[QGIS Commit] r15185 - in trunk/qgis/src/core: . composer
svn_qgis at osgeo.org
Thu Feb 17 17:33:13 EST 2011
Author: jef
Date: 2011-02-17 14:33:13 -0800 (Thu, 17 Feb 2011)
New Revision: 15185
trunk/qgis/src/core/composer/qgscomposerlegenditem.h
trunk/qgis/src/core/qgsproject.cpp
trunk/qgis/src/core/qgsvectorlayer.h
trunk/qgis/src/core/qgsvectorlayerjoinbuffer.h
doxygen fixes
Modified: trunk/qgis/src/core/composer/qgscomposerlegenditem.h
--- trunk/qgis/src/core/composer/qgscomposerlegenditem.h 2011-02-17 12:58:09 UTC (rev 15184)
+++ trunk/qgis/src/core/composer/qgscomposerlegenditem.h 2011-02-17 22:33:13 UTC (rev 15185)
@@ -43,6 +43,7 @@
virtual void writeXML( QDomElement& elem, QDomDocument& doc ) const = 0;
/**Read item content from xml
+ @param itemElem item to read from
@param xServerAvailable Read item icons if true (QIcon needs x-server)*/
virtual void readXML( const QDomElement& itemElem, bool xServerAvailable = true ) = 0;
Modified: trunk/qgis/src/core/qgsproject.cpp
--- trunk/qgis/src/core/qgsproject.cpp 2011-02-17 12:58:09 UTC (rev 15184)
+++ trunk/qgis/src/core/qgsproject.cpp 2011-02-17 22:33:13 UTC (rev 15185)
@@ -763,7 +763,7 @@
- @note it's presumed that the caller has already reset the map canvas, map registry, and legend
+ it's presumed that the caller has already reset the map canvas, map registry, and legend
bool QgsProject::read()
Modified: trunk/qgis/src/core/qgsvectorlayer.h
--- trunk/qgis/src/core/qgsvectorlayer.h 2011-02-17 12:58:09 UTC (rev 15184)
+++ trunk/qgis/src/core/qgsvectorlayer.h 2011-02-17 22:33:13 UTC (rev 15185)
@@ -758,7 +758,7 @@
@param joinFieldName name of the (source) join Field
@param joinValue lookup value for join
@param attributes (join layer) attribute indices to add
- @param attributeOffset index offset to get from join layer attribute index to layer index*/
+ @param attributeIndexOffset index offset to get from join layer attribute index to layer index*/
void addJoinedFeatureAttributes( QgsFeature& f, const QgsVectorJoinInfo& joinInfo, const QString& joinFieldName, const QVariant& joinValue,
const QgsAttributeList& attributes, int attributeIndexOffset );
Modified: trunk/qgis/src/core/qgsvectorlayerjoinbuffer.h
--- trunk/qgis/src/core/qgsvectorlayerjoinbuffer.h 2011-02-17 12:58:09 UTC (rev 15184)
+++ trunk/qgis/src/core/qgsvectorlayerjoinbuffer.h 2011-02-17 22:33:13 UTC (rev 15185)
@@ -32,8 +32,7 @@
~QgsVectorLayerJoinBuffer();
/**Joins another vector layer to this layer
- @param joinInfo join object containing join layer id, target and source field
- @param cacheInMemory if true: caches the content of the join layer in virtual memory*/
+ @param joinInfo join object containing join layer id, target and source field */
void addJoin( QgsVectorJoinInfo joinInfo );
/**Removes a vector layer join*/
@@ -89,7 +88,7 @@
