[QGIS Commit] r14643 - trunk/qgis/src/app
svn_qgis at osgeo.org
Sun Nov 14 10:49:52 EST 2010
Author: jef
Date: 2010-11-14 07:49:52 -0800 (Sun, 14 Nov 2010)
New Revision: 14643
trunk/qgis/src/app/qgisapp.cpp
change toolbar toolbuttons to menupopups and remember their last selection
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2010-11-14 14:49:17 UTC (rev 14642)
+++ trunk/qgis/src/app/qgisapp.cpp 2010-11-14 15:49:52 UTC (rev 14643)
@@ -1737,13 +1737,12 @@
mAttributesToolBar->addAction( mActionIdentify );
QToolButton *bt = new QToolButton( mAttributesToolBar );
- QMenu *menu = new QMenu( bt );
- bt->setMenu( menu );
- menu->addAction( mActionSelect );
- menu->addAction( mActionSelectRectangle );
- menu->addAction( mActionSelectPolygon );
- menu->addAction( mActionSelectFreehand );
- menu->addAction( mActionSelectRadius );
+ bt->setPopupMode( QToolButton::MenuButtonPopup );
+ bt->addAction( mActionSelect );
+ bt->addAction( mActionSelectRectangle );
+ bt->addAction( mActionSelectPolygon );
+ bt->addAction( mActionSelectFreehand );
+ bt->addAction( mActionSelectRadius );
QSettings settings;
switch ( settings.value( "/UI/selectTool", 0 ).toInt() )
@@ -1776,12 +1775,25 @@
mAttributesToolBar->addAction( mActionOpenTable );
- menu = new QMenu( bt );
- menu->addAction( mActionMeasure );
- menu->addAction( mActionMeasureArea );
- menu->addAction( mActionMeasureAngle );
- bt->setDefaultAction( mActionMeasure );
+ bt->addAction( mActionMeasure );
+ bt->addAction( mActionMeasureArea );
+ bt->addAction( mActionMeasureAngle );
+ switch ( settings.value( "/UI/measureTool", 0 ).toInt() )
+ default:
+ case 0:
+ bt->setDefaultAction( mActionMeasure );
+ break;
+ case 1:
+ bt->setDefaultAction( mActionMeasureArea );
+ break;
+ case 2:
+ bt->setDefaultAction( mActionMeasureAngle );
+ break;
mAttributesToolBar->addWidget( bt );
connect( bt, SIGNAL( triggered( QAction * ) ), this, SLOT( toolButtonActionTriggered( QAction * ) ) );
@@ -1791,19 +1803,31 @@
mAttributesToolBar->addAction( mActionLabeling );
// Annotation tools
- QToolButton *annotationToolButton = new QToolButton();
- annotationToolButton->setPopupMode( QToolButton::InstantPopup );
- annotationToolButton->setAutoRaise( true );
- annotationToolButton->setToolButtonStyle( Qt::ToolButtonIconOnly );
- annotationToolButton->setCheckable( true );
- annotationToolButton->addAction( mActionTextAnnotation );
- annotationToolButton->addAction( mActionFormAnnotation );
- annotationToolButton->addAction( mActionAnnotation );
- annotationToolButton->setDefaultAction( mActionTextAnnotation );
- connect( annotationToolButton, SIGNAL( triggered( QAction* ) ),
- annotationToolButton, SLOT( setDefaultAction( QAction* ) ) );
- mAttributesToolBar->addWidget( annotationToolButton );
+ bt = new QToolButton();
+ bt->addAction( mActionTextAnnotation );
+ bt->addAction( mActionFormAnnotation );
+ bt->addAction( mActionAnnotation );
+ switch ( settings.value( "/UI/annotationTool", 0 ).toInt() )
+ default:
+ case 0:
+ bt->setDefaultAction( mActionTextAnnotation );
+ break;
+ case 1:
+ bt->setDefaultAction( mActionFormAnnotation );
+ break;
+ case 2:
+ bt->setDefaultAction( mActionAnnotation );
+ break;
+ mAttributesToolBar->addWidget( bt );
+ connect( bt, SIGNAL( triggered( QAction * ) ), this, SLOT( toolButtonActionTriggered( QAction * ) ) );
mToolbarMenu->addAction( mAttributesToolBar->toggleViewAction() );
// Plugins Toolbar
mPluginToolBar = addToolBar( tr( "Plugins" ) );
@@ -7188,6 +7212,18 @@
settings.setValue( "/UI/selectTool", 3 );
else if ( action == mActionSelectRadius )
settings.setValue( "/UI/selectTool", 4 );
+ else if ( action == mActionMeasure )
+ settings.setValue( "/UI/measureTool", 0 );
+ else if ( action == mActionMeasureArea )
+ settings.setValue( "/UI/measureTool", 1 );
+ else if ( action == mActionMeasureAngle )
+ settings.setValue( "/UI/measureTool", 2 );
+ else if ( action == mActionTextAnnotation )
+ settings.setValue( "/UI/annotationTool", 0 );
+ else if ( action == mActionFormAnnotation )
+ settings.setValue( "/UI/annotationTool", 1 );
+ else if ( action == mActionAnnotation )
+ settings.setValue( "/UI/annotationTool", 2 );
bt->setDefaultAction( action );
