[QGIS Commit] r15250 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Wed Feb 23 16:10:52 EST 2011
Author: timlinux
Date: 2011-02-23 13:10:52 -0800 (Wed, 23 Feb 2011)
New Revision: 15250
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgsoptions.cpp
trunk/qgis/src/app/qgsoptions.h
trunk/qgis/src/app/qgspluginregistry.cpp
trunk/qgis/src/app/qgspluginregistry.h
trunk/qgis/src/ui/qgsoptionsbase.ui
[FEATURE] Added option to load c++ plugins from user specified directories. Requires application restart to activate.
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2011-02-23 20:45:46 UTC (rev 15249)
+++ trunk/qgis/src/app/qgisapp.cpp 2011-02-23 21:10:52 UTC (rev 15250)
@@ -490,6 +490,16 @@
QgsPluginRegistry::instance()->restoreSessionPlugins( QgsApplication::pluginPath() );
+ // Also restore plugins from user specified plugin directories - added for 1.7
+ QSettings settings;
+ QString myPaths = settings.value( "plugins/searchPathsForPlugins", "" ).toString();
+ if ( !myPaths.isEmpty() )
+ QStringList myPathList = myPaths.split( "|" );
+ QgsPluginRegistry::instance()->restoreSessionPlugins( myPathList );
+ QMessageBox::critical( this, tr( "Plugin paths" ), myPaths );
mSplash->showMessage( tr( "Initializing file filters" ), Qt::AlignHCenter | Qt::AlignBottom );
qApp->processEvents();
// now build vector file filter
@@ -541,7 +551,6 @@
mMapCanvas->mapRenderer()->setLabelingEngine( mLBL );
// Show a nice tip of the day
- QSettings settings;
if ( settings.value( "/qgis/showTips", 1 ).toBool() )
mSplash->hide();
Modified: trunk/qgis/src/app/qgsoptions.cpp
--- trunk/qgis/src/app/qgsoptions.cpp 2011-02-23 20:45:46 UTC (rev 15249)
+++ trunk/qgis/src/app/qgsoptions.cpp 2011-02-23 21:10:52 UTC (rev 15250)
@@ -79,9 +79,23 @@
spinBoxIdentifyValue->setMinimum( 0.01 );
spinBoxIdentifyValue->setValue( identifyValue );
+ //local directories to search when loading c++ plugins
+ QStringList::const_iterator pathIt = myPathList.constBegin();
+ for ( ; pathIt != myPathList.constEnd(); ++pathIt )
+ QListWidgetItem* newItem = new QListWidgetItem( mListPluginPaths );
+ newItem->setText( *pathIt );
+ newItem->setFlags( Qt::ItemIsEditable | Qt::ItemIsEnabled | Qt::ItemIsSelectable );
+ mListPluginPaths->addItem( newItem );
//local directories to search when looking for an SVG with a given basename
- QString myPaths = settings.value( "svg/searchPathsForSVG", "" ).toString();
+ myPaths = settings.value( "svg/searchPathsForSVG", "" ).toString();
@@ -479,8 +493,20 @@
QSettings settings;
+ //search directories for user plugins
+ QString myPaths;
+ for ( int i = 0; i < mListPluginPaths->count(); ++i )
+ if ( i != 0 )
+ myPaths += "|";
+ myPaths += mListPluginPaths->item( i )->text();
+ settings.setValue( "plugins/searchPathsForPlugins", myPaths );
//search directories for svgs
- QString myPaths;
+ myPaths;
for ( int i = 0; i < mListSVGPaths->count(); ++i )
if ( i != 0 )
@@ -881,6 +907,33 @@
return myList;
+void QgsOptions::on_mBtnAddPluginPath_clicked()
+ QString myDir = QFileDialog::getExistingDirectory(
+ this,
+ tr( "Choose a directory" ),
+ QDir::toNativeSeparators( QDir::homePath() ),
+ QFileDialog::ShowDirsOnly
+ if ( ! myDir.isEmpty() )
+ newItem->setText( myDir );
+ mListPluginPaths->setCurrentItem( newItem );
+void QgsOptions::on_mBtnRemovePluginPath_clicked()
+ int currentRow = mListPluginPaths->currentRow();
+ QListWidgetItem* itemToRemove = mListPluginPaths->takeItem( currentRow );
+ delete itemToRemove;
void QgsOptions::on_mBtnAddSVGPath_clicked()
Modified: trunk/qgis/src/app/qgsoptions.h
--- trunk/qgis/src/app/qgsoptions.h 2011-02-23 20:45:46 UTC (rev 15249)
+++ trunk/qgis/src/app/qgsoptions.h 2011-02-23 21:10:52 UTC (rev 15250)
@@ -91,6 +91,18 @@
void on_mRemoveUrlPushButton_clicked();
/* Let the user add a path to the list of search paths
+ * used for finding user Plugin libs.
+ * @note added in QGIS 1.7
+ void on_mBtnAddPluginPath_clicked();
+ /* Let the user remove a path to the list of search paths
+ * used for finding Plugin libs.
+ void on_mBtnRemovePluginPath_clicked();
+ /* Let the user add a path to the list of search paths
* used for finding SVG files.
* @note added in QGIS 1.4
Modified: trunk/qgis/src/app/qgspluginregistry.cpp
--- trunk/qgis/src/app/qgspluginregistry.cpp 2011-02-23 20:45:46 UTC (rev 15249)
+++ trunk/qgis/src/app/qgspluginregistry.cpp 2011-02-23 21:10:52 UTC (rev 15250)
@@ -356,10 +356,18 @@
QgsDebugMsg( "Plugin " + theFullPathName + " did not return a valid type and cannot be loaded" );
break;
+//overloaded version of the next method that will load from multiple directories not just one
+void QgsPluginRegistry::restoreSessionPlugins( QStringList thePluginDirList )
+ QStringListIterator myIterator( thePluginDirList );
+ while ( myIterator.hasNext() )
+ restoreSessionPlugins( myIterator.next() );
void QgsPluginRegistry::restoreSessionPlugins( QString thePluginDirString )
QSettings mySettings;
Modified: trunk/qgis/src/app/qgspluginregistry.h
--- trunk/qgis/src/app/qgspluginregistry.h 2011-02-23 20:45:46 UTC (rev 15249)
+++ trunk/qgis/src/app/qgspluginregistry.h 2011-02-23 21:10:52 UTC (rev 15250)
@@ -30,7 +30,7 @@
* \class QgsPluginRegistry
-* \brief This class tracks plugins that are currently loaded an provides
+* \brief This class tracks plugins that are currently loaded and provides
* a means to fetch a pointer to a plugin and unload it
* plugin key is:
@@ -78,6 +78,8 @@
//! Python plugin loader
void loadPythonPlugin( QString packageName );
+ //! Overloaded version of the next method that will load from multiple directories not just one
+ void restoreSessionPlugins( QStringList thePluginDirList );
//! Load any plugins used in the last qgis session
void restoreSessionPlugins( QString thePluginDirString );
Modified: trunk/qgis/src/ui/qgsoptionsbase.ui
--- trunk/qgis/src/ui/qgsoptionsbase.ui 2011-02-23 20:45:46 UTC (rev 15249)
+++ trunk/qgis/src/ui/qgsoptionsbase.ui 2011-02-23 21:10:52 UTC (rev 15250)
@@ -59,9 +59,9 @@
<property name="geometry">
<rect>
<x>0</x>
- <y>-155</y>
+ <y>-369</y>
<width>746</width>
- <height>640</height>
+ <height>827</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_12">
@@ -168,8 +168,8 @@
<property name="title">
<string>Application</string>
</property>
- <layout class="QVBoxLayout" name="verticalLayout_2">
- <item>
+ <layout class="QGridLayout" name="gridLayout">
+ <item row="0" column="0">
<layout class="QHBoxLayout" name="horizontalLayout_3">
<item>
<widget class="QLabel" name="textLabel1_4">
@@ -211,7 +211,7 @@
</item>
</layout>
</item>
- <item>
+ <item row="1" column="0">
<layout class="QHBoxLayout" name="horizontalLayout_7">
<item>
<widget class="QLabel" name="textLabel1_5">
@@ -248,77 +248,77 @@
</item>
</layout>
</item>
- <item>
+ <item row="2" column="0">
<widget class="QCheckBox" name="capitaliseCheckBox">
<property name="text">
<string>Capitalise layer names in legend</string>
</property>
</widget>
</item>
- <item>
+ <item row="3" column="0">
<widget class="QCheckBox" name="cbxLegendClassifiers">
<string>Display classification attribute names in legend</string>
</property>
</widget>
</item>
- <item>
+ <item row="4" column="0">
<widget class="QCheckBox" name="cbxCreateRasterLegendIcons">
<string>Create raster icons in legend</string>
</property>
</widget>
</item>
- <item>
+ <item row="5" column="0">
<widget class="QCheckBox" name="cbxHideSplash">
<string>Hide splash screen at startup</string>
</property>
</widget>
</item>
- <item>
+ <item row="6" column="0">
<widget class="QCheckBox" name="cbxShowTips">
<string>Show tips at start up</string>
</property>
</widget>
</item>
- <item>
+ <item row="7" column="0">
<widget class="QCheckBox" name="cbxIdentifyResultsDocked">
<string>Open identify results in a dock window (QGIS restart required)</string>
</property>
</widget>
</item>
- <item>
+ <item row="8" column="0">
<widget class="QCheckBox" name="cbxSnappingOptionsDocked">
<string>Open snapping options in a dock window (QGIS restart required)</string>
</property>
</widget>
</item>
- <item>
+ <item row="9" column="0">
<widget class="QCheckBox" name="cbxAttributeTableDocked">
<string>Open attribute table in a dock window (QGIS restart required)</string>
</property>
</widget>
</item>
- <item>
+ <item row="10" column="0">
<widget class="QCheckBox" name="cbxAddPostgisDC">
<string>Add PostGIS layers with double click and select in extended mode</string>
</property>
</widget>
</item>
- <item>
+ <item row="11" column="0">
<widget class="QCheckBox" name="cbxAddNewLayersToCurrentGroup">
<string>Add new layers to selected group</string>
</property>
</widget>
</item>
- <item>
+ <item row="12" column="0">
<layout class="QHBoxLayout" name="horizontalLayout_5">
<item>
<widget class="QLabel" name="textLabel1_7">
@@ -360,7 +360,7 @@
</item>
</layout>
</item>
- <item>
+ <item row="13" column="0">
<layout class="QHBoxLayout" name="horizontalLayout_6">
<item>
<widget class="QLabel" name="label_14">
@@ -387,6 +387,52 @@
</item>
</layout>
</item>
+ <item row="14" column="0">
+ <widget class="QGroupBox" name="groupBox_4">
+ <property name="title">
+ <string>Plugin paths</string>
+ </property>
+ <layout class="QGridLayout" name="_2">
+ <widget class="QLabel" name="mSVGLabel_2">
+ <property name="text">
+ <string>Path(s) to search for additional C++ plugins libraries</string>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="1">
+ <spacer>
+ <property name="orientation">
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <property name="sizeHint" stdset="0">
+ <size>
+ <width>31</width>
+ <height>20</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item row="0" column="2">
+ <widget class="QPushButton" name="mBtnAddPluginPath">
+ <string>Add</string>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="3">
+ <widget class="QPushButton" name="mBtnRemovePluginPath">
+ <string>Remove</string>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="0" colspan="4">
+ <widget class="QListWidget" name="mListPluginPaths"/>
+ </item>
+ </layout>
+ </widget>
+ </item>
</layout>
</widget>
</item>
@@ -416,7 +462,7 @@
<x>0</x>
<y>0</y>
<width>746</width>
- <height>466</height>
+ <height>479</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_8">
@@ -587,7 +633,7 @@
<x>0</x>
<y>0</y>
<width>746</width>
- <height>480</height>
+ <height>500</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_4">
@@ -941,8 +987,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>762</width>
- <height>458</height>
+ <width>746</width>
+ <height>462</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_13">
@@ -1272,7 +1318,7 @@
<x>0</x>
<y>0</y>
<width>746</width>
- <height>527</height>
+ <height>531</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_15">
@@ -1368,7 +1414,7 @@
<x>0</x>
<y>0</y>
<width>746</width>
- <height>545</height>
+ <height>552</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_17">
@@ -1459,7 +1505,7 @@
<x>0</x>
<y>0</y>
<width>746</width>
- <height>531</height>
+ <height>548</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_20">
