[QGIS Commit] r14475 - in trunk/qgis: mac mac/cmake src/helpviewer
svn_qgis at osgeo.org
Sun Oct 31 23:09:19 EDT 2010
Author: kyngchaos
Date: 2010-10-31 20:09:18 -0700 (Sun, 31 Oct 2010)
New Revision: 14475
trunk/qgis/mac/cmake/1qt.cmake.in
trunk/qgis/mac/cmake/2lib.cmake.in
trunk/qgis/mac/cmake/3fw.cmake.in
trunk/qgis/mac/readme.txt
trunk/qgis/src/helpviewer/CMakeLists.txt
some mac cmake cleanup, update mac folder notes
Modified: trunk/qgis/mac/cmake/1qt.cmake.in
--- trunk/qgis/mac/cmake/1qt.cmake.in 2010-11-01 02:43:17 UTC (rev 14474)
+++ trunk/qgis/mac/cmake/1qt.cmake.in 2010-11-01 03:09:18 UTC (rev 14475)
@@ -11,8 +11,6 @@
SET (QAPPDIRC "@QGIS_MACAPP_PREFIX@")
SET (QAPPDIR "@CMAKE_INSTALL_PREFIX@")
-#SET (QAPPDIRC "@CMAKE_INSTALL_PREFIX@/@QGIS_APP_NAME at .app/Contents")
-#SET (QAPPDIR "${QAPPDIRC}/MacOS")
SET (QFWDIR "${QAPPDIR}/@QGIS_FW_SUBDIR@")
SET (QBINDIR "${QAPPDIR}/@QGIS_BIN_SUBDIR@")
SET (QCGIDIR "${QAPPDIR}/@QGIS_CGIBIN_SUBDIR@")
@@ -47,7 +45,7 @@
ENDIF (@CMAKE_VERBOSE_MAKEFILE@)
ENDFUNCTION (MYMESSAGE)
-# isntall_name_tool -change CHANGE CHANGETO CHANGEBIN
+# install_name_tool -change CHANGE CHANGETO CHANGEBIN
FUNCTION (INSTALLNAMETOOL_CHANGE CHANGE CHANGETO CHANGEBIN)
MYMESSAGE ("install_name_tool -change ${CHANGE} ${CHANGETO} \"${CHANGEBIN}\"")
EXECUTE_PROCESS (COMMAND install_name_tool -change ${CHANGE} ${CHANGETO} "${CHANGEBIN}")
@@ -105,7 +103,6 @@
IF (IS_DIRECTORY "${QLIBXIR}/grass/bin")
EXECUTE_PROCESS (COMMAND ln -sfh ../@QGIS_LIBEXEC_SUBDIR_REV@/@QGIS_FW_SUBDIR@ "${QLIBXDIR}/grass/Frameworks")
ENDIF ()
- EXECUTE_PROCESS (COMMAND ln -sfh ../../../@QGIS_FW_SUBDIR@ "${QBINDIR}/qgis_help.app/Contents/Frameworks")
EXECUTE_PROCESS (COMMAND ln -sfh @QGIS_CGIBIN_SUBDIR_REV@/@QGIS_LIB_SUBDIR@ "${QCGIDIR}/lib")
ENDIF (NOT @OSX_HAVE_LOADERPATH@)
Modified: trunk/qgis/mac/cmake/2lib.cmake.in
--- trunk/qgis/mac/cmake/2lib.cmake.in 2010-11-01 02:43:17 UTC (rev 14474)
+++ trunk/qgis/mac/cmake/2lib.cmake.in 2010-11-01 03:09:18 UTC (rev 14475)
@@ -15,8 +15,6 @@
@@ -51,7 +49,7 @@
Modified: trunk/qgis/mac/cmake/3fw.cmake.in
--- trunk/qgis/mac/cmake/3fw.cmake.in 2010-11-01 02:43:17 UTC (rev 14474)
+++ trunk/qgis/mac/cmake/3fw.cmake.in 2010-11-01 03:09:18 UTC (rev 14475)
@@ -13,8 +13,6 @@
Modified: trunk/qgis/mac/readme.txt
--- trunk/qgis/mac/readme.txt 2010-11-01 02:43:17 UTC (rev 14474)
+++ trunk/qgis/mac/readme.txt 2010-11-01 03:09:18 UTC (rev 14475)
@@ -1,6 +1,23 @@
Mac Notes
-The 'extras' folder scripts are mainly for a cmake build. All the bundling
-scripts' functionality is included in the Xcode project. The readme could be
-used in packaging the Xcode build, with necessary adjustments to what's
-bundled and what's required externally.
+The 'cmake' folder scripts handle bundling dependent libraries in the QGIS
+application package and fixing up the library paths. It is automatic during
+installation. There are 2 levels currently, specified with the cmake config
+option QGIS_MACAPP_BUNDLE, and one that always occurs:
+0 = (default) fixup the library paths for all QGIS libraries if @loader_path
+ is available in the system (OS X 10.5+)
+1 = bundle Qt, PyQt and PyQwt
+2 = additionally, bundle libraries, but not frameworks
+A third level that is not finished will additionally bundle frameworks.
+This would create the "standalone" QGIS.
+The 'extras' folder scripts are for packaging the old v1.0 build. All the
+bundling is now handled in the cmake install, so these scripts are
+essentially deprecated.
+The Xcode project is now deprecated since the bundling now happens in the
+cmake build, including making sure library paths are all correct.
Modified: trunk/qgis/src/helpviewer/CMakeLists.txt
--- trunk/qgis/src/helpviewer/CMakeLists.txt 2010-11-01 02:43:17 UTC (rev 14474)
+++ trunk/qgis/src/helpviewer/CMakeLists.txt 2010-11-01 03:09:18 UTC (rev 14475)
@@ -101,6 +101,7 @@
INSTALL (TARGETS qgis_help BUNDLE DESTINATION ${QGIS_BIN_DIR})
# needed because global install_name prefix is for main qgis app
INSTALL (CODE "EXECUTE_PROCESS(COMMAND install_name_tool -change ${CMAKE_INSTALL_NAME_DIR}/libqgis_core.${COMPLETE_VERSION}.dylib @executable_path/../../../../lib/libqgis_core.${COMPLETE_VERSION}.dylib \"${CMAKE_INSTALL_PREFIX}/${QGIS_BIN_DIR}/qgis_help.app/Contents/MacOS/qgis_help\")")
+ INSTALL (CODE "EXECUTE_PROCESS (COMMAND ln -sfh ../../../${QGIS_FW_SUBDIR} \"${CMAKE_INSTALL_PREFIX}/${QGIS_BIN_DIR}/qgis_help.app/Contents/Frameworks\"")
ELSE (APPLE)
INSTALL (TARGETS qgis_help RUNTIME DESTINATION ${QGIS_BIN_DIR})
ENDIF (APPLE)
