[QGIS Commit] r14218 - trunk/qgis/i18n
svn_qgis at osgeo.org
Fri Sep 10 10:41:55 EDT 2010
Author: jef
Date: 2010-09-10 14:41:55 +0000 (Fri, 10 Sep 2010)
New Revision: 14218
trunk/qgis/i18n/qgis_de.ts
german translation update
Modified: trunk/qgis/i18n/qgis_de.ts
--- trunk/qgis/i18n/qgis_de.ts 2010-09-10 14:41:32 UTC (rev 14217)
+++ trunk/qgis/i18n/qgis_de.ts 2010-09-10 14:41:55 UTC (rev 14218)
@@ -3972,33 +3972,33 @@
<translation>Unerwarteter Operator, Skalarwert erhalten!</translation>
</message>
<message>
- <location filename="../src/core/qgssearchtreenode.cpp" line="450"/>
+ <location filename="../src/core/qgssearchtreenode.cpp" line="443"/>
<source>Unexpected state when evaluating operator!</source>
<translation>Unerwarteter Zustand bei Operatorauswertung!</translation>
</message>
<message>
- <location filename="../src/core/qgssearchtreenode.cpp" line="467"/>
+ <location filename="../src/core/qgssearchtreenode.cpp" line="460"/>
<source>Could not retrieve value of list value</source>
<translation>Konnte Wert des Listenelements nicht feststellen</translation>
</message>
<message>
- <location filename="../src/core/qgssearchtreenode.cpp" line="521"/>
- <location filename="../src/core/qgssearchtreenode.cpp" line="542"/>
+ <location filename="../src/core/qgssearchtreenode.cpp" line="513"/>
+ <location filename="../src/core/qgssearchtreenode.cpp" line="535"/>
<source>Unknown operator: %1</source>
<translation>Unbekannter Operator: %1</translation>
</message>
<message>
- <location filename="../src/core/qgssearchtreenode.cpp" line="537"/>
+ <location filename="../src/core/qgssearchtreenode.cpp" line="530"/>
<source>Division by zero.</source>
<translation>Division durch Null.</translation>
</message>
<message>
- <location filename="../src/core/qgssearchtreenode.cpp" line="545"/>
+ <location filename="../src/core/qgssearchtreenode.cpp" line="538"/>
<source>Unknown token: %1</source>
<translation>Ungültiges Zeichen: %1</translation>
</message>
<message>
- <location filename="../src/core/qgssearchtreenode.cpp" line="548"/>
+ <location filename="../src/core/qgssearchtreenode.cpp" line="541"/>
<source>Unknown error!</source>
<translation>Unbekannter Fehler!</translation>
</message>
@@ -4172,58 +4172,59 @@
<translation>Fügt einen WFS-Layer zur Kartendarstellung hinzu</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="683"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="687"/>
<source> km2</source>
<translation> km2</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="688"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="692"/>
<source> ha</source>
<translation> ha</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="693"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="683"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="697"/>
<source> m2</source>
<translation> m2</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="701"/>
- <location filename="../src/core/qgsdistancearea.cpp" line="721"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="704"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="723"/>
<source> m</source>
<translation> m</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="706"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="708"/>
<source> km</source>
<translation> km</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="711"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="713"/>
<source> mm</source>
<translation> mm</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="716"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="718"/>
<source> cm</source>
<translation> cm</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="730"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="736"/>
<source> sq mile</source>
<translation> Quadratmeile</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="735"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="732"/>
<source> sq ft</source>
<translation> Quadratfuß</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="742"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="755"/>
<source> mile</source>
<translation> Meilen</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="748"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="746"/>
<source> foot</source>
<translation> Fuß</translation>
</message>
@@ -4233,27 +4234,27 @@
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="757"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="763"/>
<source> sq.deg.</source>
<translation> sq.deg.</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="762"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="768"/>
<source> degree</source>
<translation> Grad</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="764"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="770"/>
<source> degrees</source>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="768"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="774"/>
<source> unknown</source>
<translation> unbekannt</translation>
</message>
<message>
- <location filename="../src/core/qgssearchtreenode.cpp" line="499"/>
+ <location filename="../src/core/qgssearchtreenode.cpp" line="492"/>
<source>Regular expressions on numeric values don't make sense. Use comparison instead.</source>
<translation>Reguläre Ausdrücke auf nummerische Werte haben keinen Sinn. Bitte Vergleichsoperatoren benutzen.</translation>
</message>
@@ -4731,7 +4732,7 @@
%1</translation>
</message>
<message>
- <location filename="../src/core/qgssearchtreenode.cpp" line="534"/>
+ <location filename="../src/core/qgssearchtreenode.cpp" line="527"/>
<source>Referenced column wasn't found: %1</source>
<translation>Referenzierte Spalte nicht gefunden: %1</translation>
</message>
@@ -4959,27 +4960,27 @@
</translation>
</message>
<message>
- <location filename="../src/core/qgsgeometry.cpp" line="6316"/>
+ <location filename="../src/core/qgsgeometry.cpp" line="6318"/>
<source>invalid line</source>
<translation>Ungültige Linie</translation>
</message>
<message>
- <location filename="../src/core/qgsgeometry.cpp" line="6394"/>
+ <location filename="../src/core/qgsgeometry.cpp" line="6396"/>
<source>segment %1 of ring %2 of polygon %3 intersects segment %4 of ring %5 of polygon %6 at %7</source>
<translation>Segment %1 des Rings %2 des Polygons %3 schneidet Segment %4 des Rings %5 des Polygons %6 bei %7</translation>
</message>
<message>
- <location filename="../src/core/qgsgeometry.cpp" line="6428"/>
+ <location filename="../src/core/qgsgeometry.cpp" line="6430"/>
<source>ring %1 not closed</source>
<translation>Ring %1 nicht geschlossen</translation>
</message>
<message>
- <location filename="../src/core/qgsgeometry.cpp" line="6436"/>
+ <location filename="../src/core/qgsgeometry.cpp" line="6438"/>
<source>line %1 with less than two points</source>
<translation>Linie %1 mit weniger als zwei Punkten</translation>
</message>
<message numerus="yes">
- <location filename="../src/core/qgsgeometry.cpp" line="6454"/>
+ <location filename="../src/core/qgsgeometry.cpp" line="6456"/>
<source>line %1 contains %n duplicate node(s) at %2</source>
<comment>number of duplicate nodes</comment>
<translation>
@@ -4988,35 +4989,35 @@
</translation>
</message>
<message>
- <location filename="../src/core/qgsgeometry.cpp" line="6576"/>
- <location filename="../src/core/qgsgeometry.cpp" line="6580"/>
+ <location filename="../src/core/qgsgeometry.cpp" line="6578"/>
+ <location filename="../src/core/qgsgeometry.cpp" line="6582"/>
<source>polygon %1 inside polygon %2</source>
<translation>Polygon %1 liegt im Polygon %2</translation>
</message>
<message>
- <location filename="../src/core/qgsgeometry.cpp" line="6420"/>
+ <location filename="../src/core/qgsgeometry.cpp" line="6422"/>
<source>ring %1 with less than three points</source>
<translation>Ring %1 mit weniger als drei Punkten</translation>
</message>
<message>
- <location filename="../src/core/qgsgeometry.cpp" line="6485"/>
+ <location filename="../src/core/qgsgeometry.cpp" line="6487"/>
<source>segments %1 and %2 of line %3 intersect at %4</source>
<translation>Segmente %1 und %2 der Linie %3 schneiden sich bei %4</translation>
</message>
<message>
- <location filename="../src/core/qgsgeometry.cpp" line="6402"/>
- <location filename="../src/core/qgsgeometry.cpp" line="6490"/>
+ <location filename="../src/core/qgsgeometry.cpp" line="6404"/>
+ <location filename="../src/core/qgsgeometry.cpp" line="6492"/>
<source>stopping validation after more than 100 errors</source>
<translation>Überprüfung nach mehr als 100 Fehlern gestoppt</translation>
</message>
<message>
- <location filename="../src/core/qgsgeometry.cpp" line="6506"/>
+ <location filename="../src/core/qgsgeometry.cpp" line="6508"/>
<source>ring %1 of polygon %2 not in exterior ring</source>
<translation>Ring %1 des Polygons %2 nicht innerhalb des äußeren Rings</translation>
</message>
<message>
- <location filename="../src/core/qgsgeometry.cpp" line="6592"/>
- <location filename="../src/core/qgsgeometry.cpp" line="6593"/>
+ <location filename="../src/core/qgsgeometry.cpp" line="6595"/>
+ <location filename="../src/core/qgsgeometry.cpp" line="6596"/>
<source>Unknown geometry type</source>
<translation>Unbekannter Geometrietyp</translation>
</message>
@@ -5031,63 +5032,68 @@
<translation>Kürzung des Attributnamens '%1' auf 10 signifikante Stellen führt zu doppelten Spaltennamen.</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorfilewriter.cpp" line="146"/>
+ <location filename="../src/core/qgsvectorfilewriter.cpp" line="148"/>
<source>creation of data source failed (OGR error:%1)</source>
<translation>Erzeugung der Datenquelle gescheitert (OGR-Fehler: %1)</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorfilewriter.cpp" line="222"/>
+ <location filename="../src/core/qgsvectorfilewriter.cpp" line="226"/>
<source>creation of layer failed (OGR error:%1)</source>
<translation>Layererzeugung schlug fehl (OGR-Fehler: %1)</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorfilewriter.cpp" line="272"/>
+ <location filename="../src/core/qgsvectorfilewriter.cpp" line="276"/>
<source>unsupported type for field %1</source>
<translation>Feldtyp für %1 nicht unterstützt</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorfilewriter.cpp" line="298"/>
+ <location filename="../src/core/qgsvectorfilewriter.cpp" line="302"/>
<source>creation of field %1 failed (OGR error: %2)</source>
<translation>Erzeugung des Felds %1 gescheitert (OGR-Fehler: %2)</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorfilewriter.cpp" line="309"/>
+ <location filename="../src/core/qgsvectorfilewriter.cpp" line="313"/>
<source>created field %1 not found (OGR error: %2)</source>
<translation>Erzeugtes Feld %1 nicht gefunden (OGR-Fehler: %2)</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorfilewriter.cpp" line="381"/>
+ <location filename="../src/core/qgsvectorfilewriter.cpp" line="385"/>
<source>Invalid variant type for field %1[%2]: received %3 with type %4</source>
<translation>Ungültiger Typ für Feld %1[%2]: %3 mit Typ %4 empfangen</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorfilewriter.cpp" line="397"/>
+ <location filename="../src/core/qgsvectorfilewriter.cpp" line="401"/>
<source>Invalid feature geometry</source>
<translation>Ungültige Objektgeometrie</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorfilewriter.cpp" line="420"/>
- <location filename="../src/core/qgsvectorfilewriter.cpp" line="436"/>
+ <location filename="../src/core/qgsvectorfilewriter.cpp" line="424"/>
+ <location filename="../src/core/qgsvectorfilewriter.cpp" line="440"/>
<source>Feature geometry not imported (OGR error: %1)</source>
<translation>Objektgeometrie nicht importiert (OGR-Fehler: %1)</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorfilewriter.cpp" line="450"/>
+ <location filename="../src/core/qgsvectorfilewriter.cpp" line="454"/>
<source>Feature creation error (OGR error: %1)</source>
<translation>Objekterzeugungsfehler (OGR-Fehler: %1)</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorfilewriter.cpp" line="574"/>
+ <location filename="../src/core/qgsvectorfilewriter.cpp" line="578"/>
<source>Failed to transform a point while drawing a feature of type '%1'. Writing stopped. (Exception: %2)</source>
<translation>Transformation eines Punkts schlug beim Zeichnen eines Objekts vom Typ '%1' fehl. Schreiben beendet (Ausnahme %2)</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorfilewriter.cpp" line="590"/>
+ <location filename="../src/core/qgsvectorfilewriter.cpp" line="594"/>
<source>Feature write errors:</source>
<translation>Objektschreibfehler:</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorfilewriter.cpp" line="608"/>
+ <location filename="../src/core/qgsvectorfilewriter.cpp" line="604"/>
+ <source>Stopping after %1 errors</source>
+ <translation>Abbruch nach %1 Fehlern</translation>
+ </message>
+ <message>
+ <location filename="../src/core/qgsvectorfilewriter.cpp" line="623"/>
<source>
Only %1 of %2 features written.</source>
<translation>
@@ -8194,7 +8200,7 @@
<translation> (Text)</translation>
</message>
<message>
- <location filename="../src/app/qgsattributedialog.cpp" line="197"/>
+ <location filename="../src/app/qgsattributedialog.cpp" line="203"/>
<source>Attributes - %1</source>
<translation>Attribute - %1</translation>
</message>
@@ -8212,7 +8218,7 @@
<translation>Datum wählen</translation>
</message>
<message>
- <location filename="../src/gui/qgsattributeeditor.cpp" line="410"/>
+ <location filename="../src/gui/qgsattributeeditor.cpp" line="416"/>
<source>...</source>
<translation>...</translation>
</message>
@@ -9627,7 +9633,7 @@
<context>
<name>QgsComposerLegend</name>
<message>
- <location filename="../src/core/composer/qgscomposerlegend.cpp" line="30"/>
+ <location filename="../src/core/composer/qgscomposerlegend.cpp" line="32"/>
<source>Legend</source>
<translation>Legende</translation>
</message>
@@ -11531,17 +11537,17 @@
<translation>Bitte vor dem Hinzufügen des Layers zur Karte einen Layernamen eingeben</translation>
</message>
<message>
- <location filename="../src/plugins/delimited_text/qgsdelimitedtextplugingui.cpp" line="195"/>
+ <location filename="../src/plugins/delimited_text/qgsdelimitedtextplugingui.cpp" line="206"/>
<source>No delimiter</source>
<translation>Kein Trennzeichen</translation>
</message>
<message>
<source>Please specify a delimiter prior to parsing the file</source>
<translation>Es muss ein Trennzeichen eingegeben werden, damit die Datei abgearbeitet werden kann</translation>
</message>
<message>
- <location filename="../src/plugins/delimited_text/qgsdelimitedtextplugingui.cpp" line="228"/>
+ <location filename="../src/plugins/delimited_text/qgsdelimitedtextplugingui.cpp" line="239"/>
<source>Choose a delimited text file to open</source>
<translation>Textdatei zum Öffnen wählen</translation>
</message>
@@ -11694,12 +11700,12 @@
<context>
<name>QgsDelimitedTextProvider</name>
<message>
- <location filename="../src/providers/delimitedtext/qgsdelimitedtextprovider.cpp" line="451"/>
+ <location filename="../src/providers/delimitedtext/qgsdelimitedtextprovider.cpp" line="448"/>
<source>Error</source>
<translation>Fehler</translation>
</message>
<message>
- <location filename="../src/providers/delimitedtext/qgsdelimitedtextprovider.cpp" line="452"/>
+ <location filename="../src/providers/delimitedtext/qgsdelimitedtextprovider.cpp" line="449"/>
<source>Note: the following lines were not loaded because Qgis was unable to determine values for the x and y coordinates:
</source>
<translation>Beachte: Die folgenden Linien wurden nicht geladen, da QGIS die Werte für die X und Y Koordinaten nicht herausfinden konnte:
@@ -13062,6 +13068,129 @@
</message>
</context>
<context>
+ <name>QgsGeorefConfigDialog</name>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialog.cpp" line="29"/>
+ <source>A5 (148x210 mm)</source>
+ <translation>A5 (148x210 mm)</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialog.cpp" line="30"/>
+ <source>A4 (210x297 mm)</source>
+ <translation>A4 (210x297 mm)</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialog.cpp" line="31"/>
+ <source>A3 (297x420 mm)</source>
+ <translation>A3 (297x420 mm)</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialog.cpp" line="32"/>
+ <source>A2 (420x594 mm)</source>
+ <translation>A2 (420x594 mm)</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialog.cpp" line="33"/>
+ <source>A1 (594x841 mm)</source>
+ <translation>A1 (594x841 mm)</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialog.cpp" line="34"/>
+ <source>A0 (841x1189 mm)</source>
+ <translation>A0 (841x1189 mm)</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialog.cpp" line="35"/>
+ <source>B5 (176 x 250 mm)</source>
+ <translation>B5 (176 x 250 mm)</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialog.cpp" line="36"/>
+ <source>B4 (250 x 353 mm)</source>
+ <translation>B4 (250 x 353 mm)</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialog.cpp" line="37"/>
+ <source>B3 (353 x 500 mm)</source>
+ <translation>B3 (353 x 500 mm)</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialog.cpp" line="38"/>
+ <source>B2 (500 x 707 mm)</source>
+ <translation>B2 (500 x 707 mm)</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialog.cpp" line="39"/>
+ <source>B1 (707 x 1000 mm)</source>
+ <translation>B1 (707 x 1000 mm)</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialog.cpp" line="40"/>
+ <source>B0 (1000 x 1414 mm)</source>
+ <translation>B0 (1000 x 1414 mm)</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialog.cpp" line="42"/>
+ <source>Legal (8.5x14 inches)</source>
+ <translation>Legal (8.5x14 Zoll)</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialog.cpp" line="43"/>
+ <source>ANSI A (Letter; 8.5x11 inches)</source>
+ <translation>ANSI A (Brief; 8,5x11 Zoll)</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialog.cpp" line="44"/>
+ <source>ANSI B (Tabloid; 11x17 inches)</source>
+ <translation>ANSI B (Tabloid; 11x17 Zoll)</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialog.cpp" line="45"/>
+ <source>ANSI C (17x22 inches)</source>
+ <translation>ANSI C (17x22 Zoll)</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialog.cpp" line="46"/>
+ <source>ANSI D (22x34 inches)</source>
+ <translation>ANSI D (22x34 Zoll)</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialog.cpp" line="47"/>
+ <source>ANSI E (34x44 inches)</source>
+ <translation>ANSI E (34x44 Zoll)</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialog.cpp" line="48"/>
+ <source>Arch A (9x12 inches)</source>
+ <translation>Arch A (9x12 Zoll)</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialog.cpp" line="49"/>
+ <source>Arch B (12x18 inches)</source>
+ <translation>Arch B (12x18 Zoll)</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialog.cpp" line="50"/>
+ <source>Arch C (18x24 inches)</source>
+ <translation>Arch C (18x24 Zoll)</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialog.cpp" line="51"/>
+ <source>Arch D (24x36 inches)</source>
+ <translation>Arch D (24x36 Zoll)</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialog.cpp" line="52"/>
+ <source>Arch E (36x48 inches)</source>
+ <translation>Arch E (36x48 Zoll)</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialog.cpp" line="53"/>
+ <source>Arch E1 (30x42 inches)</source>
+ <translation>Arch E1 (30x42 Zoll)</translation>
+ </message>
+</context>
+<context>
<name>QgsGeorefConfigDialogBase</name>
<message>
<location filename="../src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui" line="14"/>
@@ -13110,6 +13239,16 @@
<translation>Georeferenzierungsfenster docken</translation>
</message>
<message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui" line="131"/>
+ <source>PDF map</source>
+ <translation></translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui" line="139"/>
+ <source>Paper size</source>
+ <translation>Papierformat</translation>
+ </message>
+ <message>
<location filename="../src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui" line="43"/>
<source>Residual units</source>
<translation>Resteinheiten</translation>
@@ -13166,313 +13305,316 @@
<context>
<name>QgsGeorefPluginGui</name>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="213"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="215"/>
<source>All other files (*)</source>
<translation>Alle anderen Dateien (*)</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="220"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="222"/>
<source>Open raster</source>
<translation>Raster öffnen</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="229"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="231"/>
<source>%1 is not a supported raster data source</source>
<translation>%1 ist keine unterstützte Rasterdatenquelle</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="234"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="236"/>
<source>Unsupported Data Source</source>
<translation>Nicht unterstütztes Datenformat</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="243"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="245"/>
<source>Raster loaded: %1</source>
<translation>Geladenes Raster: %1</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="244"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="246"/>
<source>Georeferencer - %1</source>
<translation>Georeferenzierung - %1</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="314"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="998"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1533"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="316"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1000"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1651"/>
<source>Transform: </source>
<translation>Transformation: </translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="368"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="574"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="601"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1141"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1189"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1231"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1664"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1673"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1683"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1692"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1706"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="370"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="576"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="603"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1143"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1191"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1239"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1782"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1791"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1801"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1810"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1824"/>
<source>Info</source>
<translation>Information</translation>
</message>
<message>
<source>GDAL scripting is not supported for %1 transformation</source>
<translation>GDAL-Skripting für Transformation %1 nicht unterstützt</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="562"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="564"/>
<source>Load GCP points</source>
<translation>GCP-Punkte laden</translation>
</message>
<message>
<source>No GCP points to save</source>
<translation>Keine GCP-Punkte zu speichern</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="579"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="581"/>
<source>Save GCP points</source>
<translation>GCP-Punkte speichern</translation>
</message>
<message>
<source>Please load raster to be georeferenced</source>
<translation>Bitte laden Sie das zu georeferenzierende Raster</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="845"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="965"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="847"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="967"/>
<source>Help</source>
<translation>Hilfe</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="942"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="944"/>
<source>Panels</source>
<translation>Bedienfelder</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="946"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="948"/>
<source>Toolbars</source>
<translation>Werkzeugkästen</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1010"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1012"/>
<source>Coordinate: </source>
<translation>Koordinate: </translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1011"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1013"/>
<source>Current map coordinate</source>
<translation>Aktuelle Kartenkoordinate</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="999"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1001"/>
<source>Current transform parametrisation</source>
<translation>Aktuelle Transformationsparameterisierung</translation>
</message>
<message>
<source>Unable to open GCP points file %1</source>
<translation>Kann GCP-Punktdatei %1 nicht öffnen</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1260"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1272"/>
<source>Could not write to %1</source>
<translation>Konnte nicht in %1 schreiben</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1155"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1157"/>
<source>Save GCPs</source>
<translation>GCPs speichern</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="135"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="137"/>
<source>Georeferencer</source>
<translation>Georeferenzierung</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1156"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1158"/>
<source>Save GCP points?</source>
<translation>GCP-Punkte speichern?</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1190"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1192"/>
<source>Failed to get linear transform parameters</source>
<translation>Konnte Parameter der linearen Transformation nicht bestimmen</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1200"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1202"/>
<source>World file exists</source>
<translation>World-Datei existiert</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1201"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1203"/>
<source><p>The selected file already seems to have a world file! Do you want to replace it with the new world file?</p></source>
<translation><p>Die gewählte Datei scheint bereits eine World-Datei zu haben! Wollen Sie sie mit der neuen überschreiben?</p></translation>
</message>
<message>
<source>Failed to compute GCP transform: Transform is not solvable</source>
<translation>Konnte GCP-Transformation nicht berechnen. Transformation nicht lösbar</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1259"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1271"/>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1423"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1541"/>
<source>Transformation parameters</source>
<translation>Transformationsparameter</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1440"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1558"/>
<source>Translation x</source>
<translation>X-Verschiebung</translation>
</message>
<message>
<source>Translation y</source>
<translation>y-Verschiebung</translation>
</message>
<message>
<source>Scale x</source>
<translation>X-Maßstab</translation>
</message>
<message>
<source>Scale y</source>
<translation>Y-Maßstab</translation>
</message>
<message>
<source>Rotation [degrees]</source>
<translation>Drehung [Grad]</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1459"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1577"/>
<source>Residuals</source>
<translation>Rest</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1414"/>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1472"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1418"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1431"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1532"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1590"/>
<source>map units</source>
<translation>Karteneinheiten</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1418"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1422"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1536"/>
<source>pixels</source>
<translation>Pixel</translation>
</message>
<message>
<source>Mean error [%1]</source>
<translation>Mittlere Fehler [%1]</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1491"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1609"/>
<source>yes</source>
<translation>ja</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1495"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1613"/>
<source>no</source>
<translation>nein</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1540"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1658"/>
<source>Translation (%1, %2)</source>
<translation>Verschiebung (%1, %2)</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1541"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1659"/>
<source>Scale (%1, %2)</source>
<translation>Maßstab (%1, %2)</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1542"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1660"/>
<source>Rotation: %1</source>
<translation>Drehung: %1</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1549"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1667"/>
<source>Mean error: %1</source>
<translation>Mittlerer Fehler: %1</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1570"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1688"/>
<source>Copy in clipboard</source>
<translation>In Zwischenablage kopieren</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1576"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1694"/>
<source>%1</source>
<translation>%1</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1583"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1701"/>
<source>GDAL script</source>
<translation>GDAL-Skript</translation>
</message>
<message>
<source>Please set transformation type</source>
<translation>Bitte Transformationstyp setzen</translation>
</message>
<message>
<source>Please set output raster name</source>
<translation>Bitte Ausgaberasternamen angeben</translation>
</message>
<message>
<source>%1 requires at least %2 GCPs. Please define more</source>
<translation>%1 erfordert mindestens %2 GCPs. Bitte mehr definieren</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1777"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1895"/>
<source>Linear</source>
<translation>Linear</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1779"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1897"/>
<source>Helmert</source>
<translation>Helmert</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1781"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1899"/>
<source>Polynomial 1</source>
<translation>Polynomial 1</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1783"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1901"/>
<source>Polynomial 2</source>
<translation>Polynomial 2</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1785"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1903"/>
<source>Polynomial 3</source>
<translation>Polynomial 3</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1787"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1905"/>
<source>Thin plate spline (TPS)</source>
<translation>Thin-Plate-Splines (TPS)</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1789"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1907"/>
<source>Projective</source>
<translation>Projektiv</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1791"/>
+ <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1909"/>
<source>Not set</source>
<translation>Nicht gesetzt</translation>
</message>
@@ -17534,52 +17676,52 @@
<context>
<name>QgsLegendLayer</name>
<message>
- <location filename="../src/app/legend/qgslegendlayer.cpp" line="394"/>
+ <location filename="../src/app/legend/qgslegendlayer.cpp" line="406"/>
<source>&Zoom to layer extent</source>
<translation>Auf die Layerausdehnung &zoomen</translation>
</message>
<message>
- <location filename="../src/app/legend/qgslegendlayer.cpp" line="397"/>
+ <location filename="../src/app/legend/qgslegendlayer.cpp" line="409"/>
<source>&Zoom to best scale (100%)</source>
<translation>&Auf besten Maßstab zoomen (100%)</translation>
</message>
<message>
- <location filename="../src/app/legend/qgslegendlayer.cpp" line="402"/>
+ <location filename="../src/app/legend/qgslegendlayer.cpp" line="414"/>
<source>&Stretch using current extent</source>
<translation>Auf aktuelle Ausdehnung &strecken</translation>
</message>
<message>
- <location filename="../src/app/legend/qgslegendlayer.cpp" line="407"/>
+ <location filename="../src/app/legend/qgslegendlayer.cpp" line="419"/>
<source>&Show in overview</source>
<translation>&In der Übersicht anzeigen</translation>
</message>
<message>
- <location filename="../src/app/legend/qgslegendlayer.cpp" line="414"/>
+ <location filename="../src/app/legend/qgslegendlayer.cpp" line="426"/>
<source>&Remove</source>
<translation>&Entfernen</translation>
</message>
<message>
- <location filename="../src/app/legend/qgslegendlayer.cpp" line="423"/>
+ <location filename="../src/app/legend/qgslegendlayer.cpp" line="435"/>
<source>&Open attribute table</source>
<translation>&Attributtabelle öffnen</translation>
</message>
<message>
- <location filename="../src/app/legend/qgslegendlayer.cpp" line="438"/>
+ <location filename="../src/app/legend/qgslegendlayer.cpp" line="450"/>
<source>Save as...</source>
<translation>Speichern als...</translation>
</message>
<message>
- <location filename="../src/app/legend/qgslegendlayer.cpp" line="441"/>
+ <location filename="../src/app/legend/qgslegendlayer.cpp" line="453"/>
<source>Save selection as...</source>
<translation>Auswahl speichern als...</translation>
</message>
<message>
- <location filename="../src/app/legend/qgslegendlayer.cpp" line="447"/>
+ <location filename="../src/app/legend/qgslegendlayer.cpp" line="459"/>
<source>&Query...</source>
<translation>&Abfrage...</translation>
</message>
<message>
- <location filename="../src/app/legend/qgslegendlayer.cpp" line="454"/>
+ <location filename="../src/app/legend/qgslegendlayer.cpp" line="466"/>
<source>&Properties</source>
<translation>&Eigenschaften</translation>
</message>
@@ -18721,22 +18863,22 @@
<translation>&Neu</translation>
</message>
<message>
- <location filename="../src/app/qgsmeasuredialog.cpp" line="202"/>
+ <location filename="../src/app/qgsmeasuredialog.cpp" line="220"/>
<source>Segments (in meters)</source>
<translation>Segmente (in Meter)</translation>
</message>
<message>
- <location filename="../src/app/qgsmeasuredialog.cpp" line="205"/>
+ <location filename="../src/app/qgsmeasuredialog.cpp" line="223"/>
<source>Segments (in feet)</source>
<translation>Segmente (in Fuß)</translation>
</message>
<message>
- <location filename="../src/app/qgsmeasuredialog.cpp" line="210"/>
+ <location filename="../src/app/qgsmeasuredialog.cpp" line="228"/>
<source>Segments (in degrees)</source>
<translation>Segmente (in Grad)</translation>
</message>
<message>
- <location filename="../src/app/qgsmeasuredialog.cpp" line="213"/>
+ <location filename="../src/app/qgsmeasuredialog.cpp" line="231"/>
<source>Segments</source>
<translation>Segmente</translation>
</message>
@@ -19767,21 +19909,21 @@
<context>
<name>QgsOptions</name>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="320"/>
- <location filename="../src/app/qgsoptions.cpp" line="327"/>
- <location filename="../src/app/qgsoptions.cpp" line="624"/>
+ <location filename="../src/app/qgsoptions.cpp" line="336"/>
+ <location filename="../src/app/qgsoptions.cpp" line="343"/>
+ <location filename="../src/app/qgsoptions.cpp" line="648"/>
<source>Semi transparent circle</source>
<translation>Teiltransparenter Kreis</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="321"/>
- <location filename="../src/app/qgsoptions.cpp" line="331"/>
- <location filename="../src/app/qgsoptions.cpp" line="628"/>
+ <location filename="../src/app/qgsoptions.cpp" line="337"/>
+ <location filename="../src/app/qgsoptions.cpp" line="347"/>
+ <location filename="../src/app/qgsoptions.cpp" line="652"/>
<source>Cross</source>
<translation>Kreuz</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="270"/>
+ <location filename="../src/app/qgsoptions.cpp" line="286"/>
<source>Detected active locale on your system: %1</source>
<translation>Festgestellte Spracheinstellung des Systems: %1</translation>
</message>
@@ -19816,67 +19958,67 @@
<translation>Alle Objekte des aktuellen Kartenausschnitts anzeigen</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="290"/>
+ <location filename="../src/app/qgsoptions.cpp" line="306"/>
<source>To vertex</source>
<translation>Zum Stützpunkt</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="291"/>
+ <location filename="../src/app/qgsoptions.cpp" line="307"/>
<source>To segment</source>
<translation>Zum Segment</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="292"/>
+ <location filename="../src/app/qgsoptions.cpp" line="308"/>
<source>To vertex and segment</source>
<translation>Zum Stützpunkt und Segment</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="322"/>
- <location filename="../src/app/qgsoptions.cpp" line="335"/>
- <location filename="../src/app/qgsoptions.cpp" line="632"/>
+ <location filename="../src/app/qgsoptions.cpp" line="338"/>
+ <location filename="../src/app/qgsoptions.cpp" line="351"/>
+ <location filename="../src/app/qgsoptions.cpp" line="656"/>
<source>None</source>
<translation>Keine</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="829"/>
- <location filename="../src/app/qgsoptions.cpp" line="871"/>
+ <location filename="../src/app/qgsoptions.cpp" line="853"/>
+ <location filename="../src/app/qgsoptions.cpp" line="895"/>
<source>Choose a directory</source>
<translation>Verzeichnis wählen</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="300"/>
- <location filename="../src/app/qgsoptions.cpp" line="309"/>
+ <location filename="../src/app/qgsoptions.cpp" line="316"/>
+ <location filename="../src/app/qgsoptions.cpp" line="325"/>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="304"/>
- <location filename="../src/app/qgsoptions.cpp" line="313"/>
+ <location filename="../src/app/qgsoptions.cpp" line="320"/>
+ <location filename="../src/app/qgsoptions.cpp" line="329"/>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="346"/>
+ <location filename="../src/app/qgsoptions.cpp" line="362"/>
<source>Central point (fastest)</source>
<translation>Zentrum (am schnellsten)</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="347"/>
+ <location filename="../src/app/qgsoptions.cpp" line="363"/>
<source>Chain (fast)</source>
<translation>Kette (schnell)</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="348"/>
+ <location filename="../src/app/qgsoptions.cpp" line="364"/>
<source>Popmusic tabu chain (slow)</source>
<translation>Popmusik-Tabu-Kette (langsam)</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="349"/>
+ <location filename="../src/app/qgsoptions.cpp" line="365"/>
<source>Popmusic tabu (slow)</source>
<translation>Popmusik-Tabu (langsam)</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="350"/>
+ <location filename="../src/app/qgsoptions.cpp" line="366"/>
<source>Popmusic chain (very slow)</source>
<translation>Popmusik-Kette (sehr langsam)</translation>
</message>
@@ -19894,7 +20036,7 @@
<translation>Kartenanzeige wird erneuert (gezeichnet) nachdem so viele Objekte von der Datenquelle gelesen wurden</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1266"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1290"/>
<source>Select Global Default ...</source>
<translation>Globale Voreinstellung wählen ...</translation>
</message>
@@ -19924,22 +20066,22 @@
<translation>%</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="797"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="821"/>
<source>Panning and zooming</source>
<translation>Verschieben und Zoomen</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="807"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="831"/>
<source>Zoom</source>
<translation>Zoom</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="812"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="836"/>
<source>Zoom and recenter</source>
<translation>Zoomen und mittig zentrieren</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="822"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="846"/>
<source>Nothing</source>
<translation>Nichts</translation>
</message>
@@ -19949,32 +20091,32 @@
<translation>Sprache</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1299"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1323"/>
<source>Locale to use instead</source>
<translation>Stattdessen folgende Spracheinstellungen benutzen</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1322"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1346"/>
<source>Additional Info</source>
<translation>Ergänzende Informationen</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1328"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1352"/>
<source>Detected active locale on your system:</source>
<translation>Festgestellte aktive Spracheinstellung:</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="926"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="950"/>
<source>Rubberband</source>
<translation>Gummiband</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="939"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="963"/>
<source>Line width in pixels</source>
<translation>Linienbreite in Pixel</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="972"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="996"/>
<source>Snapping</source>
<translation>Objektfang</translation>
</message>
@@ -19984,7 +20126,7 @@
<translation>Das Auswählen deaktiviert die Option Linien weniger gezackt zeichnen</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="817"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="841"/>
<source>Zoom to mouse cursor</source>
<translation>Zur Mausposition zoomen</translation>
</message>
@@ -20124,7 +20266,17 @@
<translation>Suchpfad(e) für SVG-Symbole (Scalable Vector Graphic)</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1561"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="794"/>
+ <source>Decimal places</source>
+ <translation>Dezimalstellen</translation>
+ </message>
+ <message>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="804"/>
+ <source>Keep base unit</source>
+ <translation>Basiseinheit beibehalten</translation>
+ </message>
+ <message>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1585"/>
<source>Timeout for network requests (ms)</source>
<translation>Zeitüberschreitung bei Netzwerkanfragen (ms)</translation>
</message>
@@ -20164,52 +20316,52 @@
<translation>Gon</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="830"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="854"/>
<source>Zoom factor</source>
<translation>Zoomfaktor</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="837"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="861"/>
<source>Mouse wheel action</source>
<translation>Mausradaktion</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="883"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="907"/>
<source>Placement algorithm</source>
<translation>Platzierungsalgorithmus</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1441"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1465"/>
<source>Exclude URLs (starting with)</source>
<translation>URL ausschließen, die beginnen mit</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1486"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1510"/>
<source>Cache settings</source>
<translation>Cache-Einstellungen</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1492"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1516"/>
<source>Directory</source>
<translation>Verzeichnis</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1502"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1526"/>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1509"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1533"/>
<source>Size</source>
<translation>Größe</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1519"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1543"/>
<source>Clear</source>
<translation>Löschen</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1531"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1555"/>
<source>WMS search address</source>
<translation>WMS-Suchadresse</translation>
</message>
@@ -20264,88 +20416,88 @@
<translation>Modus</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="932"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="956"/>
<source>Line width</source>
<translation>Linienbreite</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="978"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1002"/>
<source>Default snap mode</source>
<translation>Voreingestellter Fangmodus</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1220"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1244"/>
<source>Default Coordinate Reference System</source>
<translation>Voreingestelltes Koordinatenbezugssystem</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1105"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1129"/>
<source>Vertex markers</source>
<translation>Stützpunktmarken</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="949"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="973"/>
<source>Line color</source>
<translation>Linienfarbe</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1111"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1135"/>
<source>Show markers only for selected features</source>
<translation>Markierungen nur für gewählte Objekte anzeigen</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1118"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1142"/>
<source>Marker style</source>
<translation>Markierungsstil</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1161"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1185"/>
<source>Marker size</source>
<translation>Markierungsgröße</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1229"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1253"/>
<source>When a new layer is created, or when a layer is loaded that has no coordinate reference system (CRS)</source>
<translation>Wenn ein neuer Layer angelegt oder geladen wird, der kein Koordinatenbezugssystem (KBS) hat</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1290"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1314"/>
<source>Override system locale</source>
<translation>System-Locale überschreiben</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1309"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1333"/>
<source><b>Note:</b> Enabling / changing overide on local requires an application restart</source>
<translation><b>Note:</b> Einschalten/Änderung der Locale-Überschreibung erfordert einen Anwendungsneustart</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1355"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1379"/>
<source>Use proxy for web access</source>
<translation>Proxy für Webzugriff benutzen</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1367"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1391"/>
<source>Host</source>
<translation>Host</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1377"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1401"/>
<source>Port</source>
<translation>Port</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1387"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1411"/>
<source>User</source>
<translation>Benutzer</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1394"/>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1408"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1418"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1432"/>
<source>Leave this blank if no proxy username / password are required</source>
<translation>Lassen Sie Benutzer/Passwort leer, wenn sie nicht benötigt werden</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1401"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1425"/>
<source>Password</source>
<translation>Passwort</translation>
</message>
@@ -20360,54 +20512,54 @@
<translation>KBS</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1239"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1263"/>
<source>Prompt for CRS</source>
<translation>KBS abfragen</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1246"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1270"/>
<source>Project wide default CRS will be used</source>
<translation>Projektweite KBS-Voreinstellung</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1253"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1277"/>
<source>Global default CRS displa&yed below will be used</source>
<translation>Unten stehende globale &Voreinstellung wird genutzt</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1184"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1208"/>
<source>Enter attribute values</source>
<translation>Attributwerte eingeben</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="995"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1019"/>
<source>Default snapping tolerance</source>
<translation>Voreingestellte Fangtoleranz</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1012"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1036"/>
<source>Search radius for vertex edits</source>
<translation>Suchradius für Stützpunktbearbeitung</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1190"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1214"/>
<source>Suppress attributes pop-up windows after each created feature</source>
<translation>Eingabe der Attributwerte bei der Erstellung neuer Objekte unterdrücken</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1418"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1442"/>
<source>Proxy type</source>
<translation>Proxytyp</translation>
</message>
<message>
<location filename="../src/ui/qgsoptionsbase.ui" line="610"/>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1457"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1481"/>
<source>Add</source>
<translation>Hinzufügen</translation>
</message>
<message>
<location filename="../src/ui/qgsoptionsbase.ui" line="617"/>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1450"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1474"/>
<source>Remove</source>
<translation>Entfernen</translation>
</message>
@@ -20417,19 +20569,19 @@
<translation>Überlagern</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="877"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="901"/>
<source>Position</source>
<translation>Position</translation>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1036"/>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1050"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1060"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1074"/>
</message>
<message>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1041"/>
- <location filename="../src/ui/qgsoptionsbase.ui" line="1055"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1065"/>
+ <location filename="../src/ui/qgsoptionsbase.ui" line="1079"/>
</message>
@@ -26743,7 +26895,7 @@
<message>
<location filename="../src/plugins/georeferencer/qgstransformsettingsdialogbase.ui" line="58"/>
<location filename="../src/plugins/georeferencer/qgstransformsettingsdialog.cpp" line="37"/>
- <location filename="../src/plugins/georeferencer/qgstransformsettingsdialog.cpp" line="278"/>
+ <location filename="../src/plugins/georeferencer/qgstransformsettingsdialog.cpp" line="295"/>
</message>
@@ -26778,44 +26930,46 @@
<translation>Thin Plate Spline</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgstransformsettingsdialog.cpp" line="160"/>
- <location filename="../src/plugins/georeferencer/qgstransformsettingsdialog.cpp" line="166"/>
- <location filename="../src/plugins/georeferencer/qgstransformsettingsdialog.cpp" line="180"/>
+ <location filename="../src/plugins/georeferencer/qgstransformsettingsdialog.cpp" line="162"/>
+ <location filename="../src/plugins/georeferencer/qgstransformsettingsdialog.cpp" line="168"/>
+ <location filename="../src/plugins/georeferencer/qgstransformsettingsdialog.cpp" line="182"/>
</message>
<message>
<source>Please set output name</source>
<translation>Bitte Ausgabenamen setzen</translation>
</message>
<message>
</message>
<message>
<source>Invalid output file name</source>
<translation>Ungültiger Ausgabedateiname</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgstransformsettingsdialog.cpp" line="207"/>
+ <location filename="../src/plugins/georeferencer/qgstransformsettingsdialog.cpp" line="209"/>
<source>Save raster</source>
<translation>Raster speichern</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgstransformsettingsdialog.cpp" line="251"/>
+ <location filename="../src/plugins/georeferencer/qgstransformsettingsdialog.cpp" line="253"/>
+ <location filename="../src/plugins/georeferencer/qgstransformsettingsdialog.cpp" line="268"/>
<source>Select save PDF file</source>
<translation>Ausgabe-PDF-Datei wählen</translation>
</message>
<message>
<source>PDF Format</source>
<translation>PDF-Format</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgstransformsettingsdialog.cpp" line="316"/>
+ <location filename="../src/plugins/georeferencer/qgstransformsettingsdialog.cpp" line="333"/>
<source>_modified</source>
<comment>Georeferencer:QgsOpenRasterDialog.cpp - used to modify a user given file name</comment>
<translation>_modifiziert</translation>
@@ -26869,6 +27023,7 @@
<location filename="../src/plugins/georeferencer/qgstransformsettingsdialogbase.ui" line="113"/>
<location filename="../src/plugins/georeferencer/qgstransformsettingsdialogbase.ui" line="134"/>
<location filename="../src/plugins/georeferencer/qgstransformsettingsdialogbase.ui" line="155"/>
+ <location filename="../src/plugins/georeferencer/qgstransformsettingsdialogbase.ui" line="239"/>
</message>
@@ -26903,12 +27058,17 @@
<translation>World-Datei erzeugen</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgstransformsettingsdialogbase.ui" line="229"/>
+ <location filename="../src/plugins/georeferencer/qgstransformsettingsdialogbase.ui" line="227"/>
+ <source>Generate pdf map:</source>
+ <translation>PDF-Karte erzeugen:</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/georeferencer/qgstransformsettingsdialogbase.ui" line="250"/>
<source>Use 0 for transparency when needed</source>
<translation>Falls nötig 0 für Transparenz verwenden</translation>
</message>
<message>
- <location filename="../src/plugins/georeferencer/qgstransformsettingsdialogbase.ui" line="239"/>
+ <location filename="../src/plugins/georeferencer/qgstransformsettingsdialogbase.ui" line="260"/>
<source>Load in QGIS when done</source>
<translation>Wenn fertig In QGIS laden</translation>
</message>
@@ -27118,37 +27278,37 @@
<context>
<name>QgsVectorLayer</name>
<message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="2702"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="2705"/>
<source>No renderer object</source>
<translation>Kein Darstellungsobjekt</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="2706"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="2709"/>
<source>Classification field not found</source>
<translation>Klassifikationsfeld nicht gefunden</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="2860"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="2863"/>
<source>renderer failed to save</source>
<translation>Darstellung konnte nicht gespeichert werden</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="2867"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="2870"/>
<source>no renderer</source>
<translation>Keine Darstellung</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3197"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3200"/>
<source>ERROR: no provider</source>
<translation>FEHLER: kein Datenlieferant</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3203"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3206"/>
<source>ERROR: layer not editable</source>
<translation>FEHLER: Layer ist nicht veränderbar</translation>
</message>
<message numerus="yes">
- <location filename="../src/core/qgsvectorlayer.cpp" line="3217"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3220"/>
<source>SUCCESS: %n attribute(s) deleted.</source>
<comment>deleted attributes count</comment>
<translation>
@@ -27157,7 +27317,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3223"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3226"/>
<source>ERROR: %n attribute(s) not deleted.</source>
<comment>not deleted attributes count</comment>
<translation>
@@ -27166,7 +27326,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3239"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3242"/>
<source>SUCCESS: %n attribute(s) added.</source>
<comment>added attributes count</comment>
<translation>
@@ -27175,7 +27335,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3245"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3248"/>
<source>ERROR: %n new attribute(s) not added</source>
<comment>not added attributes count</comment>
<translation>
@@ -27184,17 +27344,17 @@
</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3286"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3289"/>
<source>SUCCESS: attribute %1 was added.</source>
<translation>ERFOLG: Attribut %1 hinzugefügt.</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3293"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3296"/>
<source>ERROR: attribute %1 not added</source>
<translation>FEHLER: Attribut %1 nicht hinzugefügt</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3355"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3358"/>
<source>SUCCESS: %n attribute value(s) changed.</source>
<comment>changed attribute values count</comment>
<translation>
@@ -27203,7 +27363,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3360"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3363"/>
<source>ERROR: %n attribute value change(s) not applied.</source>
<comment>not changed attribute values count</comment>
<translation>
@@ -27212,7 +27372,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3393"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3396"/>
<source>SUCCESS: %n feature(s) added.</source>
<comment>added features count</comment>
<translation>
@@ -27221,7 +27381,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3398"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3401"/>
<source>ERROR: %n feature(s) not added.</source>
<comment>not added features count</comment>
<translation>
@@ -27230,7 +27390,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3411"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3414"/>
<source>SUCCESS: %n geometries were changed.</source>
<comment>changed geometries count</comment>
<translation>
@@ -27239,7 +27399,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3416"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3419"/>
<source>ERROR: %n geometries not changed.</source>
<comment>not changed geometries count</comment>
<translation>
@@ -27248,7 +27408,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3428"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3431"/>
<source>SUCCESS: %n feature(s) deleted.</source>
<comment>deleted features count</comment>
<translation>
@@ -27257,7 +27417,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3438"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3441"/>
<source>ERROR: %n feature(s) not deleted.</source>
<comment>not deleted features count</comment>
<translation>
@@ -27266,7 +27426,7 @@
</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="2696"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="2699"/>
<source>Unknown renderer</source>
<translation>Unbekannte Darstellung</translation>
</message>
