[QGIS Commit] r14707 - in trunk/qgis: scripts src/app
svn_qgis at osgeo.org
Wed Nov 17 19:24:13 EST 2010
Author: jef
Date: 2010-11-17 16:24:13 -0800 (Wed, 17 Nov 2010)
New Revision: 14707
trunk/qgis/scripts/prepare-commit.sh
trunk/qgis/src/app/qgslabelpropertydialog.cpp
fix lenny build
Modified: trunk/qgis/scripts/prepare-commit.sh
--- trunk/qgis/scripts/prepare-commit.sh 2010-11-17 22:12:51 UTC (rev 14706)
+++ trunk/qgis/scripts/prepare-commit.sh 2010-11-18 00:24:13 UTC (rev 14707)
@@ -36,7 +36,7 @@
REV=$(svn info | sed -ne "s/Revision: //p")
svn diff >r$REV.diff
elif [ -d .git ]; then
- REV=$(git svn info | sed -ne "s/Revision //p")
+ REV=$(git svn info | sed -ne "s/Revision: //p")
git diff >r$REV.diff
fi
Modified: trunk/qgis/src/app/qgslabelpropertydialog.cpp
--- trunk/qgis/src/app/qgslabelpropertydialog.cpp 2010-11-17 22:12:51 UTC (rev 14706)
+++ trunk/qgis/src/app/qgslabelpropertydialog.cpp 2010-11-18 00:24:13 UTC (rev 14707)
@@ -36,20 +36,20 @@
void QgsLabelPropertyDialog::init( const QString& layerId, int featureId )
- if( !mMapRenderer )
+ if ( !mMapRenderer )
return;
//get feature attributes
QgsVectorLayer* vlayer = dynamic_cast<QgsVectorLayer*>( QgsMapLayerRegistry::instance()->mapLayer( layerId ) );
- if( !vlayer )
+ if ( !vlayer )
return;
QgsFeature f;
- if( !vlayer->featureAtId( featureId, f, false, true ) )
+ if ( !vlayer->featureAtId( featureId, f, false, true ) )
return;
@@ -58,7 +58,7 @@
//get layerproperties. Problem: only for pallabeling...
QgsPalLabeling* lbl = dynamic_cast<QgsPalLabeling*>( mMapRenderer->labelingEngine() );
- if( !lbl )
+ if ( !lbl )
return;
@@ -67,12 +67,12 @@
//get label field and fill line edit
QString labelFieldName = vlayer->customProperty( "labeling/fieldName" ).toString();
- if( !labelFieldName.isEmpty() )
+ if ( !labelFieldName.isEmpty() )
mCurrentLabelField = vlayer->fieldNameIndex( labelFieldName );
mLabelTextLineEdit->setText( attributeValues[mCurrentLabelField].toString() );
const QgsFieldMap& layerFields = vlayer->pendingFields();
- switch( layerFields[mCurrentLabelField].type() )
+ switch ( layerFields[mCurrentLabelField].type() )
case QVariant::Double:
mLabelTextLineEdit->setValidator( new QDoubleValidator( this ) );
@@ -82,6 +82,8 @@
case QVariant::LongLong:
mLabelTextLineEdit->setValidator( new QIntValidator( this ) );
break;
+ default:
+ break;
@@ -94,17 +96,17 @@
mBufferColorButton->setColor( layerSettings.textColor );
mLabelDistanceSpinBox->setValue( layerSettings.dist );
mBufferSizeSpinBox->setValue( layerSettings.bufferSize );
- mHaliComboBox->setCurrentIndex( mHaliComboBox->findText("Left") );
- mValiComboBox->setCurrentIndex( mValiComboBox->findText("Bottom") );
+ mHaliComboBox->setCurrentIndex( mHaliComboBox->findText( "Left" ) );
+ mValiComboBox->setCurrentIndex( mValiComboBox->findText( "Bottom" ) );
disableGuiElements();
mDataDefinedProperties = layerSettings.dataDefinedProperties;
QMap< QgsPalLayerSettings::DataDefinedProperties, int >::const_iterator propIt = mDataDefinedProperties.constBegin();
- for(; propIt != mDataDefinedProperties.constEnd(); ++propIt )
+ for ( ; propIt != mDataDefinedProperties.constEnd(); ++propIt )
- switch( propIt.key() )
+ switch ( propIt.key() )
case QgsPalLayerSettings::Size:
mFontSizeSpinBox->setEnabled( true );
@@ -148,7 +150,7 @@
mRotationSpinBox->setValue( attributeValues[propIt.value()].toDouble() );
break;
- //font related properties
+ //font related properties
case QgsPalLayerSettings::Bold:
mLabelFont.setBold( attributeValues[propIt.value()].toBool() );
break;
@@ -247,8 +249,8 @@
void QgsLabelPropertyDialog::on_mFontPushButton_clicked()
bool ok;
- mLabelFont = QFontDialog::getFont( &ok, mLabelFont, 0, tr("Label font") );
- if( ok )
+ mLabelFont = QFontDialog::getFont( &ok, mLabelFont, 0, tr( "Label font" ) );
+ if ( ok )
insertChangedValue( QgsPalLayerSettings::Size, mLabelFont.pointSizeF() );
insertChangedValue( QgsPalLayerSettings::Bold, mLabelFont.bold() );
@@ -259,8 +261,12 @@
void QgsLabelPropertyDialog::on_mFontColorButton_clicked()
- QColor c = QColorDialog::getColor ( mFontColorButton->color(), 0, tr("Font color"), QColorDialog::ShowAlphaChannel );
- if( c.isValid() )
+#if QT_VERSION >= 0x040500
+ QColor c = QColorDialog::getColor( mFontColorButton->color(), 0, tr( "Font color" ), QColorDialog::ShowAlphaChannel );
+#else
+ QColor c = QColorDialog::getColor( mFontColorButton->color() );
+#endif
+ if ( c.isValid() )
mFontColorButton->setColor( c );
insertChangedValue( QgsPalLayerSettings::Color, c.name() );
@@ -269,8 +275,12 @@
void QgsLabelPropertyDialog::on_mBufferColorButton_clicked()
- QColor c = QColorDialog::getColor ( mBufferColorButton->color(), 0, tr("Buffer color"), QColorDialog::ShowAlphaChannel );
- if( c.isValid() )
+ QColor c = QColorDialog::getColor( mBufferColorButton->color(), 0, tr( "Buffer color" ), QColorDialog::ShowAlphaChannel );
+#else
+ QColor c = QColorDialog::getColor( mBufferColorButton->color() );
+#endif
insertChangedValue( QgsPalLayerSettings::BufferColor, c.name() );
@@ -287,9 +297,9 @@
insertChangedValue( QgsPalLayerSettings::Vali, text );
-void QgsLabelPropertyDialog::on_mLabelTextLineEdit_textChanged ( const QString& text )
+void QgsLabelPropertyDialog::on_mLabelTextLineEdit_textChanged( const QString& text )
- if( mCurrentLabelField != -1 )
+ if ( mCurrentLabelField != -1 )
mChangedProperties.insert( mCurrentLabelField, text );
@@ -297,8 +307,8 @@
void QgsLabelPropertyDialog::insertChangedValue( QgsPalLayerSettings::DataDefinedProperties p, QVariant value )
- QMap< QgsPalLayerSettings::DataDefinedProperties, int >::const_iterator ddIt = mDataDefinedProperties.find( p );
- if( ddIt != mDataDefinedProperties.constEnd() )
+ QMap< QgsPalLayerSettings::DataDefinedProperties, int >::const_iterator ddIt = mDataDefinedProperties.find( p );
+ if ( ddIt != mDataDefinedProperties.constEnd() )
mChangedProperties.insert( ddIt.value(), value );
