[QGIS Commit] r14556 - in trunk/qgis/src: gui/symbology-ng ui
svn_qgis at osgeo.org
Fri Nov 12 09:33:46 EST 2010
Author: timlinux
Date: 2010-11-12 06:33:46 -0800 (Fri, 12 Nov 2010)
New Revision: 14556
trunk/qgis/src/gui/symbology-ng/qgssymbolv2selectordialog.cpp
trunk/qgis/src/ui/qgssymbolv2selectordialogbase.ui
Hello from Wroclaw QGIS Hackfest November 2010! Tidy up for vector symbology dialog
Modified: trunk/qgis/src/gui/symbology-ng/qgssymbolv2selectordialog.cpp
--- trunk/qgis/src/gui/symbology-ng/qgssymbolv2selectordialog.cpp 2010-11-12 13:01:32 UTC (rev 14555)
+++ trunk/qgis/src/gui/symbology-ng/qgssymbolv2selectordialog.cpp 2010-11-12 14:33:46 UTC (rev 14556)
@@ -35,12 +35,13 @@
connect( btnSymbolProperties, SIGNAL( clicked() ), this, SLOT( changeSymbolProperties() ) );
+ connect( lblPreview, SIGNAL( clicked() ), this, SLOT( changeSymbolProperties() ) );
connect( btnStyleManager, SIGNAL( clicked() ), SLOT( openStyleManager() ) );
QStandardItemModel* model = new QStandardItemModel( viewSymbols );
viewSymbols->setModel( model );
connect( viewSymbols, SIGNAL( clicked( const QModelIndex & ) ), this, SLOT( setSymbolFromStyle( const QModelIndex & ) ) );
+ lblSymbolName->setText("");
populateSymbolView();
updateSymbolPreview();
updateSymbolInfo();
@@ -81,7 +82,9 @@
QStandardItemModel* model = qobject_cast<QStandardItemModel*>( viewSymbols->model() );
if ( !model )
return;
model->clear();
QStringList names = mStyle->symbolNames();
@@ -94,6 +97,8 @@
continue;
QStandardItem* item = new QStandardItem( names[i] );
+ item->setData( names[i], Qt::UserRole ); //so we can show a label when it is clicked
+ item->setText(""); //set the text to nothing and show in label when clicked rather
item->setFlags( Qt::ItemIsEnabled | Qt::ItemIsSelectable );
// create preview icon
QIcon icon = QgsSymbolLayerV2Utils::symbolPreviewIcon( s, previewSize );
@@ -106,7 +111,8 @@
void QgsSymbolV2SelectorDialog::setSymbolFromStyle( const QModelIndex & index )
- QString symbolName = index.data().toString();
+ QString symbolName = index.data( Qt::UserRole ).toString();
+ lblSymbolName->setText( symbolName );
// get new instance of symbol from style
QgsSymbolV2* s = mStyle->symbol( symbolName );
// remove all symbol layers from original symbol
@@ -264,7 +270,7 @@
void QgsSymbolV2SelectorDialog::displayTransparency( double alpha )
double transparencyPercent = ( 1 - alpha ) * 100;
- mTransparencyLabel->setText( tr( "Transparency: %1%" ).arg(( int ) transparencyPercent ) );
+ mTransparencyLabel->setText( tr( "Transparency %1%" ).arg(( int ) transparencyPercent ) );
QMenu* QgsSymbolV2SelectorDialog::advancedMenu()
Modified: trunk/qgis/src/ui/qgssymbolv2selectordialogbase.ui
--- trunk/qgis/src/ui/qgssymbolv2selectordialogbase.ui 2010-11-12 13:01:32 UTC (rev 14555)
+++ trunk/qgis/src/ui/qgssymbolv2selectordialogbase.ui 2010-11-12 14:33:46 UTC (rev 14556)
@@ -13,38 +13,49 @@
<property name="windowTitle">
<string>Symbol selector</string>
</property>
- <layout class="QGridLayout" name="gridLayout_5">
+ <layout class="QGridLayout" name="gridLayout_6">
<item row="0" column="0">
- <widget class="QLabel" name="lblPreview">
- <property name="sizePolicy">
- <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
- <horstretch>0</horstretch>
- <verstretch>0</verstretch>
- </sizepolicy>
- </property>
- <property name="minimumSize">
- <size>
- <width>100</width>
- <height>100</height>
- </size>
- </property>
- <property name="frameShape">
- <enum>QFrame::StyledPanel</enum>
- </property>
- <property name="frameShadow">
- <enum>QFrame::Sunken</enum>
- </property>
- <property name="text">
- <string/>
- </property>
- <property name="alignment">
- <set>Qt::AlignCenter</set>
- </property>
- </widget>
+ <layout class="QVBoxLayout" name="verticalLayout">
+ <item>
+ <widget class="QLabel" name="lblPreview">
+ <property name="sizePolicy">
+ <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <property name="minimumSize">
+ <size>
+ <width>100</width>
+ <height>100</height>
+ </size>
+ </property>
+ <property name="frameShape">
+ <enum>QFrame::StyledPanel</enum>
+ </property>
+ <property name="frameShadow">
+ <enum>QFrame::Sunken</enum>
+ </property>
+ <property name="text">
+ <string/>
+ </property>
+ <property name="alignment">
+ <set>Qt::AlignCenter</set>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QPushButton" name="btnSymbolProperties">
+ <string>Change...</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
</item>
<item row="0" column="1">
- <layout class="QVBoxLayout" name="verticalLayout">
- <item>
+ <layout class="QGridLayout" name="gridLayout_5">
+ <item row="0" column="0" colspan="2">
<layout class="QGridLayout" name="gridLayout_3">
<widget class="QLabel" name="mSymbolUnitLabel">
@@ -115,16 +126,19 @@
</item>
</layout>
</item>
- <item>
+ <item row="0" column="2" colspan="2">
<widget class="QStackedWidget" name="stackedWidget">
+ <sizepolicy hsizetype="Minimum" vsizetype="Preferred">
+ </sizepolicy>
+ </property>
<property name="currentIndex">
<number>2</number>
</property>
<widget class="QWidget" name="pageMarker">
<layout class="QGridLayout" name="gridLayout">
- <property name="margin">
- <number>0</number>
- </property>
<widget class="QLabel" name="label_2">
@@ -168,13 +182,23 @@
</property>
</widget>
</item>
+ <item row="2" column="0" colspan="2">
+ <spacer name="horizontalSpacer_3">
+ <property name="orientation">
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <property name="sizeHint" stdset="0">
+ <size>
+ <width>178</width>
+ <height>20</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
</layout>
</widget>
<widget class="QWidget" name="pageLine">
<layout class="QGridLayout" name="gridLayout_2">
- </property>
<widget class="QLabel" name="label_4">
@@ -182,7 +206,7 @@
</property>
</widget>
</item>
- <item row="0" column="1">
+ <item row="0" column="2">
<widget class="QDoubleSpinBox" name="spinWidth">
<property name="decimals">
<number>2</number>
@@ -195,6 +219,32 @@
</property>
</widget>
</item>
+ <item row="1" column="1">
+ <spacer name="horizontalSpacer_4">
+ </property>
+ <size>
+ <width>37</width>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item row="2" column="1">
+ <spacer name="horizontalSpacer_5">
+ </property>
+ <size>
+ <width>37</width>
+ </size>
+ </property>
+ </spacer>
+ </item>
</layout>
</widget>
<widget class="QWidget" name="pageFill">
@@ -206,18 +256,7 @@
</widget>
</widget>
</item>
- </layout>
- </item>
- <item row="1" column="0" colspan="2">
- <layout class="QHBoxLayout" name="horizontalLayout">
- <item>
- <widget class="QPushButton" name="btnSymbolProperties">
- <string>Properties</string>
- </property>
- </widget>
- </item>
- <item>
+ <item row="1" column="0">
<spacer name="horizontalSpacer">
@@ -230,35 +269,35 @@
</property>
</spacer>
</item>
- <item>
+ <item row="1" column="1" colspan="2">
<widget class="QPushButton" name="btnAdvanced">
<string>Advanced</string>
</property>
</widget>
</item>
- <item>
+ <item row="1" column="3">
<widget class="QPushButton" name="btnAddToStyle">
- <string>Add to style</string>
+ <string>Save as style</string>
</property>
</widget>
</item>
</layout>
</item>
- <item row="2" column="0" colspan="2">
+ <item row="1" column="0" colspan="2">
<widget class="Line" name="line">
</property>
</widget>
</item>
- <item row="3" column="0" colspan="2">
<layout class="QGridLayout" name="gridLayout_4">
<widget class="QLabel" name="label">
- <string>Symbols from style</string>
+ <string>Saved styles</string>
</property>
</widget>
</item>
@@ -308,11 +347,24 @@
<property name="viewMode">
<enum>QListView::IconMode</enum>
</property>
+ <property name="uniformItemSizes">
+ <bool>true</bool>
+ </property>
+ <property name="wordWrap">
+ <bool>true</bool>
+ </property>
</widget>
</item>
</layout>
</item>
- <item row="4" column="0" colspan="2">
+ <item row="3" column="0">
+ <widget class="QLabel" name="lblSymbolName">
+ <string>Symbol Name</string>
+ </property>
+ </widget>
+ </item>
+ <item row="3" column="1">
<widget class="QDialogButtonBox" name="buttonBox">
