[QGIS Commit] r14435 - in trunk/qgis/src: app providers/spatialite
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Oct 26 04:58:16 EDT 2010
Author: esseffe
Date: 2010-10-26 01:58:16 -0700 (Tue, 26 Oct 2010)
New Revision: 14435
   trunk/qgis/src/app/qgsspatialitesourceselect.cpp
   trunk/qgis/src/app/qgsspatialitesourceselect.h
   trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp
   trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.h
a) applied the patch suggested in ticket #3139
b) fixed the SourceSelect dialog so to avoid
   showing RasterLite-1 related tables
Modified: trunk/qgis/src/app/qgsspatialitesourceselect.cpp
--- trunk/qgis/src/app/qgsspatialitesourceselect.cpp	2010-10-25 21:01:50 UTC (rev 14434)
+++ trunk/qgis/src/app/qgsspatialitesourceselect.cpp	2010-10-26 08:58:16 UTC (rev 14435)
@@ -507,6 +507,8 @@
     for ( i = 1; i <= rows; i++ )
+      if ( isRasterlite1Datasource( handle, results[( i * columns ) + 0] ) )
+        continue;
       QString tableName = QString::fromUtf8( results[( i * columns ) + 0] );
       QString column = QString::fromUtf8( results[( i * columns ) + 1] );
       QString type = results[( i * columns ) + 2];
@@ -698,6 +700,52 @@
   return exists;
+bool QgsSpatiaLiteSourceSelect::isRasterlite1Datasource (sqlite3 * handle, const char *table)
+// testing for RasterLite-1 datasources
+  int ret;
+  int i;
+  char **results;
+  int rows;
+  int columns;
+  bool exists = false;
+  int len;
+  char table_raster[4192];
+  char sql[4192];
+  strcpy ( table_raster, table );
+  len =  strlen( table_raster );
+  if (strlen( table_raster ) < 9)
+      return false;
+  if (strcmp( table_raster + len - 9, "_metadata" ) != 0)
+      return false;
+  // ok, possible candidate
+  strcpy( table_raster + len - 9, "_rasters" );
+  // checking if the related "_RASTERS table exists
+  sprintf( sql, "SELECT name FROM sqlite_master WHERE type = 'table' AND name = '%s'", table_raster );
+  ret = sqlite3_get_table( handle, sql, &results, &rows, &columns, NULL );
+  if ( ret != SQLITE_OK )
+    return false;
+  if ( rows < 1 )
+  else
+    for ( i = 1; i <= rows; i++ )
+      if ( results[( i * columns ) + 0] != NULL )
+        const char *name = results[( i * columns ) + 0];
+        if ( name )
+          exists = true;
+  sqlite3_free_table( results );
+  return exists;
 bool QgsSpatiaLiteSourceSelect::isDeclaredHidden( sqlite3 * handle, QString table, QString geom )
   int ret;
Modified: trunk/qgis/src/app/qgsspatialitesourceselect.h
--- trunk/qgis/src/app/qgsspatialitesourceselect.h	2010-10-25 21:01:50 UTC (rev 14434)
+++ trunk/qgis/src/app/qgsspatialitesourceselect.h	2010-10-26 08:58:16 UTC (rev 14435)
@@ -117,6 +117,9 @@
     /**Checks if this layer has been declared HIDDEN*/
     bool isDeclaredHidden( sqlite3 * handle, QString table, QString geom );
+    /**Checks if this layer is a RasterLite-1 datasource*/
+    bool isRasterlite1Datasource( sqlite3 * handle, const char * table );
     /**cleaning well-formatted SQL strings*/
     QString quotedValue( QString value ) const;
Modified: trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp
--- trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp	2010-10-25 21:01:50 UTC (rev 14434)
+++ trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp	2010-10-26 08:58:16 UTC (rev 14435)
@@ -52,6 +52,8 @@
   mGeometryColumn = anUri.geometryColumn();
   mSqlitePath = anUri.database();
   mSubsetString = anUri.sql();
+  mPrimaryKey = anUri.keyColumn();
+  mQuery = mTableName;
   // trying to open the SQLite DB
   spatialite_init( 0 );
@@ -131,6 +133,7 @@
   int ret;
   int i;
+  sqlite3_stmt *stmt = NULL;
   char **results;
   int rows;
   int columns;
@@ -138,59 +141,130 @@
   QString pkName;
   int pkCount = 0;
   int fldNo = 0;
+  QString sql;
   attributeFields.clear();
-  mPrimaryKey.clear();
-  QString sql = QString( "PRAGMA table_info(\"%1\")" ).arg( mTableName );
+  if ( !isQuery )
+    mPrimaryKey.clear();
-  ret = sqlite3_get_table( sqliteHandle, sql.toUtf8().constData(), &results, &rows, &columns, &errMsg );
-  if ( ret != SQLITE_OK )
-    goto error;
-  if ( rows < 1 )
-  else
-    for ( i = 1; i <= rows; i++ )
+    sql = QString( "PRAGMA table_info(%1)" ).arg( quotedIdentifier( mTableName ) );
+    ret = sqlite3_get_table( sqliteHandle, sql.toUtf8().constData(), &results, &rows, &columns, &errMsg );
+      goto error;
+    if ( rows < 1 )
+    else
-      QString name = QString::fromUtf8( results[( i * columns ) + 1] );
-      const char *type = results[( i * columns ) + 2];
-      QString pk = results[( i * columns ) + 5];
-      if ( pk.toInt() != 0 )
-        // found a Primary Key column
-        pkCount++;
-        pkName = name;
-      if ( name != mGeometryColumn )
-        // for sure any SQLite value can be represented as SQLITE_TEXT
-        QVariant::Type fieldType = QVariant::String;
-        // making some assumptions in order to guess a more realistic type
-        if ( strcasecmp( type, "int" ) == 0 ||
-             strcasecmp( type, "integer" ) == 0 ||
-             strcasecmp( type, "bigint" ) == 0 ||
-             strcasecmp( type, "smallint" ) == 0 ||
-             strcasecmp( type, "tinyint" ) == 0 ||
-             strcasecmp( type, "boolean" ) == 0 )
+        QString name = QString::fromUtf8( results[( i * columns ) + 1] );
+        const char *type = results[( i * columns ) + 2];
+        QString pk = results[( i * columns ) + 5];
+        if ( pk.toInt() != 0 )
-          fieldType = QVariant::Int;
+          // found a Primary Key column
+          pkCount++;
+          pkName = name;
-        else if ( strcasecmp( type, "real" ) == 0 ||
-                  strcasecmp( type, "double" ) == 0 ||
-                  strcasecmp( type, "double precision" ) == 0 || strcasecmp( type, "float" ) == 0 )
+        if ( name != mGeometryColumn )
-          fieldType = QVariant::Double;
+          // for sure any SQLite value can be represented as SQLITE_TEXT
+          QVariant::Type fieldType = QVariant::String;
+          // making some assumptions in order to guess a more realistic type
+          if ( strcasecmp( type, "int" ) == 0 ||
+               strcasecmp( type, "integer" ) == 0 ||
+               strcasecmp( type, "bigint" ) == 0 ||
+               strcasecmp( type, "smallint" ) == 0 ||
+               strcasecmp( type, "tinyint" ) == 0 ||
+               strcasecmp( type, "boolean" ) == 0 )
+            fieldType = QVariant::Int;
+          else if ( strcasecmp( type, "real" ) == 0 ||
+               strcasecmp( type, "double" ) == 0 ||
+               strcasecmp( type, "double precision" ) == 0 || strcasecmp( type, "float" ) == 0 )
+            fieldType = QVariant::Double;
+          attributeFields.insert( fldNo++, QgsField( name, fieldType, type, 0, 0, "" ) );
-        attributeFields.insert( fldNo++, QgsField( name, fieldType, type, 0, 0, "" ) );
-  sqlite3_free_table( results );
+  else
+    sql = QString( "select * from %1 limit 1" ).arg( mQuery );
+    if ( sqlite3_prepare_v2( sqliteHandle, sql.toUtf8().constData(), -1, &stmt, NULL ) != SQLITE_OK )
+      // some error occurred
+      QgsDebugMsg( QString( "SQLite error: %1\n\nSQL: %2" )
+                   .arg( sql )
+                   .arg( QString::fromUtf8( sqlite3_errmsg( sqliteHandle ) ) ) );
+      return;
+    ret = sqlite3_step( stmt );
+    if ( ret == SQLITE_DONE )
+      // there are no rows to fetch
+      sqlite3_finalize( stmt );
+      return;
+    if ( ret == SQLITE_ROW )
+    // one valid row has been fetched from the result set
+      columns = sqlite3_column_count( stmt );
+      for ( i = 0; i < columns; i++ )
+        QString name = QString::fromUtf8( sqlite3_column_name( stmt, i ) );
+        const char *type = sqlite3_column_decltype( stmt, i );
+        if ( type == NULL )
+            type = "TEXT";
+        if ( name != mPrimaryKey )
+          pkCount++;
+          pkName = name;
   if ( pkCount == 1 )
     // setting the Primary Key column name
@@ -221,7 +295,9 @@
   feature.setValid( false );
-  QString sql = "SELECT ROWID";
+  QString primaryKey = !isQuery ? "ROWID" : quotedIdentifier( mPrimaryKey );
+  QString sql = QString( "SELECT %1" ).arg( primaryKey );
   for ( QgsAttributeList::const_iterator it = fetchAttributes.constBegin(); it != fetchAttributes.constEnd(); ++it )
     const QgsField & fld = field( *it );
@@ -232,7 +308,10 @@
     sql += QString( ", AsBinary(%1)" ).arg( quotedIdentifier( mGeometryColumn ) );
-  sql += QString( " FROM %1 WHERE ROWID = %2" ).arg( quotedIdentifier( mTableName ) ).arg( featureId );
+  sql += QString( " FROM %1 WHERE %2 = %3" )
+         .arg( mQuery )
+         .arg( primaryKey )
+         .arg( featureId );
@@ -267,7 +346,7 @@
       if ( ic == 0 )
-        // first column always contains the ROWID
+        // first column always contains the ROWID (or the primary key)
         feature.setFeatureId( sqlite3_column_int( stmt, ic ) );
       else
@@ -391,7 +470,7 @@
       if ( ic == 0 )
         feature.setFeatureId( sqlite3_column_int( sqliteStatement, ic ) );
       else
@@ -522,7 +601,9 @@
     sqliteStatement = NULL;
@@ -533,7 +614,7 @@
-  sql += QString( " FROM %1" ).arg( quotedIdentifier( mTableName ) );
+  sql += QString( " FROM %1" ).arg( mQuery );
   QString whereClause;
@@ -569,7 +650,10 @@
         mbrFilter += QString( "ymin <= %1 AND " ).arg( QString::number( rect.yMaximum(), 'f', 6 ) );
         mbrFilter += QString( "ymax >= %1" ).arg( QString::number( rect.yMinimum(), 'f', 6 ) );
         QString idxName = QString( "idx_%1_%2" ).arg( mIndexTable ).arg( mIndexGeometry );
-        whereClause += QString( "ROWID IN (SELECT pkid FROM %1 WHERE %2)" ).arg( quotedIdentifier( idxName ) ).arg( mbrFilter );
+        whereClause += QString( "%1 IN (SELECT pkid FROM %2 WHERE %3)" )
+                       .arg( quotedIdentifier( primaryKey ) )
+                       .arg( quotedIdentifier( idxName ) )
+                       .arg( mbrFilter );
       else if ( spatialIndexMbrCache )
@@ -579,7 +663,10 @@
                       arg( QString::number( rect.yMinimum(), 'f', 6 ) ).
                       arg( QString::number( rect.xMaximum(), 'f', 6 ) ).arg( QString::number( rect.yMaximum(), 'f', 6 ) );
         QString idxName = QString( "cache_%1_%2" ).arg( mIndexTable ).arg( mIndexGeometry );
-        whereClause += QString( "ROWID IN (SELECT rowid FROM %1 WHERE mbr = FilterMbrIntersects(%2))" ).arg( quotedIdentifier( idxName ) ).arg( mbr );
+        whereClause += QString( "%1 IN (SELECT rowid FROM %2 WHERE mbr = FilterMbrIntersects(%3))" )
+                       .arg( mbr );
       else
@@ -711,7 +798,7 @@
   // get the field name
   const QgsField & fld = field( index );
-  QString sql = QString( "SELECT Min(\"%1\") FROM \"%2\"" ).arg( fld.name() ).arg( mTableName );
+  QString sql = QString( "SELECT Min(%1) FROM %2" ).arg( quotedIdentifier( fld.name() ) ).arg( mQuery );
   if ( !mSubsetString.isEmpty() )
@@ -766,7 +853,7 @@
-  QString sql = QString( "SELECT Max(\"%1\") FROM \"%2\"" ).arg( fld.name() ).arg( mTableName );
+  QString sql = QString( "SELECT Max(%1) FROM %2" ).arg( quotedIdentifier( fld.name() ) ).arg( mQuery );
@@ -819,7 +906,7 @@
-  sql = QString( "SELECT DISTINCT \"%1\" FROM \"%2\" ORDER BY \"%1\"" ).arg( fld.name() ).arg( mTableName );
+  sql = QString( "SELECT DISTINCT %1 FROM %2 ORDER BY %1" ).arg( quotedIdentifier( fld.name() ) ).arg( mQuery );
@@ -1511,6 +1598,7 @@
   mTableBased = false;
   mViewBased = false;
   mVShapeBased = false;
+  isQuery = false;
 // checking if this one is a Table-based layer
   QString sql = QString( "SELECT read_only FROM geometry_columns "
@@ -1594,6 +1682,49 @@
+  // checking if this one is a select query
+  if ( mQuery.startsWith( "(select", Qt::CaseInsensitive ) &&
+       mQuery.endsWith( ")" ) )
+    // get a new alias for the subquery
+    int index = 0;
+    QString alias;
+    QRegExp regex;
+    do
+      alias = QString( "subQuery_%1" ).arg( QString::number( index++ ) );
+      QString pattern = QString( "(\\\"?)%1\\1" ).arg( QRegExp::escape( alias ) );
+      regex.setPattern( pattern );
+      regex.setCaseSensitivity( Qt::CaseInsensitive );
+    while ( mQuery.contains( regex ) );
+    // convert the custom query into a subquery
+    mQuery = QString( "%1 as %2" )
+             .arg( mQuery )
+             .arg( quotedIdentifier( alias ) );
+    sql = QString( "SELECT 0 FROM %1 LIMIT 1" ).arg( mQuery );
+    if ( ret == SQLITE_OK && rows == 1 )
+      isQuery = true;
+      mReadOnly = true;
+      count++;
+    if ( errMsg )
+      QgsDebugMsg( QString( "sqlite error %1 [%2]" ).arg( sql ).arg( errMsg ) );
+      sqlite3_free( errMsg );
+      errMsg = 0;
+  else
+    mQuery = quotedIdentifier( mTableName );
 // checking for validity
   return count == 1;
@@ -1607,6 +1738,8 @@
     ret = getViewGeometryDetails();
   if ( mVShapeBased )
     ret = getVShapeGeometryDetails();
+  if ( isQuery )
+    ret = getQueryGeometryDetails();
   return ret;
@@ -1845,6 +1978,122 @@
   return false;
+bool QgsSpatiaLiteProvider::getQueryGeometryDetails()
+  int ret;
+  int i;
+  char **results;
+  int rows;
+  int columns;
+  char *errMsg = NULL;
+  QString fType( "" );
+  QString xSrid( "" );
+  // get stuff from the relevant column instead. This may (will?)
+  // fail if there is no data in the relevant table.
+  QString sql = QString( "select srid(%1), geometrytype(%1) from %2" )
+        .arg( quotedIdentifier( mGeometryColumn ) )
+        .arg( mQuery );
+  //it is possible that the where clause restricts the feature type
+  if ( !mSubsetString.isEmpty() )
+    sql += " WHERE " + mSubsetString;
+  sql += " limit 1";
+    goto error;
+  if ( rows < 1 )
+  else
+      xSrid = results[( i * columns ) + 0];
+      fType = results[( i * columns ) + 1];
+  if ( !xSrid.isEmpty() && !fType.isEmpty() )
+    if ( fType == "GEOMETRY" )
+      // check to see if there is a unique geometry type
+      sql = QString( "select distinct "
+                     "case"
+                     " when geometrytype(%1) IN ('POINT','MULTIPOINT') THEN 'POINT'"
+                     " when geometrytype(%1) IN ('LINESTRING','MULTILINESTRING') THEN 'LINESTRING'"
+                     " when geometrytype(%1) IN ('POLYGON','MULTIPOLYGON') THEN 'POLYGON'"
+                     " end "
+                     "from %2" )
+            .arg( mQuery );
+        sql += " where " + mSubsetString;
+        goto error;
+      if ( rows != 1 )
+      else
+          fType = results[( 1 * columns ) + 0];
+    if ( fType == "POINT" )
+      geomType = QGis::WKBPoint;
+    else if ( fType == "MULTIPOINT" )
+      geomType = QGis::WKBMultiPoint;
+    else if ( fType == "LINESTRING" )
+      geomType = QGis::WKBLineString;
+    else if ( fType == "MULTILINESTRING" )
+      geomType = QGis::WKBMultiLineString;
+    else if ( fType == "POLYGON" )
+      geomType = QGis::WKBPolygon;
+    else if ( fType == "MULTIPOLYGON" )
+      geomType = QGis::WKBMultiPolygon;
+    mSrid = xSrid.toInt();
+  if ( geomType == QGis::WKBUnknown || mSrid < 0 )
+    goto error;
+  return getSridDetails();
+error:
+  // unexpected error
+  if ( errMsg != NULL )
+    QgsDebugMsg( QString( "SQL error: %1\n\n%2" ).arg( sql ).arg( errMsg ? QString::fromUtf8( errMsg ) : "unknown cause" ) );
+  return false;
 bool QgsSpatiaLiteProvider::getSridDetails()
   int ret;
@@ -1891,8 +2140,10 @@
   int columns;
-  QString sql = QString( "SELECT Min(MbrMinX(\"%1\")), Min(MbrMinY(\"%1\")), "
-                         "Max(MbrMaxX(\"%1\")), Max(MbrMaxY(\"%1\")), Count(*) " "FROM \"%2\"" ).arg( mGeometryColumn ).arg( mTableName );
+  QString sql = QString( "SELECT Min(MbrMinX(%1)), Min(MbrMinY(%1)), "
+                         "Max(MbrMaxX(%1)), Max(MbrMaxY(%1)), Count(*) " "FROM %2" )
+                .arg( mQuery );
Modified: trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.h
--- trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.h	2010-10-25 21:01:50 UTC (rev 14434)
+++ trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.h	2010-10-26 08:58:16 UTC (rev 14435)
@@ -257,6 +257,7 @@
     void repaintRequested();
   private:
     /** loads fields from input file to member attributeFields */
     void loadFields();
@@ -265,6 +266,10 @@
        * Flag indicating if the layer data source is a valid SpatiaLite layer
     bool valid;
+       * Flag indicating if the layer data source is based on a query
+    bool isQuery;
        * Flag indicating if the layer data source is based on a plain Table
@@ -290,6 +295,10 @@
     QString mTableName;
+       * Name of the table or subquery
+    QString mQuery;
        * Name of the primary key column in the table
     QString mPrimaryKey;
@@ -363,6 +372,7 @@
     bool getTableGeometryDetails();
     bool getViewGeometryDetails();
     bool getVShapeGeometryDetails();
+    bool getQueryGeometryDetails();
     bool getSridDetails();
     bool getTableSummary();
More information about the QGIS-commit mailing list
