[QGIS Commit] r14678 - trunk/qgis/python/plugins/fTools/tools
svn_qgis at osgeo.org
Sun Nov 14 19:33:57 EST 2010
Author: cfarmer
Date: 2010-11-14 16:33:57 -0800 (Sun, 14 Nov 2010)
New Revision: 14678
Added:
trunk/qgis/python/plugins/fTools/tools/doSimplify.py
trunk/qgis/python/plugins/fTools/tools/frmSimplify.ui
commit missing files for new simplify implementation by alexbruy
Added: trunk/qgis/python/plugins/fTools/tools/doSimplify.py
--- trunk/qgis/python/plugins/fTools/tools/doSimplify.py (rev 0)
+++ trunk/qgis/python/plugins/fTools/tools/doSimplify.py 2010-11-15 00:33:57 UTC (rev 14678)
@@ -0,0 +1,272 @@
+# -*- coding: utf-8 -*-
+from PyQt4.QtCore import *
+from PyQt4.QtGui import *
+from qgis.core import *
+from qgis.gui import *
+import ftools_utils
+from ui_frmSimplify import Ui_Dialog
+class Dialog( QDialog, Ui_Dialog ):
+ def __init__( self, iface ):
+ QDialog.__init__( self )
+ self.setupUi( self )
+ self.iface = iface
+ self.simplifyThread = None
+ self.okButton = self.buttonBox.button( QDialogButtonBox.Ok )
+ self.closeButton = self.buttonBox.button( QDialogButtonBox.Close )
+ QObject.connect( self.writeShapefileCheck, SIGNAL( "stateChanged( int )" ), self.updateGui )
+ QObject.connect( self.btnSelectOutputFile, SIGNAL( "clicked()" ), self.selectOutputFile )
+ self.manageGui()
+ def manageGui( self ):
+ layers = ftools_utils.getLayerNames( [ QGis.Polygon, QGis.Line ] )
+ self.cmbInputLayer.addItems( layers )
+ def updateGui( self ):
+ if self.writeShapefileCheck.isChecked():
+ self.outputFileEdit.setEnabled( True )
+ self.btnSelectOutputFile.setEnabled( True )
+ self.addToCanvasCheck.setEnabled( True )
+ else:
+ self.outputFileEdit.setEnabled( False )
+ self.btnSelectOutputFile.setEnabled( False )
+ self.addToCanvasCheck.setEnabled( False )
+ self.encoding = None
+ def selectOutputFile( self ):
+ self.outputFileEdit.clear()
+ (self.shapefileName, self.encoding) = ftools_utils.saveDialog(self)
+ if self.shapefileName is None or self.encoding is None:
+ return
+ self.outputFileEdit.setText(QString(self.shapefileName))
+ def accept( self ):
+ vLayer = ftools_utils.getVectorLayerByName( self.cmbInputLayer.currentText() )
+ QApplication.setOverrideCursor( Qt.WaitCursor )
+ self.okButton.setEnabled( False )
+ outFileName = self.outputFileEdit.text()
+ outFile = QFile( outFileName )
+ if outFile.exists():
+ if not QgsVectorFileWriter.deleteShapeFile( outFileName ):
+ QmessageBox.warning( self, self.tr( "Delete error" ), self.tr( "Can't delete file %1" ).arg( outFileName ) )
+ return
+ self.simplifyThread = GeneralizationThread( vLayer, self.useSelectionCheck.isChecked(), self.toleranceSpin.value(), True, outFileName, self.encoding )
+ else:
+ self.simplifyThread = GeneralizationThread( vLayer, self.useSelectionCheck.isChecked(), self.toleranceSpin.value(), False, None, None )
+ QObject.connect( self.simplifyThread, SIGNAL( "rangeCalculated( PyQt_PyObject )" ), self.setProgressRange )
+ QObject.connect( self.simplifyThread, SIGNAL( "featureProcessed()" ), self.featureProcessed )
+ QObject.connect( self.simplifyThread, SIGNAL( "generalizationFinished( PyQt_PyObject )" ), self.generalizationFinished )
+ QObject.connect( self.simplifyThread, SIGNAL( "generalizationInterrupted()" ), self.generalizationInterrupted )
+ self.closeButton.setText( self.tr( "Cancel" ) )
+ QObject.disconnect( self.buttonBox, SIGNAL( "rejected()" ), self.reject )
+ QObject.connect( self.closeButton, SIGNAL( "clicked()" ), self.stopProcessing )
+ self.simplifyThread.start()
+ def setProgressRange( self, max ):
+ self.progressBar.setRange( 0, max )
+ def featureProcessed( self ):
+ self.progressBar.setValue( self.progressBar.value() + 1 )
+ def generalizationFinished( self, pointsCount ):
+ self.stopProcessing()
+ QMessageBox.information( self,
+ self.tr( "Simplify results" ),
+ self.tr( "There were %1 vertices in original dataset which\nwere reduced to %2 vertices after simplification" )
+ .arg( pointsCount[ 0 ] )
+ .arg( pointsCount[ 1 ] ) )
+ self.restoreGui()
+ if self.addToCanvasCheck.isEnabled() and self.addToCanvasCheck.isChecked():
+ if not ftools_utils.addShapeToCanvas( unicode( self.shapefileName ) ):
+ QMessageBox.warning( self, self.tr( "Merging" ),
+ self.tr( "Error loading output shapefile:\n%1" )
+ .arg( unicode( self.shapefileName ) ) )
+ self.iface.mapCanvas().refresh()
+ #self.restoreGui()
+ def generalizationInterrupted( self ):
+ self.restoreGui()
+ def stopProcessing( self ):
+ if self.simplifyThread != None:
+ self.simplifyThread.stop()
+ def restoreGui( self ):
+ self.progressBar.setValue( 0 )
+ QApplication.restoreOverrideCursor()
+ QObject.connect( self.buttonBox, SIGNAL( "rejected()" ), self.reject )
+ self.closeButton.setText( self.tr( "Close" ) )
+ self.okButton.setEnabled( True )
+def geomVertexCount( geometry ):
+ geomType = geometry.type()
+ if geomType == 1: # line
+ points = geometry.asPolyline()
+ return len( points )
+ elif geomType == 2: # polygon
+ polylines = geometry.asPolygon()
+ points = []
+ for l in polylines:
+ points.extend( l )
+ else:
+ return None
+class GeneralizationThread( QThread ):
+ def __init__( self, inputLayer, useSelection, tolerance, writeShape, shapePath, shapeEncoding ):
+ QThread.__init__( self, QThread.currentThread() )
+ self.inputLayer = inputLayer
+ self.useSelection = useSelection
+ self.tolerance = tolerance
+ self.writeShape = writeShape
+ self.outputFileName = shapePath
+ self.outputEncoding = shapeEncoding
+ self.shapeFileWriter = None
+ self.pointsBefore = 0
+ self.pointsAfter = 0
+ self.mutex = QMutex()
+ self.stopMe = 0
+ def run( self ):
+ self.mutex.lock()
+ self.stopMe = 0
+ self.mutex.unlock()
+ interrupted = False
+ shapeFileWriter = None
+ if self.writeShape:
+ vProvider = self.inputLayer.dataProvider()
+ allAttrs = vProvider.attributeIndexes()
+ vProvider.select( allAttrs )
+ shapeFields = vProvider.fields()
+ crs = vProvider.crs()
+ wkbType = self.inputLayer.wkbType()
+ if not crs.isValid():
+ crs = None
+ shapeFileWriter = QgsVectorFileWriter( self.outputFileName, self.outputEncoding, shapeFields, wkbType, crs )
+ featureId = 0
+ if self.useSelection:
+ selection = self.inputLayer.selectedFeatures()
+ self.emit( SIGNAL( "rangeCalculated( PyQt_PyObject )" ), len( selection ) )
+ for f in selection:
+ featGeometry = QgsGeometry( f.geometry() )
+ attrMap = f.attributeMap()
+ self.pointsBefore += geomVertexCount( featGeometry )
+ newGeometry = featGeometry.simplify( self.tolerance )
+ self.pointsAfter += geomVertexCount( newGeometry )
+ feature = QgsFeature()
+ feature.setGeometry( newGeometry )
+ feature.setAttributeMap( attrMap )
+ shapeFileWriter.addFeature( feature )
+ featureId += 1
+ self.emit( SIGNAL( "featureProcessed()" ) )
+ self.mutex.lock()
+ s = self.stopMe
+ if s == 1:
+ interrupted = True
+ break
+ else:
+ self.emit( SIGNAL( "rangeCalculated( PyQt_PyObject )" ), vProvider.featureCount() )
+ f = QgsFeature()
+ while vProvider.nextFeature( f ):
+ featureId += 1
+ self.mutex.lock()
+ s = self.stopMe
+ if s == 1:
+ break
+ else: # modify existing shapefile
+ if not self.inputLayer.isEditable():
+ self.inputLayer.startEditing()
+ self.inputLayer.beginEditCommand( QString( "Simplify line(s)" ) )
+ featureId = f.id()
+ self.inputLayer.changeGeometry( featureId, newGeometry )
+ self.mutex.lock()
+ s = self.stopMe
+ if s == 1:
+ break
+ else:
+ f = QgsFeature()
+ self.mutex.lock()
+ s = self.stopMe
+ if s == 1:
+ break
+ # cleanup
+ if self.inputLayer.isEditable():
+ self.inputLayer.endEditCommand()
+ if shapeFileWriter != None:
+ del shapeFileWriter
+ if not interrupted:
+ self.emit( SIGNAL( "generalizationFinished( PyQt_PyObject )" ), ( self.pointsBefore, self.pointsAfter ) )
+ else:
+ self.emit( SIGNAL( "generalizationInterrupted()" ) )
+ def stop( self ):
+ self.mutex.lock()
+ self.stopMe = 1
+ QThread.wait( self )
Added: trunk/qgis/python/plugins/fTools/tools/frmSimplify.ui
--- trunk/qgis/python/plugins/fTools/tools/frmSimplify.ui (rev 0)
+++ trunk/qgis/python/plugins/fTools/tools/frmSimplify.ui 2010-11-15 00:33:57 UTC (rev 14678)
@@ -0,0 +1,163 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
+ <class>Dialog</class>
+ <widget class="QDialog" name="Dialog">
+ <property name="windowModality">
+ <enum>Qt::WindowModal</enum>
+ </property>
+ <property name="geometry">
+ <rect>
+ <x>0</x>
+ <y>0</y>
+ <width>400</width>
+ <height>269</height>
+ </rect>
+ </property>
+ <property name="windowTitle">
+ <string>Simplify geometries</string>
+ </property>
+ <layout class="QVBoxLayout" name="verticalLayout">
+ <item>
+ <widget class="QLabel" name="label">
+ <property name="text">
+ <string>Input line or polygon layer</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QComboBox" name="cmbInputLayer">
+ <property name="sizePolicy">
+ <sizepolicy hsizetype="Preferred" vsizetype="Fixed">
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QCheckBox" name="useSelectionCheck">
+ <string>Use only selected features</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <layout class="QHBoxLayout" name="horizontalLayout_3">
+ <item>
+ <widget class="QLabel" name="label_2">
+ <string>Simplify tolerance</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QDoubleSpinBox" name="toleranceSpin">
+ <property name="decimals">
+ <number>4</number>
+ </property>
+ <property name="minimum">
+ <double>0.000000000000000</double>
+ </property>
+ <property name="maximum">
+ <double>10000000.000000000000000</double>
+ </property>
+ <property name="value">
+ <double>0.000100000000000</double>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ <item>
+ <layout class="QHBoxLayout" name="horizontalLayout_2">
+ <item>
+ <widget class="QCheckBox" name="writeShapefileCheck">
+ <string>Save to new file</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QLineEdit" name="outputFileEdit">
+ <property name="enabled">
+ <bool>false</bool>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QPushButton" name="btnSelectOutputFile">
+ </property>
+ <string>Browse</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ <item>
+ <widget class="QCheckBox" name="addToCanvasCheck">
+ </property>
+ <string>Add result to canvas</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QProgressBar" name="progressBar">
+ <number>0</number>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QDialogButtonBox" name="buttonBox">
+ <property name="orientation">
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <property name="standardButtons">
+ <set>QDialogButtonBox::Close|QDialogButtonBox::Ok</set>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ <resources/>
+ <connections>
+ <connection>
+ <sender>buttonBox</sender>
+ <signal>accepted()</signal>
+ <receiver>Dialog</receiver>
+ <slot>accept()</slot>
+ <hints>
+ <hint type="sourcelabel">
+ <x>248</x>
+ <y>254</y>
+ </hint>
+ <hint type="destinationlabel">
+ <x>157</x>
+ <y>274</y>
+ </hint>
+ </hints>
+ </connection>
+ <connection>
+ <signal>rejected()</signal>
+ <slot>reject()</slot>
+ <hints>
+ <x>316</x>
+ <y>260</y>
+ </hint>
+ <x>286</x>
+ <y>274</y>
+ </hint>
+ </hints>
+ </connection>
+ </connections>
+</ui>
