[QGIS Commit] r14455 - in trunk/qgis: cmake src/core
svn_qgis at osgeo.org
Sat Oct 30 10:27:23 EDT 2010
Author: jef
Date: 2010-10-30 07:27:23 -0700 (Sat, 30 Oct 2010)
New Revision: 14455
trunk/qgis/cmake/FindGSL.cmake
trunk/qgis/cmake/FindQWT.cmake
trunk/qgis/src/core/qgsvectorlayer.h
fix lenny build
Modified: trunk/qgis/cmake/FindGSL.cmake
--- trunk/qgis/cmake/FindGSL.cmake 2010-10-30 11:22:42 UTC (rev 14454)
+++ trunk/qgis/cmake/FindGSL.cmake 2010-10-30 14:27:23 UTC (rev 14455)
@@ -122,7 +122,7 @@
SET(GSL_FOUND 1)
- MESSAGE(STATUS "Found GSL: ${GSL_LIB}")
+ MESSAGE(STATUS "Found GSL: ${GSL_LIBRARIES}")
ENDIF(GSL_INCLUDE_DIR OR GSL_CXX_FLAGS)
ENDIF(GSL_LIBRARIES)
Modified: trunk/qgis/cmake/FindQWT.cmake
--- trunk/qgis/cmake/FindQWT.cmake 2010-10-30 11:22:42 UTC (rev 14454)
+++ trunk/qgis/cmake/FindQWT.cmake 2010-10-30 14:27:23 UTC (rev 14455)
@@ -7,36 +7,26 @@
# Once run this will define:
# QWT_FOUND = system has QWT lib
# QWT_LIBRARY = full path to the QWT library
+# QWT_INCLUDE_DIR = where to find headers
-# QWT_INCLUDE_DIR = where to find headers
#MESSAGE("Searching for QWT")
-FIND_PATH(QWT_INCLUDE_DIR qwt.h
+FIND_PATH(QWT_INCLUDE_DIR NAMES qwt.h PATHS
/usr/include
/usr/local/include
"$ENV{LIB_DIR}/include"
"$ENV{INCLUDE}"
PATH_SUFFIXES qwt-qt4 qwt
-FIND_LIBRARY(QWT_LIBRARY NAMES qwt qwt5 PATHS
+FIND_LIBRARY(QWT_LIBRARY NAMES qwt qwt5 qwt-qt4 qwt5-qt4 PATHS
/usr/lib
/usr/local/lib
"$ENV{LIB_DIR}/lib"
"$ENV{LIB}/lib"
-IF (NOT QWT_LIBRARY)
- # try using ubuntu lib naming
- FIND_LIBRARY(QWT_LIBRARY qwt-qt4 PATHS
- /usr/lib
- /usr/local/lib
- "$ENV{LIB_DIR}/lib"
- "$ENV{LIB}/lib"
-ENDIF (NOT QWT_LIBRARY)
IF (QWT_INCLUDE_DIR AND QWT_LIBRARY)
SET(QWT_FOUND TRUE)
Modified: trunk/qgis/src/core/qgsvectorlayer.h
--- trunk/qgis/src/core/qgsvectorlayer.h 2010-10-30 11:22:42 UTC (rev 14454)
+++ trunk/qgis/src/core/qgsvectorlayer.h 2010-10-30 14:27:23 UTC (rev 14455)
@@ -170,18 +170,30 @@
/** Sets the renderer. If a renderer is already present, it is deleted */
void setRenderer( QgsRenderer * r );
- /** Return renderer V2. Added in QGIS 1.4 */
+ /** Return renderer V2.
+ * @note added in 1.4 */
QgsFeatureRendererV2* rendererV2();
- /** Set renderer V2. Added in QGIS 1.4 */
+ /** Set renderer V2.
+ * @note ddded in 1.4
void setRendererV2( QgsFeatureRendererV2* r );
- /** Return whether using renderer V2. Added in QGIS 1.4 */
+ /** Return whether using renderer V2.
bool isUsingRendererV2();
- /** set whether to use renderer V2 for drawing. Added in QGIS 1.4 */
+ /** set whether to use renderer V2 for drawing.
void setUsingRendererV2( bool usingRendererV2 );
- /** Draw layer with renderer V2. Added in QGIS 1.4 */
+ /** Draw layer with renderer V2.
void drawRendererV2( QgsRenderContext& rendererContext, bool labeling );
- /** Draw layer with renderer V2 using symbol levels. Added in QGIS 1.4 */
+ /** Draw layer with renderer V2 using symbol levels.
void drawRendererV2Levels( QgsRenderContext& rendererContext, bool labeling );
/** Returns point, line or polygon */
@@ -248,11 +260,23 @@
virtual QString subsetString();
+ * Select features with or without attributes in a given window.
+ * @param fetchAttributes indizes of attributes to fetch
+ * @param rect window (QgsRectangle() for all)
+ * @param fetchGeometry fetch features with geometry
+ * @param useIntersect fetch only features that actually intersect the window (not just the bounding box)
void select( QgsAttributeList fetchAttributes,
QgsRectangle rect = QgsRectangle(),
bool fetchGeometry = true,
bool useIntersect = false );
+ * fetch a feature (after select)
+ * @param feature buffer to read the feature into
+ * @return true, if a feature was fetched, false, if there are no more features
bool nextFeature( QgsFeature& feature );
/**Gets the feature at the given feature id. Considers the changed, added, deleted and permanent features
@@ -358,7 +382,8 @@
/** Returns true if the provider is in editing mode */
virtual bool isEditable() const;
- /** Returns true if the provider is in read-only mode */
+ /** Returns true if the provider is in read-only mode
+ * @note added in 1.6 */
virtual bool isReadOnly() const;
/** Returns true if the provider has been modified since the last commit */
@@ -407,6 +432,7 @@
/** Make layer read-only (editing disabled) or not
* @return false if the layer is in editing yet
bool setReadOnly( bool readonly = true );
