[QGIS Commit] r14546 - in trunk/qgis/src/plugins/grass: modules-6.3
modules-6.4 modules-common
svn_qgis at osgeo.org
Thu Nov 11 13:38:54 EST 2010
Author: pcav
Date: 2010-11-11 10:38:54 -0800 (Thu, 11 Nov 2010)
New Revision: 14546
Added:
trunk/qgis/src/plugins/grass/modules-common/resize_grass
trunk/qgis/src/plugins/grass/modules-common/v.in.ascii.1.png
trunk/qgis/src/plugins/grass/modules-common/v.in.ascii.2.png
trunk/qgis/src/plugins/grass/modules-common/v.in.ascii.qgm
trunk/qgis/src/plugins/grass/modules-6.3/default.qgc
trunk/qgis/src/plugins/grass/modules-6.4/default.qgc
trunk/qgis/src/plugins/grass/modules-common/v.net.iso.qgm
Improvements to the GRASS toolbox - take 1 from the hackfest
Modified: trunk/qgis/src/plugins/grass/modules-6.3/default.qgc
--- trunk/qgis/src/plugins/grass/modules-6.3/default.qgc 2010-11-11 18:36:08 UTC (rev 14545)
+++ trunk/qgis/src/plugins/grass/modules-6.3/default.qgc 2010-11-11 18:38:54 UTC (rev 14546)
@@ -36,6 +36,7 @@
<grass name="v.in.ogr.all.loc"/>
<grass name="v.in.dxf"/>
<grass name="v.in.e00"/>
+ <grass name="v.in.ascii"/>
<grass name="v.in.mapgen"/>
<grass name="v.in.db"/>
<grass name="v.in.garmin"/>
Modified: trunk/qgis/src/plugins/grass/modules-6.4/default.qgc
--- trunk/qgis/src/plugins/grass/modules-6.4/default.qgc 2010-11-11 18:36:08 UTC (rev 14545)
+++ trunk/qgis/src/plugins/grass/modules-6.4/default.qgc 2010-11-11 18:38:54 UTC (rev 14546)
@@ -64,6 +64,7 @@
Added: trunk/qgis/src/plugins/grass/modules-common/resize_grass
--- trunk/qgis/src/plugins/grass/modules-common/resize_grass (rev 0)
+++ trunk/qgis/src/plugins/grass/modules-common/resize_grass 2010-11-11 18:38:54 UTC (rev 14546)
@@ -0,0 +1,22 @@
+#!/bin/bash
+# Use a simple shell loop, to process each of the images.
+mkdir thumbnails
+# echo $a
+# do convert -thumbnail $a 32x32 thumbnails/$f.png
+#done
+# Use find to substitute filenames into a 'convert' command
+ # This also provides the ability to recurse though directories by removing
+ # the -prune option, as well as doing other file checks (like image type,
+ # or the disk space used by an image).
+ find * -prune -name '*.png' \
+ -exec convert '{}' -alpha set -channel RGBA -fill none -opaque white \
+ -thumbnail x32 thumbnails/'{}' \;
+#for i in `find . -name "*.png`
+#echo $i
+#do
+#done
Added: trunk/qgis/src/plugins/grass/modules-common/v.in.ascii.1.png
(Binary files differ)
Property changes on: trunk/qgis/src/plugins/grass/modules-common/v.in.ascii.1.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: trunk/qgis/src/plugins/grass/modules-common/v.in.ascii.2.png
Property changes on: trunk/qgis/src/plugins/grass/modules-common/v.in.ascii.2.png
Added: trunk/qgis/src/plugins/grass/modules-common/v.in.ascii.qgm
--- trunk/qgis/src/plugins/grass/modules-common/v.in.ascii.qgm (rev 0)
+++ trunk/qgis/src/plugins/grass/modules-common/v.in.ascii.qgm 2010-11-11 18:38:54 UTC (rev 14546)
@@ -0,0 +1,13 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
+<qgisgrassmodule label="Import text file" module="v.in.ascii">
+ <file key="input" label="Text file"/>
+ <option key="output"/>
+ <option key="format"/>
+ <option key="fs" label="Separator (| , \t etc.)" />
+ <option key="skip" label="Number of rows to be skipped"/>
+ <option key="x" label="Which column for the X coordinate? The first is 1"/>
+ <option key="y" label="Which column for the Y coordinate?"/>
+ <option key="z" label="Which column for the Z coordinate? If 0, z coordinate is not used"/>
+</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules-common/v.net.iso.qgm
--- trunk/qgis/src/plugins/grass/modules-common/v.net.iso.qgm 2010-11-11 18:36:08 UTC (rev 14545)
+++ trunk/qgis/src/plugins/grass/modules-common/v.net.iso.qgm 2010-11-11 18:38:54 UTC (rev 14546)
@@ -4,7 +4,7 @@
<qgisgrassmodule label="Cut network by cost isolines" module="v.net.iso">
<option key="input" layeroption="alayer" typemask="line,boundary" label="Input arcs" id="arcs" />
<option key="input" mapid="arcs" layeroption="nlayer" typemask="point" label="Input nodes" id="nodes" />
- <selection key="ccats" layerid="nodes" label="Cats" />
+ <selection key="ccats" layerid="nodes" label="Cats (select from the map or using their id)" />
<option key="costs" />
<option key="output" />
</qgisgrassmodule>
