[QGIS Commit] r15261 - trunk/qgis/src/plugins/roadgraph
svn_qgis at osgeo.org
Fri Feb 25 05:37:35 EST 2011
Author: stopa85
Date: 2011-02-25 02:37:35 -0800 (Fri, 25 Feb 2011)
New Revision: 15261
trunk/qgis/src/plugins/roadgraph/linevectorlayerwidget.cpp
trunk/qgis/src/plugins/roadgraph/roadgraphplugin.cpp
trunk/qgis/src/plugins/roadgraph/shortestpathwidget.cpp
trunk/qgis/src/plugins/roadgraph/shortestpathwidget.h
roadgraph GUI update
Modified: trunk/qgis/src/plugins/roadgraph/linevectorlayerwidget.cpp
--- trunk/qgis/src/plugins/roadgraph/linevectorlayerwidget.cpp 2011-02-24 21:01:23 UTC (rev 15260)
+++ trunk/qgis/src/plugins/roadgraph/linevectorlayerwidget.cpp 2011-02-25 10:37:35 UTC (rev 15261)
@@ -83,6 +83,12 @@
mcbSpeed = new QComboBox( frame );
h->addWidget( l );
h->addWidget( mcbSpeed );
+ mcbUnitOfSpeed = new QComboBox( this );
+ h->addWidget( mcbUnitOfSpeed );
+ mcbUnitOfSpeed->insertItem( 0, tr( "km/h" ) );
+ mcbUnitOfSpeed->insertItem( 0, tr( "m/s" ) );
v->addLayout( h );
frame = new QFrame( tab );
@@ -116,23 +122,7 @@
h->addWidget( msbSpeedDefault );
v->addLayout( h );
- frame = new QFrame( tab );
- tab->addTab( frame, tr( "Units" ) );
- v = new QVBoxLayout( frame );
- h = new QHBoxLayout();
- l = new QLabel( tr( "Unit of speed" ) );
- mcbUnitOfSpeed = new QComboBox( this );
- h->addWidget( l );
- h->addWidget( mcbUnitOfSpeed );
- v->addLayout( h );
- mcbUnitOfSpeed->insertItem( 0, tr( "km/h" ) );
- mcbUnitOfSpeed->insertItem( 0, tr( "m/s" ) );
- if ( s->mSpeedUnitName == "km/h" )
- mcbUnitOfSpeed->setCurrentIndex( 1 );
- else if ( s->mSpeedUnitName == "m/s" )
- mcbUnitOfSpeed->setCurrentIndex( 0 );
// fill list of layers
QMap<QString, QgsMapLayer*> mapLayers = QgsMapLayerRegistry::instance()->mapLayers();
QMap<QString, QgsMapLayer*>::iterator layer_it = mapLayers.begin();
@@ -177,6 +167,11 @@
mcbDirectionDefault->setCurrentIndex( 2 );
break;
+ if ( s->mSpeedUnitName == "km/h" )
+ mcbUnitOfSpeed->setCurrentIndex( 1 );
+ else if ( s->mSpeedUnitName == "m/s" )
+ mcbUnitOfSpeed->setCurrentIndex( 0 );
} // RgLineVectorLayerSettingsWidget::RgLineVectorLayerSettingsWidget()
QgsVectorLayer* RgLineVectorLayerSettingsWidget::selectedLayer()
Modified: trunk/qgis/src/plugins/roadgraph/roadgraphplugin.cpp
--- trunk/qgis/src/plugins/roadgraph/roadgraphplugin.cpp 2011-02-24 21:01:23 UTC (rev 15260)
+++ trunk/qgis/src/plugins/roadgraph/roadgraphplugin.cpp 2011-02-25 10:37:35 UTC (rev 15261)
@@ -123,7 +123,10 @@
connect( mQGisIface->mapCanvas(), SIGNAL( renderComplete( QPainter* ) ), this, SLOT( render( QPainter* ) ) );
connect( mQGisIface, SIGNAL( projectRead() ), this, SLOT( projectRead() ) );
- connect( mQGisIface , SIGNAL( newProjectCreated() ), this, SLOT( newProject() ) );
+ connect( mQGisIface, SIGNAL( newProjectCreated() ), this, SLOT( newProject() ) );
+ connect( mQGisIface, SIGNAL( projectRead() ), mQShortestPathDock, SLOT( clear() ) );
+ connect( mQGisIface, SIGNAL( newProjectCreated() ), mQShortestPathDock, SLOT( clear() ) );
// load settings
projectRead();
} // RoadGraphPlugin::initGui()
Modified: trunk/qgis/src/plugins/roadgraph/shortestpathwidget.cpp
--- trunk/qgis/src/plugins/roadgraph/shortestpathwidget.cpp 2011-02-24 21:01:23 UTC (rev 15260)
+++ trunk/qgis/src/plugins/roadgraph/shortestpathwidget.cpp 2011-02-25 10:37:35 UTC (rev 15261)
@@ -250,7 +250,7 @@
QMessageBox::critical( this, tr( "Tie point failed" ), tr( "Start point doesn't tie to the road!" ) );
return false;
- if ( p1 == QgsPoint( 0.0, 0.0 ) )
+ if ( p2 == QgsPoint( 0.0, 0.0 ) )
QMessageBox::critical( this, tr( "Tie point failed" ), tr( "Stop point doesn't tie to the road!" ) );
return false;
@@ -264,7 +264,11 @@
DijkstraFinder f( m, criterion );
matrix = f.find( p1, p2 );
+ if ( matrix.find( p1 ) == matrix.end() )
+ QMessageBox::critical( this, tr( "Path not found" ), tr( "Path not found" ) );
+ return false;
return true;
@@ -310,6 +314,8 @@
mBackPointLineEdit->setText( QString() );
mrbBackPoint->reset( true );
mrbPath->reset();
+ mPathCostLineEdit->setText( QString() );
+ mPathTimeLineEdit->setText( QString() );
void RgShortestPathWidget::exportPath()
Modified: trunk/qgis/src/plugins/roadgraph/shortestpathwidget.h
--- trunk/qgis/src/plugins/roadgraph/shortestpathwidget.h 2011-02-24 21:01:23 UTC (rev 15260)
+++ trunk/qgis/src/plugins/roadgraph/shortestpathwidget.h 2011-02-25 10:37:35 UTC (rev 15261)
@@ -96,11 +96,12 @@
void clear();
+ private:
* retrun path as a graph
bool getPath( AdjacencyMatrix &m, QgsPoint& p1, QgsPoint& p2 );
- private:
* This line edit show front points coordinates
