[QGIS Commit] r14443 - trunk/qgis/src/analysis/raster
svn_qgis at osgeo.org
Thu Oct 28 02:50:05 EDT 2010
Author: mhugent
Date: 2010-10-27 23:50:05 -0700 (Wed, 27 Oct 2010)
New Revision: 14443
Added:
trunk/qgis/src/analysis/raster/qgsrastercalcparser.yy
Also add rastercalc bison file to svn
Added: trunk/qgis/src/analysis/raster/qgsrastercalcparser.yy
--- trunk/qgis/src/analysis/raster/qgsrastercalcparser.yy (rev 0)
+++ trunk/qgis/src/analysis/raster/qgsrastercalcparser.yy 2010-10-28 06:50:05 UTC (rev 14443)
@@ -0,0 +1,137 @@
+ qgsrastercalcparser.yy
+ Bison file for raster calculation parser
+ begin : 2010-10-25
+ copyright : (C) 2010 by Marco Hugentobler
+ email : marco dot hugentobler at sourcepole dot ch
+ * This program is free software; you can redistribute it and/or modify *
+ * it under the terms of the GNU General Public License as published by *
+ * the Free Software Foundation; either version 2 of the License, or *
+ * (at your option) any later version. *
+ #include "qgsrastercalcnode.h"
+ // don't redeclare malloc/free
+ #define YYINCLUDED_STDLIB_H 1
+ QgsRasterCalcNode* parseRasterCalcString(const QString& str, QString& parserErrorMsg);
+ //! from lex.yy.c
+ extern int rasterlex();
+ extern char* rastertext;
+ extern void set_raster_input_buffer(const char* buffer);
+ //! varible where the parser error will be stored
+ QString rParserErrorMsg;
+ //! sets gParserErrorMsg
+ void rastererror(const char* msg);
+ //! temporary list for nodes without parent (if parsing fails these nodes are removed)
+ QList<QgsRasterCalcNode*> gTmpNodes;
+ void joinTmpNodes(QgsRasterCalcNode* parent, QgsRasterCalcNode* left, QgsRasterCalcNode* right);
+ void addToTmpNodes(QgsRasterCalcNode* node);
+ // we want verbose error messages
+ #define YYERROR_VERBOSE 1
+%union { QgsRasterCalcNode* node; double number; QgsRasterCalcNode::Operator op;}
+%start root
+%token RASTER_BAND_REF
+%token<number> NUMBER
+%token<op> FUNCTION
+%type <node> root
+%type <node> raster_exp
+%left '+' '-'
+%left '*' '/'
+%left '^'
+root: raster_exp{}
+raster_exp:
+ FUNCTION '(' raster_exp ')' { $$ = new QgsRasterCalcNode($1, $3, 0); joinTmpNodes($$, $3, 0);}
+ | raster_exp '^' raster_exp { $$ = new QgsRasterCalcNode(QgsRasterCalcNode::opPOW, $1, $3); joinTmpNodes($$,$1,$3); }
+ | raster_exp '*' raster_exp { $$ = new QgsRasterCalcNode(QgsRasterCalcNode::opMUL, $1, $3); joinTmpNodes($$,$1,$3); }
+ | raster_exp '/' raster_exp { $$ = new QgsRasterCalcNode(QgsRasterCalcNode::opDIV, $1, $3); joinTmpNodes($$,$1,$3); }
+ | raster_exp '+' raster_exp { $$ = new QgsRasterCalcNode(QgsRasterCalcNode::opPLUS, $1, $3); joinTmpNodes($$,$1,$3); }
+ | raster_exp '-' raster_exp { $$ = new QgsRasterCalcNode(QgsRasterCalcNode::opMINUS, $1, $3); joinTmpNodes($$,$1,$3); }
+ | '(' raster_exp ')' { $$ = $2; }
+ | NUMBER { $$ = new QgsRasterCalcNode($1); addToTmpNodes($$); }
+ | RASTER_BAND_REF { $$ = new QgsRasterCalcNode(QString::fromUtf8(rastertext)); addToTmpNodes($$); }
+void addToTmpNodes(QgsRasterCalcNode* node)
+ gTmpNodes.append(node);
+void joinTmpNodes(QgsRasterCalcNode* parent, QgsRasterCalcNode* left, QgsRasterCalcNode* right)
+ bool res;
+ if (left)
+ res = gTmpNodes.removeAll(left);
+ Q_ASSERT(res);
+ if (right)
+ res = gTmpNodes.removeAll(right);
+ Q_ASSERT(res);
+ gTmpNodes.append(parent);
+QgsRasterCalcNode* parseRasterCalcString(const QString& str, QString& parserErrorMsg)
+ // list should be empty when starting
+ Q_ASSERT(gTmpNodes.count() == 0);
+ set_raster_input_buffer(str.toUtf8().constData());
+ int res = rasterparse();
+ // list should be empty when parsing was OK
+ if (res == 0) // success?
+ Q_ASSERT(gTmpNodes.count() == 1);
+ return gTmpNodes.takeFirst();
+ else // error?
+ parserErrorMsg = rParserErrorMsg;
+ // remove nodes without parents - to prevent memory leaks
+ while (gTmpNodes.size() > 0)
+ delete gTmpNodes.takeFirst();
+ return NULL;
+void rastererror(const char* msg)
+ rParserErrorMsg = msg;
