[QGIS Commit] r15244 - trunk/qgis/src/app
svn_qgis at osgeo.org
Tue Feb 22 16:37:02 EST 2011
Author: timlinux
Date: 2011-02-22 13:37:02 -0800 (Tue, 22 Feb 2011)
New Revision: 15244
trunk/qgis/src/app/qgstipfactory.cpp
Some cleanups and additions to Andreas' tips
Modified: trunk/qgis/src/app/qgstipfactory.cpp
--- trunk/qgis/src/app/qgstipfactory.cpp 2011-02-22 21:36:46 UTC (rev 15243)
+++ trunk/qgis/src/app/qgstipfactory.cpp 2011-02-22 21:37:02 UTC (rev 15244)
@@ -106,9 +106,22 @@
" found in the tab <strong>Item --> General Options --> Position "
" and Size</strong>. For easier positioning you can also set "
" specific anchor points of the element within this dialogue. "
+ " The other move tool (the globe icon combined with the hand icon) "
+ " allows to move the map content within a map frame. "
addGuiTip(myTip);
// This tip contributed by Andreas Neumann
+ myTip.setTitle(tr("Lock an element in the layout view"));
+ myTip.setContent(tr(" By left clicking an element in the layout view you can "
+ " select it, by right clicking an element you can lock it. A lock symbol "
+ " will appear in the upper left corner of the selected element. This "
+ " prevents the element from accidentally being moved with the mouse. While "
+ " in a locked state, you cannot move an element with the mouse but you can "
+ " still move it with the arrow keys or by absolutely positioning it by "
+ " setting its <strong>Position and Size</strong>"
+ addGuiTip(myTip);
+ // This tip contributed by Andreas Neumann
myTip.setTitle(tr("Rotating a map and linking a north arrow"));
myTip.setContent(tr("You can rotate a map by setting its rotation value "
" in the <strong>Item tab --> Map</strong> section. To place a north "
@@ -128,12 +141,12 @@
" set the style to 'Numeric'. You also need to select the map frame, if there "
" is more than one."
- addGenericTip(myTip);
+ addGuiTip(myTip);
/* Template for adding more tips
myTip.setTitle(tr(""));
myTip.setContent(tr(""
+ addGuiTip(myTip);
