[QGIS Commit] r14383 - trunk/qgis/src/plugins/grass/modules-6.4
svn_qgis at osgeo.org
Sat Oct 16 09:21:44 EDT 2010
Author: pcav
Date: 2010-10-16 06:21:44 -0700 (Sat, 16 Oct 2010)
New Revision: 14383
Added:
trunk/qgis/src/plugins/grass/modules-6.4/r.external.2.png
trunk/qgis/src/plugins/grass/modules-6.4/r.external.all.2.png
trunk/qgis/src/plugins/grass/modules-6.4/r.external.qgis.2.png
trunk/qgis/src/plugins/grass/modules-6.4/default.qgc
Polished GRASS modules tree. Thanks Markus Neteler. Applies #3104
Modified: trunk/qgis/src/plugins/grass/modules-6.4/default.qgc
--- trunk/qgis/src/plugins/grass/modules-6.4/default.qgc 2010-10-16 12:43:35 UTC (rev 14382)
+++ trunk/qgis/src/plugins/grass/modules-6.4/default.qgc 2010-10-16 13:21:44 UTC (rev 14383)
@@ -5,57 +5,82 @@
<section label="GRASS MODULES">
<grass name="shell"/>
+ <section label="Create new GRASS location and transfer data into it">
+ <section label="Create new GRASS location from metadata file">
+ <grass name="g.proj.wkt"/>
+ </section>
+ <section label="Create new GRASS location from raster data">
+ <grass name="r.in.gdal.qgis.loc"/>
+ <grass name="r.in.gdal.qgis"/>
+ <grass name="r.external.qgis"/>
+ </section>
+ <section label="Create new GRASS location from vector data">
+ <grass name="v.in.ogr.qgis.loc"/>
+ <grass name="v.in.ogr.qgis"/>
+ </section>
+ <section label="Print projection information from a georeferenced file and create a new location based on it">
+ <grass name="g.proj.geo.new"/>
+ <grass name="g.proj.ascii.new"/>
+ <grass name="g.proj.proj.new"/>
+ </section>
+ </section>
+ <section label="File management">
+ <section label="Import into GRASS">
+ <section label="Import raster into GRASS">
+ <section label="Import raster into GRASS from QGIS view">
+ </section>
+ <section label="Register external data sources in GRASS">
+ <grass name="r.external"/>
+ <grass name="r.external.all"/>
+ </section>
+ <section label="Import raster into GRASS from external data sources in GRASS">
+ <grass name="r.in.gdal"/>
+ <grass name="r.in.gdal.loc"/>
+ <grass name="r.in.xyz"/>
+ <grass name="r.in.ascii"/>
+ <grass name="r.in.poly"/>
+ <grass name="r.in.bin"/>
+ <grass name="r.in.arc"/>
+ <grass name="r.in.gridatb"/>
+ <grass name="r.in.mat"/>
+ <grass name="i.in.spotvgt"/>
+ <grass name="r.in.srtm"/>
+ <grass name="r.in.aster"/>
+ <grass name="r.in.wms"/>
+ </section>
- <section label="Create new location">
- <grass name="g.proj.wkt"/>
- </section>
- <section label="File">
- <section label="Import">
- <section label="Import raster">
- <grass name="r.in.gdal.qgis"/>
- <grass name="r.in.gdal.qgis.loc"/>
- <grass name="r.in.gdal"/>
- <grass name="r.in.gdal.loc"/>
- <grass name="r.in.xyz"/>
- <grass name="r.in.ascii"/>
- <grass name="r.in.poly"/>
- <grass name="r.in.bin"/>
- <grass name="r.in.arc"/>
- <grass name="r.in.gridatb"/>
- <grass name="r.in.mat"/>
- <grass name="i.in.spotvgt"/>
- <grass name="r.in.srtm"/>
- <grass name="r.in.aster"/>
- <grass name="r.in.wms"/>
- <grass name="r.external"/>
- <grass name="r.external.qgis"/>
- <grass name="r.external.all"/>
</section>
- <section label="Import vector">
- <grass name="v.in.ogr.qgis"/>
- <grass name="v.in.ogr.qgis.loc"/>
- <grass name="v.in.ogr"/>
- <grass name="v.in.ogr.loc"/>
- <grass name="v.in.ogr.all"/>
- <grass name="v.in.ogr.all.loc"/>
- <grass name="v.in.dxf"/>
- <grass name="v.in.e00"/>
- <grass name="v.in.mapgen"/>
- <grass name="v.in.db"/>
- <grass name="v.in.garmin"/>
- <grass name="v.in.gpsbabel"/>
- <grass name="v.in.geonames"/>
- <grass name="v.in.gns"/>
+ <section label="Import vector into GRASS">
+ <section label="Import vector into GRASS from QGIS view">
+ </section>
+ <section label="Import vector into GRASS from external data sources in GRASS">
+ <grass name="v.in.ogr"/>
+ <grass name="v.in.ogr.loc"/>
+ <grass name="v.in.ogr.all"/>
+ <grass name="v.in.ogr.all.loc"/>
+ <grass name="v.in.dxf"/>
+ <grass name="v.in.e00"/>
+ <grass name="v.in.mapgen"/>
+ <grass name="v.in.db"/>
+ <grass name="v.in.garmin"/>
+ <grass name="v.in.gpsbabel"/>
+ <grass name="v.in.geonames"/>
+ <grass name="v.in.gns"/>
+ </section>
</section>
- <section label="Database">
+<section label="Import from database into GRASS">
<grass name="db.in.ogr"/>
</section>
</section>
- <section label="Export">
- <section label="Export raster">
+ <section label="Export from GRASS">
+ <section label="Export raster from GRASS">
+ <grass name="r.out.gdal.gtiff"/>
<grass name="r.out.gdal"/>
- <grass name="r.out.gdal.gtiff"/>
<grass name="r.out.ascii"/>
<grass name="r.out.xyz"/>
<grass name="r.out.arc"/>
@@ -71,7 +96,7 @@
<grass name="r.out.vrml"/>
<grass name="r.out.vtk"/>
</section>
- <section label="Export vector">
+ <section label="Export vector from GRASS">
<grass name="v.out.ogr"/>
<grass name="v.out.ogr.pg"/>
<grass name="v.out.ogr.gml"/>
@@ -82,50 +107,38 @@
<grass name="v.out.svg"/>
<grass name="v.out.vtk"/>
</section>
- <section label="Export vector table">
+ <section label="Export vector table from GRASS to database format">
<grass name="db.out.ogr"/>
</section>
</section>
<section label="Map type conversion">
- <section label="Convert a raster to vector">
+ <section label="Convert a raster to vector within GRASS">
<grass name="r.to.vect.point"/>
<grass name="r.to.vect.line"/>
<grass name="r.to.vect.area"/>
</section>
- <section label="Convert a vector to raster">
+ <section label="Convert a vector to raster within GRASS">
<grass name="v.to.rast.constant"/>
<grass name="v.to.rast.attr"/>
</section>
</section>
</section>
- <section label="Config">
- <section label="Region">
- <section label="Region settings">
- <grass name="g.region.save"/>
- <grass name="g.region.zoom"/>
- <grass name="g.region.multiple.raster"/>
- <grass name="g.region.multiple.vector"/>
- </section>
- <section label="Projection management">
- <section label="Print projection information of the current location">
- <grass name="g.proj.print"/>
- </section>
- <section label="Print projection information from a georeferenced file">
- <grass name="g.proj.geo"/>
- <grass name="g.proj.ascii"/>
- <grass name="g.proj.proj"/>
- </section>
- <section label="Print projection information from a georeferenced file and create a new location based on it">
- <grass name="g.proj.geo.new"/>
- <grass name="g.proj.ascii.new"/>
- <grass name="g.proj.proj.new"/>
- </section>
- </section>
- <section label="Convert coordinates">
- <grass name="m.cogo"/>
- </section>
+ <section label="Region settings">
+ <grass name="g.region.save"/>
+ <grass name="g.region.zoom"/>
+ <grass name="g.region.multiple.raster"/>
+ <grass name="g.region.multiple.vector"/>
+ </section>
+ <section label="Projection management">
+ <section label="Print projection information of the current location">
+ <grass name="g.proj.print"/>
</section>
+ <section label="Print projection information from a georeferenced file">
+ <grass name="g.proj.geo"/>
+ <grass name="g.proj.ascii"/>
+ <grass name="g.proj.proj"/>
+ </section>
</section>
<section label="Raster">
@@ -477,6 +490,10 @@
<section label="3d Visualization">
<grass name="nviz"/>
</section>
+ <section label="Convert coordinates">
+ <grass name="m.cogo"/>
+ <grass name="m.proj"/>
+ </section>
<section label="Help">
<grass name="g.manual"/>
Added: trunk/qgis/src/plugins/grass/modules-6.4/r.external.2.png
(Binary files differ)
Property changes on: trunk/qgis/src/plugins/grass/modules-6.4/r.external.2.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: trunk/qgis/src/plugins/grass/modules-6.4/r.external.all.2.png
Property changes on: trunk/qgis/src/plugins/grass/modules-6.4/r.external.all.2.png
Added: trunk/qgis/src/plugins/grass/modules-6.4/r.external.qgis.2.png
Property changes on: trunk/qgis/src/plugins/grass/modules-6.4/r.external.qgis.2.png
