[QGIS Commit] r14653 - trunk/qgis/src/ui
svn_qgis at osgeo.org
Sun Nov 14 15:20:54 EST 2010
Author: timlinux
Date: 2010-11-14 12:20:54 -0800 (Sun, 14 Nov 2010)
New Revision: 14653
trunk/qgis/src/ui/qgslabelingguibase.ui
Cleanups for label dialog
Modified: trunk/qgis/src/ui/qgslabelingguibase.ui
--- trunk/qgis/src/ui/qgslabelingguibase.ui 2010-11-14 19:08:48 UTC (rev 14652)
+++ trunk/qgis/src/ui/qgslabelingguibase.ui 2010-11-14 20:20:54 UTC (rev 14653)
@@ -6,8 +6,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>515</width>
- <height>692</height>
+ <width>703</width>
+ <height>446</height>
</rect>
</property>
<property name="windowTitle">
@@ -17,8 +17,87 @@
<iconset>
<normaloff>../../../../.designer/backup</normaloff>../../../../.designer/backup</iconset>
</property>
- <layout class="QGridLayout" name="gridLayout_13">
+ <layout class="QGridLayout" name="gridLayout_8">
<item row="0" column="0">
+ <layout class="QHBoxLayout" name="horizontalLayout_3">
+ <item>
+ <widget class="QCheckBox" name="chkEnableLabeling">
+ <property name="text">
+ <string>Label this layer</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <spacer name="horizontalSpacer_5">
+ <property name="orientation">
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <property name="sizeHint" stdset="0">
+ <size>
+ <width>40</width>
+ <height>20</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item>
+ <widget class="QLabel" name="label_20">
+ <string>Field with labels</string>
+ </property>
+ <property name="alignment">
+ <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QComboBox" name="cboFieldName"/>
+ </item>
+ </layout>
+ </item>
+ <item row="1" column="0">
+ <layout class="QHBoxLayout" name="horizontalLayout_4">
+ <item>
+ <widget class="QLabel" name="label_33">
+ <property name="sizePolicy">
+ <sizepolicy hsizetype="Preferred" vsizetype="Preferred">
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <string>Sample</string>
+ </property>
+ <set>Qt::AlignLeading|Qt::AlignLeft|Qt::AlignVCenter</set>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QgsLabelPreview" name="lblFontPreview">
+ <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
+ </sizepolicy>
+ </property>
+ <property name="minimumSize">
+ <size>
+ <width>30</width>
+ <height>30</height>
+ </size>
+ </property>
+ <string>Lorem Ipsum</string>
+ </property>
+ <set>Qt::AlignCenter</set>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ <item row="2" column="0">
<widget class="QTabWidget" name="mTabWidget">
<property name="currentIndex">
<number>0</number>
@@ -27,301 +106,398 @@
<attribute name="title">
<string>Label settings</string>
</attribute>
- <layout class="QGridLayout" name="gridLayout_6">
+ <layout class="QGridLayout" name="gridLayout_14">
- <widget class="QCheckBox" name="chkEnableLabeling">
- <property name="text">
- <string>Label this layer</string>
+ <widget class="QGroupBox" name="groupBox_6">
+ <property name="title">
+ <string>Text style</string>
</property>
+ <layout class="QGridLayout" name="gridLayout_9">
+ <item row="0" column="0">
+ <widget class="QLabel" name="label_28">
+ </sizepolicy>
+ </property>
+ <string>Font</string>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="1">
+ <layout class="QHBoxLayout" name="horizontalLayout_15">
+ <item>
+ <widget class="QLabel" name="lblFontName">
+ <sizepolicy hsizetype="Expanding" vsizetype="Preferred">
+ <horstretch>1</horstretch>
+ </sizepolicy>
+ </property>
+ <string>TextLabel</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QToolButton" name="btnChangeFont">
+ <string>...</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <spacer name="horizontalSpacer_6">
+ </property>
+ <size>
+ <width>999</width>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ </layout>
+ </item>
+ <widget class="QLabel" name="mFontSizeLabel">
+ <string>Font size</string>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="1">
+ <layout class="QHBoxLayout" name="horizontalLayout">
+ <item>
+ <widget class="QDoubleSpinBox" name="mFontSizeSpinBox">
+ <property name="decimals">
+ <number>4</number>
+ </property>
+ <property name="maximum">
+ <double>999999999.000000000000000</double>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QComboBox" name="mFontSizeUnitComboBox">
+ <item>
+ <string>In points</string>
+ </property>
+ </item>
+ <item>
+ <string>In map units</string>
+ </property>
+ </item>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ <widget class="QLabel" name="label_29">
+ </sizepolicy>
+ </property>
+ <string>Color</string>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="1">
+ <layout class="QHBoxLayout" name="horizontalLayout_16">
+ <item>
+ <widget class="QgsColorButton" name="btnTextColor">
+ <sizepolicy hsizetype="Preferred" vsizetype="Fixed">
+ </sizepolicy>
+ </property>
+ <string/>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <spacer name="horizontalSpacer_7">
+ </property>
+ <property name="sizeType">
+ <enum>QSizePolicy::Preferred</enum>
+ </property>
+ <size>
+ <width>142</width>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ </layout>
+ </item>
+ </layout>
</widget>
</item>
- <layout class="QHBoxLayout" name="horizontalLayout_11">
- <item>
- <widget class="QLabel" name="label_20">
- <string>Field with labels</string>
- </property>
- <property name="alignment">
- <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QComboBox" name="cboFieldName"/>
- </item>
- <item>
- <spacer name="horizontalSpacer_5">
- <property name="orientation">
- <enum>Qt::Horizontal</enum>
- </property>
- <property name="sizeHint" stdset="0">
- <size>
- <width>40</width>
- <height>20</height>
- </size>
- </property>
- </spacer>
- </item>
- </layout>
+ <widget class="QGroupBox" name="chkBuffer">
+ <string>Buffer</string>
+ </property>
+ <property name="checkable">
+ <bool>true</bool>
+ </property>
+ <layout class="QGridLayout" name="gridLayout_5">
+ <layout class="QHBoxLayout" name="horizontalLayout_17">
+ <item>
+ <widget class="QLabel" name="label_31">
+ <string>Size</string>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QDoubleSpinBox" name="spinBufferSize">
+ <property name="suffix">
+ <string> mm</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QLabel" name="label_32">
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QgsColorButton" name="btnBufferColor">
+ </sizepolicy>
+ </property>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ </layout>
+ </widget>
</item>
- <widget class="QGroupBox" name="groupBox_5">
+ <widget class="QGroupBox" name="chkScaleBasedVisibility">
- <string>Placement</string>
+ <string>Scale-based visibility</string>
</property>
- <layout class="QHBoxLayout" name="horizontalLayout_12">
- <property name="leftMargin">
- <number>0</number>
+ <bool>true</bool>
+ </property>
+ <layout class="QGridLayout" name="gridLayout_10">
+ <widget class="QSpinBox" name="spinScaleMax">
+ <property name="prefix">
+ <string>Maximum </string>
+ </property>
+ <property name="minimum">
+ <number>1</number>
+ </property>
+ <number>10000000</number>
+ </property>
+ <property name="value">
+ </property>
+ </widget>
+ </item>
+ <widget class="QSpinBox" name="spinScaleMin">
+ <string>Minimum </string>
+ </property>
+ </property>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ <widget class="QWidget" name="tab">
+ <attribute name="title">
+ <string>Advanced</string>
+ </attribute>
+ <layout class="QGridLayout" name="gridLayout_6">
+ <widget class="QScrollArea" name="scrollArea_2">
+ <property name="widgetResizable">
+ <bool>true</bool>
+ </property>
+ <widget class="QWidget" name="scrollAreaWidgetContents_2">
+ <property name="geometry">
+ <rect>
+ <x>0</x>
+ <y>0</y>
+ <width>645</width>
+ <height>495</height>
+ </rect>
</property>
- <property name="topMargin">
- </property>
- <property name="rightMargin">
- </property>
- <property name="bottomMargin">
- <number>4</number>
- </property>
- <item>
- <widget class="QStackedWidget" name="stackedPlacement">
- <property name="currentIndex">
- <number>2</number>
- </property>
- <widget class="QWidget" name="pagePoint">
- <layout class="QVBoxLayout" name="verticalLayout_6">
+ <layout class="QGridLayout" name="gridLayout_13">
+ <widget class="QGroupBox" name="groupBox_7">
+ <string>Priority</string>
+ </property>
+ <layout class="QHBoxLayout" name="horizontalLayout_18">
<item>
- <widget class="QRadioButton" name="radAroundPoint">
+ <widget class="QLabel" name="label_34">
- <string>around point</string>
+ <string>Low</string>
</property>
- <property name="checked">
- <bool>true</bool>
- </property>
</widget>
</item>
<item>
- <widget class="QRadioButton" name="radOverPoint">
- <string>over point</string>
+ <widget class="QSlider" name="sliderPriority">
+ <number>10</number>
</property>
- </widget>
- </item>
- </layout>
- </widget>
- <widget class="QWidget" name="pageLine">
- <layout class="QVBoxLayout" name="verticalLayout_7">
- <item>
- <widget class="QRadioButton" name="radLineParallel">
- <string>parallel</string>
+ <number>5</number>
</property>
- <bool>true</bool>
</property>
- </widget>
- </item>
- <item>
- <widget class="QRadioButton" name="radLineCurved">
- <string>curved</string>
+ <property name="tickPosition">
+ <enum>QSlider::TicksBelow</enum>
</property>
- </widget>
- </item>
- <item>
- <widget class="QRadioButton" name="radLineHorizontal">
- <string>horizontal</string>
+ <property name="tickInterval">
</property>
</widget>
</item>
- </layout>
- </widget>
- <widget class="QWidget" name="pagePolygon">
- <layout class="QVBoxLayout" name="verticalLayout_8">
<item>
- <widget class="QRadioButton" name="radOverCentroid">
+ <widget class="QLabel" name="label_35">
- <string>over centroid</string>
+ <string>High</string>
</property>
- <bool>true</bool>
- </property>
</widget>
</item>
- <item>
- <widget class="QRadioButton" name="radAroundCentroid">
- <string>around centroid</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QRadioButton" name="radPolygonHorizontal">
- <string>horizontal (slow)</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QRadioButton" name="radPolygonFree">
- <string>free (slow)</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QRadioButton" name="radPolygonPerimeter">
- <string>using perimeter</string>
- </property>
- </widget>
- </item>
</layout>
</widget>
- </widget>
- </item>
- <item>
- <widget class="Line" name="line_3">
- <enum>Qt::Vertical</enum>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QStackedWidget" name="stackedOptions">
- <number>1</number>
- </property>
- <widget class="QWidget" name="pageOptionsPoint">
- <layout class="QGridLayout" name="gridLayout_7">
+ </item>
+ <widget class="QGroupBox" name="groupBox">
+ <string>Options</string>
+ </property>
+ <layout class="QGridLayout" name="gridLayout_12">
- <widget class="QLabel" name="label_21">
+ <widget class="QCheckBox" name="chkLabelPerFeaturePart">
- <string>Label distance</string>
+ <string>Label every part of multi-part features</string>
</property>
- </property>
</widget>
</item>
- <item row="0" column="1">
- <widget class="QDoubleSpinBox" name="spinDistPoint">
- <property name="decimals">
- </property>
- </widget>
- </item>
- <item row="0" column="2">
- <widget class="QLabel" name="label_22">
- <string>mm</string>
- </property>
- </widget>
- </item>
- <widget class="QLabel" name="label_23">
+ <widget class="QCheckBox" name="chkMergeLines">
- <string>Rotation</string>
+ <string>Merge connected lines to avoid duplicate labels</string>
</property>
- </property>
</widget>
</item>
- <item row="1" column="1">
- <widget class="QSpinBox" name="spinAngle">
- <property name="enabled">
- <bool>false</bool>
- </property>
- </widget>
- </item>
- <item row="1" column="2">
- <widget class="QLabel" name="label_24">
+ <widget class="QCheckBox" name="chkMultiLine">
- <string>degrees</string>
+ <string>Multiline labels</string>
</property>
</widget>
</item>
- </layout>
- </widget>
- <widget class="QWidget" name="pageOptionsLine">
- <layout class="QVBoxLayout" name="verticalLayout_9">
- <item>
- <widget class="QCheckBox" name="chkLineAbove">
+ <item row="3" column="0">
+ <widget class="QCheckBox" name="chkAddDirectionSymbol">
- <string>above line</string>
+ <string>Add direction symbol</string>
</property>
- <bool>true</bool>
- </property>
</widget>
</item>
- <item>
- <widget class="QCheckBox" name="chkLineOn">
- <string>on line</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QCheckBox" name="chkLineBelow">
- <string>below line</string>
- </property>
- </widget>
- </item>
- <item>
- <layout class="QHBoxLayout" name="horizontalLayout_13">
+ <item row="4" column="0">
+ <layout class="QHBoxLayout" name="horizontalLayout_2">
<item>
- <widget class="QLabel" name="label_25">
+ <widget class="QLabel" name="label_19">
- <string>Orientation</string>
+ <string>Suppress labeling of features smaller than</string>
</property>
</widget>
</item>
<item>
- <widget class="QRadioButton" name="radOrientationMap">
- <string>map</string>
+ <widget class="QDoubleSpinBox" name="mMinSizeSpinBox">
</property>
- <bool>true</bool>
- </property>
</widget>
</item>
+ </layout>
+ </item>
+ <item row="5" column="0">
+ <layout class="QHBoxLayout" name="horizontalLayout_20">
<item>
- <widget class="QRadioButton" name="radOrientationLine">
+ <widget class="QCheckBox" name="chkNoObstacle">
+ <property name="enabled">
+ <bool>true</bool>
+ </property>
- <string>line</string>
+ <string>Features don't act as obstacles for labels</string>
</property>
</widget>
</item>
- </layout>
- </item>
- <item>
- <layout class="QHBoxLayout" name="horizontalLayout_14">
<item>
- <widget class="QLabel" name="label_26">
+ <spacer name="horizontalSpacer_8">
</property>
+ <size>
+ <width>40</width>
+ </size>
</property>
- </widget>
+ </spacer>
</item>
<item>
- <widget class="QDoubleSpinBox" name="spinDistLine">
+ <widget class="QPushButton" name="btnEngineSettings">
+ <bool>true</bool>
</property>
- </widget>
- </item>
- <item>
- <widget class="QLabel" name="label_27">
+ <string>Engine settings</string>
</property>
</widget>
</item>
@@ -329,666 +505,495 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="pageOptionsEmpty"/>
- </widget>
- </item>
- </layout>
- </widget>
- </item>
- <item row="3" column="0">
- <layout class="QGridLayout" name="gridLayout_8">
- <item row="0" column="0" rowspan="2">
- <widget class="QGroupBox" name="groupBox_6">
- <property name="title">
- <string>Text style</string>
- </property>
- <layout class="QGridLayout" name="gridLayout_9">
- <item row="0" column="0">
- <widget class="QLabel" name="label_28">
- <property name="sizePolicy">
- <sizepolicy hsizetype="Preferred" vsizetype="Preferred">
- <horstretch>0</horstretch>
- <verstretch>0</verstretch>
- </sizepolicy>
+ </item>
+ <widget class="QGroupBox" name="groupBox_5">
+ <string>Placement</string>
+ </property>
+ <layout class="QHBoxLayout" name="horizontalLayout_12">
+ <property name="leftMargin">
+ <number>0</number>
</property>
- <string>Font</string>
+ <property name="topMargin">
</property>
+ <property name="rightMargin">
</property>
- </widget>
- </item>
- <layout class="QHBoxLayout" name="horizontalLayout_15">
+ <property name="bottomMargin">
+ </property>
<item>
- <widget class="QLabel" name="lblFontName">
- <sizepolicy hsizetype="Expanding" vsizetype="Preferred">
- <horstretch>1</horstretch>
- </sizepolicy>
+ <widget class="QStackedWidget" name="stackedPlacement">
+ <property name="currentIndex">
+ <number>2</number>
</property>
- <string>TextLabel</string>
- </property>
+ <widget class="QWidget" name="pagePoint">
+ <layout class="QVBoxLayout" name="verticalLayout_6">
+ <item>
+ <widget class="QRadioButton" name="radAroundPoint">
+ <string>around point</string>
+ </property>
+ <property name="checked">
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QRadioButton" name="radOverPoint">
+ <string>over point</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ <widget class="QWidget" name="pageLine">
+ <layout class="QVBoxLayout" name="verticalLayout_7">
+ <item>
+ <widget class="QRadioButton" name="radLineParallel">
+ <string>parallel</string>
+ </property>
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QRadioButton" name="radLineCurved">
+ <string>curved</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QRadioButton" name="radLineHorizontal">
+ <string>horizontal</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ <widget class="QWidget" name="pagePolygon">
+ <layout class="QVBoxLayout" name="verticalLayout_8">
+ <item>
+ <widget class="QRadioButton" name="radOverCentroid">
+ <string>over centroid</string>
+ </property>
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QRadioButton" name="radAroundCentroid">
+ <string>around centroid</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QRadioButton" name="radPolygonHorizontal">
+ <string>horizontal (slow)</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QRadioButton" name="radPolygonFree">
+ <string>free (slow)</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QRadioButton" name="radPolygonPerimeter">
+ <string>using perimeter</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
</widget>
</item>
<item>
- <spacer name="horizontalSpacer_6">
+ <widget class="Line" name="line_3">
+ <enum>Qt::Vertical</enum>
</property>
- <size>
- <width>40</width>
- </size>
- </property>
- </spacer>
+ </widget>
</item>
<item>
- <widget class="QToolButton" name="btnChangeFont">
- <string>...</string>
+ <widget class="QStackedWidget" name="stackedOptions">
</property>
+ <widget class="QWidget" name="pageOptionsPoint">
+ <layout class="QGridLayout" name="gridLayout_7">
+ <widget class="QLabel" name="label_21">
+ <string>Label distance</string>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <widget class="QDoubleSpinBox" name="spinDistPoint">
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="2">
+ <widget class="QLabel" name="label_22">
+ <string>mm</string>
+ </property>
+ </widget>
+ </item>
+ <widget class="QLabel" name="label_23">
+ <string>Rotation</string>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <widget class="QSpinBox" name="spinAngle">
+ <bool>false</bool>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="2">
+ <widget class="QLabel" name="label_24">
+ <string>degrees</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ <widget class="QWidget" name="pageOptionsLine">
+ <layout class="QVBoxLayout" name="verticalLayout_9">
+ <item>
+ <widget class="QCheckBox" name="chkLineAbove">
+ <string>above line</string>
+ </property>
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QCheckBox" name="chkLineOn">
+ <string>on line</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QCheckBox" name="chkLineBelow">
+ <string>below line</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <layout class="QHBoxLayout" name="horizontalLayout_13">
+ <item>
+ <widget class="QLabel" name="label_25">
+ <string>Orientation</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QRadioButton" name="radOrientationMap">
+ <string>map</string>
+ </property>
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QRadioButton" name="radOrientationLine">
+ <string>line</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ <item>
+ <layout class="QHBoxLayout" name="horizontalLayout_14">
+ <item>
+ <widget class="QLabel" name="label_26">
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QDoubleSpinBox" name="spinDistLine">
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QLabel" name="label_27">
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ </layout>
+ </widget>
+ <widget class="QWidget" name="pageOptionsEmpty"/>
</widget>
</item>
</layout>
- </item>
- <item row="2" column="0">
- <widget class="QLabel" name="label_29">
- </sizepolicy>
- </property>
- <string>Color</string>
- </property>
- </property>
- </widget>
- </item>
- <item row="2" column="1">
- <layout class="QHBoxLayout" name="horizontalLayout_16">
- <item>
- <widget class="QgsColorButton" name="btnTextColor">
- <sizepolicy hsizetype="Preferred" vsizetype="Fixed">
- </sizepolicy>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ <widget class="QWidget" name="tab_4">
+ <string>Data defined settings</string>
+ </attribute>
+ <layout class="QGridLayout" name="gridLayout_3">
+ <item row="3" column="1">
+ <widget class="QScrollArea" name="scrollArea">
+ <bool>true</bool>
+ </property>
+ <widget class="QWidget" name="scrollAreaWidgetContents">
+ <rect>
+ <x>0</x>
+ <y>0</y>
+ <height>615</height>
+ </rect>
+ </property>
+ <layout class="QGridLayout" name="gridLayout_11">
+ <widget class="QGroupBox" name="mFontAttributePropertiesGroupBox">
+ </sizepolicy>
+ </property>
+ <string>Font properties</string>
+ </property>
+ <layout class="QGridLayout" name="gridLayout">
+ <widget class="QLabel" name="mSizeLabel">
</property>
+ </widget>
+ </item>
+ <widget class="QComboBox" name="mSizeAttributeComboBox"/>
+ </item>
+ <widget class="QLabel" name="mColorLabel">
- <string/>
</property>
</widget>
</item>
- <item>
- <spacer name="horizontalSpacer_7">
+ <widget class="QComboBox" name="mColorAttributeComboBox"/>
+ </item>
+ <widget class="QLabel" name="mBoldLabel">
+ <string>Bold</string>
</property>
- <property name="sizeType">
- <enum>QSizePolicy::Preferred</enum>
+ </widget>
+ </item>
+ <widget class="QComboBox" name="mBoldAttributeComboBox"/>
+ </item>
+ <widget class="QLabel" name="mItalicLabel">
+ <string>Italic</string>
</property>
- <size>
- <width>142</width>
- </size>
+ </widget>
+ </item>
+ <widget class="QComboBox" name="mItalicAttributeComboBox"/>
+ </item>
+ <widget class="QLabel" name="mUnderlineLabel">
+ <string>Underline</string>
</property>
- </spacer>
+ </widget>
</item>
- </layout>
- </item>
- <widget class="QLabel" name="label_30">
- <string>Buffer</string>
- </property>
- </property>
- </widget>
- </item>
- <item row="3" column="1">
- <layout class="QHBoxLayout" name="horizontalLayout_17">
- <item>
- <widget class="QCheckBox" name="chkBuffer">
- <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
- </sizepolicy>
+ <item row="4" column="1">
+ <widget class="QComboBox" name="mUnderlineAttributeComboBox"/>
+ </item>
+ <widget class="QLabel" name="mStrikeoutLabel">
+ <string>Strikeout</string>
</property>
+ </widget>
+ </item>
+ <item row="5" column="1">
+ <widget class="QComboBox" name="mStrikeoutAttributeComboBox"/>
+ </item>
+ <item row="6" column="0">
+ <widget class="QLabel" name="mFontFamilyLabel">
- <string/>
+ <string>Font family</string>
</property>
</widget>
</item>
- <item>
- <widget class="QLabel" name="label_31">
+ <item row="6" column="1">
+ <widget class="QComboBox" name="mFontFamilyAttributeComboBox"/>
+ </item>
+ </layout>
+ </widget>
+ </item>
+ <widget class="QGroupBox" name="mBufferAttributesPropertiesGroupBox">
+ <string>Buffer properties</string>
+ </property>
+ <layout class="QGridLayout" name="gridLayout_2">
+ <widget class="QLabel" name="mBufferSizeLabel">
- <string>Size</string>
+ <string>Buffer size</string>
</property>
+ </widget>
+ </item>
+ <widget class="QComboBox" name="mBufferSizeAttributeComboBox"/>
+ </item>
+ <widget class="QLabel" name="mBufferColorLabel">
+ <string>Buffer color</string>
</property>
</widget>
</item>
- <item>
- <widget class="QDoubleSpinBox" name="spinBufferSize">
- <property name="suffix">
- <string> mm</string>
+ <widget class="QComboBox" name="mBufferColorAttributeComboBox"/>
+ </item>
+ </layout>
+ </widget>
+ </item>
+ <widget class="QGroupBox" name="mPositionAttributeGroupBox">
+ <string>Position</string>
+ </property>
+ <layout class="QGridLayout" name="gridLayout_4">
+ <widget class="QLabel" name="mXCoordinateLabel">
+ <string>X Coordinate</string>
</property>
</widget>
</item>
- <item>
- <widget class="QLabel" name="label_32">
+ <widget class="QComboBox" name="mXCoordinateComboBox"/>
+ </item>
+ <widget class="QLabel" name="mYCoordinateLabel">
+ <string>Y Coordinate</string>
</property>
+ </widget>
+ </item>
+ <widget class="QComboBox" name="mYCoordinateComboBox"/>
+ </item>
+ <widget class="QLabel" name="mHorizontalAlignmentLabel">
+ <string>Horizontal alignment</string>
</property>
</widget>
</item>
- <item>
- <widget class="QgsColorButton" name="btnBufferColor">
- </sizepolicy>
- </property>
+ <widget class="QComboBox" name="mHorizontalAlignmentComboBox"/>
+ </item>
+ <widget class="QLabel" name="mVerticalAlignmentLabel">
+ <string>Vertical alignment</string>
</property>
</widget>
</item>
- </layout>
- </item>
- <item row="5" column="0">
- <widget class="QLabel" name="label_33">
- </sizepolicy>
- </property>
- <string>Sample</string>
- </property>
- </property>
- </widget>
- </item>
- <item row="5" column="1">
- <widget class="QgsLabelPreview" name="lblFontPreview">
- </sizepolicy>
- </property>
- <property name="minimumSize">
- <size>
- <width>30</width>
- <height>30</height>
- </size>
- </property>
- <string>Lorem Ipsum</string>
- </property>
- <set>Qt::AlignCenter</set>
- </property>
- </widget>
- </item>
- <item row="4" column="0" colspan="2">
- <widget class="Line" name="line_4">
- </property>
- </widget>
- </item>
- <item row="1" column="0">
- <widget class="QLabel" name="mFontSizeLabel">
- <string>Font size</string>
- </property>
- </widget>
- </item>
- <layout class="QHBoxLayout" name="horizontalLayout">
- <item>
- <widget class="QDoubleSpinBox" name="mFontSizeSpinBox">
+ <widget class="QComboBox" name="mVerticalAlignmentComboBox"/>
+ </item>
+ <widget class="QComboBox" name="mRotationComboBox"/>
+ </item>
+ <widget class="QLabel" name="mRotationLabel">
</property>
- <property name="maximum">
- <double>999999999.000000000000000</double>
- </property>
</widget>
</item>
- <item>
- <widget class="QComboBox" name="mFontSizeUnitComboBox">
- <item>
- <string>In points</string>
- </property>
- </item>
- <item>
- <string>In map units</string>
- </property>
- </item>
+ <widget class="QComboBox" name="mLabelDistanceComboBox"/>
+ </item>
+ <widget class="QLabel" name="mLabelDistanceLabel">
+ </property>
</widget>
</item>
</layout>
- </item>
- </layout>
- </widget>
- </item>
- <widget class="QGroupBox" name="groupBox_7">
- <string>Priority</string>
- </property>
- <layout class="QHBoxLayout" name="horizontalLayout_18">
- <item>
- <widget class="QLabel" name="label_34">
- <string>Low</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QSlider" name="sliderPriority">
- <number>10</number>
- </property>
- <property name="value">
- <number>5</number>
- </property>
- </property>
- <property name="tickPosition">
- <enum>QSlider::TicksBelow</enum>
- </property>
- <property name="tickInterval">
- </property>
- </widget>
- </item>
- <item>
- <widget class="QLabel" name="label_35">
- <string>High</string>
- </property>
- </widget>
- </item>
- </layout>
- </widget>
- </item>
- <widget class="QGroupBox" name="groupBox_8">
- <string>Scale-based visibility</string>
- </property>
- <layout class="QGridLayout" name="gridLayout_10">
- <item row="0" column="0" colspan="2">
- <widget class="QCheckBox" name="chkScaleBasedVisibility">
- <string>Enabled</string>
- </property>
- </widget>
- </item>
- <widget class="QLabel" name="label_36">
- <string>Minimum</string>
- </property>
- </property>
- </widget>
- </item>
- <widget class="QSpinBox" name="spinScaleMin">
- <property name="minimum">
- </property>
- <number>10000000</number>
- </property>
- </widget>
- </item>
- <widget class="QLabel" name="label_37">
- <string>Maximum</string>
- </property>
- </property>
- </widget>
- </item>
- <widget class="QSpinBox" name="spinScaleMax">
- </property>
- </property>
- </property>
- </widget>
- </item>
- </layout>
- </widget>
- </item>
- </layout>
- </item>
- <item row="4" column="0">
- <widget class="QCheckBox" name="chkLabelPerFeaturePart">
- <string>label every part of multi-part features</string>
- </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
</widget>
</item>
- <widget class="QCheckBox" name="chkMergeLines">
- <string>merge connected lines to avoid duplicate labels</string>
- </property>
- </widget>
- </item>
- <item row="6" column="0">
- <widget class="QCheckBox" name="chkMultiLine">
- <string>multiline labels</string>
- </property>
- </widget>
- </item>
- <item row="8" column="0">
- <layout class="QHBoxLayout" name="horizontalLayout_19">
- <item>
- <widget class="QLabel" name="label_19">
- <string>Suppress labeling of features smaller than</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QDoubleSpinBox" name="mMinSizeSpinBox">
- </property>
- </widget>
- </item>
- </layout>
- </item>
- <item row="9" column="0">
- <layout class="QHBoxLayout" name="horizontalLayout_20">
- <item>
- <widget class="QCheckBox" name="chkNoObstacle">
- <bool>true</bool>
- </property>
- <string>features don't act as obstacles for labels</string>
- </property>
- </widget>
- </item>
- <item>
- <spacer name="horizontalSpacer_8">
- </property>
- <size>
- <width>40</width>
- </size>
- </property>
- </spacer>
- </item>
- <item>
- <widget class="QPushButton" name="btnEngineSettings">
- <bool>true</bool>
- </property>
- <string>Engine settings</string>
- </property>
- </widget>
- </item>
- </layout>
- </item>
- <item row="7" column="0">
- <widget class="QCheckBox" name="chkAddDirectionSymbol">
- <string>add direction symbol</string>
- </property>
- </widget>
- </item>
</layout>
</widget>
- <widget class="QWidget" name="tab_4">
- <attribute name="title">
- <string>Data defined settings</string>
- </attribute>
- <layout class="QGridLayout" name="gridLayout_3">
- <widget class="QGroupBox" name="mFontAttributePropertiesGroupBox">
- </sizepolicy>
- </property>
- <string>Font properties</string>
- </property>
- <layout class="QGridLayout" name="gridLayout">
- <widget class="QLabel" name="mSizeLabel">
- </property>
- </widget>
- </item>
- <widget class="QComboBox" name="mSizeAttributeComboBox"/>
- </item>
- <widget class="QLabel" name="mColorLabel">
- </property>
- </widget>
- </item>
- <widget class="QComboBox" name="mColorAttributeComboBox"/>
- </item>
- <widget class="QLabel" name="mBoldLabel">
- <string>Bold</string>
- </property>
- </widget>
- </item>
- <widget class="QComboBox" name="mBoldAttributeComboBox"/>
- </item>
- <widget class="QLabel" name="mItalicLabel">
- <string>Italic</string>
- </property>
- </widget>
- </item>
- <widget class="QComboBox" name="mItalicAttributeComboBox"/>
- </item>
- <widget class="QLabel" name="mUnderlineLabel">
- <string>Underline</string>
- </property>
- </widget>
- </item>
- <item row="4" column="1">
- <widget class="QComboBox" name="mUnderlineAttributeComboBox"/>
- </item>
- <widget class="QLabel" name="mStrikeoutLabel">
- <string>Strikeout</string>
- </property>
- </widget>
- </item>
- <widget class="QComboBox" name="mStrikeoutAttributeComboBox"/>
- </item>
- <widget class="QLabel" name="mFontFamilyLabel">
- <string>Font family</string>
- </property>
- </widget>
- </item>
- <item row="6" column="1">
- <widget class="QComboBox" name="mFontFamilyAttributeComboBox"/>
- </item>
- </layout>
- </widget>
- </item>
- <widget class="QGroupBox" name="mBufferAttributesPropertiesGroupBox">
- <string>Buffer properties</string>
- </property>
- <layout class="QGridLayout" name="gridLayout_2">
- <widget class="QLabel" name="mBufferSizeLabel">
- <string>Buffer size</string>
- </property>
- </widget>
- </item>
- <widget class="QComboBox" name="mBufferSizeAttributeComboBox"/>
- </item>
- <widget class="QLabel" name="mBufferColorLabel">
- <string>Buffer color</string>
- </property>
- </widget>
- </item>
- <widget class="QComboBox" name="mBufferColorAttributeComboBox"/>
- </item>
- </layout>
- </widget>
- </item>
- <widget class="QGroupBox" name="mPositionAttributeGroupBox">
- <string>Position</string>
- </property>
- <layout class="QGridLayout" name="gridLayout_4">
- <widget class="QLabel" name="mXCoordinateLabel">
- <string>X Coordinate</string>
- </property>
- </widget>
- </item>
- <widget class="QComboBox" name="mXCoordinateComboBox"/>
- </item>
- <widget class="QLabel" name="mYCoordinateLabel">
- <string>Y Coordinate</string>
- </property>
- </widget>
- </item>
- <widget class="QComboBox" name="mYCoordinateComboBox"/>
- </item>
- <widget class="QLabel" name="mHorizontalAlignmentLabel">
- <string>Horizontal alignment</string>
- </property>
- </widget>
- </item>
- <widget class="QComboBox" name="mHorizontalAlignmentComboBox"/>
- </item>
- <widget class="QLabel" name="mVerticalAlignmentLabel">
- <string>Vertical alignment</string>
- </property>
- </widget>
- </item>
- <widget class="QComboBox" name="mVerticalAlignmentComboBox"/>
- </item>
- <widget class="QComboBox" name="mRotationComboBox"/>
- </item>
- <widget class="QLabel" name="mRotationLabel">
- </property>
- </widget>
- </item>
- <widget class="QComboBox" name="mLabelDistanceComboBox"/>
- </item>
- <widget class="QLabel" name="mLabelDistanceLabel">
- </property>
- </widget>
- </item>
- </layout>
- </widget>
- </item>
- <spacer name="verticalSpacer">
- </property>
- <size>
- <width>20</width>
- <height>521</height>
- </size>
- </property>
- </spacer>
- </item>
- </layout>
- </widget>
</widget>
</item>
<widget class="QDialogButtonBox" name="buttonBox">
