[QGIS Commit] r15198 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Fri Feb 18 10:18:10 EST 2011
Author: timlinux
Date: 2011-02-18 07:18:10 -0800 (Fri, 18 Feb 2011)
New Revision: 15198
Added:
trunk/qgis/src/app/qgstip.h
trunk/qgis/src/app/qgstipfactory.cpp
trunk/qgis/src/app/qgstipfactory.h
trunk/qgis/src/app/qgstipgui.cpp
trunk/qgis/src/app/qgstipgui.h
trunk/qgis/src/ui/qgstipguibase.ui
[FEATURE] Not sure how we coped without this till now...we now have a tip presented at startup. You can en/disable tips in the options panel. To contribute more tips, please add them to src/app/qgstipfactory.cpp
Added: trunk/qgis/src/app/qgstip.h
--- trunk/qgis/src/app/qgstip.h (rev 0)
+++ trunk/qgis/src/app/qgstip.h 2011-02-18 15:18:10 UTC (rev 15198)
@@ -0,0 +1,64 @@
+ * Copyright (C) 2007 by Tim Sutton *
+ * tim at linfiniti.com *
+ * This program is free software; you can redistribute it and/or modify *
+ * it under the terms of the GNU General Public License as published by *
+ * the Free Software Foundation; either version 2 of the License, or *
+ * (at your option) any later version. *
+ * This program is distributed in the hope that it will be useful, *
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of *
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the *
+ * GNU General Public License for more details. *
+ * You should have received a copy of the GNU General Public License *
+ * along with this program; if not, write to the *
+ * Free Software Foundation, Inc., *
+ * 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. *
+#ifndef QGSTIP
+#define QGSTIP
+#include <QObject>
+#include <QString>
+/** \ingroup app
+* \brief An QgsTip represents a tip generated by the
+* QgsTipFactory factory class to serve up tips to the user.
+* Tips can be generic, in which case they make no mention of
+* gui dialogs etc, or gui-secific in which case they may allude
+* to features of the graphical user interface.
+* @see also QgsTipOfTheDay, QgsTipFactory
+class QgsTip
+ public:
+ /** Constructor */
+ QgsTip() {};
+ /**Destructor */
+ ~QgsTip() {};
+ // Accessors
+ /** Get the tip title */
+ QString title() {return mTitle;};
+ /** Get the tip content */
+ QString content() {return mContent;}
+ // Mutators
+ /** Set the tip title */
+ void setTitle(QString theTitle) {mTitle = theTitle;};
+ /** Set the tip content*/
+ void setContent(QString theContent) {mContent = theContent;};
+ private:
+ QString mTitle;
+ QString mContent;
+#endif //QGSTIP
Added: trunk/qgis/src/app/qgstipfactory.cpp
--- trunk/qgis/src/app/qgstipfactory.cpp (rev 0)
+++ trunk/qgis/src/app/qgstipfactory.cpp 2011-02-18 15:18:10 UTC (rev 15198)
@@ -0,0 +1,176 @@
+#include "omgtipfactory.h"
+#include <QTime>
+//for rand & srand
+#include <cstdlib>
+OmgTipFactory::OmgTipFactory() : QObject()
+ // Im just doing this in a simple way so
+ // its easy for translators...later
+ // it its worth the time Ill move this data
+ // into a sqlite database...
+ OmgTip myTip;
+ myTip.setTitle(tr("openModeller is open source"));
+ myTip.setContent(tr("openModeller is open source software."
+ " This means that the software source code can be freely viewed "
+ " and modified. The GPL places a restriction that any modifications "
+ " you make must be made available to the openModeller project, and "
+ " that you can not create a new version of openModeller under a "
+ " 'closed source' license. Visit <a href=\"http://openModeller.sf.net\">"
+ " the openModeller home page (http://openModeller.sf.net)</a> for more"
+ " information."));
+ addGenericTip(myTip);
+ myTip.setTitle(tr("openModeller Publications"));
+ myTip.setContent(tr("If you write a scientific paper or any other article"
+ " that refers to openModeller we would love to include your work"
+ " in the references section of "
+ " the openModeller home page (http://openModeller.sf.net).</a>"
+ myTip.setTitle(tr("Become an openModeller Desktop translator"));
+ myTip.setContent(tr("Would you like to see openModeller Desktop"
+ " in your native language? We are looking for more translators"
+ " and would appreciate your help! The translation process is "
+ " fairly straight forward - instructions are available in the "
+ " resources section of "
+ addGuiTip(myTip);
+ myTip.setTitle(tr("openModeller Mailing lists"));
+ myTip.setContent(tr("If you need help using openModeller Desktop"
+ " we have a mailing list where users help each other with issues"
+ " related to niche modelling and using openModeller Desktop."
+ " Details on how to subscribe are in the resources section of"
+ addGuiTip(myTip);
+ myTip.setTitle(tr("Is it 'modelling' or 'modeling'?"));
+ myTip.setContent(tr("Both spellings are correct. For openModeller"
+ " we use the former spelling."
+ myTip.setTitle(tr("How do I refer to openModeller?"));
+ myTip.setContent(tr("openModeller is spelled with a lower case"
+ " 'o' at the start of the word - even if its the beginning"
+ " of a sentance. We have various subprojects of the openModeller "
+ " project and it will help to avoid confusion if you refer to each by"
+ " its name:"
+ "<ul>"
+ "<li>openModeller Library - this is the C++ library that contains"
+ " the core logic for carrying out niche modelling"
+ "<li>openModeller Console - these are a collection of command"
+ " line tools that allow you to run niche models from a unix or"
+ " DOS shell, or from a scripting environment."
+ "<li>openModeller Web Service - The openModeller Web Service"
+ " allows for remote execution of niche models."
+ "<li>openModeller Desktop - the openModeller Desktop provides"
+ " a graphical user interface for the openModeller Library. It"
+ " also includes the capability to run models using the"
+ " openModeller Web Service (though this is still considered"
+ " experimental)."
+ "</ul>"
+ myTip.setTitle(tr("How can I improve model execution times?"));
+ myTip.setContent(tr("Model processing time is typically determined by"
+ "<ul>"
+ "<li>the algorithm you select,</li>"
+ "<li>the number, extents and spatial resolution of your format and environmental layers,</li>"
+ "<li>the number of cells excluded by your mask (if any),</li>"
+ "<li>in some cases the number of presence and absence points (e.g. distance algs),</li>"
+ "<li>the speed of the computer the model is running on (CPU, disk access etc).</li>"
+ "</ul>"
+ "So if you want to improve model processing times you need to adjust "
+ "one of these variables. One thing noticed quite commonly is that people "
+ "use extremely high resolution datasets that often carry little "
+ "additional information over lower resolution equivalents. For example "
+ "interpolating widely dispersed weather station data to produce a 50cm "
+ "raster probably carries little additional value over for example using "
+ "10m2 pixels.<br>"
+ "Another area of performance improvement you can look at is "
+ "preselecting environmental variables using techniques such as Chi "
+ "Square test. Future versions of openModeller will integrate the ability "
+ "to do this type of preselection."
+ /* Template for adding more tips
+ myTip.setTitle(tr(""));
+ myTip.setContent(tr(""
+OmgTipFactory::~OmgTipFactory()
+//private helper method
+void OmgTipFactory::addGuiTip(OmgTip theTip)
+ mGuiTips << theTip;
+ mAllTips << theTip;
+void OmgTipFactory::addGenericTip(OmgTip theTip)
+ mGenericTips << theTip;
+OmgTip OmgTipFactory::getTip()
+ srand(QTime::currentTime().msec());
+ int myRand = rand();
+ int myValue = static_cast<int> (myRand % mAllTips.count()); //range [0,(count-1)]
+ OmgTip myTip = mAllTips.at(myValue);
+ return myTip;
+OmgTip OmgTipFactory::getTip(int thePosition)
+ OmgTip myTip = mAllTips.at(thePosition);
+ return myTip;
+OmgTip OmgTipFactory::getGenericTip()
+ int myValue = static_cast<int> (myRand % mGenericTips.count()); //range [0,(count-1)]
+ OmgTip myTip = mGenericTips.at(myValue);
+ return myTip;
+OmgTip OmgTipFactory::getGuiTip()
+ int myValue = static_cast<int> (myRand % mGuiTips.count()); //range [0,(count-1)]
+ OmgTip myTip = mGuiTips.at(myValue);
+ return myTip;
+int OmgTipFactory::randomNumber(int theMax)
+ return 0;
Added: trunk/qgis/src/app/qgstipfactory.h
--- trunk/qgis/src/app/qgstipfactory.h (rev 0)
+++ trunk/qgis/src/app/qgstipfactory.h 2011-02-18 15:18:10 UTC (rev 15198)
@@ -0,0 +1,74 @@
+#ifndef OMGTIPFACTORY
+#define OMGTIPFACTORY
+#include "omgtip.h"
+#include <QList>
+/** \ingroup lib
+* \brief A factory class to serve up tips to the user.
+* @see also OmgTipOfTheDay, OmgTip
+class OMG_LIB_EXPORT OmgTipFactory : public QObject
+ Q_OBJECT; //used for tr() so we dont need to do QObject::tr()
+ public:
+ OmgTipFactory();
+ /** Destructor */
+ ~OmgTipFactory();
+ /** Get a random tip (generic or gui-centric)
+ * @return An OmgTip containing the tip
+ OmgTip getTip();
+ /** Get a specific tip (generic or gui-centric).
+ * @param thePosition The tip returned will be based on the
+ * number passed in as thePosition. If the
+ * position is invalid, an empty string will be
+ * returned.
+ OmgTip getTip(int thePosition);
+ /** Get a random generic tip
+ OmgTip getGenericTip();
+ /** Get a random gui-centric tip
+ OmgTip getGuiTip();
+ private:
+ void addGenericTip(OmgTip);
+ void addGuiTip(OmgTip);
+ int randomNumber(int theMax);
+ //@TODO move tipts into a sqlite db
+ QList <OmgTip> mGenericTips;
+ QList <OmgTip> mGuiTips;
+ QList <OmgTip> mAllTips;
+#endif //OMGTIPFACTORY
Added: trunk/qgis/src/app/qgstipgui.cpp
--- trunk/qgis/src/app/qgstipgui.cpp (rev 0)
+++ trunk/qgis/src/app/qgstipgui.cpp 2011-02-18 15:18:10 UTC (rev 15198)
@@ -0,0 +1,61 @@
+ qgstipgui.cpp - description
+ begin : Sat Aug 10 2002
+ copyright : (C) 2002 by Gary E.Sherman
+ email : sherman at mrcc.com
+/* $Id$ */
+#include <QSettings>
+#include "qgstipgui.h"
+#include "qgsapplication.h"
+#include <qgstip.h>
+#include <qgstipfactory.h>
+#ifdef Q_OS_MACX
+QgsTipGui::QgsTipGui()
+ : QDialog( NULL, Qt::WindowSystemMenuHint ) // Modeless dialog with close button only
+#else
+ : QDialog( NULL ) // Normal dialog in non Mac-OS
+#endif
+ setupUi( this );
+ init();
+QgsTipGui::~QgsTipGui()
+void QgsTipGui::init()
+ // set the 60x60 icon pixmap
+ QPixmap icon( QgsApplication::iconsPath() + "qgis-icon-60x60.png" );
+ qgisIcon->setPixmap( icon );
+ QgsTipFactory myFactory;
+ QgsTip myTip = myFactory.getTip();
+ lblTitle->setText(myTip.title());
+ txtTip->setHtml(myTip.content());
+void QgsTipGui::on_cbxDisableTips_toggled(bool theFlag)
+ QSettings settings;
+ //note the ! below as when the cbx is checked (true) we want to
+ //change the setting to false
+ settings.setValue( "/qgis/showTips", !theFlag );
+ hide();
Added: trunk/qgis/src/app/qgstipgui.h
--- trunk/qgis/src/app/qgstipgui.h (rev 0)
+++ trunk/qgis/src/app/qgstipgui.h 2011-02-18 15:18:10 UTC (rev 15198)
@@ -0,0 +1,37 @@
+ qgstipgui.h - description
+ begin : Fri 18 Feb 2011
+ copyright : (C) 2011 by Tim Sutton
+ email : tim at linfiniti.com
+/* $Id:$ */
+#ifndef QGSTIPGUI_H
+#define QGSTIPGUI_H
+#include "ui_qgstipguibase.h"
+class QgsTipGui : public QDialog, private Ui::QgsTipGuiBase
+ Q_OBJECT
+ public:
+ QgsTipGui();
+ ~QgsTipGui();
+ private:
+ void init();
+ private slots:
+ void on_cbxDisableTips_toggled(bool theFlag);
+#endif
Added: trunk/qgis/src/ui/qgstipguibase.ui
--- trunk/qgis/src/ui/qgstipguibase.ui (rev 0)
+++ trunk/qgis/src/ui/qgstipguibase.ui 2011-02-18 15:18:10 UTC (rev 15198)
@@ -0,0 +1,98 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
+ <class>QgsTipGuiBase</class>
+ <widget class="QDialog" name="QgsTipGuiBase">
+ <property name="geometry">
+ <rect>
+ <x>0</x>
+ <y>0</y>
+ <width>492</width>
+ <height>283</height>
+ </rect>
+ </property>
+ <property name="windowTitle">
+ <string>QGIS Tips!</string>
+ </property>
+ <layout class="QGridLayout" name="gridLayout">
+ <item row="0" column="0">
+ <widget class="QLabel" name="qgisIcon">
+ <property name="text">
+ <string>TextLabel</string>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="1" colspan="2">
+ <widget class="QTextBrowser" name="txtTip">
+ <property name="sizePolicy">
+ <sizepolicy hsizetype="Expanding" vsizetype="Expanding">
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <property name="html">
+ <string><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><meta name="qrichtext" content="1" /><style type="text/css">
+p, li { white-space: pre-wrap; }
+</style></head><body style=" font-family:'Ubuntu'; font-size:10pt; font-weight:400; font-style:normal;">
+<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;">A nice tip goes here...</p></body></html></string>
+ </property>
+ <property name="openExternalLinks">
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="1" colspan="2">
+ <widget class="QCheckBox" name="checkBox">
+ <string>I've had enough tips, don't show this on start up any more!</string>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="2">
+ <widget class="QDialogButtonBox" name="buttonBox">
+ <property name="orientation">
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <property name="standardButtons">
+ <set>QDialogButtonBox::Ok</set>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ <resources/>
+ <connections>
+ <connection>
+ <sender>buttonBox</sender>
+ <signal>accepted()</signal>
+ <receiver>QgsTipGuiBase</receiver>
+ <slot>accept()</slot>
+ <hints>
+ <hint type="sourcelabel">
+ <x>248</x>
+ <y>254</y>
+ </hint>
+ <hint type="destinationlabel">
+ <x>157</x>
+ <y>274</y>
+ </hint>
+ </hints>
+ </connection>
+ <connection>
+ <signal>rejected()</signal>
+ <slot>reject()</slot>
+ <hints>
+ <x>316</x>
+ <y>260</y>
+ </hint>
+ <x>286</x>
+ <y>274</y>
+ </hint>
+ </hints>
+ </connection>
+ </connections>
+</ui>
