[QGIS Commit] r14274 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Thu Sep 23 04:19:57 EDT 2010
Author: timlinux
Date: 2010-09-23 08:19:57 +0000 (Thu, 23 Sep 2010)
New Revision: 14274
trunk/qgis/src/app/qgsrasterlayerproperties.cpp
trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
Use qwt to plot raster rather than my my homegrown charting stuff
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.cpp
--- trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2010-09-22 18:49:13 UTC (rev 14273)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2010-09-23 08:19:57 UTC (rev 14274)
@@ -51,6 +51,12 @@
#include <QMouseEvent>
#include "qgslogger.h"
+// QWT Charting widget
+#include <qwt_array.h>
+#include <qwt_legend.h>
+#include <qwt_plot.h>
+#include <qwt_plot_curve.h>
+#include <qwt_plot_grid.h>
const char * const ident =
"$Id$";
@@ -218,8 +224,6 @@
myPixmap.fill( Qt::gray );
lstHistogramLabels->addItem( new QListWidgetItem( myPixmap, myRasterBandNameQString ) );
- mGradientHeight = pixHistogram->height() / 2;
- mGradientWidth = pixHistogram->width() / 2;
//keep a list of band names for later use
//! @note band names should not be translated!
myBandNameList.append( myRasterBandNameQString );
@@ -1948,8 +1952,8 @@
int myXAxisMax = 0;
bool myFirstItemFlag = true;
for ( int myIteratorInt = 1;
- myIteratorInt <= myBandCountInt;
- ++myIteratorInt )
+ myIteratorInt <= myBandCountInt;
+ ++myIteratorInt )
QgsRasterBandStats myRasterBandStats = mRasterLayer->bandStatistics( myIteratorInt );
//calculate the x axis min max
@@ -1998,318 +2002,51 @@
QgsDebugMsg( QString( "max %1" ).arg( myYAxisMax ) );
QgsDebugMsg( QString( "min %1" ).arg( myYAxisMin ) );
- //create the image onto which graph and axes will be drawn
- int myImageWidth = pixHistogram->width() - 2;
- int myImageHeight = pixHistogram->height() - 2; //Take two pixels off to account for the boarder around the QLabel
- QPixmap myPixmap( myImageWidth, myImageHeight );
- myPixmap.fill( Qt::white );
- // TODO: Confirm that removing the "const QWidget * copyAttributes" 2nd parameter,
- // in order to make things work in Qt4, doesn't break things in Qt3.
- //QPainter myPainter(&myPixmap, this);
- QPainter myPainter( &myPixmap );
- //anti alias lines in the graph
- myPainter.setRenderHint( QPainter::Antialiasing );
- //determine labels sizes and draw them
- QFont myQFont( "arial", 8, QFont::Normal );
- QFontMetrics myFontMetrics( myQFont );
- myPainter.setFont( myQFont );
- myPainter.setPen( Qt::black );
- QString myYMaxLabel = QString::number( static_cast < unsigned int >( myYAxisMax ) );
- QString myXMinLabel = QString::number( myXAxisMin );
- QString myXMaxLabel = QString::number( myXAxisMax );
- //calculate the gutters
- int myYGutterWidth = 0;
- if ( myFontMetrics.width( myXMinLabel ) < myFontMetrics.width( myYMaxLabel ) )
- myYGutterWidth = myFontMetrics.width( myYMaxLabel ) + 2; //add 2 so we can have 1 pix whitespace either side of label
- else
- myYGutterWidth = myFontMetrics.width( myXMinLabel ) + 2; //add 2 so we can have 1 pix whitespace either side of label
- int myXGutterHeight = myFontMetrics.height() + 2;
- int myXGutterWidth = myFontMetrics.width( myXMaxLabel ) + 1;//1 pix whtispace from right edge of image
+ QwtPlot * mypPlot = new QwtPlot( mChartWidget );
+ //ensure all children get removed
+ mypPlot->setAutoDelete( true );
+ QVBoxLayout *mpHistogramLayout = new QVBoxLayout( mChartWidget );
+ mpHistogramLayout->setContentsMargins( 0, 0, 0, 0 );
+ mpHistogramLayout->addWidget( mypPlot );
+ mChartWidget->setLayout( mpHistogramLayout );
+ mypPlot->setTitle(QObject::tr("Raster Histogram"));
+ mypPlot->insertLegend(new QwtLegend(), QwtPlot::BottomLegend);
+ // Set axis titles
+ mypPlot->setAxisTitle(QwtPlot::xBottom, QObject::tr("Pixel Value"));
+ mypPlot->setAxisTitle(QwtPlot::yLeft, QObject::tr("Frequency"));
- // Now calculate the graph drawable area after the axis labels have been taken
- // into account
+ // add a grid
- int myGraphImageWidth = myImageWidth - myYGutterWidth;
- int myGraphImageHeight = myImageHeight - myXGutterHeight;
- //find out how wide to draw bars when in bar chart mode
- int myBarWidth = static_cast<int>(((( double )myGraphImageWidth ) / (( double )BINCOUNT ) ) );
+ QwtPlotGrid * myGrid = new QwtPlotGrid();
+ myGrid->attach(mypPlot);
//now draw actual graphs
- if ( mRasterLayer->rasterType()
- == QgsRasterLayer::Palette ) //paletted layers have hard coded color entries
+ QList<QColor> myColors;
+ myColors << Qt::black << Qt::red << Qt::green << Qt::blue << Qt::magenta << Qt::darkRed << Qt::darkGreen << Qt::darkBlue;
+ for ( int myIteratorInt = 1;
+ ++myIteratorInt )
- QPolygonF myPolygon;
- QgsColorRampShader* myRasterShaderFunction = ( QgsColorRampShader* )mRasterLayer->rasterShader()->rasterShaderFunction();
- QgsDebugMsg( "Making paletted image histogram....computing band stats" );
- QgsDebugMsg( QString( "myLastBinWithData = %1" ).arg( myLastBinWithData ) );
- QgsRasterBandStats myRasterBandStats = mRasterLayer->bandStatistics( 1 );
- for ( int myBin = 0; myBin < myLastBinWithData; myBin++ )
+ QgsRasterBandStats myRasterBandStats = mRasterLayer->bandStatistics( myIteratorInt );
+ QListWidgetItem *myItem = lstHistogramLabels->item( myIteratorInt - 1 );
+ if ( myItem->isSelected() )
- double myBinValue = myRasterBandStats.histogramVector->at( myBin );
- QgsDebugMsg( QString( "myBin = %1 myBinValue = %2" ).arg( myBin ).arg( myBinValue ) );
- //NOTE: Int division is 0 if the numerator is smaller than the denominator.
- //hence the casts
- int myX = static_cast<int>(((( double )myGraphImageWidth ) / (( double )myLastBinWithData ) ) * myBin );
- //height varies according to freq. and scaled to greatet value in all layers
- int myY = 0;
- if ( myYAxisMax != 0 )
+ QwtPlotCurve * mypCurve = new QwtPlotCurve( tr( "Band %i" ).arg( myIteratorInt ) );
+ mypCurve->setRenderHint( QwtPlotItem::RenderAntialiased );
+ mypCurve->setPen(QPen( myColors.at( myIteratorInt ) ) );
+ QwtArray<double> myX2Data;//qwtarray is just a wrapped qvector
+ QwtArray<double> myY2Data;//qwtarray is just a wrapped qvector
+ for ( int myBin = 0; myBin < myLastBinWithData; myBin++ )
- myY = static_cast<int>((( double )myBinValue / ( double )myYAxisMax ) * myGraphImageHeight );
+ double myBinValue = myRasterBandStats.histogramVector->at( myBin );
+ myX2Data.append(myBin);
+ myY2Data.append(myBinValue);
- //see wehter to draw something each loop or to save up drawing for after iteration
- if ( myGraphType == BAR_CHART )
- //determine which color to draw the bar
- int c1, c2, c3;
- // Take middle of the interval for color
- // TODO: this is not precise
- double myInterval = ( myXAxisMax - myXAxisMin ) / myLastBinWithData;
- double myMiddle = myXAxisMin + myBin * myInterval + myInterval / 2;
- QgsDebugMsg( QString( "myMiddle = %1" ).arg( myMiddle ) );
- if ( myRasterShaderFunction->shade( myMiddle, &c1, &c2, &c3 ) )
- QgsDebugMsg( "Color not found" );
- c1 = c2 = c3 = 180; // grey
- QgsDebugMsg( QString( "c1 = %1 c2 = %2 c3 = %3" ).arg( c1 ).arg( c2 ).arg( c3 ) );
- //draw the bar
- //QBrush myBrush(QColor(c1,c2,c3));
- myPainter.setBrush( QColor( c1, c2, c3 ) );
- myPainter.setPen( QColor( c1, c2, c3 ) );
- QgsDebugMsg( QString( "myX = %1 myY = %2" ).arg( myX ).arg( myY ) );
- QgsDebugMsg( QString( "rect: %1, %2, %3, %4" ).arg( myX + myYGutterWidth ).arg( myImageHeight - ( myY + myXGutterHeight ) ).arg( myBarWidth ).arg( myY ) );
- myPainter.drawRect( myX + myYGutterWidth, myImageHeight - ( myY + myXGutterHeight ), myBarWidth, myY );
- //store this point in our line too
- myY = myGraphImageHeight - myY;
- myPolygon << QPointF( myX + myYGutterWidth, myY - myXGutterHeight );
+ mypCurve->setData(myX2Data,myY2Data);
+ mypCurve->attach(mypPlot);
- //draw a line on the graph along the bar peaks;
- if ( myGraphType == LINE_CHART )
- //close of the point array so it makes a nice polygon
- //bottom right point
- myImageWidth,
- myImageHeight - myXGutterHeight );
- //bottom left point
- myYGutterWidth,
- //set a gradient fill for the path
- QLinearGradient myGradient = greenGradient();
- myPainter.setBrush( myGradient );
- QPainterPath myPath;
- myPath.addPolygon( myPolygon );
- myPainter.drawPath( myPath );
- else
- for ( int myIteratorInt = 1;
- ++myIteratorInt )
- QgsRasterBandStats myRasterBandStats = mRasterLayer->bandStatistics( myIteratorInt );
- QListWidgetItem *myItem = lstHistogramLabels->item( myIteratorInt - 1 );
- if ( myItem->isSelected() )
- //hence the casts
- int myY = static_cast<int>((( double )myBinValue / ( double )myYAxisMax ) * myGraphImageHeight );
- //adjust for image origin being top left
- QgsDebugMsg( "-------------" );
- QgsDebugMsg( "int myY = (myBinValue/myCellCount)*myGraphImageHeight" );
- QgsDebugMsg( QString( "int myY = (%1/%2)*%3" ).arg( myBinValue ).arg( myCellCount ).arg( myGraphImageHeight ) );
- QgsDebugMsg( QString( "Band %1, bin %2, Hist Value : %3, Scaled Value : %4" ).arg( myIteratorInt ).arg( myBin ).arg( myBinValue ).arg( myY ) );
- QgsDebugMsg( "myY = myGraphImageHeight - myY" );
- QgsDebugMsg( QString( "myY = %1-%2" ).arg( myGraphImageHeight ).arg( myY ) );
- //draw the bar
- if ( myBandCountInt == 1 ) //draw single band images with black
- else if ( myIteratorInt == 1 )
- myPainter.setPen( Qt::red );
- else if ( myIteratorInt == 2 )
- myPainter.setPen( Qt::green );
- else if ( myIteratorInt == 3 )
- myPainter.setPen( Qt::blue );
- else if ( myIteratorInt == 4 )
- myPainter.setPen( Qt::magenta );
- else if ( myIteratorInt == 5 )
- myPainter.setPen( Qt::darkRed );
- else if ( myIteratorInt == 6 )
- myPainter.setPen( Qt::darkGreen );
- else if ( myIteratorInt == 7 )
- myPainter.setPen( Qt::darkBlue );
- else
- myPainter.setPen( Qt::gray );
- // QgsDebugMsg(QString("myPainter.fillRect(QRect(%1,%2,%3,%2), myBrush );").arg(myX).arg(myY).arg(myBarWidth));
- else //line graph
- myPolygon << QPointF( myX + myYGutterWidth, myY );
- QLinearGradient myGradient;
- myGradient = grayGradient();
- myGradient = redGradient();
- myGradient = greenGradient();
- myGradient = blueGradient();
- else
- myImageWidth,
- myYGutterWidth,
- // Now draw interval markers on the x axis
- int myXDivisions = myGraphImageWidth / 10;
- for ( int i = 0; i < myXDivisions; ++i )
- QPolygon myPolygon;
- myPolygon << QPoint(( i*myXDivisions ) + myYGutterWidth, myImageHeight - myXGutterHeight );
- myPolygon << QPoint(( i*myXDivisions ) + myYGutterWidth, myImageHeight - ( myXGutterHeight - 5 ) );
- myPolygon << QPoint((( i + 1 )*myXDivisions ) + myYGutterWidth, myImageHeight - myXGutterHeight );
- myPainter.drawPolyline( myPolygon );
- // Now draw interval markers on the y axis
- int myYDivisions = myGraphImageHeight / 10;
- for ( int i = myYDivisions; i > 0; --i )
- int myYOrigin = myImageHeight - myXGutterHeight;
- myPolygon << QPoint( myYGutterWidth, myYOrigin - ( i*myYDivisions ) );
- myPolygon << QPoint( myYGutterWidth - 5, myYOrigin - ( i*myYDivisions ) );
- myPolygon << QPoint( myYGutterWidth, myYOrigin - (( i - 1 )*myYDivisions ) );
- //now draw the axis labels onto the graph
- myPainter.drawText( 1, 12, myYMaxLabel );
- myPainter.drawText( 1, myImageHeight - myXGutterHeight, QString::number( static_cast < unsigned int >( myYAxisMin ) ) );
- myPainter.drawText( myYGutterWidth, myImageHeight - 1, myXMinLabel );
- myPainter.drawText( myImageWidth - myXGutterWidth, myImageHeight - 1, myXMaxLabel );
- // Finish up
- myPainter.end();
- pixHistogram->setPixmap( myPixmap );
QApplication::restoreOverrideCursor();
Modified: trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
--- trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui 2010-09-22 18:49:13 UTC (rev 14273)
+++ trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui 2010-09-23 08:19:57 UTC (rev 14274)
@@ -1892,6 +1892,7 @@
<tr>
<td style="border: none;">
<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"></p>
+<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"></p>
<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt;"></p></td></tr></table></body></html></string>
</property>
</widget>
@@ -1960,42 +1961,24 @@
</layout>
</widget>
<widget class="QWidget" name="tabPageHistogram">
- <layout class="QGridLayout">
- <property name="margin">
- <number>0</number>
- </property>
- <item row="0" column="0" colspan="2">
- <widget class="QLabel" name="pixHistogram">
- <property name="sizePolicy">
- <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
- <horstretch>0</horstretch>
- <verstretch>0</verstretch>
- </sizepolicy>
- </property>
- <property name="minimumSize">
+ <layout class="QGridLayout" name="gridLayout_4">
+ <item row="0" column="0" colspan="3">
+ <widget class="QWidget" name="mChartWidget" native="true"/>
+ </item>
+ <item row="1" column="0" rowspan="3">
+ <widget class="QListWidget" name="lstHistogramLabels">
+ <property name="maximumSize">
<size>
- <width>200</width>
- <height>200</height>
+ <width>99999</width>
+ <height>32767</height>
</size>
</property>
- <property name="frameShape">
- <enum>QFrame::Box</enum>
+ <property name="selectionMode">
+ <enum>QAbstractItemView::MultiSelection</enum>
</property>
- <property name="lineWidth">
- <number>1</number>
- </property>
- <property name="scaledContents">
- <bool>true</bool>
- </property>
- </property>
- <property name="indent">
- <number>-1</number>
- </property>
</widget>
</item>
- <item row="1" column="0">
+ <item row="1" column="1" colspan="2">
<widget class="QGroupBox" name="grpHistCharType">
@@ -2030,7 +2013,7 @@
</layout>
</widget>
</item>
- <item row="1" column="1" rowspan="2">
+ <item row="2" column="1" colspan="2">
<widget class="QGroupBox" name="groupBox">
<property name="title">
<string>Options</string>
@@ -2079,40 +2062,14 @@
</layout>
</widget>
</item>
- <item row="2" column="0" rowspan="4">
- <widget class="QListWidget" name="lstHistogramLabels">
- <property name="maximumSize">
- <size>
- <width>99999</width>
- <height>32767</height>
- </size>
- </property>
- <property name="selectionMode">
- <enum>QAbstractItemView::MultiSelection</enum>
- </property>
- </widget>
- </item>
<item row="3" column="1">
- <spacer>
- <property name="orientation">
- <enum>Qt::Vertical</enum>
- </property>
- <property name="sizeHint" stdset="0">
- <size>
- <width>20</width>
- <height>40</height>
- </size>
- </property>
- </spacer>
- </item>
- <item row="4" column="1">
<widget class="QProgressBar" name="mHistogramProgress">
<property name="value">
<number>0</number>
</property>
</widget>
</item>
- <item row="5" column="1">
+ <item row="3" column="2">
<widget class="QPushButton" name="pbnHistRefresh">
<property name="text">
<string>Refresh</string>
