[QGIS Commit] r14667 - trunk/qgis/src/ui
svn_qgis at osgeo.org
Sun Nov 14 17:45:20 EST 2010
Author: timlinux
Date: 2010-11-14 14:45:20 -0800 (Sun, 14 Nov 2010)
New Revision: 14667
trunk/qgis/src/ui/qgscontinuouscolordialogbase.ui
trunk/qgis/src/ui/qgssinglesymboldialogbase.ui
Small ui tidy ups
Modified: trunk/qgis/src/ui/qgscontinuouscolordialogbase.ui
--- trunk/qgis/src/ui/qgscontinuouscolordialogbase.ui 2010-11-14 22:45:13 UTC (rev 14666)
+++ trunk/qgis/src/ui/qgscontinuouscolordialogbase.ui 2010-11-14 22:45:20 UTC (rev 14667)
@@ -6,8 +6,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>453</width>
- <height>222</height>
+ <width>256</width>
+ <height>175</height>
</rect>
</property>
<property name="windowTitle">
@@ -15,19 +15,6 @@
</property>
<layout class="QGridLayout" name="gridLayout">
<item row="0" column="0">
- <spacer name="horizontalSpacer_2">
- <property name="orientation">
- <enum>Qt::Horizontal</enum>
- </property>
- <property name="sizeHint" stdset="0">
- <size>
- <width>40</width>
- <height>20</height>
- </size>
- </property>
- </spacer>
- </item>
- <item row="0" column="1">
<widget class="QLabel" name="classvarlabel">
<property name="minimumSize">
<size>
@@ -43,7 +30,7 @@
</property>
</widget>
</item>
- <item row="0" column="2">
+ <item row="0" column="1">
<widget class="QComboBox" name="classificationComboBox">
<size>
@@ -53,7 +40,7 @@
</property>
</widget>
</item>
- <item row="0" column="3">
+ <item row="0" column="2">
<spacer name="horizontalSpacer">
@@ -66,7 +53,7 @@
</property>
</spacer>
</item>
- <item row="1" column="1">
+ <item row="1" column="0">
<widget class="QLabel" name="mincolorlabel">
<size>
@@ -82,7 +69,7 @@
</property>
</widget>
</item>
- <item row="1" column="2">
+ <item row="1" column="1">
<widget class="QgsColorButton" name="btnMinValue">
<size>
@@ -92,7 +79,7 @@
</property>
</widget>
</item>
- <item row="2" column="1">
+ <item row="2" column="0">
<widget class="QLabel" name="maxcolorlabel">
<size>
@@ -108,7 +95,7 @@
</property>
</widget>
</item>
- <item row="2" column="2">
+ <item row="2" column="1">
<widget class="QgsColorButton" name="btnMaxValue">
<size>
@@ -118,7 +105,7 @@
</property>
</widget>
</item>
- <item row="3" column="1">
+ <item row="3" column="0">
<widget class="QLabel" name="outlinewidthlabel">
<size>
@@ -134,17 +121,17 @@
</property>
</widget>
</item>
- <item row="3" column="2">
+ <item row="3" column="1">
<widget class="QDoubleSpinBox" name="outlinewidthspinbox"/>
</item>
- <item row="4" column="1" colspan="2">
+ <item row="4" column="0" colspan="2">
<widget class="QCheckBox" name="cb_polygonOutline">
<property name="text">
<string>Draw polygon outline</string>
</property>
</widget>
</item>
- <item row="5" column="1" colspan="2">
+ <item row="5" column="0" colspan="2">
<spacer name="verticalSpacer">
<enum>Qt::Vertical</enum>
Modified: trunk/qgis/src/ui/qgssinglesymboldialogbase.ui
--- trunk/qgis/src/ui/qgssinglesymboldialogbase.ui 2010-11-14 22:45:13 UTC (rev 14666)
+++ trunk/qgis/src/ui/qgssinglesymboldialogbase.ui 2010-11-14 22:45:20 UTC (rev 14667)
@@ -6,8 +6,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>366</width>
- <height>470</height>
+ <width>337</width>
+ <height>620</height>
</rect>
</property>
<property name="sizePolicy">
@@ -33,8 +33,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>350</width>
- <height>604</height>
+ <width>335</width>
+ <height>618</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_5">
@@ -83,9 +83,6 @@
</property>
</widget>
</item>
- <layout class="QHBoxLayout" name="horizontalLayout"/>
- </item>
<item row="0" column="0" colspan="3">
<widget class="QListView" name="lstSymbols">
@@ -247,9 +244,6 @@
</property>
<layout class="QHBoxLayout" name="horizontalLayout_3">
<item>
- <layout class="QHBoxLayout"/>
- </item>
- <item>
<widget class="QComboBox" name="cboOutlineStyle">
<sizepolicy hsizetype="Expanding" vsizetype="Fixed">
@@ -395,6 +389,19 @@
</layout>
</widget>
</item>
+ <item row="6" column="0">
+ <spacer name="verticalSpacer_2">
+ <property name="orientation">
+ <enum>Qt::Vertical</enum>
+ </property>
+ <property name="sizeHint" stdset="0">
+ <size>
+ <width>20</width>
+ <height>40</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
</layout>
</widget>
</widget>
