[QGIS Commit] r14381 - trunk/qgis/src/app
svn_qgis at osgeo.org
Fri Oct 15 19:05:11 EDT 2010
Author: timlinux
Date: 2010-10-15 16:05:11 -0700 (Fri, 15 Oct 2010)
New Revision: 14381
trunk/qgis/src/app/qgsrasterlayerproperties.cpp
Show actual pixel values on x axis of raster histogram
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.cpp
--- trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2010-10-14 15:42:55 UTC (rev 14380)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2010-10-15 23:05:11 UTC (rev 14381)
@@ -1872,8 +1872,8 @@
// Set axis titles
mpPlot->setAxisTitle( QwtPlot::xBottom, QObject::tr("Pixel Value") );
mpPlot->setAxisTitle( QwtPlot::yLeft, QObject::tr("Frequency") );
- mpPlot->setAxisAutoScale( QwtPlot::xBottom );
mpPlot->setAxisAutoScale( QwtPlot::yLeft );
+ // x axis scale only set after computing global min/max across bands (see below)
// add a grid
QwtPlotGrid * myGrid = new QwtPlotGrid();
myGrid->attach(mpPlot);
@@ -1905,6 +1905,9 @@
// scan through to get counts from layers' histograms
+ float myGlobalMin = 0;
+ float myGlobalMax = 0;
+ bool myFirstIteration = true;
for ( int myIteratorInt = 1;
myIteratorInt <= myBandCountInt;
++myIteratorInt )
@@ -1924,7 +1927,22 @@
mypCurve->setData(myX2Data,myY2Data);
mypCurve->attach(mpPlot);
+ if ( myFirstIteration || myGlobalMin < myRasterBandStats.minimumValue )
+ myGlobalMin = myRasterBandStats.minimumValue;
+ if ( myFirstIteration || myGlobalMax < myRasterBandStats.maximumValue )
+ myGlobalMax = myRasterBandStats.maximumValue;
+ myFirstIteration = false;
+ // for x axis use band pixel values rather than gdal hist. bin values
+ // subtract -0.5 to prevent rounding errors
+ // see http://www.gdal.org/classGDALRasterBand.html#3f8889607d3b2294f7e0f11181c201c8
+ mpPlot->setAxisScale ( QwtPlot::xBottom,
+ myGlobalMin - 0.5,
+ myGlobalMax + 0.5 );
mpPlot->replot();
disconnect( mRasterLayer, SIGNAL( progressUpdate( int ) ), mHistogramProgress, SLOT( setValue( int ) ) );
mHistogramProgress->hide();
