[QGIS Commit] r14638 - in trunk/qgis: python/gui src/app
svn_qgis at osgeo.org
Sun Nov 14 09:00:57 EST 2010
Author: brushtyler
Date: 2010-11-14 06:00:57 -0800 (Sun, 14 Nov 2010)
New Revision: 14638
trunk/qgis/python/gui/qgisinterface.sip
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgisapp.h
trunk/qgis/src/app/qgisappinterface.cpp
trunk/qgis/src/app/qgisappinterface.h
added Database menu and related methods add/remove plugins
Modified: trunk/qgis/python/gui/qgisinterface.sip
--- trunk/qgis/python/gui/qgisinterface.sip 2010-11-14 13:27:03 UTC (rev 14637)
+++ trunk/qgis/python/gui/qgisinterface.sip 2010-11-14 14:00:57 UTC (rev 14638)
@@ -94,7 +94,14 @@
/** Remove action from the plugins menu */
virtual void removePluginMenu(QString name, QAction* action)=0;
- /** Add a dock widget to the main window */
+ /** Add action to the Database menu
+ @note added in version 1.7 */
+ virtual void addPluginToDatabaseMenu(QString name, QAction* action)=0;
+ /** Remove action from the Database menu */
+ virtual void removePluginDatabaseMenu(QString name, QAction* action)=0;
+ /** Add a dock widget to the main window
virtual void addDockWidget ( Qt::DockWidgetArea area, QDockWidget * dockwidget )=0;
/** Remove specified dock widget from main window (doesn't delete it). Added in QGIS 1.1. */
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2010-11-14 13:27:03 UTC (rev 14637)
+++ trunk/qgis/src/app/qgisapp.cpp 2010-11-14 14:00:57 UTC (rev 14638)
@@ -1611,6 +1611,11 @@
mActionWindowSeparator2 = mWindowMenu->addSeparator();
#endif
+ // Database Menu
+ // don't add it yet, wait for a plugin
+ mDatabaseMenu = new QMenu( tr( "&Database" ) );
// Help Menu
menuBar()->addSeparator();
@@ -5657,6 +5662,93 @@
+QMenu* QgisApp::getDatabaseMenu( QString menuName )
+#ifdef Q_WS_MAC
+ // Mac doesn't have '&' keyboard shortcuts.
+ menuName.remove( QChar( '&' ) );
+#endif
+ QString dst = menuName;
+ dst.remove( QChar( '&' ) );
+ QAction *before = NULL;
+ QList<QAction*> actions = mDatabaseMenu->actions();
+ for ( int i = 0; i < actions.count(); i++ )
+ QString src = actions.at( i )->text();
+ src.remove( QChar( '&' ) );
+ int comp = dst.localeAwareCompare( src );
+ if ( comp < 0 )
+ // Add item before this one
+ before = actions.at( i );
+ break;
+ else if ( comp == 0 )
+ // Plugin menu item already exists
+ return actions.at( i )->menu();
+ // It doesn't exist, so create
+ QMenu *menu = new QMenu( menuName, this );
+ if ( before )
+ mDatabaseMenu->insertMenu( before, menu );
+ else
+ mDatabaseMenu->addMenu( menu );
+ return menu;
+void QgisApp::addPluginToDatabaseMenu( QString name, QAction* action )
+ QMenu* menu = getDatabaseMenu( name );
+ menu->addAction( action );
+ // add the Database menu to the menuBar if not added yet
+ if ( mDatabaseMenu->actions().count() != 1 )
+ return;
+ QAction* before = NULL;
+ QList<QAction*> actions = menuBar()->actions();
+ if ( actions.at( i )->menu() == mDatabaseMenu )
+ return;
+ if ( actions.at( i )->menu() == mHelpMenu )
+ break;
+ if ( before )
+ menuBar()->insertMenu( before, mDatabaseMenu );
+ else
+ menuBar()->addMenu( mDatabaseMenu );
+void QgisApp::removePluginDatabaseMenu( QString name, QAction* action )
+ menu->removeAction( action );
+ // remove the Database menu from the menuBar if there are no more actions
+ if ( mDatabaseMenu->actions().count() > 0 )
+ return;
+ menuBar()->removeAction( actions.at( i ) );
+ return;
int QgisApp::addPluginToolBarIcon( QAction * qAction )
mPluginToolBar->addAction( qAction );
Modified: trunk/qgis/src/app/qgisapp.h
--- trunk/qgis/src/app/qgisapp.h 2010-11-14 13:27:03 UTC (rev 14637)
+++ trunk/qgis/src/app/qgisapp.h 2010-11-14 14:00:57 UTC (rev 14638)
@@ -333,6 +333,7 @@
QMenu *layerMenu() { return mLayerMenu; }
QMenu *settingsMenu() { return mSettingsMenu; }
QMenu *pluginMenu() { return mPluginMenu; }
+ QMenu *databaseMenu() { return mDatabaseMenu; }
#ifdef Q_WS_MAC
QMenu *firstRightStandardMenu() { return mWindowMenu; }
QMenu *windowMenu() { return mWindowMenu; }
@@ -498,12 +499,18 @@
void showPluginManager();
//! load python support if possible
void loadPythonSupport();
- //! Find the QMenu with the given name (ie the user visible text on the menu item)
+ //! Find the QMenu with the given name within plugin menu (ie the user visible text on the menu item)
QMenu* getPluginMenu( QString menuName );
//! Add the action to the submenu with the given name under the plugin menu
void addPluginToMenu( QString name, QAction* action );
//! Remove the action to the submenu with the given name under the plugin menu
void removePluginMenu( QString name, QAction* action );
+ //! Find the QMenu with the given name within the Database menu (ie the user visible text on the menu item)
+ QMenu* getDatabaseMenu( QString menuName );
+ //! Add the action to the submenu with the given name under the Database menu
+ void addPluginToDatabaseMenu( QString name, QAction* action );
+ //! Remove the action to the submenu with the given name under the Database menu
+ void removePluginDatabaseMenu( QString name, QAction* action );
//! Add an icon to the plugin toolbar
int addPluginToolBarIcon( QAction * qAction );
//! Remove an icon from the plugin toolbar
@@ -1093,6 +1100,8 @@
QMenu * mPopupMenu;
//! Top level plugin menu
QMenu *mPluginMenu;
+ //! Top level database menu
+ QMenu *mDatabaseMenu;
//! Popup menu for the map overview tools
QMenu *toolPopupOverviews;
//! Popup menu for the display tools
Modified: trunk/qgis/src/app/qgisappinterface.cpp
--- trunk/qgis/src/app/qgisappinterface.cpp 2010-11-14 13:27:03 UTC (rev 14637)
+++ trunk/qgis/src/app/qgisappinterface.cpp 2010-11-14 14:00:57 UTC (rev 14638)
@@ -144,6 +144,16 @@
qgis->removePluginMenu( name, action );
+void QgisAppInterface::addPluginToDatabaseMenu( QString name, QAction* action )
+ qgis->addPluginToDatabaseMenu( name, action );
+void QgisAppInterface::removePluginDatabaseMenu( QString name, QAction* action )
+ qgis->removePluginDatabaseMenu( name, action );
int QgisAppInterface::addToolBarIcon( QAction * qAction )
// add the menu to the master Plugins menu
@@ -242,6 +252,7 @@
QMenu *QgisAppInterface::layerMenu() { return qgis->layerMenu(); }
QMenu *QgisAppInterface::settingsMenu() { return qgis->settingsMenu(); }
QMenu *QgisAppInterface::pluginMenu() { return qgis->pluginMenu(); }
+QMenu *QgisAppInterface::databaseMenu() { return qgis->databaseMenu(); }
QMenu *QgisAppInterface::firstRightStandardMenu() { return qgis->firstRightStandardMenu(); }
QMenu *QgisAppInterface::windowMenu() { return qgis->windowMenu(); }
QMenu *QgisAppInterface::helpMenu() { return qgis->helpMenu(); }
Modified: trunk/qgis/src/app/qgisappinterface.h
--- trunk/qgis/src/app/qgisappinterface.h 2010-11-14 13:27:03 UTC (rev 14637)
+++ trunk/qgis/src/app/qgisappinterface.h 2010-11-14 14:00:57 UTC (rev 14638)
@@ -107,6 +107,11 @@
+ /** Add action to the Database menu */
void addDockWidget( Qt::DockWidgetArea area, QDockWidget * dockwidget );
@@ -143,6 +148,7 @@
virtual QMenu *layerMenu();
virtual QMenu *settingsMenu();
virtual QMenu *pluginMenu();
+ virtual QMenu *databaseMenu();
virtual QMenu *firstRightStandardMenu();
virtual QMenu *windowMenu();
virtual QMenu *helpMenu();
