[QGIS Commit] r14631 - trunk/qgis/src/ui
svn_qgis at osgeo.org
Sat Nov 13 19:52:08 EST 2010
Author: timlinux
Date: 2010-11-13 16:52:08 -0800 (Sat, 13 Nov 2010)
New Revision: 14631
trunk/qgis/src/ui/qgssymbollevelsv2dialogbase.ui
Small tweak to make symbol layers dialog vaguely clearer sort of
Modified: trunk/qgis/src/ui/qgssymbollevelsv2dialogbase.ui
--- trunk/qgis/src/ui/qgssymbollevelsv2dialogbase.ui 2010-11-14 00:50:43 UTC (rev 14630)
+++ trunk/qgis/src/ui/qgssymbollevelsv2dialogbase.ui 2010-11-14 00:52:08 UTC (rev 14631)
@@ -13,24 +13,34 @@
<property name="windowTitle">
<string>Symbol Levels</string>
</property>
- <layout class="QVBoxLayout">
- <item>
+ <layout class="QGridLayout" name="gridLayout">
+ <item row="0" column="0">
<widget class="QCheckBox" name="chkEnable">
<property name="text">
<string>Enable symbol levels</string>
</property>
</widget>
</item>
- <item>
+ <item row="1" column="0">
+ <widget class="QLabel" name="label">
+ <property name="text">
+ <string>Define the order in which the symbol layers are rendered. The numbers in the cells define in which rendering pass the layer will be drawn.</string>
+ </property>
+ <property name="wordWrap">
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="0">
<widget class="QTableWidget" name="tableLevels"/>
</item>
- <item>
+ <item row="3" column="0">
<widget class="QDialogButtonBox" name="buttonBox">
<property name="orientation">
<enum>Qt::Horizontal</enum>
</property>
<property name="standardButtons">
- <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
+ <set>QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::Ok</set>
</property>
</widget>
</item>
