[QGIS Commit] r14467 - in trunk/qgis: . doc
svn_qgis at osgeo.org
Sun Oct 31 14:09:25 EDT 2010
Author: kyngchaos
Date: 2010-10-31 11:09:25 -0700 (Sun, 31 Oct 2010)
New Revision: 14467
trunk/qgis/INSTALL
trunk/qgis/doc/osx.t2t
update OS X install
Modified: trunk/qgis/INSTALL
--- trunk/qgis/INSTALL 2010-10-31 18:04:50 UTC (rev 14466)
+++ trunk/qgis/INSTALL 2010-10-31 18:09:25 UTC (rev 14467)
@@ -1,7 +1,7 @@
Quantum GIS (QGIS)
Building QGIS from source - step by step
-Last update: 20101028
+Last update: 20101031
Last change: 20101028
1. Introduction
@@ -23,16 +23,14 @@
4.1. Building with Microsoft Visual Studio
4.2. Building using MinGW
4.3. Creation of MSYS environment for compilation of Quantum GIS
- 5. MacOS X: building using frameworks and cmake or Xcode
- 5.1. Install Xcode
- 5.2. Install Qt4 from .dmg
- 5.3. Install development frameworks for QGIS dependencies
- 5.4. Install CMake for OSX
- 5.5. Install subversion for OSX
- 5.6. Check out QGIS from SVN
- 5.7. Configure the build
- 5.8. Building
- 5.9. Running and packaging
+ 5. MacOS X: building using frameworks and Cmake
+ 5.1. Install Qt4 from .dmg
+ 5.2. Install development frameworks for QGIS dependencies
+ 5.3. Install CMake for OSX
+ 5.4. Install subversion for OSX
+ 5.5. Check out QGIS from SVN
+ 5.6. Configure the build
+ 5.7. Building
6. Authors and Acknowledgments
@@ -723,7 +721,7 @@
- sip
-This will also selected more packages that above packages depend on.
+This will also select packages the above packages depend on.
Additionally QGIS also needs the include file unistd.h, which normally
doesn't exist on Windows. It's shipped with Flex/Bison in GnuWin32\include
@@ -1263,40 +1261,41 @@
of space and it's not necessary at all.
In this approach I will try to avoid as much as possible building dependencies
from source and rather use frameworks wherever possible.
-The base system here is Mac OS X 10.4 (Tiger). Included are a few notes
-for building on Mac OS X 10.5 (Leopard) and 10.6 (Snow Leopard).
+The base system here is Mac OS X 10.4 (Tiger), with a single architecture build.
+Included are a few notes for building on Mac OS X 10.5 (Leopard) and 10.6 (Snow Leopard).
+Make sure to read each section completely before typing the first command you see.
-Snow Leopard note: A cmake/qt/sip bug currently exists where a 32-bit
-cmake build fails to provide python bindings. This means that python plugin support
-is currently lacking for 32-bit builds using cmake in Snow Leopard. See the Xcode
-build method to if you require python support.
+General note on Terminal usage: When I say "cd" to a folder in a Terminal,
+it means type "cd " (without the quotes, make sure to type a space after) and
+then type the path to said folder, then <return>. A simple way to do this without having to know
+and type the full path is, after type the "cd " part, drag the folder (use the icon
+in its window title bar, or drag a folder from within a window) from the Desktop
+to the Terminal, then tap <return>.
+Parallel Compilation: On multiprocessor/multicore Macs, it's possible to speed
+up compilation, but it's not automatic. Whenever you type "make" (but NOT "make install"),
+instead type:
-I recommend to get the latest Xcode dmg from the Apple XDC Web site
-(http:/developer.apple.com). The Mac system install disks come with a copy of
-Xcode, but it's likely out of date.
-Install Xcode after the ~1gb download is complete.
+ make -j [n]
-/!\ Note: It may be that you need to create some symlinks after installing
-Xcode (in particular if you are using Xcode 2.5 on Tiger):
+Replace [n] with the number of cores and/or processors your Mac has. On recent
+models with hyperthreading processors this can be double the physical count of
+processors and cores.
- cd /Developer/SDKs/MacOSX10.4u.sdk/usr/
- sudo mv local/ local_
- sudo ln -s /usr/local/ local
+ie: Mac Pro "8 Core" model (2 quad core processors) = 8
+ie: Macbook Pro i5 (hyperthreading) = 2 cores X 2 = 4
You need a minimum of Qt-4.4.0. I suggest getting the latest.
@@ -1306,7 +1305,10 @@
support in the Qt Cocoa branch. Appropriate installers are available for both
as of Qt-4.5.2. Qt 4.6+ is recommended for Cocoa.
+PPC note: There appear to be issues with Qt Cocoa on PPC Macs. QT Carbon
+is recommended on PPC Macs.
http://qt.nokia.com/downloads
@@ -1317,8 +1319,8 @@
privileges to install.
Qt note: Starting in Qt 4.4, libQtCLucene was added, and in 4.5
-libQtUiTools was added, both in /usr/lib. When using a system SDK (which will
-happen in the Xcode build), these libraries will not be found. To fix this problem,
+libQtUiTools was added, both in /usr/lib. When using a system SDK
+these libraries will not be found. To fix this problem,
add symlinks to /usr/local:
@@ -1331,7 +1333,7 @@
CMAKE_MODULE_LINKER_FLAGS and CMAKE_EXE_LINKER_FLAGS in the cmake build.
Download William Kyngesburye's excellent GDAL Complete package that includes
@@ -1360,7 +1362,7 @@
- 5.3.1. Additional Dependencies: General compatibility note
+ 5.2.1. Additional Dependencies: General compatibility note
There are some additional dependencies that, at the time of writing, are not
@@ -1375,7 +1377,7 @@
have problems and you are on your own with those.
- 5.3.2. Additional Dependencies: Expat
+ 5.2.2. Additional Dependencies: Expat
Snow Leopard note: Snow Leopard includes a usable expat, so this step is
@@ -1396,14 +1398,14 @@
- 5.3.3. Additional Dependencies: Python
+ 5.2.3. Additional Dependencies: Python
Leopard and Snow Leopard note: Leopard and Snow Leopard include a usable
Python 2.5 and 2.6, respectively. So there is no need to install Python on
Leopard and Snow Leopard. You can still install Python from python.org if preferred.
-Make sure you install at least the latest Python 2.5 from
+If installing from python.org, make sure you install at least the latest Python 2.x from
http://www.python.org/download/
@@ -1412,7 +1414,7 @@
Python 3 is a major change, and may have compatibility issues, so try it at your own risk.
- 5.3.4. Additional Dependencies: SIP
+ 5.2.4. Additional Dependencies: SIP
Retrieve the python bindings toolkit SIP from
@@ -1422,7 +1424,8 @@
Double-click the source tarball to unpack it, then, in Terminal.app, cd to the source folder
-and (this installs by default into the Python framework, and is appropriate only for python.org Python installs):
+and (this installs by default into the Python framework, and is appropriate only for
+python.org Python installs):
python configure.py
@@ -1461,7 +1464,7 @@
- 5.3.5. Additional Dependencies: PyQt
+ 5.2.5. Additional Dependencies: PyQt
Retrieve the python bindings toolkit for Qt from
@@ -1471,20 +1474,23 @@
python configure.py
yes
-There is a problem with the configuration that needs to be fixed now (it affects PyQwt compilation later). Edit pyqtconfig.py and change the qt_dir line to:
+There is a problem with the configuration that needs to be fixed now
+(it affects PyQwt compilation later). Edit pyqtconfig.py and change the qt_dir line to:
'qt_dir': '/usr',
-Then continue with compilation and installation:
+Then continue with compilation and installation (this is a good place to use
+parallel compilation, if you can):
make
@@ -1524,7 +1530,7 @@
- 5.3.6. Additional Dependencies: Qwt/PyQwt
+ 5.2.6. Additional Dependencies: Qwt/PyQwt
The GPS tracking feature uses Qwt. Some popular 3rd-party plugins use PyQwt.
@@ -1535,8 +1541,10 @@
Double-click the tarball to unpack it. The following assumes PyQwt v5.2.0 (comes with Qwt 5.2.1).
+Normal compilation does both Qwt and PyQwt at the same time, but Qwt is staically linked
+into PyQwt, and Qgis can't use it. So, we need to split the build.
-Now, first edit qwtconfig.pri in the qwt-5.2 subdir and change some settings so
+First edit qwtconfig.pri in the qwt-5.2 subdir and change some settings so
you don't get a bloated debug static library (too bad they are not configurable from
qmake). Scroll down to the 'release/debug mode' block. Edit the last 'CONFIG +='
line, within an 'else' block, and change 'debug' to 'release'. Like so:
@@ -1553,6 +1561,12 @@
CONFIG += QwtDll
+If you are building for Qt Carbon 32bit on Snow Leopard, add a line at the bottom:
+ CONFIG += x86
Save and close.
Now, cd into the qwt-5.2 subdir in a Terminal. Type these commands to build and install:
@@ -1561,6 +1575,8 @@
qmake -spec macx-g++
make
sudo make install
+ sudo install_name_tool -id /usr/local/qwt-5.2.1-svn/lib/libqwt.5.dylib \
+ /usr/local/qwt-5.2.1-svn/lib/libqwt.5.dylib
The Qwt shared library is now installed in /usr/local/qwt-5.x.x[-svn] (x.x is the
@@ -1578,12 +1594,6 @@
Make sure to use the qwt install path from the Qwt build above.
-Finally, if you run into problems with the library not being properly linked after you build qgis, you may need to fix that as follows and then rebuild qgis (this is not needed when bundling all Qt/PyQt related components, which is recommended, and default in the Xcode build):
- sudo install_name_tool -id /usr/local/qwt-5.2.1-svn/lib/libqwt.5.dylib /usr/local/qwt-5.2.1-svn/lib/libqwt.5.dylib
Snow Leopard note
If using Qt Carbon, you need to specify which architectures to build, otherwise
@@ -1597,7 +1607,7 @@
- 5.3.7. Additional Dependencies: Bison
+ 5.2.7. Additional Dependencies: Bison
Leopard and Snow Leopard note: Leopard and Snow Leopard include Bison 2.3, so this step can be skipped on Leopard and Snow Leopard.
@@ -1619,7 +1629,7 @@
(Only needed for a cmake build.)
@@ -1642,7 +1652,7 @@
Leopard and Snow Leopard note: Leopard and Snow Leopard (Xcode 3+)
@@ -1688,7 +1698,7 @@
Now close and reopen your shell to get the updated vars.
Now we are going to check out the sources for QGIS. First we will create a
@@ -1729,69 +1739,42 @@
I suggest you press 'p' to accept the key permanently.
-There are 2 different methods to build QGIS: the traditional CMake method,
-and the new Xcode project (starting with QGIS 1.1). The Xcode project has
-additional bundling steps, though some optional QGIS features must be explicitly
-stated in a user configuration file. The CMake build handles optional features,
-and some bundling steps are available with scripts in the mac directory.
- 5.7.1. Configure the CMake build
CMake supports out of source build so we will create a 'build' dir for the
build process. OS X uses ${HOME}/Applications as a standard user app folder (it gives it the system app folder icon).
If you have the correct permissions you may want to build
straight into your /Applications folder. The instructions below assume you are
-building into a pre-existing ${HOME}/Applications directory ...
+building into a pre-existing ${HOME}/Applications directory.
+In a Terminal cd to the qgis source folder previously downloaded, then:
- cd qgis
mkdir build
cd build
- cmake -D CMAKE_INSTALL_PREFIX=~/Applications -D CMAKE_BUILD_TYPE=Release ..
-To use the application build of GRASS on OSX, you can optionally use the
-following cmake invocation (minimum GRASS 6.3 required, substitute the GRASS
-version as required):
cmake -D CMAKE_INSTALL_PREFIX=~/Applications -D CMAKE_BUILD_TYPE=Release \
- -D GRASS_INCLUDE_DIR=/Applications/GRASS-6.4.app/Contents/MacOS/include \
- -D GRASS_PREFIX=/Applications/GRASS-6.4.app/Contents/MacOS \
+ -D CMAKE_BUILD_TYPE=MinSizeRel -D WITH_INTERNAL_SPATIALITE=FALSE \
+This will automatically find and use the previously installed frameworks, and the GRASS
+application if installed.
Or, to use a Unix-style build of GRASS, use the following cmake invocation
(minimum GRASS version as stated in the Qgis requirements, substitute the GRASS
path and version as required):
- -D GRASS_INCLUDE_DIR=/user/local/grass-6.4.0/include \
-D GRASS_PREFIX=/user/local/grass-6.4.0 \
-Leopard note: To find the custom install of SIP on Leopard, add
-'-D SIP_BINARY_PATH=/usr/local/bin/sip' to the cmake commands above,
-before the '..' at the end, ie:
+Snow Leopard note: To handle 32-bit Qt (Carbon), create a 32bit python wrapper
+script and add arch flags to the configuration:
- cmake -D CMAKE_INSTALL_PREFIX=~/Applications -D CMAKE_BUILD_TYPE=Release \
- -D SIP_BINARY_PATH=/usr/local/bin/sip \
-Snow Leopard note: To handle the appropriate version of Qt (32-bit or 64-bit), you will need to invoke cmake based on which version of Qt you installed. Also, SIP/PyQt detection will fail for 32bit because Python runs 64bit.
-For 32-bit Qt (Carbon) with GRASS-6.4, create a 32bit python script and add arch flags to the configuration:
sudo cat >/usr/local/bin/python32 <<EOF
#!/bin/sh
exec arch -i386 /usr/bin/python2.6 \${1+"\$@"}
@@ -1800,52 +1783,31 @@
sudo chmod +x /usr/local/bin/python32
- -D CMAKE_CXX_FLAGS="-arch i386" -D CMAKE_OSX_ARCHITECTURES=i386 \
- -D PYTHON_EXECUTABLE=/usr/local/bin/python32 \
+ -D CMAKE_OSX_ARCHITECTURES=i386 -D PYTHON_EXECUTABLE=/usr/local/bin/python32 \
-For 64-bit Qt (Cocoa) with GRASS-6.4:
+Bundling note: Older Qt versions may have problems with some Qt plugins and Qgis.
+The way to handle this is bundle Qt inside the Qgis application. You can do this now
+or wait to see if there are immediate crahses when running Qgis. It's also a good
+idea to bundle Qt if you need to copy Qgis to other Macs (where you would have to
+install Xcode just so Qt would install!).
+To bundle Qt, add the following line before the last line in the above cmake configurations:
- -D CMAKE_CXX_FLAGS="-arch x86_64" -D CMAKE_OSX_ARCHITECTURES=x86_64 \
+ -D QGIS_MACAPP_BUNDLE=1 \
- 5.7.2. Configure the Xcode build
-In the mac/xcode folder in the source, duplicate the 'qgis_user-template.xcconfig'
-file and name it 'qgis_user.xcconfig'. A default build will use the KyngChaos
-frameworks, Postgres, GRASS 6.4, the python.org Python 2.5 (for Tiger)
-or the system Python (for Leopard and Snow Leopard) and extra dependencies
-as described above, and compile for the current OSX architecture and version, so no
-extra configuration is necessary.
-See the mac/xcode/readme.rtf for details, if you need to customize the build.
-The default build will also bundle the Qt frameworks, Postgres library, and
-other dependency libraries to create a self-contained package. The KyngChaos
-frameworks and GRASS application are not bundled.
- 5.8. Building
+ 5.7. Building
+Now we can start the build process (remember the parallel compilation note at
+the beginning, this is a good place to use it, if you can):
- 5.8.1. Building with Cmake
-Now we can start the build process:
make
@@ -1855,39 +1817,13 @@
make install
-or, for a Unix-style build
+or, for a /Applications build:
sudo make install
- 5.8.2. Building with Xcode
-Open the Xcode project file in the mac/xcode directory. Select 'Release' build
-configuration and select the 'Full Qgis' target, then build. If you use ccache,
-there have been compilation problems reported, so it is suggested that you disable
-ccache support.
-Alternatively, from within the mac/xcode directory, build with the command:
- xcodebuild
-The Qgis application will be found in the 'build/$SDKSYS/Release' folder
-in the xcode folder, where $SDKSYS is the system you configured for in your
-qgis_user.xcconfig. Copy this to whereever you like.
-To run QGIS you need to at the minimum copy the dlls from c:\dev\cpp\qgislibs-release\bin
-into the c:\program files\qgisX.X.X directory.
Modified: trunk/qgis/doc/osx.t2t
--- trunk/qgis/doc/osx.t2t 2010-10-31 18:04:50 UTC (rev 14466)
+++ trunk/qgis/doc/osx.t2t 2010-10-31 18:09:25 UTC (rev 14467)
@@ -1,33 +1,36 @@
-= MacOS X: building using frameworks and cmake or Xcode =
+= MacOS X: building using frameworks and Cmake =
-The base system here is Mac OS X 10.4 (__Tiger__). Included are a few notes
-for building on Mac OS X 10.5 (__Leopard__) and 10.6 (__Snow Leopard__).
+The base system here is Mac OS X 10.4 (__Tiger__), with a single architecture build.
+Included are a few notes for building on Mac OS X 10.5 (__Leopard__) and 10.6 (__Snow Leopard__).
-__Snow Leopard note:__ A cmake/qt/sip bug currently exists where a 32-bit
+__General note on Terminal usage:__ When I say "cd" to a folder in a Terminal,
-== Install Xcode ==
+__Parallel Compilation:__ On multiprocessor/multicore Macs, it's possible to speed
+instead type:
-cd /Developer/SDKs/MacOSX10.4u.sdk/usr/
-sudo mv local/ local_
-sudo ln -s /usr/local/ local
+make -j [n]
== Install Qt4 from .dmg ==
@@ -37,6 +40,9 @@
+__PPC note:__ There appear to be issues with Qt Cocoa on PPC Macs. QT Carbon
@@ -48,8 +54,8 @@
__Qt note:__ Starting in Qt 4.4, libQtCLucene was added, and in 4.5
@@ -127,7 +133,7 @@
@@ -144,7 +150,8 @@
python configure.py
@@ -192,20 +199,23 @@
python configure.py
yes
'qt_dir': '/usr',
make
@@ -255,8 +265,10 @@
@@ -273,6 +285,12 @@
CONFIG += QwtDll
+CONFIG += x86
Save and close.
@@ -281,6 +299,8 @@
make
sudo make install
+sudo install_name_tool -id /usr/local/qwt-5.2.1-svn/lib/libqwt.5.dylib \
+/usr/local/qwt-5.2.1-svn/lib/libqwt.5.dylib
@@ -298,11 +318,6 @@
-sudo install_name_tool -id /usr/local/qwt-5.2.1-svn/lib/libqwt.5.dylib /usr/local/qwt-5.2.1-svn/lib/libqwt.5.dylib
__Snow Leopard note__
@@ -441,64 +456,39 @@
== Configure the build ==
-=== Configure the CMake build ===
-cd qgis
mkdir build
cd build
-cmake -D CMAKE_INSTALL_PREFIX=~/Applications -D CMAKE_BUILD_TYPE=Release ..
--D GRASS_INCLUDE_DIR=/Applications/GRASS-6.4.app/Contents/MacOS/include \
--D GRASS_PREFIX=/Applications/GRASS-6.4.app/Contents/MacOS \
+-D CMAKE_BUILD_TYPE=MinSizeRel -D WITH_INTERNAL_SPATIALITE=FALSE \
--D GRASS_INCLUDE_DIR=/user/local/grass-6.4.0/include \
-__Leopard note:__ To find the custom install of SIP on Leopard, add
+__Snow Leopard note:__ To handle 32-bit Qt (Carbon), create a 32bit python wrapper
-cmake -D CMAKE_INSTALL_PREFIX=~/Applications -D CMAKE_BUILD_TYPE=Release \
--D SIP_BINARY_PATH=/usr/local/bin/sip \
-__Snow Leopard note:__ To handle the appropriate version of Qt (32-bit or 64-bit), you will need to invoke cmake based on which version of Qt you installed. Also, SIP/PyQt detection will fail for 32bit because Python runs 64bit.
#!/bin/sh
@@ -507,45 +497,28 @@
--D CMAKE_CXX_FLAGS="-arch i386" -D CMAKE_OSX_ARCHITECTURES=i386 \
--D PYTHON_EXECUTABLE=/usr/local/bin/python32 \
+-D CMAKE_OSX_ARCHITECTURES=i386 -D PYTHON_EXECUTABLE=/usr/local/bin/python32 \
+__Bundling note:__ Older Qt versions may have problems with some Qt plugins and Qgis.
--D CMAKE_CXX_FLAGS="-arch x86_64" -D CMAKE_OSX_ARCHITECTURES=x86_64 \
+-D QGIS_MACAPP_BUNDLE=1 \
-=== Configure the Xcode build ===
== Building ==
-=== Building with Cmake ===
make
@@ -556,30 +529,8 @@
make install
sudo make install
-=== Building with Xcode ===
-ccache support.
-xcodebuild
-== Running and packaging ==
