[QGIS Commit] r14660 - trunk/qgis/src/plugins/grass
svn_qgis at osgeo.org
Sun Nov 14 16:41:55 EST 2010
Author: brushtyler
Date: 2010-11-14 13:41:55 -0800 (Sun, 14 Nov 2010)
New Revision: 14660
trunk/qgis/src/plugins/grass/qgsgrassplugin.cpp
trunk/qgis/src/plugins/grass/qgsgrassregion.cpp
trunk/qgis/src/plugins/grass/qgsgrassregion.h
trunk/qgis/src/plugins/grass/qgsgrassregionbase.ui
cleaned the "select region" GUI for GRASS,
fixed validation of input
Modified: trunk/qgis/src/plugins/grass/qgsgrassplugin.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassplugin.cpp 2010-11-14 21:33:34 UTC (rev 14659)
+++ trunk/qgis/src/plugins/grass/qgsgrassplugin.cpp 2010-11-14 21:41:55 UTC (rev 14660)
@@ -651,7 +651,7 @@
// Warning: don't use Qt::WType_Dialog, it would ignore restorePosition
- mRegion = new QgsGrassRegion( this, qGisInterface, qGisInterface->mainWindow(), Qt::Window );
+ mRegion = new QgsGrassRegion( this, qGisInterface, qGisInterface->mainWindow() );
connect( mRegion, SIGNAL( destroyed( QObject * ) ), this, SLOT( regionClosed() ) );
Modified: trunk/qgis/src/plugins/grass/qgsgrassregion.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassregion.cpp 2010-11-14 21:33:34 UTC (rev 14659)
+++ trunk/qgis/src/plugins/grass/qgsgrassregion.cpp 2010-11-14 21:41:55 UTC (rev 14660)
@@ -33,84 +33,78 @@
/** map tool which uses rubber band for changing grass region */
-class QgsGrassRegionEdit : public QgsMapTool
+QgsGrassRegionEdit::QgsGrassRegionEdit( QgsMapCanvas* canvas )
+ : QgsMapTool( canvas )
- public:
- QgsGrassRegionEdit( QgsGrassRegion* reg )
- : QgsMapTool( reg->mCanvas ), mRegion( reg )
- mDraw = false;
- mRubberBand = new QRubberBand( QRubberBand::Rectangle, mCanvas );
+ mDraw = false;
+ mRubberBand = new QgsRubberBand( mCanvas, true );
- ~QgsGrassRegionEdit()
- delete mRubberBand;
+QgsGrassRegionEdit::~QgsGrassRegionEdit()
+ delete mRubberBand;
- //! mouse click in map canvas
- void canvasPressEvent( QMouseEvent * event )
- QgsPoint point = toMapCoordinates( event->pos() );
- double x = point.x();
- double y = point.y();
+//! mouse pressed in map canvas
+void QgsGrassRegionEdit::canvasPressEvent( QMouseEvent * event )
+ QgsDebugMsg( "entered." );
+ mDraw = true;
+ mRubberBand->reset( true );
+ emit captureStarted();
- QgsDebugMsg( "entered." );
+ mStartPoint = toMapCoordinates( event->pos() );
+ mEndPoint = mStartPoint;
+ setRegion( mStartPoint, mEndPoint );
- if ( !mDraw ) // first corner
- mRegion->mX = x;
- mRegion->mY = y;
+//! mouse movement in map canvas
+void QgsGrassRegionEdit::canvasMoveEvent( QMouseEvent * event )
+ if ( !mDraw ) return;
- mRegion->draw( x, y, x, y );
- mDraw = true;
- else
- mRegion->draw( mRegion->mX, mRegion->mY, x, y );
- mDraw = false;
- mRubberBand->show();
+ mEndPoint = toMapCoordinates( event->pos() );
- //! mouse movement in map canvas
- void canvasMoveEvent( QMouseEvent * event )
+//! mouse button released
+void QgsGrassRegionEdit::canvasReleaseEvent( QMouseEvent * event )
+ mDraw = false;
+ emit captureEnded();
- if ( !mDraw ) return;
- mRegion->draw( mRegion->mX, mRegion->mY, point.x(), point.y() );
+//! called when map tool is about to get inactive
+void QgsGrassRegionEdit::deactivate()
+ QgsMapTool::deactivate();
- //! called when map tool is about to get inactive
- void deactivate()
- mRubberBand->hide();
+void QgsGrassRegionEdit::setRegion( const QgsPoint& ul, const QgsPoint& lr )
+ mStartPoint = ul;
+ mEndPoint = lr;
- QgsMapTool::deactivate();
+ mRubberBand->addPoint( ul, false );
+ mRubberBand->addPoint( QgsPoint( ul.x(), lr.y() ), false );
+ mRubberBand->addPoint( lr, false );
+ mRubberBand->addPoint( QgsPoint( lr.x(), ul.y() ), true ); // true to update canvas
- void setRegion( const QgsPoint& ul, const QgsPoint& lr )
- QPoint qul = toCanvasCoordinates( ul );
- QPoint qlr = toCanvasCoordinates( lr );
- mRubberBand->setGeometry( QRect( qul, qlr ) );
+ mRubberBand->show();
+QgsRectangle QgsGrassRegionEdit::getRegion()
+ return QgsRectangle( mStartPoint, mEndPoint );
- private:
- //! Rubber band for selecting grass region
- QRubberBand* mRubberBand;
- //! Status of input from canvas
- bool mDraw;
- QgsGrassRegion* mRegion;
QgsGrassRegion::QgsGrassRegion( QgsGrassPlugin *plugin, QgisInterface *iface,
QWidget * parent, Qt::WFlags f )
: QDialog( parent, f ), QgsGrassRegionBase( )
@@ -118,13 +112,16 @@
QgsDebugMsg( "QgsGrassRegion()" );
setupUi( this );
+ setAttribute( Qt::WA_DeleteOnClose );
+ connect( buttonBox, SIGNAL( accepted() ), this, SLOT( accept() ) );
+ connect( buttonBox, SIGNAL( rejected() ), this, SLOT( reject() ) );
mPlugin = plugin;
mInterface = iface;
mCanvas = mInterface->mapCanvas();
restorePosition();
mUpdatingGui = false;
- mDisplayed = false;
// Set input validators
QDoubleValidator *dv = new QDoubleValidator( 0 );
@@ -140,19 +137,14 @@
mCols->setValidator( iv );
// Group radio buttons
- mNSRadioGroup = new QButtonGroup();
- mEWRadioGroup = new QButtonGroup();
- mNSRadioGroup->addButton( mNSResRadio );
- mNSRadioGroup->addButton( mRowsRadio );
- mEWRadioGroup->addButton( mEWResRadio );
- mEWRadioGroup->addButton( mColsRadio );
- mNSResRadio->setChecked( true );
- mEWResRadio->setChecked( true );
- mRows->setEnabled( false );
- mCols->setEnabled( false );
- connect( mNSRadioGroup, SIGNAL( clicked( int ) ), this, SLOT( radioChanged() ) );
- connect( mEWRadioGroup, SIGNAL( clicked( int ) ), this, SLOT( radioChanged() ) );
+ mRadioGroup = new QButtonGroup();
+ mRadioGroup->addButton( mCellResRadio );
+ mRadioGroup->addButton( mRowsColsRadio );
+ mCellResRadio->setChecked( true );
+ radioChanged();
+ connect( mRadioGroup, SIGNAL( buttonClicked( int ) ), this, SLOT( radioChanged() ) );
// Set values to current region
QString gisdbase = QgsGrass::getDefaultGisdbase();
QString location = QgsGrass::getDefaultLocation();
@@ -169,23 +161,28 @@
if ( err )
- QMessageBox::warning( 0, tr( "Warning" ), tr( "Cannot read current region: %1" ).arg( err ) );
+ QMessageBox::warning( 0, tr( "Warning" ), tr( "Cannot read current region: %1" ).arg( QString::fromUtf8( err ) ) );
return;
- setGuiValues();
+ mRegionEdit = new QgsGrassRegionEdit( mCanvas );
+ connect( mRegionEdit, SIGNAL( captureStarted() ), this, SLOT( hide() ) );
+ connect( mRegionEdit, SIGNAL( captureEnded() ), this, SLOT( onCaptureFinished() ) );
+ mCanvas->setMapTool( mRegionEdit );
+ refreshGui();
connect( mCanvas, SIGNAL( renderComplete( QPainter * ) ), this, SLOT( postRender( QPainter * ) ) );
// Connect entries
- connect( mNorth, SIGNAL( textChanged( const QString & ) ), this, SLOT( northChanged( const QString & ) ) );
- connect( mSouth, SIGNAL( textChanged( const QString & ) ), this, SLOT( southChanged( const QString & ) ) );
- connect( mEast, SIGNAL( textChanged( const QString & ) ), this, SLOT( eastChanged( const QString & ) ) );
- connect( mWest, SIGNAL( textChanged( const QString & ) ), this, SLOT( westChanged( const QString & ) ) );
- connect( mNSRes, SIGNAL( textChanged( const QString & ) ), this, SLOT( NSResChanged( const QString & ) ) );
- connect( mEWRes, SIGNAL( textChanged( const QString & ) ), this, SLOT( EWResChanged( const QString & ) ) );
- connect( mRows, SIGNAL( textChanged( const QString & ) ), this, SLOT( rowsChanged( const QString & ) ) );
- connect( mCols, SIGNAL( textChanged( const QString & ) ), this, SLOT( colsChanged( const QString & ) ) );
+ connect( mNorth, SIGNAL( editingFinished() ), this, SLOT( northChanged() ) );
+ connect( mSouth, SIGNAL( editingFinished() ), this, SLOT( southChanged() ) );
+ connect( mEast, SIGNAL( editingFinished() ), this, SLOT( eastChanged() ) );
+ connect( mWest, SIGNAL( editingFinished() ), this, SLOT( westChanged() ) );
+ connect( mNSRes, SIGNAL( editingFinished() ), this, SLOT( NSResChanged() ) );
+ connect( mEWRes, SIGNAL( editingFinished() ), this, SLOT( EWResChanged() ) );
+ connect( mRows, SIGNAL( editingFinished() ), this, SLOT( rowsChanged() ) );
+ connect( mCols, SIGNAL( editingFinished() ), this, SLOT( colsChanged() ) );
// Symbology
QPen pen = mPlugin->regionPen();
@@ -194,12 +191,6 @@
mWidthSpinBox->setValue( pen.width() );
connect( mWidthSpinBox, SIGNAL( valueChanged( int ) ), this, SLOT( changeWidth() ) );
- mRegionEdit = new QgsGrassRegionEdit( this ); // will be deleted by map canvas
- mCanvas->setMapTool( mRegionEdit );
- setAttribute( Qt::WA_DeleteOnClose );
- displayRegion();
void QgsGrassRegion::changeColor( void )
@@ -233,22 +224,25 @@
return QString( "%1" ).arg( v, 0, 'g' );
-void QgsGrassRegion::setGuiValues( bool north, bool south, bool east, bool west,
- bool nsres, bool ewres, bool rows, bool cols )
+void QgsGrassRegion::refreshGui()
+ if ( mUpdatingGui )
+ return;
mUpdatingGui = true;
- if ( north ) mNorth->setText( QString( "%1" ).arg( mWindow.north, 0, 'g', 15 ) );
- if ( south ) mSouth->setText( QString( "%1" ).arg( mWindow.south, 0, 'g', 15 ) );
- if ( east ) mEast->setText( QString( "%1" ).arg( mWindow.east, 0, 'g', 15 ) );
- if ( west ) mWest->setText( QString( "%1" ).arg( mWindow.west, 0, 'g', 15 ) );
- if ( nsres ) mNSRes->setText( QString( "%1" ).arg( mWindow.ns_res, 0, 'g' ) );
- if ( ewres ) mEWRes->setText( QString( "%1" ).arg( mWindow.ew_res, 0, 'g' ) );
- if ( rows ) mRows->setText( QString( "%1" ).arg( mWindow.rows ) );
- if ( cols ) mCols->setText( QString( "%1" ).arg( mWindow.cols ) );
+ mNorth->setText( QString( "%1" ).arg( mWindow.north, 0, 'g', 15 ) );
+ mSouth->setText( QString( "%1" ).arg( mWindow.south, 0, 'g', 15 ) );
+ mEast->setText( QString( "%1" ).arg( mWindow.east, 0, 'g', 15 ) );
+ mWest->setText( QString( "%1" ).arg( mWindow.west, 0, 'g', 15 ) );
+ mNSRes->setText( QString( "%1" ).arg( mWindow.ns_res, 0, 'g' ) );
+ mEWRes->setText( QString( "%1" ).arg( mWindow.ew_res, 0, 'g' ) );
+ mRows->setText( QString( "%1" ).arg( mWindow.rows ) );
+ mCols->setText( QString( "%1" ).arg( mWindow.cols ) );
+ displayRegion();
@@ -257,162 +251,155 @@
delete mRegionEdit;
-void QgsGrassRegion::northChanged( const QString &str )
+void QgsGrassRegion::northChanged()
if ( mUpdatingGui ) return;
mWindow.north = mNorth->text().toDouble();
+ if ( mWindow.north < mWindow.south )
+ mWindow.north = mWindow.south;
adjust();
- setGuiValues( false );
- displayRegion();
+ refreshGui();
-void QgsGrassRegion::southChanged( const QString &str )
+void QgsGrassRegion::southChanged()
mWindow.south = mSouth->text().toDouble();
+ if ( mWindow.south > mWindow.north )
+ mWindow.south = mWindow.north;
adjust();
- setGuiValues( true, false );
- displayRegion();
+ refreshGui();
-void QgsGrassRegion::eastChanged( const QString &str )
+void QgsGrassRegion::eastChanged()
mWindow.east = mEast->text().toDouble();
+ if ( mWindow.east < mWindow.west )
+ mWindow.east = mWindow.west;
adjust();
- setGuiValues( true, true, false );
- displayRegion();
+ refreshGui();
-void QgsGrassRegion::westChanged( const QString &str )
+void QgsGrassRegion::westChanged()
mWindow.west = mWest->text().toDouble();
+ if ( mWindow.west > mWindow.east )
+ mWindow.west = mWindow.east;
adjust();
- setGuiValues( true, true, true, false );
- displayRegion();
+ refreshGui();
-void QgsGrassRegion::NSResChanged( const QString &str )
+void QgsGrassRegion::NSResChanged()
mWindow.ns_res = mNSRes->text().toDouble();
+ if ( mWindow.ns_res <= 0)
+ mWindow.ns_res = 1;
adjust();
- setGuiValues( true, true, true, true, false );
- displayRegion();
+ refreshGui();
-void QgsGrassRegion::EWResChanged( const QString &str )
+void QgsGrassRegion::EWResChanged()
mWindow.ew_res = mEWRes->text().toDouble();
+ if ( mWindow.ew_res <= 0)
+ mWindow.ew_res = 1;
adjust();
- setGuiValues( true, true, true, true, true, false );
- displayRegion();
+ refreshGui();
-void QgsGrassRegion::rowsChanged( const QString &str )
+void QgsGrassRegion::rowsChanged()
mWindow.rows = mRows->text().toInt();
+ if ( mWindow.rows < 1)
+ mWindow.rows = 1;
adjust();
- setGuiValues( true, true, true, true, true, true, false );
- displayRegion();
+ refreshGui();
-void QgsGrassRegion::colsChanged( const QString &str )
+void QgsGrassRegion::colsChanged()
mWindow.cols = mCols->text().toInt();
+ if ( mWindow.cols < 1)
+ mWindow.cols = 1;
adjust();
- setGuiValues( true, true, true, true, true, true, true, false );
- displayRegion();
+ refreshGui();
void QgsGrassRegion::adjust()
- int r, c;
- if ( mRowsRadio->isChecked() ) r = 1; else r = 0;
- if ( mColsRadio->isChecked() ) c = 1; else c = 0;
- G_adjust_Cell_head( &mWindow, r, c );
+ int rc = 0;
+ if ( mRowsColsRadio->isChecked() )
+ rc = 1;
+ G_adjust_Cell_head( &mWindow, rc, rc );
void QgsGrassRegion::radioChanged()
mNSRes->setEnabled( false );
- mRows->setEnabled( true );
- else
- mNSRes->setEnabled( true );
mEWRes->setEnabled( false );
+ mRows->setEnabled( true );
mCols->setEnabled( true );
else
+ mNSRes->setEnabled( true );
mEWRes->setEnabled( true );
+ mRows->setEnabled( false );
-void QgsGrassRegion::draw( double x1, double y1, double x2, double y2 )
+void QgsGrassRegion::onCaptureFinished()
+ QgsRectangle rect = mRegionEdit->getRegion();
- if ( x1 < x2 )
- mWindow.west = x1;
- mWindow.east = x2;
- else
- mWindow.west = x2;
- mWindow.east = x1;
- if ( y1 < y2 )
- mWindow.south = y1;
- mWindow.north = y2;
- else
- mWindow.south = y2;
- mWindow.north = y1;
+ mWindow.west = rect.xMinimum();
+ mWindow.east = rect.xMaximum();
+ mWindow.south = rect.yMinimum();
+ mWindow.north = rect.yMaximum();
adjust();
- setGuiValues();
- displayRegion();
+ refreshGui();
+ show();
void QgsGrassRegion::displayRegion()
QgsPoint ul( mWindow.west, mWindow.north );
QgsPoint lr( mWindow.east, mWindow.south );
mRegionEdit->setRegion( ul, lr );
- mDisplayed = true;
-void QgsGrassRegion::postRender( QPainter *painter )
- displayRegion();
void QgsGrassRegion::accept()
// TODO: better repaint region
@@ -441,14 +428,14 @@
saveWindowLocation();
mCanvas->setMapTool( NULL );
- delete this;
+ QDialog::accept();
void QgsGrassRegion::reject()
- delete this;
+ QDialog::reject();
void QgsGrassRegion::restorePosition()
Modified: trunk/qgis/src/plugins/grass/qgsgrassregion.h
--- trunk/qgis/src/plugins/grass/qgsgrassregion.h 2010-11-14 21:33:34 UTC (rev 14659)
+++ trunk/qgis/src/plugins/grass/qgsgrassregion.h 2010-11-14 21:41:55 UTC (rev 14660)
@@ -17,13 +17,16 @@
#define QGSGRASSREGION_H
#include "ui_qgsgrassregionbase.h"
+#include "qgsmaptool.h"
+#include "qgsrubberband.h"
+#include "qgspoint.h"
class QgsGrassPlugin;
class QgsGrassRegionEdit;
class QgisInterface;
class QgsMapCanvas;
-//class QgsPoint;
+class QgsRectangle;
class QButtonGroup;
@@ -50,16 +53,11 @@
public slots:
//! OK
- void on_acceptButton_clicked() { accept(); }
void accept( void );
- //! Close
- void on_rejectButton_clicked() { reject(); }
+ //! Cancel
void reject( void );
- //! Called when rendering is finished
- void postRender( QPainter * );
//! Mouse event receiver
//void mouseEventReceiverMove ( QgsPoint & );
@@ -70,14 +68,14 @@
void adjust( void );
//! Value in GUI was changed
- void northChanged( const QString &str );
- void southChanged( const QString &str );
- void eastChanged( const QString &str );
- void westChanged( const QString &str );
- void NSResChanged( const QString &str );
- void EWResChanged( const QString &str );
- void rowsChanged( const QString &str );
- void colsChanged( const QString &str );
+ void northChanged();
+ void southChanged();
+ void eastChanged();
+ void westChanged();
+ void NSResChanged();
+ void EWResChanged();
+ void rowsChanged();
+ void colsChanged();
void radioChanged( void ) ;
@@ -86,6 +84,9 @@
void restorePosition( void );
+ //! Called when the capture finished to refresh the mWindow values
+ void onCaptureFinished();
private:
//! Pointer to plugin
QgsGrassPlugin *mPlugin;
@@ -96,8 +97,7 @@
//! Pointer to canvas
QgsMapCanvas *mCanvas;
- QButtonGroup *mNSRadioGroup;
- QButtonGroup *mEWRadioGroup;
+ QButtonGroup *mRadioGroup;
//! Current new region
struct Cell_head mWindow;
@@ -105,12 +105,9 @@
//! Display current state of new region in XOR mode
void displayRegion( void );
- //! Region was displayed
- bool mDisplayed;
+ // Set region values in GUI from mWindow
+ void refreshGui();
- //! Draw region
- void draw( double x1, double y1, double x2, double y2 );
//! First corner coordinates
double mX;
double mY;
@@ -118,19 +115,61 @@
//! Currently updating GUI, don't run *Changed methods
bool mUpdatingGui;
- // Set region values in GUI from mWindow
- void setGuiValues( bool north = true, bool south = true, bool east = true, bool west = true,
- bool nsres = true, bool ewres = true, bool rows = true, bool cols = true );
void saveWindowLocation( void );
// Format N, S, E, W value
QString formatEdge( double v );
QgsGrassRegionEdit* mRegionEdit;
- friend class QgsGrassRegionEdit;
+/** map tool which uses rubber band for changing grass region */
+class QgsGrassRegionEdit : public QgsMapTool
+ Q_OBJECT
+ public:
+ QgsGrassRegionEdit( QgsMapCanvas* );
+ ~QgsGrassRegionEdit();
+ //! mouse pressed in map canvas
+ void canvasPressEvent( QMouseEvent * );
+ //! mouse movement in map canvas
+ void canvasMoveEvent( QMouseEvent * );
+ //! mouse released
+ void canvasReleaseEvent( QMouseEvent * );
+ //! called when map tool is about to get inactive
+ void deactivate();
+ //! get the rectangle
+ QgsRectangle getRegion();
+ //! refresh the rectangle displayed in canvas
+ void setRegion( const QgsPoint&, const QgsPoint& );
+ signals:
+ void captureStarted();
+ void captureEnded();
+ private:
+ //! Rubber band for selecting grass region
+ QgsRubberBand* mRubberBand;
+ //! Status of input from canvas
+ bool mDraw;
+ //! First rectangle point
+ QgsPoint mStartPoint;
+ //! Last rectangle point
+ QgsPoint mEndPoint;
#endif // QGSGRASSREGION_H
Modified: trunk/qgis/src/plugins/grass/qgsgrassregionbase.ui
--- trunk/qgis/src/plugins/grass/qgsgrassregionbase.ui 2010-11-14 21:33:34 UTC (rev 14659)
+++ trunk/qgis/src/plugins/grass/qgsgrassregionbase.ui 2010-11-14 21:41:55 UTC (rev 14660)
@@ -1,448 +1,204 @@
-<ui version="4.0" >
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
<class>QgsGrassRegionBase</class>
- <widget class="QDialog" name="QgsGrassRegionBase" >
- <property name="geometry" >
+ <widget class="QDialog" name="QgsGrassRegionBase">
+ <property name="geometry">
<rect>
<x>0</x>
<y>0</y>
- <width>420</width>
- <height>297</height>
+ <width>445</width>
+ <height>348</height>
</rect>
</property>
- <property name="windowTitle" >
+ <property name="windowTitle">
<string>GRASS Region Settings</string>
</property>
- <layout class="QGridLayout" >
- <property name="leftMargin" >
- <number>2</number>
- </property>
- <property name="topMargin" >
- </property>
- <property name="rightMargin" >
- </property>
- <property name="bottomMargin" >
- </property>
- <property name="horizontalSpacing" >
- </property>
- <property name="verticalSpacing" >
- </property>
- <item row="0" column="0" >
- <widget class="QFrame" name="frame4" >
- <property name="sizePolicy" >
- <sizepolicy vsizetype="Minimum" hsizetype="Expanding" >
- <horstretch>0</horstretch>
- <verstretch>0</verstretch>
- </sizepolicy>
+ <layout class="QGridLayout" name="gridLayout_4">
+ <item row="0" column="0">
+ <widget class="QGroupBox" name="groupBox">
+ <property name="title">
+ <string>Extent</string>
</property>
- <property name="minimumSize" >
- <size>
- <width>0</width>
- <height>35</height>
- </size>
- </property>
- <property name="maximumSize" >
- <size>
- <width>32767</width>
- </size>
- </property>
- <property name="frameShape" >
- <enum>QFrame::StyledPanel</enum>
- </property>
- <property name="frameShadow" >
- <enum>QFrame::Raised</enum>
- </property>
- <layout class="QHBoxLayout" >
- <number>6</number>
- </property>
- </property>
- </property>
- </property>
- <item>
- <spacer>
- <property name="orientation" >
- <enum>Qt::Horizontal</enum>
+ <layout class="QGridLayout" name="gridLayout">
+ <item row="0" column="2">
+ <widget class="QLabel" name="textLabel1">
+ <property name="sizePolicy">
+ <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
</property>
- <property name="sizeType" >
- <enum>QSizePolicy::Expanding</enum>
+ <property name="text">
+ <string>North</string>
</property>
- <property name="sizeHint" >
- <size>
- <width>72</width>
- <height>16</height>
- </size>
- </property>
- </spacer>
- </item>
- <item>
- <widget class="QLabel" name="textLabel1" >
- <property name="text" >
- <string>N</string>
- </property>
</widget>
</item>
- <item>
- <widget class="QLineEdit" name="mNorth" />
- </item>
- <item>
- <spacer>
+ <item row="1" column="0">
+ <widget class="QLabel" name="textLabel2">
+ </sizepolicy>
</property>
- </property>
- <size>
- <width>71</width>
- <height>21</height>
- </size>
- </property>
- </spacer>
- </item>
- </layout>
- </widget>
- </item>
- <item row="1" column="0" >
- <widget class="QFrame" name="frame19" >
- </sizepolicy>
- </property>
- <size>
- <width>0</width>
- </size>
- </property>
- <size>
- </size>
- </property>
- </property>
- </property>
- <property name="spacing" >
- </property>
- </property>
- </property>
- </property>
- </property>
- <item>
- <widget class="QLabel" name="textLabel2" >
+ <property name="frameShape">
<enum>QFrame::NoFrame</enum>
</property>
+ <property name="frameShadow">
<enum>QFrame::Plain</enum>
</property>
- <string>W</string>
+ <string>West</string>
</property>
</widget>
</item>
- <item>
- <widget class="QLineEdit" name="mWest" />
+ <item row="1" column="1" colspan="2">
+ <widget class="QLineEdit" name="mWest"/>
</item>
- <item>
- <spacer>
+ <item row="1" column="4">
+ <widget class="QLabel" name="textLabel3">
+ </sizepolicy>
</property>
+ <string>East</string>
</property>
- <size>
- <width>51</width>
- <height>26</height>
- </size>
- </property>
- </spacer>
- </item>
- <item>
- <widget class="QLabel" name="textLabel3" >
- <string>E</string>
- </property>
</widget>
</item>
- <item>
- <widget class="QLineEdit" name="mEast" />
+ <item row="1" column="5">
+ <widget class="QLineEdit" name="mEast"/>
</item>
- </layout>
- </widget>
- </item>
- <item row="2" column="0" >
- <widget class="QFrame" name="frame20" >
- </sizepolicy>
- </property>
- <size>
- <width>0</width>
- </size>
- </property>
- <size>
- </size>
- </property>
- </property>
- </property>
- </property>
- </property>
- </property>
- </property>
- </property>
- <item>
- <spacer>
+ <item row="2" column="2">
+ <widget class="QLabel" name="textLabel4">
+ </sizepolicy>
</property>
+ <string>South</string>
</property>
- <size>
- <width>73</width>
- </size>
- </property>
- </spacer>
- </item>
- <item>
- <widget class="QLabel" name="textLabel4" >
- <string>S</string>
- </property>
</widget>
</item>
- <item>
- <widget class="QLineEdit" name="mSouth" />
+ <item row="2" column="3" colspan="2">
+ <widget class="QLineEdit" name="mSouth"/>
</item>
- <item>
- <spacer>
- </property>
- </property>
- <size>
- <width>57</width>
- <height>23</height>
- </size>
- </property>
- </spacer>
+ <item row="0" column="3" colspan="2">
+ <widget class="QLineEdit" name="mNorth"/>
</item>
</layout>
</widget>
</item>
- <item row="3" column="0" >
- <widget class="QFrame" name="frame5" >
+ <widget class="QGroupBox" name="groupBox_2">
+ <string>Resolution</string>
</property>
- </property>
- </property>
- </property>
- </property>
- </property>
- <widget class="QRadioButton" name="mNSResRadio" >
- <string>N-S Res</string>
+ <layout class="QGridLayout" name="gridLayout_2">
+ <widget class="QRadioButton" name="mCellResRadio">
+ <string>Cell width</string>
</property>
- <property name="checked" >
- <bool>false</bool>
+ <property name="checked">
+ <bool>true</bool>
</property>
</widget>
</item>
- <item row="0" column="1" >
- <widget class="QLineEdit" name="mNSRes" />
+ <item row="0" column="1">
+ <widget class="QLineEdit" name="mEWRes"/>
</item>
- <item row="0" column="2" >
- <widget class="QRadioButton" name="mRowsRadio" >
- <string>Rows</string>
+ <widget class="QLabel" name="label_2">
+ <string>Cell height</string>
</property>
+ <property name="indent">
+ <number>20</number>
+ </property>
</widget>
</item>
- <item row="0" column="3" >
- <widget class="QLineEdit" name="mRows" />
+ <item row="0" column="3">
+ <widget class="QLineEdit" name="mNSRes"/>
</item>
- <item row="1" column="2" >
- <widget class="QRadioButton" name="mColsRadio" >
- <string>Cols</string>
+ <widget class="QRadioButton" name="mRowsColsRadio">
+ <string>Columns</string>
</property>
</widget>
</item>
- <item row="1" column="1" >
- <widget class="QLineEdit" name="mEWRes" />
+ <item row="1" column="1">
+ <widget class="QLineEdit" name="mCols"/>
</item>
- <item row="1" column="3" >
- <widget class="QLineEdit" name="mCols" />
- </item>
- <widget class="QRadioButton" name="mEWResRadio" >
- <string>E-W Res</string>
+ <item row="1" column="2">
+ <widget class="QLabel" name="label">
+ <string>Rows</string>
</property>
- <bool>true</bool>
</property>
</widget>
</item>
+ <item row="1" column="3">
+ <widget class="QLineEdit" name="mRows"/>
+ </item>
</layout>
</widget>
</item>
- <item row="4" column="0" >
- <widget class="QFrame" name="frame6" >
- </sizepolicy>
+ <item row="2" column="0">
+ <widget class="QGroupBox" name="groupBox_3">
+ <string>Border</string>
</property>
- <size>
- <width>0</width>
- </size>
- </property>
- <size>
- </size>
- </property>
- </property>
- </property>
- <number>3</number>
- </property>
- </property>
- </property>
- </property>
- </property>
- <item>
- <widget class="QLabel" name="textLabel7" >
+ <layout class="QGridLayout" name="gridLayout_3">
+ <widget class="QLabel" name="textLabel7">
<string>Color</string>
</property>
</widget>
</item>
- <item>
- <widget class="QgsColorButton" native="1" name="mColorButton" >
+ <widget class="QgsColorButton" name="mColorButton" native="true">
+ <property name="minimumSize">
<size>
<width>35</width>
<height>25</height>
</size>
</property>
- <property name="text" stdset="0" >
+ <property name="text" stdset="0">
<string/>
</property>
</widget>
</item>
- <item>
- <widget class="QLabel" name="textLabel6" >
+ <widget class="QLabel" name="textLabel6">
<string>Width</string>
</property>
+ </property>
</widget>
</item>
- <item>
- <widget class="QSpinBox" name="mWidthSpinBox" />
+ <widget class="QSpinBox" name="mWidthSpinBox"/>
</item>
- <item>
- <spacer>
+ <item row="0" column="4">
+ <spacer name="horizontalSpacer">
+ <property name="orientation">
</property>
- </property>
+ <property name="sizeHint" stdset="0">
<size>
- <width>69</width>
- <height>24</height>
+ <width>40</width>
+ <height>20</height>
</size>
</property>
</spacer>
@@ -450,116 +206,18 @@
</layout>
</widget>
</item>
- <item row="5" column="0" >
- <widget class="QFrame" name="frame8" >
- </sizepolicy>
+ <item row="3" column="0">
+ <widget class="QDialogButtonBox" name="buttonBox">
+ <enum>Qt::Horizontal</enum>
</property>
- <size>
- <width>0</width>
- <height>38</height>
- </size>
+ <property name="standardButtons">
+ <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
</property>
- <size>
- </size>
- </property>
- </property>
- </property>
- </property>
- </property>
- </property>
- </property>
- </property>
- <item>
- <spacer>
- </property>
- </property>
- <size>
- <width>45</width>
- </size>
- </property>
- </spacer>
- </item>
- <item>
- <widget class="QPushButton" name="acceptButton" >
- <string>OK</string>
- </property>
- </widget>
- </item>
- <item>
- <spacer>
- </property>
- </property>
- <size>
- <width>47</width>
- <height>25</height>
- </size>
- </property>
- </spacer>
- </item>
- <item>
- <widget class="QPushButton" name="rejectButton" >
- <string>Cancel</string>
- </property>
- </widget>
- </item>
- <item>
- <spacer>
- </property>
- </property>
- <size>
- <width>54</width>
- </size>
- </property>
- </spacer>
- </item>
- </layout>
</widget>
</item>
</layout>
</widget>
- <layoutdefault spacing="6" margin="11" />
<customwidgets>
<customwidget>
<class>QgsColorButton</class>
