[QGIS Commit] r15891 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Fri Jul 22 12:41:01 EDT 2011
Author: dassau
Date: 2011-07-22 09:41:01 -0700 (Fri, 22 Jul 2011)
New Revision: 15891
docs/trunk/english_us/user_guide/working_with_vector.tex
more updates for working with vector layers
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex 2011-07-22 12:35:12 UTC (rev 15890)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex 2011-07-22 16:41:01 UTC (rev 15891)
@@ -832,33 +832,6 @@
\caption{Style Manager to manage symbols and color ramps \nixcaption}\label{fig:stylemanager}
\end{figure}
\subsection{Old Symbology}\label{sec:oldsymbology}
\index{vector layers!old symbology}
@@ -937,34 +910,29 @@
If you wish to always use a particular style whenever the layer is loaded,
use the \button{Save As Default} button to make your style the default. Also,
-if you make changes to the style that you are not happy with, use the \button{Restore
-Default Style} button to revert to your default style.
+if you make changes to the style that you are not happy with, use the
+\button{Restore Default Style} button to revert to your default style.
\minisec{Vector transparency} \label{sec:vect_transparency}
\index{vector layers!transparency}
\qg allows to set a transparency for every vector layer. This can be done with
-the slider \\
-\slider{Transparency} inside the \tab{Style} tab (see
+the slider \slider{Transparency} inside the \tab{Style} tab (see
fig. \ref{subfig:single_symbol}). This is very useful for overlaying several
vector layers.
\subsection{Labels Tab}\label{labeltab}
-The \tab{Labels} tab allows you to enable labeling features and control a number of
-options related to fonts, placement, style, alignment and buffering.
+As for the symbology \qg 1.7.0 currently provides an old and a new labeling
+engine in parallel. The \tab{Labels} tab still contains the old labeling. The
+new labeling is implemented as a core application and will replace the features
+of the old labels tab in one of the next versions.
-We will illustrate this by labelling the lakes shapefile of the
+We recommend to switch to the new labeling, described in section \ref{newlabel}.
+The labeling in the \tab{Labels} tab allows you to enable labeling features and
+control a number of options related to fonts, placement, style, alignment and
+buffering. We will illustrate this by labelling the lakes shapefile of the
\filename{\qg\_example\_dataset}:
\begin{enumerate}
