[QGIS Commit] r14684 - in branches/raster-providers/src: core core/raster providers/wms
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Nov 15 06:31:36 EST 2010
Author: rblazek
Date: 2010-11-15 03:31:35 -0800 (Mon, 15 Nov 2010)
New Revision: 14684
   branches/raster-providers/src/core/qgsrasterdataprovider.h
   branches/raster-providers/src/core/raster/qgsrasterlayer.cpp
   branches/raster-providers/src/core/raster/qgsrasterlayer.h
   branches/raster-providers/src/providers/wms/qgswmsprovider.cpp
   branches/raster-providers/src/providers/wms/qgswmsprovider.h
wms swithed from draw() to readBlock using ARGBDataType
Modified: branches/raster-providers/src/core/qgsrasterdataprovider.h
--- branches/raster-providers/src/core/qgsrasterdataprovider.h	2010-11-15 11:12:03 UTC (rev 14683)
+++ branches/raster-providers/src/core/qgsrasterdataprovider.h	2010-11-15 11:31:35 UTC (rev 14684)
@@ -80,7 +80,8 @@
       /*! Complex Int32 */                        CInt32 = 9,
       /*! Complex Float32 */                      CFloat32 = 10,
       /*! Complex Float64 */                      CFloat64 = 11,
-      TypeCount = 12          /* maximum type # + 1 */
+      /*! Color, alpha, red, green, blue, 4 bytes */ ARGBDataType = 12,
+      TypeCount = 13          /* maximum type # + 1 */
     // This is modified copy of GDALColorInterp
@@ -195,6 +196,9 @@
         case CFloat64:
           return 128;
+        case ARGBDataType:
+          return 32;
         default:
           return 0;
@@ -206,7 +210,7 @@
     /** Get numbur of bands */
     virtual int bandCount() const {
-      return 0;
+      return 1;
     /** Returns data type for the band specified by number */
Modified: branches/raster-providers/src/core/raster/qgsrasterlayer.cpp
--- branches/raster-providers/src/core/raster/qgsrasterlayer.cpp	2010-11-15 11:12:03 UTC (rev 14683)
+++ branches/raster-providers/src/core/raster/qgsrasterlayer.cpp	2010-11-15 11:31:35 UTC (rev 14684)
@@ -376,6 +376,13 @@
   QgsDebugMsg( "theBandNo = " + QString::number(theBandNo) );
   QgsDebugMsg( "mRasterType = " + QString::number(mRasterType) );
+  if ( mRasterType == ColorLayer )
+    // Statistics have no sense for ColorLayer
+    QgsRasterBandStats myNullReturnStats;
+    return myNullReturnStats;
   // check if we have received a valid band number
   if (( mDataProvider->bandCount() < theBandNo ) && mRasterType != Palette )
@@ -969,13 +976,14 @@
   // Provider mode: See if a provider key is specified, and if so use the provider instead
-  QgsDebugMsg( "Checking for provider key." );
+  QgsDebugMsg( "Checking for provider capability." );
-  //if ( !mProviderKey.isEmpty() )
+  // Some providers were returning QImage directly, not they are passing ARGB data - ARGBDataType
   if ( mDataProvider->capabilities() & QgsRasterDataProvider::Draw )
     QgsDebugMsg( "Wanting a '" + mProviderKey + "' provider to draw this." );
+    // TODO this should be probably moved to WMS?
     mDataProvider->setDpi( rendererContext.rasterScaleFactor() * 25.4 * rendererContext.scaleFactor() );
     //fetch image in several parts if it is too memory consuming
@@ -1037,6 +1045,7 @@
       //QImage::setAlphaChannel does not work quite as expected so set each pixel individually
       //Currently this is only done for WMS images, which should be small enough not to impact performance
       if ( mTransparencyLevel != 255 ) //improve performance if layer transparency not altered
         QImage* transparentImageCopy = new QImage( *image ); //copy image if there is user transparency
@@ -1232,6 +1241,18 @@
                             theQgsMapToPixel );
       break;
+    case SingleBandColorDataStyle:
+      //check the band is set!
+      if ( mGrayBandName == TRSTRING_NOT_SET )
+        break;
+      else
+        drawSingleBandColorData( theQPainter, theRasterViewPort,
+                            theQgsMapToPixel, bandNumber( mGrayBandName ) );
+        break;
     default:
       break;
@@ -1271,6 +1292,9 @@
     case MultiBandColor:
       return QString( "MultiBandColor" );//no need to tr() this its not shown in ui
       break;
+      return QString( "SingleBandColorDataStyle" );//no need to tr() this its not shown in ui
+      break;
     default:
       break;
@@ -2524,10 +2548,16 @@
   //decide what type of layer this is...
   //TODO Change this to look at the color interp and palette interp to decide which type of layer it is
+  QgsDebugMsg("bandCount = " + QString::number( mDataProvider->bandCount()));
+  QgsDebugMsg("dataType = " + QString::number( mDataProvider->dataType( 1 )));
   if (( mDataProvider->bandCount() > 1 ) )
     mRasterType = Multiband;
+  else if ( mDataProvider->dataType( 1 ) == QgsRasterDataProvider::ARGBDataType )
+    mRasterType = ColorLayer;
   //TODO hasBand is really obsolete and only used in the Palette instance, change to new function hasPalette(int)
   //else if ( hasBand( "Palette" ) ) //don't tr() this its a gdal word!
   // not sure if is worth to add colorTable capability - CT can be empty in any case
@@ -2540,8 +2570,15 @@
     mRasterType = GrayOrUndefined;
-  if ( mRasterType == Palette )
+  QgsDebugMsg("mRasterType = " + QString::number(mRasterType));
+    QgsDebugMsg("Setting mDrawingStyle to SingleBandColorDataStyle " + QString::number ( SingleBandColorDataStyle ) );
+    mDrawingStyle = SingleBandColorDataStyle;
+    mGrayBandName = bandName( 1 );  //sensible default
+  else if ( mRasterType == Palette )
     mRedBandName = TRSTRING_NOT_SET; // sensible default
     mGreenBandName = TRSTRING_NOT_SET; // sensible default
     mBlueBandName = TRSTRING_NOT_SET;// sensible default
@@ -2789,8 +2826,14 @@
     mDrawingStyle = MultiBandColor;
-  else
+  else if ( theDrawingStyleQString == "SingleBandColorDataStyle" )//no need to tr() this its not shown in ui
+    QgsDebugMsg("Setted mDrawingStyle to " + QString::number ( mDrawingStyle ) );
+  else
     mDrawingStyle = UndefinedDrawingStyle;
@@ -3708,6 +3751,25 @@
 // Private methods
+void QgsRasterLayer::drawSingleBandColorData( QPainter * theQPainter, QgsRasterViewPort * theRasterViewPort,
+    const QgsMapToPixel* theQgsMapToPixel, int theBandNo )
+  QgsDebugMsg( "entered." );
+  QgsRasterImageBuffer imageBuffer( mDataProvider, theBandNo, theQPainter, theRasterViewPort, theQgsMapToPixel, &mGeoTransform[0] );
+  imageBuffer.reset();
+  QRgb* imageScanLine = 0;
+  void* rasterScanLine = 0;
+  while ( imageBuffer.nextScanLine( &imageScanLine, &rasterScanLine ) )
+    int size = theRasterViewPort->drawableAreaXDim * 4;
+    memcpy( imageScanLine, rasterScanLine, size );
 void QgsRasterLayer::drawMultiBandColor( QPainter * theQPainter, QgsRasterViewPort * theRasterViewPort,
     const QgsMapToPixel* theQgsMapToPixel )
Modified: branches/raster-providers/src/core/raster/qgsrasterlayer.h
--- branches/raster-providers/src/core/raster/qgsrasterlayer.h	2010-11-15 11:12:03 UTC (rev 14683)
+++ branches/raster-providers/src/core/raster/qgsrasterlayer.h	2010-11-15 11:31:35 UTC (rev 14684)
@@ -241,8 +241,8 @@
       //added in 1.6 to fix naming glitch
       MultiBandSingleBandGray = MultiBandSingleGandGray, // a layer containing 2 or more bands, but a single band drawn as a range of gray colors
       MultiBandSingleBandPseudoColor, //a layer containing 2 or more bands, but a single band drawn using a pseudocolor algorithm
-      MultiBandColor                  //a layer containing 2 or more bands, mapped to RGB color space.
-      //In the case of a multiband with only two bands, one band will be mapped to more than one color.
+      MultiBandColor,                  //a layer containing 2 or more bands, mapped to RGB color space. In the case of a multiband with only two bands, one band will be mapped to more than one color.
+      SingleBandColorDataStyle         // ARGB values rendered directly
     /** \brief This enumerator describes the type of raster layer */
@@ -250,7 +250,8 @@
       GrayOrUndefined,
       Palette,
-      Multiband
+      Multiband,
+      ColorLayer
     /** \brief A list containing on ContrastEnhancement object per raster band in this raster layer */
@@ -713,6 +714,11 @@
     // Private methods
+    /** \brief Drawing routine for color type data  */
+    void drawSingleBandColorData( QPainter * theQPainter,
+                             QgsRasterViewPort * theRasterViewPort,
+                             int theBandNoInt  );
     /** \brief Drawing routine for multiband image  */
     void drawMultiBandColor( QPainter * theQPainter,
Modified: branches/raster-providers/src/providers/wms/qgswmsprovider.cpp
--- branches/raster-providers/src/providers/wms/qgswmsprovider.cpp	2010-11-15 11:12:03 UTC (rev 14683)
+++ branches/raster-providers/src/providers/wms/qgswmsprovider.cpp	2010-11-15 11:31:35 UTC (rev 14684)
@@ -489,7 +489,9 @@
     //MH: jpeg does not support transparency and some servers complain if jpg and transparent=true
     if ( !imageMimeType.contains( "jpeg", Qt::CaseInsensitive ) && !imageMimeType.contains( "jpg", Qt::CaseInsensitive ) )
-      url += "&TRANSPARENT=true";
+      // some servers giving error for 'true' (lowercase)
+      //url += "&TRANSPARENT=true";
+      url += "&TRANSPARENT=TRUE";
     mGetFeatureInfoUrlBase = mIgnoreGetFeatureInfoUrl ? mBaseUrl : getFeatureInfoUrl();
@@ -676,6 +678,30 @@
   return cachedImage;
+void QgsWmsProvider::readBlock( int bandNo, QgsRectangle  const & viewExtent, int pixelWidth, int pixelHeight, void *block )
+  QgsDebugMsg( "Entered" );
+  // TODO: optimize to avoid writing to QImage
+  QImage* image = draw( viewExtent, pixelWidth, pixelHeight );
+  if ( ! image ) { // should not happen
+    QgsDebugMsg( "image is NULL" );
+    return;
+  QgsDebugMsg( QString("image height = %1 bytesPerLine = %2").arg(image->height() ) . arg ( image->bytesPerLine() ) ) ;
+  int myExpectedSize = pixelWidth * pixelHeight * 4;
+  int myImageSize = image->height() *  image->bytesPerLine();
+  if ( myExpectedSize != myImageSize ) { // should not happen
+    QgsDebugMsg( "unexpected image size" );
+    return;
+  uchar * ptr = image->bits( ) ;
+  memcpy( block, ptr, myExpectedSize );
+  // do not delete the image, it is handled by draw()
+  //delete image;
 void QgsWmsProvider::tileReplyFinished()
   QNetworkReply *reply = qobject_cast<QNetworkReply*>( sender() );
@@ -947,6 +973,16 @@
   mCapabilitiesReply = 0;
+int QgsWmsProvider::dataType( int bandNo ) const
+  return QgsRasterDataProvider::ARGBDataType;
+int QgsWmsProvider::bandCount() const
+  return 1;
 void QgsWmsProvider::capabilitiesReplyProgress( qint64 bytesReceived, qint64 bytesTotal )
   emit statusChanged( tr( "%1 of %2 bytes of capabilities downloaded." ).arg( bytesReceived ).arg( bytesTotal < 0 ? QString( "unknown number of" ) : QString::number( bytesTotal ) ) );
@@ -2109,7 +2145,8 @@
 int QgsWmsProvider::capabilities() const
-  int capability = 0;
+  //int capability = QgsRasterDataProvider::Draw;
+  int capability = QgsRasterDataProvider::Data;
   bool canIdentify = false;
   QgsDebugMsg( "entering." );
@@ -2144,7 +2181,7 @@
-  QgsDebugMsg( "exiting with '"  + QString( capability )  + "'." );
+  //QgsDebugMsg( "exiting with '"  + QString( capability )  + "'." );
   return capability;
@@ -2784,7 +2821,6 @@
   return QgsCoordinateReferenceSystem();
 QString QgsWmsProvider::lastErrorTitle()
   return mErrorCaption;
Modified: branches/raster-providers/src/providers/wms/qgswmsprovider.h
--- branches/raster-providers/src/providers/wms/qgswmsprovider.h	2010-11-15 11:12:03 UTC (rev 14683)
+++ branches/raster-providers/src/providers/wms/qgswmsprovider.h	2010-11-15 11:31:35 UTC (rev 14684)
@@ -459,6 +459,9 @@
     QImage *draw( QgsRectangle const &  viewExtent, int pixelWidth, int pixelHeight );
+    void readBlock( int bandNo, QgsRectangle  const & viewExtent, int width, int height,  void *data );
     /** Return the extent for this data layer
     virtual QgsRectangle extent();
@@ -524,6 +527,11 @@
     int capabilities() const;
+    int dataType ( int bandNo ) const;
+    int bandCount() const;
      * Get metadata in a format suitable for feeding directly
      * into a subset of the GUI raster properties "Metadata" tab.
More information about the QGIS-commit mailing list
