[QGIS Commit] r14241 - in trunk/qgis/src: app/attributetable ui
svn_qgis at osgeo.org
Thu Sep 16 18:52:26 EDT 2010
Author: timlinux
Date: 2010-09-16 22:52:26 +0000 (Thu, 16 Sep 2010)
New Revision: 14241
trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp
trunk/qgis/src/ui/qgsattributetabledialog.ui
Applied patch to close #25 - allow case insensitive search of attribute table
Modified: trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp
--- trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp 2010-09-16 22:35:07 UTC (rev 14240)
+++ trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp 2010-09-16 22:52:26 UTC (rev 14241)
@@ -627,12 +627,16 @@
int fldIndex = mLayer->fieldNameIndex( fieldName );
QVariant::Type fldType = flds[fldIndex].type();
bool numeric = ( fldType == QVariant::Int || fldType == QVariant::Double );
+ QString sensString = "ILIKE";
+ if (cbxCaseSensitive->isChecked()) {
+ sensString = "LIKE";
QString str = QString( "%1 %2 '%3'" )
.arg( QgsSearchTreeNode::quotedColumnRef( fieldName ) )
- .arg( numeric ? "=" : "~" )
- .arg( mQuery->displayText().replace( "'", "''" ) ); // escape quotes
+ .arg( numeric ? "=" : sensString )
+ .arg( numeric ? mQuery->displayText().replace( "'", "''" ) :
+ "%" + mQuery->displayText().replace ("'", "''") + "%" ); // escape quotes
doSearch( str );
Modified: trunk/qgis/src/ui/qgsattributetabledialog.ui
--- trunk/qgis/src/ui/qgsattributetabledialog.ui 2010-09-16 22:35:07 UTC (rev 14240)
+++ trunk/qgis/src/ui/qgsattributetabledialog.ui 2010-09-16 22:52:26 UTC (rev 14241)
@@ -26,18 +26,28 @@
<item>
<widget class="QCheckBox" name="cbxShowSelectedOnly">
<property name="text">
- <string>Show selected records only</string>
+ <string>Show selected only</string>
</property>
</widget>
</item>
<item>
<widget class="QCheckBox" name="cbxSearchSelectedOnly">
- <string>Search selected records only</string>
+ <string>Search selected only</string>
</property>
</widget>
</item>
<item>
+ <widget class="QCheckBox" name="cbxCaseSensitive">
+ <property name="text">
+ <string>Case sensitive</string>
+ </property>
+ <property name="checked">
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item>
<spacer>
<property name="orientation">
<enum>Qt::Horizontal</enum>
@@ -68,8 +78,14 @@
</item>
<item>
<widget class="QPushButton" name="mHelpButton">
+ <property name="minimumSize">
+ <size>
+ <width>85</width>
+ <height>0</height>
+ </size>
+ </property>
- <string>Help</string>
+ <string>?</string>
</property>
</widget>
</item>
