[QGIS Commit] r14396 - in trunk/qgis/tests: src/core testdata
svn_qgis at osgeo.org
Mon Oct 18 11:12:03 EDT 2010
Author: timlinux
Date: 2010-10-18 08:12:03 -0700 (Mon, 18 Oct 2010)
New Revision: 14396
Added:
trunk/qgis/tests/src/core/testqgsvectorlayer.cpp
trunk/qgis/tests/testdata/nonspatial.dbf
trunk/qgis/tests/src/core/CMakeLists.txt
Beginnings of unit test for vector layer
Modified: trunk/qgis/tests/src/core/CMakeLists.txt
--- trunk/qgis/tests/src/core/CMakeLists.txt 2010-10-18 00:40:19 UTC (rev 14395)
+++ trunk/qgis/tests/src/core/CMakeLists.txt 2010-10-18 15:12:03 UTC (rev 14396)
@@ -116,4 +116,5 @@
ADD_QGIS_TEST(coordinatereferencesystemtest testqgscoordinatereferencesystem.cpp)
ADD_QGIS_TEST(pointtest testqgspoint.cpp)
ADD_QGIS_TEST(searchstringtest testqgssearchstring.cpp)
+ADD_QGIS_TEST(vectorlayertest testqgsvectorlayer.cpp)
Added: trunk/qgis/tests/src/core/testqgsvectorlayer.cpp
--- trunk/qgis/tests/src/core/testqgsvectorlayer.cpp (rev 0)
+++ trunk/qgis/tests/src/core/testqgsvectorlayer.cpp 2010-10-18 15:12:03 UTC (rev 14396)
@@ -0,0 +1,650 @@
+ test_template.cpp
+ Date : Sun Sep 16 12:22:23 AKDT 2007
+ Copyright : (C) 2007 by Gary E. Sherman
+ Email : sherman at mrcc dot com
+ * This program is free software; you can redistribute it and/or modify *
+ * it under the terms of the GNU General Public License as published by *
+ * the Free Software Foundation; either version 2 of the License, or *
+ * (at your option) any later version. *
+#include <QtTest>
+#include <QObject>
+#include <QString>
+#include <QStringList>
+#include <QObject>
+#include <QApplication>
+#include <QFileInfo>
+#include <QDir>
+#include <QDesktopServices>
+#include <iostream>
+//qgis includes...
+#include <qgsmaprenderer.h>
+#include <qgsmaplayer.h>
+#include <qgsvectordataprovider.h>
+#include <qgsvectorlayer.h>
+#include <qgsapplication.h>
+#include <qgsproviderregistry.h>
+#include <qgsmaplayerregistry.h>
+//qgis test includes
+#include "qgsrenderchecker.h"
+/** \ingroup UnitTests
+ * This is a unit test for the vector layer class.
+class TestQgsVectorLayer: public QObject
+ Q_OBJECT;
+ private:
+ bool mTestHasError;
+ QgsMapRenderer * mpMapRenderer;
+ QgsMapLayer * mpPointsLayer;
+ QgsMapLayer * mpLinesLayer;
+ QgsMapLayer * mpPolysLayer;
+ QgsVectorLayer * mpNonSpatialLayer;
+ QString mTestDataDir;
+ QString mReport;
+ private slots:
+ // will be called before the first testfunction is executed.
+ void initTestCase()
+ mTestHasError = false;
+ // init QGIS's paths - true means that all path will be inited from prefix
+ QString qgisPath = QCoreApplication::applicationDirPath();
+ QgsApplication::setPrefixPath( INSTALL_PREFIX, true );
+ QgsApplication::showSettings();
+ // Instantiate the plugin directory so that providers are loaded
+ QgsProviderRegistry::instance( QgsApplication::pluginPath() );
+ //create some objects that will be used in all tests...
+ std::cout << "Prefix PATH: " << QgsApplication::prefixPath().toLocal8Bit().data() << std::endl;
+ std::cout << "Plugin PATH: " << QgsApplication::pluginPath().toLocal8Bit().data() << std::endl;
+ std::cout << "PkgData PATH: " << QgsApplication::pkgDataPath().toLocal8Bit().data() << std::endl;
+ std::cout << "User DB PATH: " << QgsApplication::qgisUserDbFilePath().toLocal8Bit().data() << std::endl;
+ //create a non spatial layer that will be used in all tests...
+ QString myDataDir( TEST_DATA_DIR ); //defined in CmakeLists.txt
+ mTestDataDir = myDataDir + QDir::separator();
+ QString myDbfFileName = mTestDataDir + "nonspatial.dbf";
+ QFileInfo myDbfFileInfo( myDbfFileName );
+ mpNonSpatialLayer = new QgsVectorLayer( myDbfFileInfo.filePath(),
+ myDbfFileInfo.completeBaseName(), "ogr" );
+ // Register the layer with the registry
+ QgsMapLayerRegistry::instance()->addMapLayer( mpNonSpatialLayer );
+ //create a point layer that will be used in all tests...
+ QString myPointsFileName = mTestDataDir + "points.shp";
+ QFileInfo myPointFileInfo( myPointsFileName );
+ mpPointsLayer = new QgsVectorLayer( myPointFileInfo.filePath(),
+ myPointFileInfo.completeBaseName(), "ogr" );
+ QgsMapLayerRegistry::instance()->addMapLayer( mpPointsLayer );
+ //create a poly layer that will be used in all tests...
+ QString myPolysFileName = mTestDataDir + "polys.shp";
+ QFileInfo myPolyFileInfo( myPolysFileName );
+ mpPolysLayer = new QgsVectorLayer( myPolyFileInfo.filePath(),
+ myPolyFileInfo.completeBaseName(), "ogr" );
+ QgsMapLayerRegistry::instance()->addMapLayer( mpPolysLayer );
+ // Create a line layer that will be used in all tests...
+ QString myLinesFileName = mTestDataDir + "lines.shp";
+ QFileInfo myLineFileInfo( myLinesFileName );
+ mpLinesLayer = new QgsVectorLayer( myLineFileInfo.filePath(),
+ myLineFileInfo.completeBaseName(), "ogr" );
+ QgsMapLayerRegistry::instance()->addMapLayer( mpLinesLayer );
+ // We only need maprender instead of mapcanvas
+ // since maprender does not require a qui
+ // and is more light weight
+ mpMapRenderer = new QgsMapRenderer();
+ QStringList myLayers;
+ myLayers << mpPointsLayer->getLayerID();
+ myLayers << mpPolysLayer->getLayerID();
+ myLayers << mpLinesLayer->getLayerID();
+ mpMapRenderer->setLayerSet( myLayers );
+ mReport += "<h1>Vector Renderer Tests</h1>\n";
+ // will be called after the last testfunction was executed.
+ void cleanupTestCase()
+ QString myReportFile = QDir::tempPath() + QDir::separator() + "renderertest.html";
+ QFile myFile( myReportFile );
+ if ( myFile.open( QIODevice::WriteOnly ) )
+ QTextStream myQTextStream( &myFile );
+ myQTextStream << mReport;
+ myFile.close();
+ QDesktopServices::openUrl( "file://" + myReportFile );
+ void init() {};// will be called before each testfunction is executed.
+ void cleanup() {};// will be called after every testfunction.
+ void QgsVectorLayerNonSpatialIterator()
+ QgsVectorDataProvider * myProvider = mpNonSpatialLayer->dataProvider();
+ QgsFeature f;
+ int myCount = 0;
+ myProvider->select();
+ while ( myProvider->nextFeature( f ) )
+ qDebug("Getting feature from provider");
+ myCount++;
+ QVERIFY( myCount > 10);
+ void QgsVectorLayerstorageType()
+ void QgsVectorLayercapabilitiesString()
+ void QgsVectorLayerdataComment()
+ void QgsVectorLayerproviderType()
+ void QgsVectorLayersetDisplayField()
+ void QgsVectorLayerdrawLabels()
+ void QgsVectorLayerdrawLineString()
+ void QgsVectorLayerdrawPolygon()
+ void QgsVectorLayerdrawRendererV2()
+ void QgsVectorLayerdrawRendererV2Levels()
+ void QgsVectorLayerreload()
+ void QgsVectorLayerdraw()
+ void QgsVectorLayerdeleteCachedGeometries()
+ void QgsVectorLayerdrawVertexMarker()
+ void QgsVectorLayerselect()
+ void QgsVectorLayerinvertSelection()
+ void QgsVectorLayerinvertSelectionInRectangle()
+ void QgsVectorLayerremoveSelection()
+ void QgsVectorLayertriggerRepaint()
+ void QgsVectorLayerdataProvider()
+ void QgsVectorLayersetProviderEncoding()
+ void QgsVectorLayerrenderer()
+ void QgsVectorLayersetRenderer()
+ void QgsVectorLayergeometryType()
+ void QgsVectorLayerwkbType()
+ void QgsVectorLayerboundingBoxOfSelected()
+ void QgsVectorLayerfeatureCount()
+ void QgsVectorLayerupdateFeatureCount()
+ void QgsVectorLayerupdateExtents()
+ void QgsVectorLayersubsetString()
+ void QgsVectorLayersetSubsetString()
+ void QgsVectorLayerupdateFeatureAttributes()
+ void QgsVectorLayerupdateFeatureGeometry()
+ void QgsVectorLayernextFeature()
+ void QgsVectorLayerfeatureAtId()
+ void QgsVectorLayeraddFeature()
+ void QgsVectorLayerinsertVertex()
+ void QgsVectorLayermoveVertex()
+ void QgsVectorLayerdeleteVertex()
+ void QgsVectorLayerdeleteSelectedFeatures()
+ void QgsVectorLayeraddRing()
+ void QgsVectorLayeraddIsland()
+ void QgsVectorLayertranslateFeature()
+ void QgsVectorLayersplitFeatures()
+ void QgsVectorLayerremovePolygonIntersections()
+ void QgsVectorLayeraddTopologicalPoints()
+ void QgsVectorLayerlabel()
+ void QgsVectorLayerenableLabels()
+ void QgsVectorLayerhasLabelsEnabled()
+ void QgsVectorLayerstartEditing()
+ void QgsVectorLayerreadXml()
+ void QgsVectorLayersetDataProvider()
+ void QgsVectorLayerwriteXml()
+ void QgsVectorLayerreadSymbology()
+ void QgsVectorLayerwriteSymbology()
+ void QgsVectorLayerchangeGeometry()
+ void QgsVectorLayerchangeAttributeValue()
+ void QgsVectorLayeraddAttribute()
+ void QgsVectorLayeraddAttributeAlias()
+ void QgsVectorLayerattributeAlias()
+ void QgsVectorLayerattributeDisplayName()
+ void QgsVectorLayerdeleteAttribute()
+ void QgsVectorLayerdeleteFeature()
+ void QgsVectorLayerpendingFields()
+ void QgsVectorLayerpendingAllAttributesList()
+ void QgsVectorLayerpendingFeatureCount()
+ void QgsVectorLayercommitChanges()
+ void QgsVectorLayercommitErrors()
+ void QgsVectorLayerrollBack()
+ void QgsVectorLayersetSelectedFeatures()
+ void QgsVectorLayerselectedFeatureCount()
+ void QgsVectorLayerselectedFeaturesIds()
+ void QgsVectorLayerselectedFeatures()
+ void QgsVectorLayeraddFeatures()
+ void QgsVectorLayercopySymbologySettings()
+ void QgsVectorLayerhasCompatibleSymbology()
+ void QgsVectorLayersnapPoint()
+ void QgsVectorLayersnapWithContext()
+ void QgsVectorLayersnapToGeometry()
+ void QgsVectorLayerinsertSegmentVerticesForSnap()
+ void QgsVectorLayerboundingBoxFromPointList()
+ void QgsVectorLayercurrentVertexMarkerType()
+ void QgsVectorLayercurrentVertexMarkerSize()
+ void QgsVectorLayerdrawFeature()
+ void QgsVectorLayersetCoordinateSystem()
+ void QgsVectorLayertransformPoint()
+ void QgsVectorLayertransformPoints()
+ void QgsVectorLayerdisplayField()
+ void QgsVectorLayerisEditable()
+ void QgsVectorLayerisModified()
+ void QgsVectorLayersetModified()
+ void QgsVectorLayereditType()
+ void QgsVectorLayersetEditType()
+ void QgsVectorLayereditForm()
+ void QgsVectorLayersetEditForm()
+ void QgsVectorLayersetAnnotationForm()
+ void QgsVectorLayereditFormInit()
+ void QgsVectorLayersetEditFormInit()
+ void QgsVectorLayervalueMap()
+ void QgsVectorLayerrange()
+ void QgsVectorLayeraddOverlay()
+ void QgsVectorLayerremoveOverlay()
+ void QgsVectorLayervectorOverlays()
+ void QgsVectorLayerfindOverlayByType()
+ void QgsVectorLayerrendererV2()
+ void QgsVectorLayersetRendererV2()
+ void QgsVectorLayerisUsingRendererV2()
+ void QgsVectorLayersetUsingRendererV2()
+ void QgsVectorLayereditGeometryChange()
+ void QgsVectorLayereditFeatureAdd()
+ void QgsVectorLayereditFeatureDelete()
+ void QgsVectorLayereditAttributeChange()
+ void QgsVectorLayerbeginEditCommand()
+ void QgsVectorLayerendEditCommand()
+ void QgsVectorLayerdestroyEditCommand()
+ void QgsVectorLayerredoEditCommand()
+ void QgsVectorLayerundoEditCommand()
+ void QgsVectorLayersetCheckedState()
+ void QgsVectorLayercheckedState()
+ void QgsVectorLayerfieldNameIndex()
+ void QgsVectorLayerstopRendererV2()
+QTEST_MAIN(TestQgsVectorLayer)
+#include "moc_testqgsvectorlayer.cxx"
Added: trunk/qgis/tests/testdata/nonspatial.dbf
(Binary files differ)
Property changes on: trunk/qgis/tests/testdata/nonspatial.dbf
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
