widgetOverview.ui 2010-11-11 06:08:19 UTC (rev 14541)
@@ -32,7 +32,7 @@
</property>
@@ -183,7 +183,7 @@
the JPEG quality can be set.</string>
</property>
- <string>JPEG Quality (1-100):</string>
+ <string>JPEG Quality (1-100)</string>
</property>
</widget>
</item>
Modified: trunk/qgis/python/plugins/GdalTools/tools/widgetPolygonize.ui
--- trunk/qgis/python/plugins/GdalTools/tools/widgetPolygonize.ui 2010-11-10 07:56:10 UTC (rev 14540)
+++ trunk/qgis/python/plugins/GdalTools/tools/widgetPolygonize.ui 2010-11-11 06:08:19 UTC (rev 14541)
@@ -25,7 +25,7 @@
</property>
@@ -62,7 +62,7 @@
- <string>&Output file for polygons (shapefile):</string>
+ <string>&Output file for polygons (shapefile)</string>
</property>
@@ -93,7 +93,7 @@
<widget class="QCheckBox" name="fieldCheck">
- <string>&Field name:</string>
+ <string>&Field name</string>
</property>
</widget>
</item>
Modified: trunk/qgis/python/plugins/GdalTools/tools/widgetProjection.ui
--- trunk/qgis/python/plugins/GdalTools/tools/widgetProjection.ui 2010-11-10 07:56:10 UTC (rev 14540)
+++ trunk/qgis/python/plugins/GdalTools/tools/widgetProjection.ui 2010-11-11 06:08:19 UTC (rev 14541)
@@ -39,7 +39,7 @@
</property>
@@ -77,7 +77,7 @@
- <string>Desired SRS:</string>
+ <string>Desired SRS</string>
</property>
</widget>
</item>
Modified: trunk/qgis/python/plugins/GdalTools/tools/widgetProximity.ui
--- trunk/qgis/python/plugins/GdalTools/tools/widgetProximity.ui 2010-11-10 07:56:10 UTC (rev 14540)
+++ trunk/qgis/python/plugins/GdalTools/tools/widgetProximity.ui 2010-11-11 06:08:19 UTC (rev 14541)
@@ -25,7 +25,7 @@
</property>
@@ -62,7 +62,7 @@
</property>
@@ -86,7 +86,7 @@
<widget class="QCheckBox" name="valuesCheck">
- <string>&Values:</string>
+ <string>&Values</string>
</property>
</widget>
</item>
@@ -118,7 +118,7 @@
<widget class="QCheckBox" name="distUnitsCheck">
- <string>&Dist units:</string>
+ <string>&Dist units</string>
</property>
<property name="checked">
<bool>true</bool>
@@ -142,7 +142,7 @@
<widget class="QCheckBox" name="maxDistCheck">
- <string>&Max dist:</string>
+ <string>&Max dist</string>
</property>
</widget>
</item>
@@ -156,7 +156,7 @@
- <string>&No data:</string>
+ <string>&No data</string>
</property>
</widget>
</item>
@@ -170,7 +170,7 @@
<widget class="QCheckBox" name="fixedBufValCheck">
- <string>&Fixed buf val:</string>
+ <string>&Fixed buf val</string>
</property>
</widget>
</item>
Modified: trunk/qgis/python/plugins/GdalTools/tools/widgetRasterize.ui
--- trunk/qgis/python/plugins/GdalTools/tools/widgetRasterize.ui 2010-11-10 07:56:10 UTC (rev 14540)
+++ trunk/qgis/python/plugins/GdalTools/tools/widgetRasterize.ui 2010-11-11 06:08:19 UTC (rev 14541)
@@ -25,7 +25,7 @@
- <string>&Input file (shapefile):</string>
+ <string>&Input file (shapefile)</string>
</property>
@@ -62,7 +62,7 @@
- <string>&Attribute field:</string>
+ <string>&Attribute field</string>
</property>
<cstring>attributeComboBox</cstring>
@@ -82,7 +82,7 @@
- <string>&Output file for rasterized vectors (raster, must exists):</string>
+ <string>&Output file for rasterized vectors (raster, must exists)</string>
</property>
Modified: trunk/qgis/python/plugins/GdalTools/tools/widgetSieve.ui
--- trunk/qgis/python/plugins/GdalTools/tools/widgetSieve.ui 2010-11-10 07:56:10 UTC (rev 14540)
+++ trunk/qgis/python/plugins/GdalTools/tools/widgetSieve.ui 2010-11-11 06:08:19 UTC (rev 14541)
@@ -25,7 +25,7 @@
</property>
@@ -62,7 +62,7 @@
</property>
@@ -93,7 +93,7 @@
<widget class="QCheckBox" name="thresholdCheck">
- <string>&Threshold:</string>
+ <string>&Threshold</string>
</property>
</widget>
</item>
@@ -107,7 +107,7 @@
<widget class="QCheckBox" name="connectionsCheck">
- <string>&Pixel connections:</string>
+ <string>&Pixel connections</string>
</property>
</widget>
</item>
Modified: trunk/qgis/python/plugins/GdalTools/tools/widgetTranslate.ui
--- trunk/qgis/python/plugins/GdalTools/tools/widgetTranslate.ui 2010-11-10 07:56:10 UTC (rev 14540)
+++ trunk/qgis/python/plugins/GdalTools/tools/widgetTranslate.ui 2010-11-11 06:08:19 UTC (rev 14541)
@@ -32,7 +32,7 @@
- <string>&Input Layer:</string>
+ <string>&Input Layer</string>
</property>
<cstring>inputLayerCombo</cstring>
@@ -69,7 +69,7 @@
</property>
@@ -117,7 +117,7 @@
<widget class="QCheckBox" name="targetSRSCheck">
- <string>&Target SRS:</string>
+ <string>&Target SRS</string>
</property>
</widget>
</item>
@@ -154,7 +154,7 @@
<string>Percentage to resize image. This will change pixel size/image resolution accordingly: 25% will create an image with pixels 4x larger.</string>
</property>
- <string>Outsize:</string>
+ <string>Outsize</string>
</property>
</widget>
</item>
@@ -186,7 +186,7 @@
<string>Assign a specified nodata value to output bands.</string>
</property>
</property>
</widget>
</item>
@@ -198,7 +198,7 @@
The 'gray' value (from GDAL 1.7.0) enables to expand a dataset with a color table that only contains gray levels to a gray indexed dataset.</string>
</property>
- <string>Expand:</string>
+ <string>Expand</string>
</property>
</widget>
</item>
@@ -232,7 +232,7 @@
<string>Selects a subwindow from the source image for copying based on pixel/line location. (Enter Xoff Yoff Xsize Ysize)</string>
</property>
- <string>Srcwin:</string>
+ <string>Srcwin</string>
</property>
</widget>
</item>
@@ -249,7 +249,7 @@
<string>Selects a subwindow from the source image for copying (like -srcwin) but with the corners given in georeferenced coordinates. (Enter ulx uly lrx lry)</string>
</property>
- <string>Prjwin:</string>
+ <string>Prjwin</string>
</property>
</widget>
</item>
@@ -294,7 +294,7 @@
<item>
</property>
<bool>true</bool>
Modified: trunk/qgis/python/plugins/GdalTools/tools/widgetWarp.ui
--- trunk/qgis/python/plugins/GdalTools/tools/widgetWarp.ui 2010-11-10 07:56:10 UTC (rev 14540)
+++ trunk/qgis/python/plugins/GdalTools/tools/widgetWarp.ui 2010-11-11 06:08:19 UTC (rev 14541)
@@ -32,7 +32,7 @@
</property>
@@ -69,7 +69,7 @@
</property>
@@ -100,7 +100,7 @@
<widget class="QCheckBox" name="sourceSRSCheck">
- <string>&Source SRS:</string>
+ <string>&Source SRS</string>
</property>
</widget>
</item>
@@ -128,7 +128,7 @@
</property>
</widget>
</item>
@@ -156,7 +156,7 @@
<widget class="QCheckBox" name="resamplingCheck">
- <string>&Resampling method:</string>
+ <string>&Resampling method</string>
</property>
</widget>
</item>
@@ -202,7 +202,7 @@
<widget class="QCheckBox" name="cacheCheck">
- <string>&Memory used for caching:</string>
+ <string>&Memory used for caching</string>
</property>
</widget>
</item>
Modified: trunk/qgis/python/plugins/fTools/tools/frmPointDistance.ui
--- trunk/qgis/python/plugins/fTools/tools/frmPointDistance.ui 2010-11-10 07:56:10 UTC (rev 14540)
+++ trunk/qgis/python/plugins/fTools/tools/frmPointDistance.ui 2010-11-11 06:08:19 UTC (rev 14541)
@@ -108,7 +108,7 @@
<item row="3" column="0" >
<widget class="QCheckBox" name="chkNearest" >
<property name="text" >
- <string>Use only the nearest (k) target points:</string>
+ <string>Use only the nearest (k) target points</string>
</property>
</widget>
</item>
Modified: trunk/qgis/python/plugins/fTools/tools/frmReProject.ui
--- trunk/qgis/python/plugins/fTools/tools/frmReProject.ui 2010-11-10 07:56:10 UTC (rev 14540)
+++ trunk/qgis/python/plugins/fTools/tools/frmReProject.ui 2010-11-11 06:08:19 UTC (rev 14541)
@@ -97,7 +97,7 @@
<bool>false</bool>
</property>
- <string>Import spatial reference system:</string>
+ <string>Import spatial reference system</string>
</property>
</widget>
</item>
Modified: trunk/qgis/python/plugins/fTools/tools/frmSpatialJoin.ui
--- trunk/qgis/python/plugins/fTools/tools/frmSpatialJoin.ui 2010-11-10 07:56:10 UTC (rev 14540)
+++ trunk/qgis/python/plugins/fTools/tools/frmSpatialJoin.ui 2010-11-11 06:08:19 UTC (rev 14541)
@@ -147,7 +147,7 @@
<item>
<widget class="QLabel" name="label_2" >
- <string>Output Shapefile:</string>
+ <string>Output Shapefile</string>
</property>
</widget>
</item>
