[QGIS Commit] r14596 - trunk/qgis/src/plugins/grass/modules-common
svn_qgis at osgeo.org
Sat Nov 13 09:19:20 EST 2010
Author: pcav
Date: 2010-11-13 06:19:20 -0800 (Sat, 13 Nov 2010)
New Revision: 14596
Added:
trunk/qgis/src/plugins/grass/modules-common/db.connect.1.svg
trunk/qgis/src/plugins/grass/modules-common/db.copy.1.svg
Removed:
trunk/qgis/src/plugins/grass/modules-common/db.copy.1.png
trunk/qgis/src/plugins/grass/modules-common/db.copy.2.png
Improving the appearance of GRASS toolbox - take 3: first new icons from Robert Szczepanek
Added: trunk/qgis/src/plugins/grass/modules-common/db.connect.1.svg
--- trunk/qgis/src/plugins/grass/modules-common/db.connect.1.svg (rev 0)
+++ trunk/qgis/src/plugins/grass/modules-common/db.connect.1.svg 2010-11-13 14:19:20 UTC (rev 14596)
@@ -0,0 +1,88 @@
+<?xml version="1.0" encoding="UTF-8" standalone="no"?>
+<!-- Created with Inkscape (http://www.inkscape.org/) -->
+<svg
+ xmlns:dc="http://purl.org/dc/elements/1.1/"
+ xmlns:cc="http://creativecommons.org/ns#"
+ xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
+ xmlns:svg="http://www.w3.org/2000/svg"
+ xmlns="http://www.w3.org/2000/svg"
+ version="1.1"
+ width="32"
+ height="32"
+ id="svg5692">
+ <defs
+ id="defs5694" />
+ <metadata
+ id="metadata5697">
+ <rdf:RDF>
+ <cc:Work
+ rdf:about="">
+ <dc:format>image/svg+xml</dc:format>
+ <dc:type
+ rdf:resource="http://purl.org/dc/dcmitype/StillImage" />
+ <dc:title></dc:title>
+ </cc:Work>
+ </rdf:RDF>
+ </metadata>
+ <g
+ id="layer1">
+ <g
+ transform="translate(2,7.8666667)"
+ id="g3771"
+ style="display:inline;enable-background:new">
+ <path
+ d="m 9.2,12.3 0,-8.4 c 0,0 0,-1.2 4.8,-1.2 4.8,0 4.8,1.2 4.8,1.2 l 0,8.4 c 0,0 0,1.2 -4.8,1.2 -4.8,0 -4.742286,-1.146586 -4.8,-1.2 z"
+ id="path3685"
+ style="fill:#82a0b4;fill-rule:evenodd;stroke:#82a0b4;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1" />
+ <path
+ d="m 8,4.5 c 2.4,2.4 9.6,2.4 12,0 0,0 0,-1.2 0,-1.2 -2.4,2.4 -9.6,2.4 -12,0 0,0 0,1.2 0,1.2 z"
+ id="path3669"
+ style="fill:#3c5a6e;fill-opacity:1;fill-rule:evenodd;stroke:none;stroke-width:1px;marker:none;visibility:visible;display:inline;overflow:visible;enable-background:accumulate" />
+ <path
+ d="m 20,3.3 c -2.4,-2.4 -9.6,-2.4 -12,0 0,0 0,1.2 0,1.2 2.4,-2.4 9.6,-2.4 12,0 0,0 0,-1.2 0,-1.2 z"
+ id="path3671"
+ <path
+ d="m 8,12.9 c 2.4,2.4 9.6,2.4 12,0 0,0 0,-1.2 0,-1.2 -2.4,2.4 -9.6,2.4 -12,0 0,0 0,1.2 0,1.2 z"
+ id="path3678"
+ <path
+ d="m 8,8.7 c 2.4,2.4 9.6,2.4 12,0 0,0 0,-1.2 0,-1.2 -2.4,2.4 -9.6,2.4 -12,0 0,0 0,1.2 0,1.2 z"
+ id="path3680"
+ <path
+ d="m 19.5,12.5 0,-8"
+ id="path3683"
+ style="fill:#3c5a6e;fill-rule:evenodd;stroke:#3c5a6e;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1" />
+ <path
+ d="m 8.5,12.5 0,-8"
+ id="path3769"
+ <path
+ d="m 8,3.3 c 0,0 0,9.6 0,9.6 3.6,2.4 6,1.8 6,1.8 0,0 0,-9.6 0,-9.6 -1.2,0 -2.4,0.6 -6,-1.8 z"
+ id="path3689"
+ style="opacity:0.2;fill:#fcffff;fill-rule:evenodd;stroke:none" />
+ </g>
+ <rect
+ width="11"
+ height="11"
+ ry="1.881395"
+ x="21"
+ y="21"
+ id="rect7388"
+ style="opacity:0.9;fill:#204a87;fill-opacity:1;fill-rule:nonzero;stroke:none;display:inline;enable-background:new" />
+ <path
+ d="m 21.5,26.999851 10,0 c 0,0 0,-1.099971 0,-3.299911 C 31.5,21.5 30.388888,21.5 26.5,21.5 c -3.888888,0 -5,0 -5,2.19994 0,2.19994 0.03588,3.351238 0,3.299911 z"
+ id="path4077"
+ style="opacity:0.3;fill:#fcffff;fill-rule:evenodd;stroke:none;display:inline;enable-background:new" />
+ <path
+ d="m 22.5,26.5 4,0"
+ id="path4884"
+ style="fill:#eeeeec;stroke:#eeeeec;stroke-width:1px;stroke-linecap:round;stroke-linejoin:round;stroke-opacity:1;display:inline;enable-background:new" />
+ <path
+ d="m 30.5,24.5 c -3,0 -4,0 -4,2 0,2 1,2 4,2"
+ id="path5690"
+ style="fill:none;stroke:#eeeeec;stroke-width:1px;stroke-linecap:round;stroke-linejoin:round;stroke-opacity:1;display:inline;enable-background:new" />
+ </g>
+</svg>
Deleted: trunk/qgis/src/plugins/grass/modules-common/db.copy.1.png
(Binary files differ)
Added: trunk/qgis/src/plugins/grass/modules-common/db.copy.1.svg
--- trunk/qgis/src/plugins/grass/modules-common/db.copy.1.svg (rev 0)
+++ trunk/qgis/src/plugins/grass/modules-common/db.copy.1.svg 2010-11-13 14:19:20 UTC (rev 14596)
@@ -0,0 +1,94 @@
+<svg
+ version="1.1"
+ width="32"
+ height="32"
+ id="svg5692">
+ <defs
+ id="defs5694" />
+ <metadata
+ <rdf:RDF>
+ <cc:Work
+ rdf:about="">
+ <dc:type
+ </cc:Work>
+ </rdf:RDF>
+ </metadata>
+ <g
+ id="layer1">
+ <g
+ id="g3771"
+ <path
+ id="path3685"
+ <path
+ id="path3669"
+ <path
+ id="path3671"
+ <path
+ id="path3678"
+ <path
+ id="path3680"
+ <path
+ id="path3683"
+ <path
+ id="path3769"
+ <path
+ id="path3689"
+ </g>
+ <rect
+ width="11"
+ height="11"
+ ry="1.881395"
+ x="21"
+ y="21"
+ id="rect7388"
+ <path
+ id="path4077"
+ <rect
+ width="5"
+ height="5"
+ x="24.5"
+ y="23.5"
+ id="rect5209"
+ style="opacity:0.8;fill:#fcffff;fill-opacity:1;fill-rule:evenodd;stroke:#505050;stroke-width:1;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-opacity:1;stroke-dasharray:none;stroke-dashoffset:0;marker:none;visibility:visible;display:inline;overflow:visible;enable-background:accumulate" />
+ <rect
+ width="5"
+ height="5"
+ x="22.5"
+ y="25.5"
+ id="rect5207"
+ </g>
+</svg>
Deleted: trunk/qgis/src/plugins/grass/modules-common/db.copy.2.png
