[QGIS Commit] r15895 - docs/branches/1.6.0/chinese/user_guide
svn_qgis at osgeo.org
Thu Jul 28 06:41:31 EDT 2011
Author: wbprime
Date: 2011-07-28 03:41:31 -0700 (Thu, 28 Jul 2011)
New Revision: 15895
docs/branches/1.6.0/chinese/user_guide/features_at_a_glance.tex
Additional Chinese translation for features_at_first_glance.tex
Modified: docs/branches/1.6.0/chinese/user_guide/features_at_a_glance.tex
--- docs/branches/1.6.0/chinese/user_guide/features_at_a_glance.tex 2011-07-28 10:33:56 UTC (rev 15894)
+++ docs/branches/1.6.0/chinese/user_guide/features_at_a_glance.tex 2011-07-28 10:41:31 UTC (rev 15895)
@@ -808,7 +808,7 @@
\item \checkbox{需要时提示保存工程文件}
\item \checkbox{打开一个旧版本工程文件时提出警告}
\item 改变选择项颜色和背景色
-\item 改变图标主题(在默认(default)、传统(classic)、gis和newgis)
+\item 改变图标主题(在默认(default)、传统(classic)、gis和newgis中切换)
\item \checkbox{图例中的图层名大写}
\item \checkbox{图例中显示分类属性}
\item \checkbox{图例中创建栅格图标}
@@ -823,78 +823,66 @@
\minisec{绘制 \& SVG标签页}
\begin{itemize}
-\item \checkbox{By default new layers added to the map should be displayed}
-\item Define number of features to draw before updating the display.
-\item \checkbox{Use render caching where possible to speed up redraws}
-\item \checkbox{Make lines appear less jagged at the expense of some drawing
-performance}
-\item \checkbox{Fix problems with incorrectly filled polygons}
-\item \checkbox{Use new generation symbology for rendering}
-\item Add/remove path(s) to search for Scalable Vector Graphics (SVG) symbols
+\item \checkbox{默认显示新添加的图层}
+\item 设置更新显示前绘制的图元数量
+\item \checkbox{尽量使用渲染缓存来加速地图绘制}
+\item \checkbox{忽略其它效果以使线段反锯齿}
+\item \checkbox{修复填充多边形错误的问题}
+\item \checkbox{渲染时使用新的图标}
+\item 添加或删除搜索可缩放矢量图形(SVG)文件的路径
\end{itemize}
-Additionally you can define wether to save the path for svg textures
-absolute or relative in the \tab{General} tab of the
-\mainmenuopt{Settings} \arrow \dropmenuopttwo{mActionOptions}{Project Properties}
-menu.
+此外,在菜单项 \mainmenuopt{设置} \arrow \dropmenuopttwo{mActionOptions}{项目特性} 下的标签页 \tab{通用} 中可定义存储SVG文件的绝对或相对路径。
-\minisec{Map tools Tab}
+\minisec{地图工具标签页}
\begin{itemize}
-\item The Mode setting determines which layers will be shown by the Identify
-tool. By switching to \usertext{Top down} or \usertext{Top down, stop at
-first} instead of \usertext{Current layer} attributes for all identifiable
-layers (see the Project properties section under: \ref{sec:projects} to set
-which layers are identifiable) will be shown with the Identify tool.
-\item \checkbox{Open feature form, if a single feature is identified}
-\item Define search radius for identifying and displaying map tips as a
-percentage of the map width
-\item Define ellipsoid for distance calculations
-\item Define rubberband color for measure tools
-\item \radiobuttonon{Define preferred measurement units (meters or feet)}
-\item \radiobuttonon{Define preferred angle units (Degrees, Radians or Gon)}
-\item Define Mouse wheel action (Zoom, Zoom and recenter, Zoom to mouse
-cursor, Nothing)
-\item Define Zoom factor for wheel mouse
+\item 模式设置通过标识工具确定哪一图层将被显示出来。通过设置 \usertext{上下} 或 \usertext{上下,但到第一层为止} ,而不是 \usertext{当前图层},所有图层上图元的属性(参见 \ref{sec:projects} 的项目属性部分来设置哪些图层可查询)都可以用查询工具显示出来。
+\item \checkbox{查询单个图元时打开图元窗口}
+\item 为识别和显示地图提示设置搜索半径作为地图宽度的百分比
+\item 设置距离计算的椭球体
+\item 设置测量工具橡皮圈颜色
+\item \radiobuttonon{设置默认的量测单位(米或英尺)}
+\item \radiobuttonon{设置默认的角度单位(度,弧度或百分度)}
+\item 设置鼠标滚轮行为(缩放,缩放并重定位,缩放鼠标光标处,无变化)
+\item 设置鼠标滚轮缩放因子
\end{itemize}
-\minisec{Overlay}
+\minisec{叠置标签页}
\begin{itemize}
-\item Define placement algorithm for labels (choose between central point
-(standard), chain, popmusic tabu chain, popmusic tabu and popmusic chain)
+\item 为标签设置位置选择算法(包括中心点法,chain, popmusic tabu chain,popmusic tabut和popmusic chain)
\end{itemize}
-\minisec{Digitizing Tab}
+\minisec{数字化标签页}
\begin{itemize}
-\item Define Rubberband line color and line width
-\item Define default snap mode (to vertex, to segment, to vertex and segment)
-\item Define default snapping tolerance in map units or pixel
-\item Define search radius for vertex edits in map units or pixel
-\item \checkbox{Show markers only for selected features}
-\item Define vertex marker style (cross (default), semi transparent circle or
-none) and vertex marker size
-\item \checkbox{Suppress attributes pop-up windows after each created feature}
+\item 设置橡皮圈线的颜色和宽度
+\item 设置默认捕捉模式(顶点捕捉,线段捕捉,顶点和线段捕捉)
+\item 设置地图单位或像素的默认捕捉容限值
+\item 设置地图单位或像素的顶点编辑搜索半径
+\item \checkbox{仅对选中图元显示标记}
+\item 设置顶点标记样式(十字形(默认),半透明圆或者无)和顶点标记大小
+\item \checkbox{创建图元之后不弹出属性窗口}
\end{itemize}
-\minisec{CRS Tab}
+\minisec{参考坐标系(CRS)标签页}
\begin{itemize}
-\item \radiobuttonoff{Prompt for Coordinate Reference System (CRS)}
-\item \radiobuttonoff{Project wide default Coordinate Reference System (CRS) will be used}
-\item \radiobuttonon{Global default Coordinate Reference System (CRS) displayed below will be used}
-\item Select global default Coordinate Reference System (CRS)
+\item \radiobuttonoff{弹出选择参考坐标系(CRS)}
+\item \radiobuttonoff{使用项目默认的参考坐标系(CRS)}
+\item \radiobuttonon{使用全局默认的参考坐标系(CRS)}
+\item 选择全局默认的参考坐标系(CRS)
\end{itemize}
-\minisec{Locale Tab}
+\minisec{用户区域设置(Locale)标签页}
\begin{itemize}
-\item \checkbox{Overwrite system locale and use defined locale instead}
-\item Information about active system locale
+\item \checkbox{使用自定义的区域设置覆盖系统设置}
+\item 活动的系统区域设置信息
\end{itemize}
-\minisec{Proxy Tab}
+\minisec{代理标签页}
\begin{itemize}
\item \checkbox{Define timeout for network requests in ms}
