[QGIS Commit] r15168 - in trunk/qgis: python/core
python/plugins/osm src/app src/app/legend src/core
src/core/composer src/gui src/mapserver
src/plugins/georeferencer src/plugins/grass
src/plugins/grass/qtermwidget src/plugins/offline_editing
src/plugins/raster_terrain_analysis src/plugins/roadgraph
src/plugins/spatialquery src/providers/delimitedtext
src/providers/memory
svn_qgis at osgeo.org
Sun Feb 13 15:24:55 EST 2011
Author: jef
Date: 2011-02-13 12:24:55 -0800 (Sun, 13 Feb 2011)
New Revision: 15168
trunk/qgis/python/core/qgsapplication.sip
trunk/qgis/python/core/qgscomposermap.sip
trunk/qgis/python/core/qgslabel.sip
trunk/qgis/python/core/qgsmaplayer.sip
trunk/qgis/python/core/qgsoverlayobject.sip
trunk/qgis/python/core/qgsrenderer.sip
trunk/qgis/python/core/qgssearchtreenode.sip
trunk/qgis/python/core/qgsvectordataprovider.sip
trunk/qgis/python/core/qgsvectorlayer.sip
trunk/qgis/python/plugins/osm/OsmDatabaseManager.py
trunk/qgis/python/plugins/osm/OsmLoadDlg.py
trunk/qgis/src/app/legend/qgsapplegendinterface.cpp
trunk/qgis/src/app/legend/qgslegend.cpp
trunk/qgis/src/app/legend/qgslegendlayer.cpp
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgisappinterface.cpp
trunk/qgis/src/app/qgsaddjoindialog.cpp
trunk/qgis/src/app/qgsattributedialog.cpp
trunk/qgis/src/app/qgsmaptoolidentify.cpp
trunk/qgis/src/app/qgsprojectproperties.cpp
trunk/qgis/src/app/qgsrasterlayerproperties.cpp
trunk/qgis/src/app/qgssnappingdialog.cpp
trunk/qgis/src/app/qgsvectorlayerproperties.cpp
trunk/qgis/src/core/composer/qgscomposerattributetable.cpp
trunk/qgis/src/core/composer/qgslegendmodel.cpp
trunk/qgis/src/core/qgsapplication.h
trunk/qgis/src/core/qgslabel.h
trunk/qgis/src/core/qgsmaplayer.cpp
trunk/qgis/src/core/qgsmaplayer.h
trunk/qgis/src/core/qgsmaplayerregistry.cpp
trunk/qgis/src/core/qgsmaprenderer.h
trunk/qgis/src/core/qgsoverlayobject.h
trunk/qgis/src/core/qgspallabeling.cpp
trunk/qgis/src/core/qgspluginlayerregistry.cpp
trunk/qgis/src/core/qgssearchtreenode.h
trunk/qgis/src/core/qgsvectordataprovider.h
trunk/qgis/src/core/qgsvectorfilewriter.h
trunk/qgis/src/core/qgsvectorlayer.cpp
trunk/qgis/src/core/qgsvectorlayer.h
trunk/qgis/src/gui/qgisinterface.h
trunk/qgis/src/gui/qgsformannotationitem.cpp
trunk/qgis/src/gui/qgsmapcanvas.cpp
trunk/qgis/src/mapserver/qgsconfigparser.cpp
trunk/qgis/src/mapserver/qgsprojectparser.cpp
trunk/qgis/src/mapserver/qgswmsserver.cpp
trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp
trunk/qgis/src/plugins/grass/qgsgrassplugin.cpp
trunk/qgis/src/plugins/grass/qtermwidget/TerminalDisplay.cpp
trunk/qgis/src/plugins/offline_editing/offline_editing.cpp
trunk/qgis/src/plugins/raster_terrain_analysis/qgsrasterterrainanalysisdialog.cpp
trunk/qgis/src/plugins/roadgraph/exportdlg.cpp
trunk/qgis/src/plugins/roadgraph/settingsdlg.cpp
trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp
trunk/qgis/src/providers/delimitedtext/qgsdelimitedtextprovider.cpp
trunk/qgis/src/providers/memory/qgsmemoryprovider.cpp
fix API QgsMapLayer::getLayerID() to id()), some warnings and use doxygen deprecation tag.
Modified: trunk/qgis/python/core/qgsapplication.sip
--- trunk/qgis/python/core/qgsapplication.sip 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/python/core/qgsapplication.sip 2011-02-13 20:24:55 UTC (rev 15168)
@@ -159,7 +159,7 @@
static const QStringList svgPaths();
//! Returns the path to the applications svg paths
- //! @note deprecated
+ //! @deprecated
static const QString svgPath();
//! Returns the path to the application prefix directory.
Modified: trunk/qgis/python/core/qgscomposermap.sip
--- trunk/qgis/python/core/qgscomposermap.sip 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/python/core/qgscomposermap.sip 2011-02-13 20:24:55 UTC (rev 15168)
@@ -47,7 +47,7 @@
BoundaryDirection
- /**This function is deprecated*/
+ /**@deprecated*/
void draw( QPainter *painter, const QgsRectangle& extent, const QSize& size, int dpi );
/** \brief Draw to paint device
Modified: trunk/qgis/python/core/qgslabel.sip
--- trunk/qgis/python/core/qgslabel.sip 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/python/core/qgslabel.sip 2011-02-13 20:24:55 UTC (rev 15168)
@@ -49,7 +49,7 @@
/** \brief render label
- \note deprecated
+ \deprecated
void renderLabel ( QPainter* painter, QgsRectangle& viewExtent,
QgsCoordinateTransform* coordinateTransform,
@@ -83,8 +83,7 @@
QMap<int, QgsField> & fields ( );
/** Pointer to default attributes.
- * @note this will be deprecated in version 2 as it is
- * badly named. Rather use attributes.
+ * @deprecated in version 2 badly named. Rather use attributes.
* @see labelAttributes method rather */
QgsLabelAttributes *layerAttributes( );
Modified: trunk/qgis/python/core/qgsmaplayer.sip
--- trunk/qgis/python/core/qgsmaplayer.sip 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/python/core/qgsmaplayer.sip 2011-02-13 20:24:55 UTC (rev 15168)
@@ -57,7 +57,14 @@
QgsMapLayer::LayerType type() const;
- /** Get this layer's unique ID, this ID is used to access this layer from map layer registry */
+ /** Get this layer's unique ID, this ID is used to access this layer from map layer registry
+ * @note added in 1.7
+ QString id() const;
+ * @deprecated in 1.7
QString getLayerID() const;
/** Set the display name of the layer
@@ -215,7 +222,7 @@
/** Returns layer's spatial reference system
@note This method is here for API compatibility
- and will be deprecited in 2.0
+ and will be deprecated in 2.0
@see crs()
const QgsCoordinateReferenceSystem& srs();
Modified: trunk/qgis/python/core/qgsoverlayobject.sip
--- trunk/qgis/python/core/qgsoverlayobject.sip 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/python/core/qgsoverlayobject.sip 2011-02-13 20:24:55 UTC (rev 15168)
@@ -14,9 +14,10 @@
//this function fill not be wrapped to not depend on geos python bindings
/**Returns the feature geometry in geos format. The calling function does _not_ take
ownership of the generated object. The geometry is in map coordinates
- @note: this function is deprecated. Please use geometry() and QgsGeometry::asGeos instead*/
+ @deprecated Please use geometry() and QgsGeometry::asGeos instead*/
//GEOSGeometry* getGeosGeometry();
- /**Feature geometry is released when object is destructed so this function is empty. This function is deprecated and does nothing*/
+ /**Feature geometry is released when object is destructed so this function is empty.
+ @deprecated nop */
//void releaseGeosGeometry( GEOSGeometry *the_geom )
//getters
Modified: trunk/qgis/python/core/qgsrenderer.sip
--- trunk/qgis/python/core/qgsrenderer.sip 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/python/core/qgsrenderer.sip 2011-02-13 20:24:55 UTC (rev 15168)
@@ -40,7 +40,7 @@
@param widthScale scale factor
@param rasterScaleFactor scale factor for rasters
- deprecated */
+ @deprecated */
void renderFeature(QPainter* p, QgsFeature& f,QImage* pic, bool selected, double widthScale = 1.0, double rasterScaleFactor = 1.0);
/**A vector layer passes features to a renderer object to change the brush ans pen of the qpainter
Modified: trunk/qgis/python/core/qgssearchtreenode.sip
--- trunk/qgis/python/core/qgssearchtreenode.sip 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/python/core/qgssearchtreenode.sip 2011-02-13 20:24:55 UTC (rev 15168)
@@ -104,7 +104,7 @@
//! @note attributes and optional geom parameter replace with feature in 1.6
bool checkAgainst( const QMap<int,QgsField>& fields, QgsFeature &f );
+ //! @deprecated
bool checkAgainst( const QMap<int,QgsField>& fields, const QMap<int, QVariant>& attributes, QgsGeometry* geom = 0 );
//! checks if there were errors during evaluation
@@ -119,7 +119,7 @@
bool getValue( QgsSearchTreeValue& value /Out/, QgsSearchTreeNode* node,
+ //! @deprecated
const QMap<int,QgsField>& fields, const QMap<int,QVariant>& attributes, QgsGeometry* geom = 0 );
@@ -149,7 +149,7 @@
//! @note attribute/geom replaced by feature in 1.6
QgsSearchTreeValue valueAgainst( const QMap<int,QgsField>& fields, QgsFeature &f );
+ //! @deprecated
QgsSearchTreeValue valueAgainst( const QMap<int,QgsField>& fields, const QMap<int,QVariant>& attributes, QgsGeometry* geom = 0 );
//! strips mText when node is of string type
Modified: trunk/qgis/python/core/qgsvectordataprovider.sip
--- trunk/qgis/python/core/qgsvectordataprovider.sip 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/python/core/qgsvectordataprovider.sip 2011-02-13 20:24:55 UTC (rev 15168)
@@ -196,7 +196,7 @@
* Adds new attributes
* @param attributes map with attribute name as key and type as value
* @return true in case of success and false in case of failure
- * @note deprecated
+ * @deprecated
virtual bool addAttributes(const QMap<QString, QString> &attributes);
@@ -283,7 +283,7 @@
const QList< QgsVectorDataProvider::NativeType > &nativeTypes() const;
/**Returns the names of the numerical types
- @note deprecated */
+ @deprecated */
const QMap<QString,QVariant::Type> &supportedNativeTypes() const;
Modified: trunk/qgis/python/core/qgsvectorlayer.sip
--- trunk/qgis/python/core/qgsvectorlayer.sip 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/python/core/qgsvectorlayer.sip 2011-02-13 20:24:55 UTC (rev 15168)
@@ -390,7 +390,7 @@
/** add an attribute field (but does not commit it)
returns true in case of success
- @note deprecated
+ @deprecated
bool addAttribute( QString name, QString type );
Modified: trunk/qgis/python/plugins/osm/OsmDatabaseManager.py
--- trunk/qgis/python/plugins/osm/OsmDatabaseManager.py 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/python/plugins/osm/OsmDatabaseManager.py 2011-02-13 20:24:55 UTC (rev 15168)
@@ -143,21 +143,21 @@
key=dbFileName.toLatin1().data()
# remove map layers that belong to dbFileName database
- if key in self.lineLayers.keys() and layer.getLayerID()==self.lineLayers[key].getLayerID():
+ if key in self.lineLayers.keys() and layer.id()==self.lineLayers[key].getLayerID():
del self.lineLayers[key]
- elif key in self.pointLayers.keys() and layer.getLayerID()==self.pointLayers[key].getLayerID():
+ elif key in self.pointLayers.keys() and layer.id()==self.pointLayers[key].id():
del self.pointLayers[key]
if key in self.lineLayers.keys():
if self.lineLayers[key]:
- lineLayID=self.lineLayers[key].getLayerID()
+ lineLayID=self.lineLayers[key].id()
self.mapReg.removeMapLayer(lineLayID,True)
- elif key in self.polygonLayers.keys() and layer.getLayerID()==self.polygonLayers[key].getLayerID():
+ elif key in self.polygonLayers.keys() and layer.id()==self.polygonLayers[key].id():
del self.polygonLayers[key]
if key in self.pointLayers.keys():
if self.pointLayers[key]:
- pointLayID=self.pointLayers[key].getLayerID()
+ pointLayID=self.pointLayers[key].id()
self.mapReg.removeMapLayer(pointLayID,True)
if key in self.dbConns.keys():
@@ -177,7 +177,7 @@
continue
if layer.type()==QgsMapLayer.VectorLayer and layer.dataProvider().name()=="osm":
- QgsMapLayerRegistry.instance().removeMapLayer(layer.getLayerID(),True)
+ QgsMapLayerRegistry.instance().removeMapLayer(layer.id(),True)
self.dbConns={} # map dbFileName->sqlite3ConnectionObject
self.pointLayers={}
Modified: trunk/qgis/python/plugins/osm/OsmLoadDlg.py
--- trunk/qgis/python/plugins/osm/OsmLoadDlg.py 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/python/plugins/osm/OsmLoadDlg.py 2011-02-13 20:24:55 UTC (rev 15168)
@@ -131,7 +131,7 @@
if replacing:
# remove layers of current data first
- QgsMapLayerRegistry.instance().removeMapLayer(self.canvas.currentLayer().getLayerID(),True)
+ QgsMapLayerRegistry.instance().removeMapLayer(self.canvas.currentLayer().id(),True)
if self.chkCustomRenderer.isChecked():
styleFile=self.styleFiles[self.styleCombo.currentIndex()]
Modified: trunk/qgis/src/app/legend/qgsapplegendinterface.cpp
--- trunk/qgis/src/app/legend/qgsapplegendinterface.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/app/legend/qgsapplegendinterface.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -134,5 +134,5 @@
void QgsAppLegendInterface::refreshLayerSymbology( QgsMapLayer *ml )
- mLegend->refreshLayerSymbology( ml->getLayerID() );
+ mLegend->refreshLayerSymbology( ml->id() );
Modified: trunk/qgis/src/app/legend/qgslegend.cpp
--- trunk/qgis/src/app/legend/qgslegend.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/app/legend/qgslegend.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -230,7 +230,7 @@
// save legend layer (parent of a legend layer file we're going to delete)
QgsLegendLayer* ll = qobject_cast<QgsLegendLayer *>( li );
- if ( ll && ll->layer() && ll->layer()->getLayerID() == layerId )
+ if ( ll && ll->layer() && ll->layer()->id() == layerId )
removeItem( ll );
delete ll;
Modified: trunk/qgis/src/app/legend/qgslegendlayer.cpp
--- trunk/qgis/src/app/legend/qgslegendlayer.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/app/legend/qgslegendlayer.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -540,7 +540,7 @@
widthScale = canvas->map()->paintDevice().logicalDpiX() / 25.4;
- refreshSymbology( mLyr.layer()->getLayerID(), widthScale );
+ refreshSymbology( mLyr.layer()->id(), widthScale );
void QgsLegendLayer::updateItemListCountV2( SymbologyList& itemList, QgsVectorLayer* layer )
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/app/qgisapp.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -4920,7 +4920,7 @@
mMapCanvas->refresh();
if ( mMapLegend )
- mMapLegend->refreshLayerSymbology( vlayer->getLayerID(), false );
+ mMapLegend->refreshLayerSymbology( vlayer->id(), false );
Modified: trunk/qgis/src/app/qgisappinterface.cpp
--- trunk/qgis/src/app/qgisappinterface.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/app/qgisappinterface.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -220,7 +220,7 @@
if ( l && qgis && qgis->legend() )
- qgis->legend()->refreshLayerSymbology( l->getLayerID() );
+ qgis->legend()->refreshLayerSymbology( l->id() );
Modified: trunk/qgis/src/app/qgsaddjoindialog.cpp
--- trunk/qgis/src/app/qgsaddjoindialog.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/app/qgsaddjoindialog.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -44,7 +44,7 @@
if ( currentVectorLayer && currentVectorLayer != mLayer )
if ( currentVectorLayer->dataProvider() && currentVectorLayer->dataProvider()->supportsSubsetString() )
- mJoinLayerComboBox->addItem( currentLayer->name(), QVariant( currentLayer->getLayerID() ) );
+ mJoinLayerComboBox->addItem( currentLayer->name(), QVariant( currentLayer->id() ) );
Modified: trunk/qgis/src/app/qgsattributedialog.cpp
--- trunk/qgis/src/app/qgsattributedialog.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/app/qgsattributedialog.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -288,7 +288,7 @@
mFormNr = smFormCounter++;
QgisApp::instance()->runPythonString( QString( "_qgis_featureform_%1 = wrapinstance( %2, QtGui.QDialog )" ).arg( mFormNr ).arg(( unsigned long ) mDialog ) );
- QString expr = QString( "%1(_qgis_featureform_%2,'%3',%4)" ).arg( vl->editFormInit() ).arg( mFormNr ).arg( vl->getLayerID() ).arg( mFeature->id() );
+ QString expr = QString( "%1(_qgis_featureform_%2,'%3',%4)" ).arg( vl->editFormInit() ).arg( mFormNr ).arg( vl->id() ).arg( mFeature->id() );
QgsDebugMsg( QString( "running featureForm init: %1" ).arg( expr ) );
QgisApp::instance()->runPythonString( expr );
Modified: trunk/qgis/src/app/qgsmaptoolidentify.cpp
--- trunk/qgis/src/app/qgsmaptoolidentify.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/app/qgsmaptoolidentify.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -120,7 +120,7 @@
emit identifyProgress( i, mCanvas->layerCount() );
emit identifyMessage( tr( "Identifying on %1..." ).arg( layer->name() ) );
- if ( noIdentifyLayerIdList.contains( layer->getLayerID() ) )
+ if ( noIdentifyLayerIdList.contains( layer->id() ) )
continue;
if ( identifyLayer( layer, e->x(), e->y() ) )
Modified: trunk/qgis/src/app/qgsprojectproperties.cpp
--- trunk/qgis/src/app/qgsprojectproperties.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/app/qgsprojectproperties.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -159,7 +159,7 @@
twIdentifyLayers->setItem( i, 1, twi );
QCheckBox *cb = new QCheckBox();
- cb->setChecked( !noIdentifyLayerIdList.contains( currentLayer->getLayerID() ) );
+ cb->setChecked( !noIdentifyLayerIdList.contains( currentLayer->id() ) );
twIdentifyLayers->setCellWidget( i, 2, cb );
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.cpp
--- trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -1393,7 +1393,7 @@
pixmapThumbnail->setPixmap( myQPixmap );
// update symbology
- emit refreshLegend( mRasterLayer->getLayerID(), false );
+ emit refreshLegend( mRasterLayer->id(), false );
//no need to delete the old one, maplayer will do it if needed
mRasterLayer->setCacheImage( 0 );
Modified: trunk/qgis/src/app/qgssnappingdialog.cpp
--- trunk/qgis/src/app/qgssnappingdialog.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/app/qgssnappingdialog.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -157,7 +157,7 @@
QCheckBox *cbxEnable = new QCheckBox( mLayerTreeWidget );
mLayerTreeWidget->setItemWidget( item, 0, cbxEnable );
- item->setData( 0, Qt::UserRole, currentVectorLayer->getLayerID() );
+ item->setData( 0, Qt::UserRole, currentVectorLayer->id() );
item->setText( 1, currentVectorLayer->name() );
Modified: trunk/qgis/src/app/qgsvectorlayerproperties.cpp
--- trunk/qgis/src/app/qgsvectorlayerproperties.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/app/qgsvectorlayerproperties.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -683,7 +683,7 @@
// update symbology
- emit refreshLegend( layer->getLayerID(), false );
+ emit refreshLegend( layer->id(), false );
layer->setCacheImage( 0 );
Modified: trunk/qgis/src/core/composer/qgscomposerattributetable.cpp
--- trunk/qgis/src/core/composer/qgscomposerattributetable.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/core/composer/qgscomposerattributetable.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -193,7 +193,7 @@
if ( mVectorLayer )
- if ( layerId == mVectorLayer->getLayerID() )
+ if ( layerId == mVectorLayer->id() )
mVectorLayer = 0;
Modified: trunk/qgis/src/core/composer/qgslegendmodel.cpp
--- trunk/qgis/src/core/composer/qgslegendmodel.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/core/composer/qgslegendmodel.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -210,7 +210,7 @@
continue;
- QStandardItem* currentSymbolItem = itemFromSymbol( *symbolIt, opacity, vlayer->getLayerID() );
+ QStandardItem* currentSymbolItem = itemFromSymbol( *symbolIt, opacity, vlayer->id() );
if ( !currentSymbolItem )
continue;
Modified: trunk/qgis/src/core/qgsapplication.h
--- trunk/qgis/src/core/qgsapplication.h 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/core/qgsapplication.h 2011-02-13 20:24:55 UTC (rev 15168)
@@ -110,7 +110,7 @@
//! Returns the paths to svg applications svg directory.
- //! @note deprecated since 1.4
+ //! @deprecated since 1.4
Modified: trunk/qgis/src/core/qgslabel.h
--- trunk/qgis/src/core/qgslabel.h 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/core/qgslabel.h 2011-02-13 20:24:55 UTC (rev 15168)
@@ -146,8 +146,7 @@
QgsFieldMap & fields( void );
+ * @deprecated in version 2 as it is badly named. Rather use attributes.
QgsLabelAttributes *layerAttributes( void );
Modified: trunk/qgis/src/core/qgsmaplayer.cpp
--- trunk/qgis/src/core/qgsmaplayer.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/core/qgsmaplayer.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -95,7 +95,7 @@
/** Get this layer's unique ID */
-QString QgsMapLayer::getLayerID() const
+QString QgsMapLayer::id() const
return mID;
@@ -282,11 +282,11 @@
maplayer.setAttribute( "maximumScale", maximumScale() );
// ID
- QDomElement id = document.createElement( "id" );
- QDomText idText = document.createTextNode( getLayerID() );
- id.appendChild( idText );
+ QDomElement layerId = document.createElement( "id" );
+ QDomText layerIdText = document.createTextNode( id() );
+ layerId.appendChild( layerIdText );
- maplayer.appendChild( id );
+ maplayer.appendChild( layerId );
// data source
QDomElement dataSource = document.createElement( "datasource" );
Modified: trunk/qgis/src/core/qgsmaplayer.h
--- trunk/qgis/src/core/qgsmaplayer.h 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/core/qgsmaplayer.h 2011-02-13 20:24:55 UTC (rev 15168)
@@ -67,9 +67,16 @@
- QString getLayerID() const;
+ * @deprecated use id()
+ QString getLayerID() const { return id(); }
* @param name New name for the layer
Modified: trunk/qgis/src/core/qgsmaplayerregistry.cpp
--- trunk/qgis/src/core/qgsmaplayerregistry.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/core/qgsmaplayerregistry.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -72,16 +72,16 @@
//check the layer is not already registered!
- QMap<QString, QgsMapLayer*>::iterator myIterator = mMapLayers.find( theMapLayer->getLayerID() );
+ QMap<QString, QgsMapLayer*>::iterator myIterator = mMapLayers.find( theMapLayer->id() );
//if myIterator returns mMapLayers.end() then it does not exist in registry and its safe to add it
if ( myIterator == mMapLayers.end() )
- mMapLayers[theMapLayer->getLayerID()] = theMapLayer;
+ mMapLayers[theMapLayer->id()] = theMapLayer;
if ( theEmitSignal )
emit layerWasAdded( theMapLayer );
- return mMapLayers[theMapLayer->getLayerID()];
+ return mMapLayers[theMapLayer->id()];
else
Modified: trunk/qgis/src/core/qgsmaprenderer.h
--- trunk/qgis/src/core/qgsmaprenderer.h 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/core/qgsmaprenderer.h 2011-02-13 20:24:55 UTC (rev 15168)
@@ -134,7 +134,7 @@
void updateScale();
//! Return the measuring object
- //! @note deprecated.
+ //! @deprecated
QgsDistanceArea* distanceArea() { return mDistArea; }
QGis::UnitType mapUnits() const;
void setMapUnits( QGis::UnitType u );
Modified: trunk/qgis/src/core/qgsoverlayobject.h
--- trunk/qgis/src/core/qgsoverlayobject.h 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/core/qgsoverlayobject.h 2011-02-13 20:24:55 UTC (rev 15168)
@@ -42,9 +42,11 @@
+ * @deprecated nop
void releaseGeosGeometry( GEOSGeometry *the_geom ) { Q_UNUSED( the_geom ); }
//getters
Modified: trunk/qgis/src/core/qgspallabeling.cpp
--- trunk/qgis/src/core/qgspallabeling.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/core/qgspallabeling.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -696,7 +696,7 @@
max_scale = lyr.scaleMax;
- Layer* l = mPal->addLayer( layer->getLayerID().toLocal8Bit().data(),
+ Layer* l = mPal->addLayer( layer->id().toLocal8Bit().data(),
min_scale, max_scale, arrangement,
METER, priority, lyr.obstacle, true, true );
@@ -781,7 +781,7 @@
QHash<QgsVectorLayer*, QgsPalLayerSettings>::iterator lit;
for ( lit = mActiveLayers.begin(); lit != mActiveLayers.end(); ++lit )
- if ( lit.key() && lit.key()->getLayerID() == layerName )
+ if ( lit.key() && lit.key()->id() == layerName )
return lit.value();
Modified: trunk/qgis/src/core/qgspluginlayerregistry.cpp
--- trunk/qgis/src/core/qgspluginlayerregistry.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/core/qgspluginlayerregistry.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -100,7 +100,7 @@
QgsPluginLayer* pl = qobject_cast<QgsPluginLayer*>( layer );
if ( pl->pluginLayerType() == typeName )
- QgsMapLayerRegistry::instance()->removeMapLayer( layer->getLayerID() );
+ QgsMapLayerRegistry::instance()->removeMapLayer( layer->id() );
Modified: trunk/qgis/src/core/qgssearchtreenode.h
--- trunk/qgis/src/core/qgssearchtreenode.h 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/core/qgssearchtreenode.h 2011-02-13 20:24:55 UTC (rev 15168)
@@ -154,7 +154,7 @@
//! @note attribute and optional geom parameter replaced with feature in 1.6
bool checkAgainst( const QgsFieldMap& fields, QgsFeature &f );
+ //! @deprecated
bool checkAgainst( const QgsFieldMap& fields, const QgsAttributeMap& attributes, QgsGeometry* geom = 0 );
@@ -170,7 +170,7 @@
QgsFeature &f );
+ //! @deprecated
bool getValue( QgsSearchTreeValue& value,
const QgsFieldMap &fields,
@@ -210,7 +210,7 @@
//! returns scalar value of node
QgsSearchTreeValue valueAgainst( const QgsFieldMap& fields, QgsFeature &f );
+ //! @deprecated
QgsSearchTreeValue valueAgainst( const QgsFieldMap& fields, const QgsAttributeMap& attributes, QgsGeometry* geom = 0 );
Modified: trunk/qgis/src/core/qgsvectordataprovider.h
--- trunk/qgis/src/core/qgsvectordataprovider.h 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/core/qgsvectordataprovider.h 2011-02-13 20:24:55 UTC (rev 15168)
@@ -235,7 +235,7 @@
* Add new attributes
* @param attributes map of attributes name as key and type as value
+ * @deprecated
virtual bool addAttributes( const QMap<QString, QString> &attributes );
@@ -345,7 +345,7 @@
* Returns the names of the supported types
+ * @deprecated
const QMap<QString, QVariant::Type> &supportedNativeTypes() const;
Modified: trunk/qgis/src/core/qgsvectorfilewriter.h
--- trunk/qgis/src/core/qgsvectorfilewriter.h 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/core/qgsvectorfilewriter.h 2011-02-13 20:24:55 UTC (rev 15168)
@@ -57,7 +57,7 @@
/** Write contents of vector layer to a shapefile
- @note: deprecated. Use writeAsVectorFormat instead*/
+ @deprecated Use writeAsVectorFormat instead*/
static WriterError writeAsShapefile( QgsVectorLayer* layer,
const QString& shapefileName,
const QString& fileEncoding,
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -3396,7 +3396,7 @@
mCommitErrors << tr( "SUCCESS: %n attribute(s) deleted.", "deleted attributes count", mDeletedAttributeIds.size() );
- emit committedAttributesDeleted( getLayerID(), mDeletedAttributeIds );
+ emit committedAttributesDeleted( id(), mDeletedAttributeIds );
mDeletedAttributeIds.clear();
attributesChanged = true;
@@ -3424,7 +3424,7 @@
mCommitErrors << tr( "SUCCESS: %n attribute(s) added.", "added attributes count", mAddedAttributeIds.size() );
- emit committedAttributesAdded( getLayerID(), addedAttributes );
+ emit committedAttributesAdded( id(), addedAttributes );
mAddedAttributeIds.clear();
@@ -3543,7 +3543,7 @@
mCommitErrors << tr( "SUCCESS: %n attribute value(s) changed.", "changed attribute values count", mChangedAttributeValues.size() );
- emit committedAttributeValuesChanges( getLayerID(), mChangedAttributeValues );
+ emit committedAttributeValuesChanges( id(), mChangedAttributeValues );
mChangedAttributeValues.clear();
@@ -3584,7 +3584,7 @@
mCommitErrors << tr( "SUCCESS: %n feature(s) added.", "added features count", mAddedFeatures.size() );
- emit committedFeaturesAdded( getLayerID(), mAddedFeatures );
+ emit committedFeaturesAdded( id(), mAddedFeatures );
mAddedFeatures.clear();
@@ -3605,7 +3605,7 @@
mCommitErrors << tr( "SUCCESS: %n geometries were changed.", "changed geometries count", mChangedGeometries.size() );
- emit committedGeometriesChanges( getLayerID(), mChangedGeometries );
+ emit committedGeometriesChanges( id(), mChangedGeometries );
mChangedGeometries.clear();
@@ -3630,7 +3630,7 @@
mChangedGeometries.remove( *it );
- emit committedFeaturesRemoved( getLayerID(), mDeletedFeatureIds );
+ emit committedFeaturesRemoved( id(), mDeletedFeatureIds );
mDeletedFeatureIds.clear();
Modified: trunk/qgis/src/core/qgsvectorlayer.h
--- trunk/qgis/src/core/qgsvectorlayer.h 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/core/qgsvectorlayer.h 2011-02-13 20:24:55 UTC (rev 15168)
@@ -489,7 +489,7 @@
returns true if the field was added
+ @deprecated */
/**Sets an alias (a display name) for attributes to display in dialogs
Modified: trunk/qgis/src/gui/qgisinterface.h
--- trunk/qgis/src/gui/qgisinterface.h 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/gui/qgisinterface.h 2011-02-13 20:24:55 UTC (rev 15168)
@@ -145,7 +145,7 @@
virtual void removeDockWidget( QDockWidget * dockwidget ) = 0;
/** refresh the legend of a layer
- \note deprecated - use QgsLegendInterface::refreshLayerSymbology
+ \deprecated use QgsLegendInterface::refreshLayerSymbology
virtual void refreshLegend( QgsMapLayer *l ) = 0;
Modified: trunk/qgis/src/gui/qgsformannotationitem.cpp
--- trunk/qgis/src/gui/qgsformannotationitem.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/gui/qgsformannotationitem.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -177,7 +177,7 @@
QDomElement formAnnotationElem = doc.createElement( "FormAnnotationItem" );
if ( mVectorLayer )
- formAnnotationElem.setAttribute( "vectorLayer", mVectorLayer->getLayerID() );
+ formAnnotationElem.setAttribute( "vectorLayer", mVectorLayer->id() );
formAnnotationElem.setAttribute( "hasFeature", mHasAssociatedFeature );
formAnnotationElem.setAttribute( "feature", mFeature );
Modified: trunk/qgis/src/gui/qgsmapcanvas.cpp
--- trunk/qgis/src/gui/qgsmapcanvas.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/gui/qgsmapcanvas.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -243,11 +243,11 @@
if ( lyr.isVisible() )
- layerSet.push_back( lyr.layer()->getLayerID() );
+ layerSet.push_back( lyr.layer()->id() );
if ( lyr.isInOverview() )
- layerSetOverview.push_back( lyr.layer()->getLayerID() );
+ layerSetOverview.push_back( lyr.layer()->id() );
@@ -937,7 +937,7 @@
void QgsMapCanvas::paintEvent( QPaintEvent *e )
- if( mNewSize.isValid() )
+ if ( mNewSize.isValid() )
static bool isAlreadyIn = false;
static QSize lastSize = QSize();
@@ -980,7 +980,7 @@
emit extentsChanged();
- isAlreadyIn = false;
+ isAlreadyIn = false;
QGraphicsView::paintEvent( e );
Modified: trunk/qgis/src/mapserver/qgsconfigparser.cpp
--- trunk/qgis/src/mapserver/qgsconfigparser.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/mapserver/qgsconfigparser.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -392,7 +392,7 @@
if ( *mapIdIt )
- layerSet.push_back(( *mapIdIt )->getLayerID() );
+ layerSet.push_back(( *mapIdIt )->id() );
Modified: trunk/qgis/src/mapserver/qgsprojectparser.cpp
--- trunk/qgis/src/mapserver/qgsprojectparser.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/mapserver/qgsprojectparser.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -64,7 +64,7 @@
QgsMapLayer *layer = createLayerFromElement( *layerIt );
if ( layer )
- QgsMSDebugMsg( QString( "add layer %1 to map" ).arg( layer->getLayerID() ) );
+ QgsMSDebugMsg( QString( "add layer %1 to map" ).arg( layer->id() ) );
layerMap.insert( layer->getLayerID(), layer );
#if QGSMSDEBUG
Modified: trunk/qgis/src/mapserver/qgswmsserver.cpp
--- trunk/qgis/src/mapserver/qgswmsserver.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/mapserver/qgswmsserver.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -612,7 +612,7 @@
//create maplayer from sld parser
layerList = mConfigParser->mapLayerFromStyle( *layerIt, "" );
currentLayer = layerList.at( 0 );
- if ( !currentLayer || nonIdentifiableLayers.contains( currentLayer->getLayerID() ) )
+ if ( !currentLayer || nonIdentifiableLayers.contains( currentLayer->id() ) )
continue;
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -147,7 +147,7 @@
// delete layer (and don't signal it as it's our private layer)
if ( mLayer )
- QgsMapLayerRegistry::instance()->removeMapLayer( mLayer->getLayerID(), false );
+ QgsMapLayerRegistry::instance()->removeMapLayer( mLayer->id(), false );
delete mToolZoomIn;
Modified: trunk/qgis/src/plugins/grass/qgsgrassplugin.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassplugin.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/plugins/grass/qgsgrassplugin.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -466,7 +466,7 @@
void QgsGrassPlugin::closeEdit( QString layerId )
- if ( mEdit->layer()->getLayerID() == layerId )
+ if ( mEdit->layer()->id() == layerId )
mEdit->closeEdit();
Modified: trunk/qgis/src/plugins/grass/qtermwidget/TerminalDisplay.cpp
--- trunk/qgis/src/plugins/grass/qtermwidget/TerminalDisplay.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/plugins/grass/qtermwidget/TerminalDisplay.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -2423,6 +2423,8 @@
case Qt::ImCurrentSelection:
return QString();
break;
+ default:
+ break;
return QVariant();
Modified: trunk/qgis/src/plugins/offline_editing/offline_editing.cpp
--- trunk/qgis/src/plugins/offline_editing/offline_editing.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/plugins/offline_editing/offline_editing.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -189,7 +189,7 @@
QgsMapLayerRegistry::instance()->addMapLayer( remoteLayer, true );
// apply layer edit log
- QString qgisLayerId = layer->getLayerID();
+ QString qgisLayerId = layer->id();
QString sql = QString( "SELECT \"id\" FROM 'log_layer_ids' WHERE \"qgis_id\" = '%1'" ).arg( qgisLayerId );
int layerId = sqlQueryInt( db, sql, -1 );
if ( layerId != -1 )
Modified: trunk/qgis/src/plugins/raster_terrain_analysis/qgsrasterterrainanalysisdialog.cpp
--- trunk/qgis/src/plugins/raster_terrain_analysis/qgsrasterterrainanalysisdialog.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/plugins/raster_terrain_analysis/qgsrasterterrainanalysisdialog.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -43,7 +43,7 @@
QgsRasterLayer* rl = qobject_cast<QgsRasterLayer *>( layer_it.value() );
if ( rl )
- mInputLayerComboBox->addItem( rl->name(), QVariant( rl->getLayerID() ) );
+ mInputLayerComboBox->addItem( rl->name(), QVariant( rl->id() ) );
Modified: trunk/qgis/src/plugins/roadgraph/exportdlg.cpp
--- trunk/qgis/src/plugins/roadgraph/exportdlg.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/plugins/roadgraph/exportdlg.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -59,7 +59,7 @@
continue;
if ( vl->geometryType() != QGis::Line )
continue;
- mcbLayers->insertItem( 0, vl->name(), QVariant( vl->getLayerID() ) );
+ mcbLayers->insertItem( 0, vl->name(), QVariant( vl->id() ) );
} // RgSettingsDlg::RgSettingsDlg()
Modified: trunk/qgis/src/plugins/roadgraph/settingsdlg.cpp
--- trunk/qgis/src/plugins/roadgraph/settingsdlg.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/plugins/roadgraph/settingsdlg.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -26,7 +26,8 @@
//standard includes
RgSettingsDlg::RgSettingsDlg( RgSettings *settings, QWidget* parent, Qt::WFlags fl )
- : mSettings( settings ), QDialog( parent, fl )
+ : QDialog( parent, fl )
+ , mSettings( settings )
// create base widgets;
setWindowTitle( tr( "Road graph plugin settings" ) );
Modified: trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp
--- trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -495,7 +495,7 @@
addLayerCombobox( true, vectorLayer );
- mMapIdVectorLayers.insert( vectorLayer->getLayerID(), vectorLayer );
+ mMapIdVectorLayers.insert( vectorLayer->id(), vectorLayer );
targetLayerComboBox->setCurrentIndex( 0 );
targetLayerComboBox->blockSignals( false );
Modified: trunk/qgis/src/providers/delimitedtext/qgsdelimitedtextprovider.cpp
--- trunk/qgis/src/providers/delimitedtext/qgsdelimitedtextprovider.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/providers/delimitedtext/qgsdelimitedtextprovider.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -132,41 +132,41 @@
QgsDelimitedTextProvider::QgsDelimitedTextProvider( QString uri )
: QgsVectorDataProvider( uri )
+ , mDelimiter( "," )
+ , mDelimiterRegexp()
+ , mDelimiterType( "plain" )
, mHasWktField( false )
, mFieldCount( 0 )
- , mXFieldIndex( -1 )
+ , mXFieldIndex( -1 )
, mYFieldIndex( -1 )
, mWktFieldIndex( -1 )
- , mDelimiterType( "plain" )
- , mDelimiter( "," )
- , mDelimiterRegexp()
, mWktHasZM( false )
, mWktZMRegexp( "\\s+(?:z|m|zm)(?=\\s*\\()", Qt::CaseInsensitive )
, mWktCrdRegexp( "(\\-?\\d+(?:\\.\\d*)?\\s+\\-?\\d+(?:\\.\\d*)?)\\s[\\s\\d\\.\\-]+" )
- , mSkipLines(0)
+ , mSkipLines( 0 )
, mFirstDataLine( 0 )
, mShowInvalidLines( true )
+ , mCrs()
, mWkbType( QGis::WKBNoGeometry )
- , mCrs()
- QUrl url = QUrl::fromEncoded(uri.toUtf8());
+ QUrl url = QUrl::fromEncoded( uri.toUtf8() );
// Extract the provider definition from the url
mFileName = url.path();
- QString wktField("");
- QString xField("");
- QString yField("");
+ QString wktField( "" );
+ QString xField( "" );
+ QString yField( "" );
- if( url.hasQueryItem("delimiter")) mDelimiter = url.queryItemValue("delimiter");
- if( url.hasQueryItem("delimiterType")) mDelimiterType = url.queryItemValue("delimiterType");
- if( url.hasQueryItem("wktField")) wktField = url.queryItemValue("wktField");
- if( url.hasQueryItem("xField")) xField = url.queryItemValue("xField");
- if( url.hasQueryItem("yField")) yField = url.queryItemValue("yField");
- if( url.hasQueryItem("skipLines")) mSkipLines = url.queryItemValue("skipLines").toInt();
- if( url.hasQueryItem("crs")) mCrs.createFromString( url.queryItemValue("crs"));
+ if ( url.hasQueryItem( "delimiter" ) ) mDelimiter = url.queryItemValue( "delimiter" );
+ if ( url.hasQueryItem( "delimiterType" ) ) mDelimiterType = url.queryItemValue( "delimiterType" );
+ if ( url.hasQueryItem( "wktField" ) ) wktField = url.queryItemValue( "wktField" );
+ if ( url.hasQueryItem( "xField" ) ) xField = url.queryItemValue( "xField" );
+ if ( url.hasQueryItem( "yField" ) ) yField = url.queryItemValue( "yField" );
+ if ( url.hasQueryItem( "skipLines" ) ) mSkipLines = url.queryItemValue( "skipLines" ).toInt();
+ if ( url.hasQueryItem( "crs" ) ) mCrs.createFromString( url.queryItemValue( "crs" ) );
mHasWktField = wktField != "";
Modified: trunk/qgis/src/providers/memory/qgsmemoryprovider.cpp
--- trunk/qgis/src/providers/memory/qgsmemoryprovider.cpp 2011-02-13 20:02:34 UTC (rev 15167)
+++ trunk/qgis/src/providers/memory/qgsmemoryprovider.cpp 2011-02-13 20:24:55 UTC (rev 15168)
@@ -34,17 +34,17 @@
mSelectRectGeom( NULL ),
mSpatialIndex( NULL )
- // Initiallize the geometry with the uri to support old style uri's
+ // Initialize the geometry with the uri to support old style uri's
// (ie, just 'point', 'line', 'polygon')
QString geometry;
- if( url.hasQueryItem("geometry"))
+ if ( url.hasQueryItem( "geometry" ) )
- geometry = url.queryItemValue("geometry");
+ geometry = url.queryItemValue( "geometry" );
else
- geometry = url.path();
+ geometry = url.path();
geometry = geometry.toLower();
@@ -63,10 +63,10 @@
else
mWkbType = QGis::WKBUnknown;
- QString crsDef = url.queryItemValue("crs");
- mCrs.createFromString(crsDef);
+ QString crsDef = url.queryItemValue( "crs" );
+ mCrs.createFromString( crsDef );
mNextFeatureId = 1;
@@ -77,60 +77,60 @@
<< QgsVectorDataProvider::NativeType( tr( "Text (string)" ), "string", QVariant::String, 1, 255 )
- if( url.hasQueryItem("field"))
+ if ( url.hasQueryItem( "field" ) )
QList<QgsField> attributes;
- QRegExp reFieldDef("\\:"
- "(int|integer|real|double|string)" // type
- "(?:\\((\\d+)" // length
- "(?:\\,(\\d+))?" // precision
- "$", Qt::CaseInsensitive);
- QStringList fields = url.allQueryItemValues("field");
- for( int i = 0; i < fields.size(); i++ )
+ QRegExp reFieldDef( "\\:"
+ "(int|integer|real|double|string)" // type
+ "(?:\\((\\d+)" // length
+ "(?:\\,(\\d+))?" // precision
+ "$", Qt::CaseInsensitive );
+ QStringList fields = url.allQueryItemValues( "field" );
+ for ( int i = 0; i < fields.size(); i++ )
- QString name = fields.at(i);
- QVariant::Type type = QVariant::String;
- QString typeName("string");
- int length = 255;
- int precision = 0;
- int pos = reFieldDef.indexIn(name);
- if( pos >= 0 )
+ QString name = fields.at( i );
+ QVariant::Type type = QVariant::String;
+ QString typeName( "string" );
+ int length = 255;
+ int precision = 0;
+ int pos = reFieldDef.indexIn( name );
+ if ( pos >= 0 )
+ name = name.mid( 0, pos );
+ typeName = reFieldDef.cap( 1 ).toLower();
+ if ( typeName == "int" || typeName == "integer" )
- name = name.mid(0,pos);
- typeName = reFieldDef.cap(1).toLower();
- if( typeName == "int" || typeName == "integer" )
- type = QVariant::Int;
- typeName = "integer";
- length = 10;
- else if( typeName == "real" || typeName == "double" )
- type = QVariant::Double;
- typeName = "double";
- length=20;
- precision = 5;
+ type = QVariant::Int;
+ typeName = "integer";
+ length = 10;
+ else if ( typeName == "real" || typeName == "double" )
+ type = QVariant::Double;
+ typeName = "double";
+ length = 20;
+ precision = 5;
- if( reFieldDef.cap(2) != "" )
- length = reFieldDef.cap(2).toInt();
- if( reFieldDef.cap(3) != "" )
- precision = reFieldDef.cap(3).toInt();
+ if ( reFieldDef.cap( 2 ) != "" )
+ length = reFieldDef.cap( 2 ).toInt();
- if( name != "" ) attributes.append(QgsField(name,type,typeName,length,precision));
+ if ( reFieldDef.cap( 3 ) != "" )
+ precision = reFieldDef.cap( 3 ).toInt();
+ if ( name != "" ) attributes.append( QgsField( name, type, typeName, length, precision ) );
- addAttributes(attributes);
+ addAttributes( attributes );
- if( url.hasQueryItem("index") && url.queryItemValue("index") == "yes" )
+ if ( url.hasQueryItem( "index" ) && url.queryItemValue( "index" ) == "yes" )
- createSpatialIndex();
+ createSpatialIndex();
@@ -143,65 +143,68 @@
QString QgsMemoryProvider::dataSourceUri() const
- QUrl uri("memory");
- QString geometry("");
- switch(mWkbType)
+ QUrl uri( "memory" );
+ QString geometry;
+ switch ( mWkbType )
case QGis::WKBPoint :
- geometry="Point";
- break;
+ geometry = "Point";
+ break;
case QGis::WKBLineString :
- geometry="LineString";
- break;
+ geometry = "LineString";
+ break;
case QGis::WKBPolygon :
- geometry="Polygon";
- break;
+ geometry = "Polygon";
+ break;
case QGis::WKBMultiPoint :
- geometry="MultiPoint";
- break;
+ geometry = "MultiPoint";
+ break;
case QGis::WKBMultiLineString :
- geometry="MultiLineString";
- break;
+ geometry = "MultiLineString";
+ break;
case QGis::WKBMultiPolygon :
- geometry="MultiPolygon";
- break;
- uri.addQueryItem("geometry",geometry);
+ geometry = "MultiPolygon";
+ break;
+ default:
+ geometry = "";
+ break;
+ uri.addQueryItem( "geometry", geometry );
- if( mCrs.isValid())
+ if ( mCrs.isValid() )
+ QString crsDef( "" );
+ long srid = mCrs.epsg();
+ if ( srid )
- QString crsDef("");
- long srid = mCrs.epsg();
- if( srid )
- crsDef = QString("epsg:%1").arg(srid);
- else if( srid=mCrs.postgisSrid() )
- crsDef = QString("postgis:%1").arg(srid);
- else
- crsDef = QString("wkt:%1").arg(mCrs.toWkt());
- uri.addQueryItem("crs",crsDef);
+ crsDef = QString( "epsg:%1" ).arg( srid );
- if( mSpatialIndex )
+ else if (( srid = mCrs.postgisSrid() ) )
- uri.addQueryItem("index","yes");
+ crsDef = QString( "postgis:%1" ).arg( srid );
- QgsAttributeList attrs = const_cast<QgsMemoryProvider *>(this)->attributeIndexes();
- for( int i = 0; i < attrs.size(); i++ )
+ else
- QgsField field = mFields[attrs[i]];
- QString fieldDef = field.name();
- fieldDef.append(QString(":%2(%3,%4)").arg(field.typeName()).arg(field.length()).arg(field.precision()));
- uri.addQueryItem("field",fieldDef);
+ crsDef = QString( "wkt:%1" ).arg( mCrs.toWkt() );
+ uri.addQueryItem( "crs", crsDef );
+ if ( mSpatialIndex )
+ uri.addQueryItem( "index", "yes" );
- return QString(uri.toEncoded());
+ QgsAttributeList attrs = const_cast<QgsMemoryProvider *>( this )->attributeIndexes();
+ for ( int i = 0; i < attrs.size(); i++ )
+ QgsField field = mFields[attrs[i]];
+ QString fieldDef = field.name();
+ fieldDef.append( QString( ":%2(%3,%4)" ).arg( field.typeName() ).arg( field.length() ).arg( field.precision() ) );
+ uri.addQueryItem( "field", fieldDef );
+ return QString( uri.toEncoded() );
QString QgsMemoryProvider::storageType() const
