[QGIS Commit] r14798 - trunk/qgis/src/app
svn_qgis at osgeo.org
Mon Nov 29 15:40:51 EST 2010
Author: jef
Date: 2010-11-29 12:40:51 -0800 (Mon, 29 Nov 2010)
New Revision: 14798
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgsmaptoolmovelabel.h
trunk/qgis/src/app/qgsmaptoolrotatelabel.h
activate/deactivate labeling tools
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2010-11-29 20:40:42 UTC (rev 14797)
+++ trunk/qgis/src/app/qgisapp.cpp 2010-11-29 20:40:51 UTC (rev 14798)
@@ -584,6 +584,7 @@
delete mMapTools.mAddIsland;
delete mMapTools.mNodeTool;
delete mMapTools.mMoveLabel;
+ delete mMapTools.mRotateLabel;
delete mMapTools.mChangeLabelProperties;
delete mPythonUtils;
@@ -3955,6 +3956,8 @@
// alter labeling - save the changes
labelGui.layerSettings().writeToLayer( vlayer );
+ activateDeactivateLayerRelatedActions( layer );
// trigger refresh
if ( mMapCanvas )
@@ -6171,6 +6174,10 @@
mActionCaptureLine->setVisible( false );
mActionCapturePolygon->setVisible( false );
+ mActionMoveLabel->setEnabled( false );
+ mActionRotateLabel->setEnabled( false );
+ mActionChangeLabelProperties->setEnabled( false );
return;
@@ -6247,11 +6254,29 @@
dprovider->capabilities() & QgsVectorDataProvider::AddFeatures );
mActionMergeFeatureAttributes->setEnabled( layerHasSelection );
+ if ( layer->customProperty( "labeling" ).toString() == QString( "pal" ) )
+ int colX, colY, colAng;
+ mActionMoveLabel->setEnabled( qobject_cast<QgsMapToolMoveLabel*>( mMapTools.mMoveLabel ) && qobject_cast<QgsMapToolMoveLabel*>( mMapTools.mMoveLabel )->layerIsMoveable( layer, colX, colY ) );
+ mActionRotateLabel->setEnabled( qobject_cast<QgsMapToolRotateLabel*>( mMapTools.mRotateLabel ) && qobject_cast<QgsMapToolRotateLabel*>( mMapTools.mMoveLabel )->layerIsRotatable( layer, colAng ) );
+ mActionChangeLabelProperties->setEnabled( true );
+ else
else
mActionMergeFeatures->setEnabled( false );
mActionMergeFeatureAttributes->setEnabled( false );
// moving enabled if geometry changes are supported
Modified: trunk/qgis/src/app/qgsmaptoolmovelabel.h
--- trunk/qgis/src/app/qgsmaptoolmovelabel.h 2010-11-29 20:40:42 UTC (rev 14797)
+++ trunk/qgis/src/app/qgsmaptoolmovelabel.h 2010-11-29 20:40:51 UTC (rev 14798)
@@ -35,6 +35,12 @@
virtual void canvasReleaseEvent( QMouseEvent * e );
+ /**Returns true if layer move can be applied to a layer
+ @param xCol out: index of the attribute for data defined x coordinate
+ @param yCol out: index of the attribute for data defined y coordinate
+ @return true if labels of layer can be moved*/
+ bool layerIsMoveable( const QgsMapLayer* ml, int& xCol, int& yCol ) const;
protected:
/**Get data defined position of a feature
@param layerId layer identification string
@@ -47,12 +53,6 @@
@return false if layer does not have data defined label position enabled*/
bool dataDefinedPosition( QgsVectorLayer* vlayer, int featureId, double& x, bool& xSuccess, double& y, bool& ySuccess, int& xCol, int& yCol ) const;
- /**Returns true if layer move can be applied to a layer
- @param xCol out: index of the attribute for data defined x coordinate
- @param yCol out: index of the attribute for data defined y coordinate
- @return true if labels of layer can be moved*/
- bool layerIsMoveable( const QgsMapLayer* ml, int& xCol, int& yCol ) const;
/**Start point of the move in map coordinates*/
QgsPoint mStartPointMapCoords;
Modified: trunk/qgis/src/app/qgsmaptoolrotatelabel.h
--- trunk/qgis/src/app/qgsmaptoolrotatelabel.h 2010-11-29 20:40:42 UTC (rev 14797)
+++ trunk/qgis/src/app/qgsmaptoolrotatelabel.h 2010-11-29 20:40:51 UTC (rev 14798)
@@ -33,10 +33,11 @@
virtual void canvasMoveEvent( QMouseEvent * e );
- protected:
/**Checks if labels in a layer can be rotated
@param rotationCol out: attribute column for data defined label rotation*/
bool layerIsRotatable( const QgsMapLayer* layer, int& rotationCol ) const;
+ protected:
/**Returns data defined rotation of a feature.
@param rotation out: rotation value
@param rotationSuccess out: false if rotation value is NULL
