[QGIS Commit] r15173 - trunk/qgis/src/app
svn_qgis at osgeo.org
Tue Feb 15 01:21:15 EST 2011
Author: mhugent
Date: 2011-02-14 22:21:15 -0800 (Mon, 14 Feb 2011)
New Revision: 15173
trunk/qgis/src/app/qgsvectorlayerproperties.cpp
Fewer redraws if toggeling editing from vector props
Modified: trunk/qgis/src/app/qgsvectorlayerproperties.cpp
--- trunk/qgis/src/app/qgsvectorlayerproperties.cpp 2011-02-14 19:02:06 UTC (rev 15172)
+++ trunk/qgis/src/app/qgsvectorlayerproperties.cpp 2011-02-15 06:21:15 UTC (rev 15173)
@@ -166,6 +166,7 @@
void QgsVectorLayerProperties::loadRows()
+ QObject::disconnect( tblAttributes, SIGNAL( cellChanged( int, int ) ), this, SLOT( on_tblAttributes_cellChanged( int, int ) ) );
const QgsFieldMap &fields = layer->pendingFields();
tblAttributes->clear();
@@ -191,6 +192,7 @@
setRow( row, it.key(), it.value() );
tblAttributes->resizeColumnsToContents();
+ QObject::connect( tblAttributes, SIGNAL( cellChanged( int, int ) ), this, SLOT( on_tblAttributes_cellChanged( int, int ) ) );
void QgsVectorLayerProperties::setRow( int row, int idx, const QgsField &field )
@@ -382,7 +384,7 @@
void QgsVectorLayerProperties::editingToggled()
- if ( layer->isEditable() )
+ if ( !layer->isEditable() )
loadRows();
updateButtons();
@@ -1200,11 +1202,7 @@
layer->addJoin( info );
- //prevent complete redraw for each row
- QObject::disconnect( tblAttributes, SIGNAL( cellChanged( int, int ) ), this, SLOT( on_tblAttributes_cellChanged( int, int ) ) );
loadRows(); //update attribute tab
- QObject::connect( tblAttributes, SIGNAL( cellChanged( int, int ) ), this, SLOT( on_tblAttributes_cellChanged( int, int ) ) );
addJoinToTreeWidget( info );
@@ -1241,11 +1239,7 @@
layer->removeJoin( currentJoinItem->data( 0, Qt::UserRole ).toString() );
loadRows();
mJoinTreeWidget->takeTopLevelItem( mJoinTreeWidget->indexOfTopLevelItem( currentJoinItem ) );
